Usb key + usb ssd to install Umbrel
Hello,
I have a Pi 4, 8 GB and the support of the micro ssd card is broken and I can’t boot on it. I boot with a USB key to install Umbrel but the installation does not finish, I have a message that says because there are two devices storage in USB : the key and the SSD. I have boot directly on the ssd to install Umbrel but it does not work, , there is a lots off error messages.
Is there a solution to install with a usb key with the ssd ?
Thank you,
