Hi everyone,
I have some bigger problems after a recent Umbrel restart. It does not start up anymore. I get this nice picture, when I want to access the web UI.
When I try to start it up manually through the command line, I get this error message. Does anyone know where it comes from and what I can do against it?
umbrel@umbrel:~/umbrel $ docker-compose start
File “/usr/local/bin/docker-compose”, line 8, in
sys.exit(main())
File “/usr/local/lib/python3.7/dist-packages/compose/cli/main.py”, line 81, in main
command_func()
File “/usr/local/lib/python3.7/dist-packages/compose/cli/main.py”, line 200, in perform_command
project = project_from_options(‘.’, options)
File “/usr/local/lib/python3.7/dist-packages/compose/cli/command.py”, line 40, in project_from_options
environment = Environment.from_env_file(override_dir or project_dir, environment_file)
File “/usr/local/lib/python3.7/dist-packages/compose/config/environment.py”, line 67, in from_env_file
instance = _initialize()
File “/usr/local/lib/python3.7/dist-packages/compose/config/environment.py”, line 62, in _initialize
return cls(env_vars_from_file(env_file_path))
File “/usr/local/lib/python3.7/dist-packages/compose/config/environment.py”, line 38, in env_vars_from_file
env = dotenv.dotenv_values(dotenv_path=filename, encoding=‘utf-8-sig’, interpolate=interpolate)
File “/usr/local/lib/python3.7/dist-packages/dotenv/main.py”, line 377, in dotenv_values
encoding=encoding,
File “/usr/local/lib/python3.7/dist-packages/dotenv/main.py”, line 69, in dict
self._dict = OrderedDict(resolve_variables(raw_values, override=self.override))
File “/usr/local/lib/python3.7/dist-packages/dotenv/main.py”, line 229, in resolve_variables
for (name, value) in values:
File “/usr/local/lib/python3.7/dist-packages/dotenv/main.py”, line 77, in parse
for mapping in with_warn_for_invalid_lines(parse_stream(stream)):
File “/usr/local/lib/python3.7/dist-packages/dotenv/main.py”, line 19, in with_warn_for_invalid_lines
for mapping in mappings:
File “/usr/local/lib/python3.7/dist-packages/dotenv/parser.py”, line 180, in parse_stream
reader = Reader(stream)
File “/usr/local/lib/python3.7/dist-packages/dotenv/parser.py”, line 71, in init
self.string = stream.read()
File “/usr/lib/python3.7/codecs.py”, line 322, in decode
(result, consumed) = self._buffer_decode(data, self.errors, final)
File “/usr/lib/python3.7/encodings/utf_8_sig.py”, line 69, in _buffer_decode
return codecs.utf_8_decode(input, errors, final)
UnicodeDecodeError: ‘utf-8’ codec can’t decode byte 0xc1 in position 0: invalid start byte
History
- The node was extremely slow
- I did a restart
- I did not restarted properly
- I reflashed the SD card with the recent umbrel version (which was already running before)
- Started to do more investigations. I don’t know if before the reflash, the same or a different error message was shown.
Thanks for any help in advance!
