Would something like this work for Vaultwarden Using IOS mobile app or desktop browser extension or Bitwarden desktop app in windows.?
I dont see a Orbot windows version or a IOS version.
Second question would be is this a good idea in regards to “security” vs just using the Bitwarden servers
So far I have only be able to use the .onion address it TOR browser or the bitwarden extension in tor with the onion address.
Im starting to realize the limitations of Windows and IOS Roadblocks. Working my way to android and Linux.
Check this post here: How to selectively expose Umbrels Hidden Tor Services to Clearnet (Reverse Proxy SSL) (dont be fooled by that thread’s title, there’s no need for reverse proxies now)
Now you can connect your Bitwarden phone app and I suppose it works the same for a browser extension, just using Tailscale!
Toti_G
47
Thanks Darth! Worked perfectly
skeeter
48
this works if, after pasting in the onion url, you go back in and remove the “s” from the “https” that was auto-added by Bitwarden.
