I want to ssh into my pi. I tried the default for raspberry pi os, raspberry, and the one I set for the dashboard.
edit: Thank you for your help but turns out I was trying to use ssh umbrel.local instead of ssh umbrel@umbrel.local
Hi @aidan ,
During the inital setup phase you are asked to copy down the 24-word recovery phrases and its at this point you need to create a master password.
Failing this its “moneyprintergobrrr” (Without the “quotes”)
It should be the same password that you initially set. Same password when you login to dashboard.
username: umbrel@umbrel.local
pass: same password as the dashboard password.
