Hey guys!
I have Umbrel installed on my Raspi. I didn’t access it for a while but did now again today and couldn’t reach it at first. I re-flashed the MicroSD so that I was able to access the node again. It worked but then it showed a warning “Your Umbrel is running low on storage”. I looked at the settings and saw that my system uses 395.4 GB. It wasn’t like this before and I was wondering if any of you guys have a solution for that or a reason why this is happening.
Cheers!
elutac
edit: I am also not able to troubleshoot because there is an error occurring when I try to generate the logs (“Error: Failed to fetch debug data.”).
