Command failed with exit code 1: /usr/local/lib/node_modules/umbreld/source/modules/apps/legacy-compat/app-script logs bitcoin
time="2024-03-23T09:46:48Z" level=warning msg="/usr/local/lib/node_modules/umbreld/source/modules/apps/legacy-compat/docker-compose.app_proxy.yml: `version` is obsolete"
time="2024-03-23T09:46:48Z" level=warning msg="/usr/local/lib/node_modules/umbreld/source/modules/apps/legacy-compat/docker-compose.tor.yml: `version` is obsolete"
time="2024-03-23T09:46:48Z" level=warning msg="/usr/local/lib/node_modules/umbreld/source/modules/apps/legacy-compat/docker-compose.common.yml: `version` is obsolete"
time="2024-03-23T09:46:48Z" level=warning msg="/home/umbrel/umbrel/app-data/bitcoin/docker-compose.yml: `version` is obsolete"
time="2024-03-23T09:46:48Z" level=warning msg="networks.default: external.name is deprecated. Please set name and external: true"
If I try run some script, there is a problem with docker-compose:
Killing background services
Stopping installed apps...
This script requires "docker-compose" to be installed
Apologies @jrck@clemsy. Can you please confirm whether you’re running umbrelOS 1.0.0, 1.0.1, or 1.0.2? Also, please let me know on which device are you running umbrelOS.
Alternatively, if you are using a Raspberry Pi and aren’t comfortable with running terminal command, you can simply re-flash your microSD card with umbrelOS 1.0.3 by following the instructions here: How to update to umbrelOS 1.0
I have same problem can not install apps after OS update to 1.05
OS log entry:
] GET /trpc/user.get
Mar 22 19:13:57 umbrel umbreld[1650]: [server ] POST /trpc/apps.install
Mar 22 19:13:57 umbrel umbreld[1650]: [apps ] Installing app bitcoin
Mar 22 19:13:57 umbrel umbreld[1650]: [apps ] Setting up data directory for bitcoin
Mar 22 19:13:58 umbrel umbreld[4281]: time=“2024-03-22T19:13:58Z” level=warning msg=“/usr/local/lib/node_modules/umbreld/source/modules/apps/legacy-compat/docker-compose.yml: version is obsolete”
Mar 22 19:13:58 umbrel umbreld[4281]: Container auth Running
Yes I have same problem. I reinstalled OS 1.0.3 several times, then Umbrel starts, but cannot install any apps. Press the “install” button next to bitcoin app, and it just stops
Thank you for your advice! I’m using Raspbery Pi. Unfortunately, after update to 1.0.3 the problem still persists. Apps not running and trials to run scripts ends up with the same error.
Mar 24 09:04:33 umbrel systemd[1]: Started umbrel.service - Umbrel daemon.
Mar 24 09:04:49 umbrel umbreld[791]: [umbreld ] ☂️ Starting Umbrel v1.0.3
Mar 24 09:04:49 umbrel umbreld[791]: [umbreld ] dataDirectory: /home/umbrel/umbrel
Mar 24 09:04:49 umbrel umbreld[791]: [umbreld ] port: 80
Mar 24 09:04:49 umbrel umbreld[791]: [umbreld ] logLevel: verbose
Mar 24 09:04:49 umbrel mender[924]: time="2024-03-24T09:04:49Z" level=info msg="'UpdateControlMapExpirationTimeSeconds' i>
Mar 24 09:04:49 umbrel mender[924]: time="2024-03-24T09:04:49Z" level=info msg="'UpdateControlMapBootExpirationTimeSecond>
Mar 24 09:04:49 umbrel mender[924]: time="2024-03-24T09:04:49Z" level=info msg="No configuration files present. Using def>
Mar 24 09:04:49 umbrel mender[924]: time="2024-03-24T09:04:49Z" level=warning msg="No server URL(s) specified in mender c>
Mar 24 09:04:49 umbrel mender[924]: time="2024-03-24T09:04:49Z" level=warning msg="Server entry 1 has no associated serve>
