Vaultwarden. Help on setup
Hi All. Just trying out one of the new features, Vaultwarden.
I’m failing at the first hurdle of trying to create an account. I’m using Brave as my Tor browser, but when I try and create the account I’m getting a message that I need to have a HTTPS enabled browser.
How/what should I use to access my umbrel to enable me to setup Vaultwarden?
Thanks
Use Tor browser.
Thank you. It worked perfectly
Do you know what the server name is in order to get it working with the web extension?
Did you have any luck?
