Unable to get to umbrel.locla browser view
Using Umbrel with Raspberry PI, SSD harddrive and connected to network by cable.
After power shortage I connot longer conenct through umbrel.local to get to my login. Will only get me to umbrel start. as of starting a new account.
I am a newbie and probably did not set a static IP to the Raspberr and since then the TOR hash adress does not get me to my Umbrel login screen…
I can SSH into my umbrel with my old password on a terminal.
But i realy would like to start GUI mode from Tor or else to be able to use my umbrel properly.
What to do?
For any noob starting with Umbrel, first pit stop is … the guides section of this forum.
Is full of useful guides, troubleshooting manuals, how to etc.
In order to have a better diagnose, you need to generate, read for yourself and provide logs if you really don’t understand what is going on.
Here is a simple guide how to generate logs:
http://community.umbrel.com/t/how-to-generate-debugging-logs/
READ your logs and try to understand them. Only like that you can became a node operator.