Mar 24 09:04:49 umbrel mender[924]: time="2024-03-24T09:04:49Z" level=info msg="No dual rootfs configuration present"
Mar 24 09:04:49 umbrel mender[924]: time="2024-03-24T09:04:49Z" level=error msg="Could not commit Artifact: There is noth>
Mar 24 09:04:49 umbrel mender[924]: time="2024-03-24T09:04:49Z" level=warning msg="There is nothing to commit"
Mar 24 09:04:49 umbrel umbreld[791]: [umbreld ] [error] Failed to commit OS partition: Command failed with exit code 2: >
Mar 24 09:04:49 umbrel umbreld[791]: time="2024-03-24T09:04:49Z" level=info msg="'UpdateControlMapExpirationTimeSeconds' >
Mar 24 09:04:49 umbrel umbreld[791]: time="2024-03-24T09:04:49Z" level=info msg="'UpdateControlMapBootExpirationTimeSecon>
Mar 24 09:04:49 umbrel umbreld[791]: time="2024-03-24T09:04:49Z" level=info msg="No configuration files present. Using de>
Mar 24 09:04:49 umbrel umbreld[791]: time="2024-03-24T09:04:49Z" level=warning msg="No server URL(s) specified in mender >
Mar 24 09:04:49 umbrel umbreld[791]: time="2024-03-24T09:04:49Z" level=warning msg="Server entry 1 has no associated serv>
Mar 24 09:04:49 umbrel umbreld[791]: time="2024-03-24T09:04:49Z" level=info msg="No dual rootfs configuration present"
Mar 24 09:04:49 umbrel umbreld[791]: time="2024-03-24T09:04:49Z" level=error msg="Could not commit Artifact: There is not>
Mar 24 09:04:49 umbrel umbreld[791]: time="2024-03-24T09:04:49Z" level=warning msg="There is nothing to commit"
Mar 24 09:04:49 umbrel umbreld[791]: [umbreld ] Set ondemand cpu governor
Mar 24 09:04:49 umbrel umbreld[791]: [umbreld ] Checking if system time is synced before continuing...
Mar 24 09:04:49 umbrel umbreld[791]: [umbreld ] System time is not currently synced, waiting...
Mar 24 09:04:50 umbrel umbreld[791]: [umbreld ] System time is not currently synced, waiting...
Mar 24 09:04:52 umbrel umbreld[791]: [umbreld ] System time is not currently synced, waiting...
Mar 24 09:04:53 umbrel umbreld[791]: [umbreld ] System time is not currently synced, waiting...
Mar 24 09:04:54 umbrel umbreld[791]: [umbreld ] System time is not currently synced, waiting...
Mar 24 09:04:55 umbrel umbreld[791]: [umbreld ] System time is not currently synced, waiting...
Mar 24 09:04:56 umbrel umbreld[791]: [umbreld ] System time is not currently synced, waiting...
Mar 24 09:04:57 umbrel umbreld[791]: [umbreld ] System time is not currently synced, waiting...
Mar 24 09:04:58 umbrel umbreld[791]: [umbreld ] System time is not currently synced, waiting...
Mar 24 09:04:59 umbrel umbreld[791]: [umbreld ] System time is not currently synced, waiting...
Mar 24 09:05:00 umbrel umbreld[791]: [umbreld ] [error] System time is not synced but timeout was reached. Continuing...
Mar 24 09:05:00 umbrel umbreld[791]: [apps ] [error] Failed to clean containers: Command failed with exit code 1: doc>
Mar 24 09:05:00 umbrel umbreld[791]: Cannot connect to the Docker daemon at unix:///var/run/docker.sock. Is the docker da>
Mar 24 09:05:00 umbrel umbreld[791]: [apps ] Cleaning up old networks...
Mar 24 09:05:00 umbrel umbreld[980]: Cannot connect to the Docker daemon at unix:///var/run/docker.sock. Is the docker da>
Mar 24 09:05:00 umbrel umbreld[791]: [apps ] [error] Failed to clean networks: Command failed with exit code 1: docke>
Mar 24 09:05:00 umbrel umbreld[791]: [appstore ] Initialising app store
Mar 24 09:05:01 umbrel umbreld[791]: [appstore ] Initialising repositories...
lines 1-44
