Hey @lamda I’m sorry you’re continuing to have this issue, and I assume we tried reflashing the MicroSD card again?
Out of curiosity what kind of SSD are you using, is it an external one or is it an internal one that plugs inside an enclosure first then into your Pi 4? Sometimes I’ve seen a quick fix to be replace the cable, try a different USB 3.0 port, or replace the enclosure that could save you some time…
As long as you have your 24-word seed phrase, you can recover funds back onchain on any new instance of Lightning Node app, that process is demonstrated here: https://twitter.com/umbrel/status/1562099972547690501
I’m happy to help with this just ping me or feel free to post in the Telegram group chat and ping me there too for realtime assistance!!
