Can't connect to umbrel.local, even though node is accessible through SSH
I recently connected my Raspi Umbrel Node node to a new modem via Ethernet, and while I’m able to shell in via SSH, I can’t access it in the browser at umbrel.local, or even find its IP when doing a LAN scan.
The node isn’t making any syncing progress — and basically it seems like it’s unable to communicate with the outside world in any way.
When I generate logs, mostly everything seems like it’s functioning as expected — except for tor, bitcoin-cli, and lnd.
Here’s what I’m seeing in the tor logs:
Tor logs
Attaching to umbrel_app_2_tor_1, umbrel_app_3_tor_1, umbrel_app_tor_1, tor
tor                  | Nov 16 07:02:57.000 [warn]  25865 connections died in state connect()ing with SSL state (No SSL object)
tor                  | Nov 16 07:02:57.000 [warn] Problem bootstrapping. Stuck at 5% (conn): Connecting to a relay. (Network is unreachable; NOROUTE; count 25867; recommendation warn; host 24E2F139121D4394C54B5BCC368B3B411857C413 at 204.13.164.118:443)
tor                  | Nov 16 07:02:57.000 [warn] 25866 connections have failed:
tor                  | Nov 16 07:02:57.000 [warn]  25866 connections died in state connect()ing with SSL state (No SSL object)
tor                  | Nov 16 07:02:57.000 [warn] Problem bootstrapping. Stuck at 5% (conn): Connecting to a relay. (Network is unreachable; NOROUTE; count 25868; recommendation warn; host A68097FE97D3065B1A6F4CE7187D753F8B8513F5 at 212.47.233.86:9101)
tor                  | Nov 16 07:02:57.000 [warn] 25867 connections have failed:
tor                  | Nov 16 07:02:57.000 [warn]  25867 connections died in state connect()ing with SSL state (No SSL object)
tor                  | Nov 16 07:02:58.000 [warn] Problem bootstrapping. Stuck at 5% (conn): Connecting to a relay. (Network is unreachable; NOROUTE; count 25869; recommendation warn; host 68F175CCABE727AA2D2309BCD8789499CEE36ED7 at 163.172.139.104:443)
tor                  | Nov 16 07:02:58.000 [warn] 25868 connections have failed:
tor                  | Nov 16 07:02:58.000 [warn]  25868 connections died in state connect()ing with SSL state (No SSL object)
app_2_tor_1          | Nov 15 21:28:21.000 [warn] Problem bootstrapping. Stuck at 5% (conn): Connecting to a relay. (Network is unreachable; NOROUTE; count 84; recommendation warn; host C793AB88565DDD3C9E4C6F15CCB9D8C7EF964CE9 at 85.248.227.163:9001)
I’m pretty much at a loss here for why this is happening or what to do.
If tor is not working, none of the rest will sync/work.
Try restarting your node and tour router to get a new bootstrapping from Tor nodes.
How would you recommend doing this? I’ve tried cycling the power, and I’ve tried the sudo reboot command several times – across several days, even – and still get stuck with the same exact errors.
Have you solved this? I had related issue; solution for me was to start over with clean install. Wrote new image, and deleted partition on harddrive.
I’ve solved my issue, but unfortunately, I wasn’t able to precisely pin down the cause.
My hunch is that I might have misconfigured my /etc/dhcpcd.conf file, as described here.
I went down the rabbit hole of trying to change these settings while debugging my connection failures, and that might have been premature. Reverting those changes, and then doing a full sudo reboot from the command line was enough to get Tor fully bootstrapped again.
I
I tried everything including re-imaging via USB flash drive using the Umbrel .iso image…what actually worked was me changing my local Mac DNS settings in => System settings > Network > Ethernet > Details > DNS > change DNS server to 1.1.1.1
