Unable to access Raspberry Pi
Newbie error
I have set up raspberry pi 4 many months ago, and must have changed my username and password as I am unable to SSH in.
The only thing I am using the pi for is Umbrel.
The boot configuration goes straight through, loads umbrel just fine, so ti must be entering my password.
I can TOR into umbrel, and I have the latest version installed.
I can shutdown Umbrel from TOR, but that seems to shutdown the Raspberry Pi as well.
When I connect a keyboard and screen directly to the PI I can see Umbrel is up and running and the cursor is blinking just below. How can run I interupt Umbrel so tnat I can type standard sudo prompts?
I tried repeatedlyt pressing Shift on wakeup but that did nothing.
thank you
use umbrel as the username, not pi, as Umbrel changes the default username.
For example: ssh umbrel@umbrel.local or ssh umbrel@<your_node_ip_address>
Don’t worry about being a newbie, everyone is one at some point, and I’ve gotten so used to enter the pi username, and I would get so frustrated when it won’t work, then I realized that it’s Umbrel that changed the default username.
yes that worked thankyou!!!
