Issue with Umbrel Home (out of the box)
Hello, I am super new to Umbrel (and the world of raspberry Pi’s) and just purchased the Umbrel home because I had hoped that the OS like interface would enable me to effortlessly set it up.
However, I am experienced issues out of the box and tried (unsuccessfully) following the steps on the troubleshooting guide but nothing seems to work.
  • I was able to access the Umbrel device on a Mac using http://umbrel NOT http://umbrel.local (this didn’t work). I was also able to access via the IP address, which I found through the router.
  • When I tried to install my first App, I was stuck with the installing indicator but nothing actually happened.
  • When I tried to restart the device I got stuck on the rebooting screen, it never actually restarted. However I was able to open a new tab and reconnect to the OS.
  • When I tried to use settings/troubleshooting to get the logs I got the following error “Error: Failed to fetch debug data.”
  • When I tried to SSH into the device following the instructions from the Troubleshooting guide the steps didn’t work as expected (I was able to eventually get the logs - see my reply comment).
Hoping someone from the community can help me figure out what is going on?
I’ve read a few posts in which it seems like people have similar issues, however these all seem unresolved.
Would appreciate any support!
I noticed that when I tried to SSH into the umbrella using the password I set up when I originally started the device it didn’t work, however, when I used “umbrel” per information provided on another post it worked.
here is the debug info:
0.5.4
Mem: 15G 590M 14G 1.0M 630M 14G
Swap: 0B 0B 0B
total: 3.8%
system: 3.8%
Memory monitor logs
2024-02-26 19:04:00 Memory monitor running!
2024-02-26 19:04:10 Memory monitor running!
2024-02-26 19:04:21 Memory monitor running!
2024-02-26 19:04:32 Memory monitor running!
2791 ? R 0:00 bash ./scripts/memory-monitor
2024-02-26 19:04:53 Memory monitor running!
2024-02-26 19:05:04 Memory monitor running!
2024-02-26 19:05:15 Memory monitor running!
2024-02-26 19:09:49 Memory monitor running!
/dev/nvme0n1p2 9.6G 1.6G 7.6G 18% /
/dev/nvme0n1p4 1.8T 1.4G 1.8T 1% /home
Karen logs
Got signal:
karen is getting triggered!
Got signal:
Got signal:
Got signal:
Got signal:
Got signal:
1543 ? R 0:00 bash ./karen
1545 ? R 0:00 bash ./karen
karen is already running
Docker containers
Got permission denied while trying to connect to the Docker daemon socket at unix:///var/run/docker.sock: Get “http://%2Fvar%2Frun%2Fdocker.sock/v1.24/containers/json”: dial unix /var/run/docker.sock: connect: permission denied
Umbrel logs
ERROR: Couldn’t connect to Docker daemon at http+docker://localhost - is it running?
If it’s at a non-standard location, specify the URL with the DOCKER_HOST environment variable.
Tor Proxy logs
==== Result ====
Update, for anyone wanting to answer while I am asleep (AU).
I was able to reflash the internal SSD and reset the device. This has allowed me to successfully install apps on the device.
