Sparrow Wallet (Desktop)
Same here - it worked a week ago. Not now. Same settings as before and same as you.
Also having this problem. Anybody got a solution?
@DarthCoin could you have a look at this issue? Lots of us Umbrel users having Electrs sync issues stuck at 99%. It’s been over a month and still no resolution. Thanks Mate!
Also having trouble connecting to Electrs recently. Everything was working fine for several months beforehand.
I have electrs fully synchronized, as well as my node, but when I try to connect to sparrow (via private electrum) it is just stuck on "connecting to tcp://onionaddres:50001
I wait more than 24 hours behin of node install and now obtain this error. Could not connect: Retries exhausted
Thanks for your help, and tips to resolve
Hello… after the connection is made, what is the method to import the wallet? THS
My Bitcoin Node has been active for a few months but I cannot get the Electrs to be at 100%. It is stuck at ‘Waiting for Bitcoin Node to finish syncing…’
So I cannot connect to Electrum which makes everything more complicated in following the tutoriels… Can someone help?
I’m having the same problem! Did you get anything resolved? Mine is stuck on umbrel.local:50001
I am now having the same problem of Electrs stuck at Waiting for Bitcoin Node to finish syncing". Have you guys been able to solved it? My Bitcoin Node on Umbrel already 100% synced.
I solved the problem using a simple solution. I uninstalled Electrs from Umbrel and reinstalled it and waited about 24 hours for it to resync. Now Electrs sync 100%.
yeah, that’s basically what ended up working for me, as well. when in doubt, wait a day. This seems to solve many of the problems I’ve had so far.
I was able to connect without electrz directly to the BTC Core node using RPC(tor) details which is too slow, still wondering how to connect locally P2P or RPC, I’m always getting: “Could not connect:
Connection refused” or “Could not connect: Unexpected end of file from server”
or
“Could not connect:
Server returned HTTP response code: 403 for URL: http://192.168.1.116:8332/wallet/cormorant
I hope this helps everyone having the problems with trying to connect bitcoin core
I was stuck on this too. NOW I just entered my local umbrel IP (128.xxx.xxx.xx) and … voila, Sparrow happy & connected to my own node!
I just completed this setup again after updating to a 2TB SSD and Raspberry Pi 5 with 8 GB of RAM, and it took me a took me a while to figure this out again - I was stuck at step 2 above:
  1. For Type, select Private Electrum
I couldn’t find the correct URL on my Umbrel for Sparrow’s Private Electrum server option in the Bitcoin Node (Core) app on Umbrel. You have to install Electrs - go into the Electrs app on Umbrel and copy the Tor address into the Sparrow URL field along with the port # (typically 50001).
As explained on the Sparrow website, using the Electrs (Electrum server) instead of Bitcoin Node (Bitcoin core) app provides speed and privacy over connecting directly to the bitcoin node with how it indexes transactions.
Be careful with @Tavernier… he is a potential scammer.
There is no live technical support on the forum. All help received is on the forum and publicly from other users of the same forum.
Be careful if someone promises you help in private and, above all, do not give out any sensitive information about yourself. Especially if it is about wallets, private keys, etc.
Will sparrow wallet via electrs work with bitcoin knots? Do people suggest local connection or TOR?
Yes works fine…running Local
I just wanted to let everybody interested in connecting Sparrow to Umbrel’s Bitcoin Node WITHOUT installing Electrs, that it is possible using the option “Bitcoin Core” in Sparrow server configuration. In URL you must put your RPC (TOR) configuration, that is: onion URL, your port (8332 in my case), and your RPC User and Pass, after choosing User/Pass in Sparrow.
That works
