umbrelOS 1.0 reads only microsd storage
I was having the same issue as you, have upgraded to 1.0.3 and all is still good. But as you say, I did start the download from scratch. I was having issue after issue with 1.0 that I never got to far into the download before having to start again. So yes I have 1.0.3 but started the download again.
@smolgrrr, is it okay if I don’t upgrade to 1.0.3 from 1.0.1? Everything seems to working ok since I did my last flash. @whynot confirmed that after he reflashed to upgrade from 1.0.0 to 1.0.3, he did have to start the blockchain download again. I don’t want to lose another 3 days downloading the blockchain if I don’t have to. Thanks for your help!
Sounds like its going to be fixed in 1.2 https://twitter.com/mayankdotch/status/1780628827737309359
I did all the steps you mentioned in this post. Still my 2 TB SSD not being recognized. Can you please help?
Please try these new steps here and let me know how that goes! https://github.com/getumbrel/umbrel/wiki/Raspberry-Pi-5-%E2%80%90-Boot-from-NVMe-or-USB
Hi @smolgrr,
I have the bitcoin machine from Umbrel and it has it’s own SSD. This being the case, how do I go about the installation? I don’t see a way to get the umbrel image at the below link onto that SSD?
Please find attached a picture of machine I have.
Thanks and regards,
Chets
Oh I see, if you’re using a Bitcoin Machine it is best to use the SD card method, instead of flashing umbrelOS directly onto your SSD.
Just to confirm, have you followed the exact steps found here? How to update to umbrelOS 1.0
Yes i did but when i install umbrel OS 1.0 i only see 20 GB disk space and the bitcoin block chain download is not successful. Please find attached the screen shot post upgrade.
I am sorry but just wanted to check if I can go ahead and install the version you have provided link to?
Thanks in advance for your help.
Regards
Chets
Hi @smolgrrr ,
After much trial and error I managed to get into my old node. I think i have upgraded the umbrel OS.
Now All i can do on this node is to sync the “Bitcoin Node”. By the time i sync the Bitcoin chain to current block the node literally hangs and none of the other apps work. I have to do a hard reboot and then again “Bitcoin node” is out of sync. The process starts. It is endless loop.
Can you please help me with this endless loop?
I am worried about the BTC stuck on my lightning node . I have substantial amount in there and my previous attempts at restoring to Blue wallet has been unsuccessful.
I am attaching some screen shots here
but my umbrel debug is saying the Umbrel OS is different. Not sure why?
can you please help?
Interesting, can you please navigate to Settings (http:umbrel.local/settings) > Troubleshoot > App > Bitcoin node Then click on “Download Bitcoin node logs”, and please send us the log file here.
Also, just for the general logs, can you please navigate to the Settings (http:umbrel.local/settings) > Troubleshoot > umbrelOS? Then click on “Download umbrelOS logs”, and please send us the log file here.
Hi @smolgrrr,
Please find the logs attached.
regards
Chets
umbrel_bitcoin_2024-06-20_23-20.log (102 KB)
(Attachment Unconfirmed 88675.crdownload is missing)
Sending it again since the earlier email bounced due to attachments being wrong.
Regards
Chets
umbrel_bitcoin_2024-06-21_07-41.log (191 KB)
umbrel_umbrelos_2024-06-21_07-40.log (121 KB)
