Unable to Install Apps?
Just started w/Umbrel. Purchased all the HW recommended from Umbrel.com
Set everything up last night. Went to Umbrel.Local - created my account.
No issues so far. Now, I’m trying to install apps - Doesn’t matter what App I choose
(And I’ve tried several) - the apps just will not install. The button is flashing “INSTALLING this
may take a few minutes”: but that’s it. Monitoring storage in settings - no change.
Any idea what’s going on? Did I do something wrong during setup or is something going on with the
Umbrel App Store? Any suggestions will be appreciated.
Can you SSH into your node and run this command to get your logs
sudo ~/umbrel/scripts/debug
There is instructions for doing that in the
FAQ
Karen logs
Got signal: debug
karen is getting triggered!
Debug result file generated
Got signal: app-install-electrs
Installing ‘electrs’ from: GitHub - getumbrel/umbrel-apps: The official app repository of the Umbrel App Store. Submit apps and updates here. Learn how → https://github.com/getumbrel/umbrel-apps#readme
Setting up data dir for app electrs…
sending incremental file list
sent 312 bytes received 15 bytes 654.00 bytes/sec
total size is 4,132 speedup is 12.64
Pulling images for app electrs…
Pulling app_proxy …
Pulling electrs …
Pulling app …
Pulling tor …
Pulling electrs … pulling from getumbrel/electrs
Pulling tor … pulling from getumbrel/tor
Pulling app … pulling from getumbrel/umbrel-ele…
Pulling app_proxy … pulling from getumbrel/app-proxy
Pulling electrs … digest: sha256:f215ca7163a3bd42ae…
Pulling electrs … status: image is up to date for g…
Pulling tor … digest: sha256:2ace83f22501f58857…
Pulling tor … status: image is up to date for g…
Pulling app_proxy … digest: sha256:a2e3e0ddfcf84838bf…
Pulling app_proxy … status: image is up to date for g…
Pulling electrs … done
Pulling tor … done
Pulling app … digest: sha256:3dae686b22b1fdfd72…
Pulling app … status: image is up to date for g…
Pulling app_proxy … done
Pulling app … done
Starting app electrs…
Executing hook: /home/umbrel/umbrel/app-data/electrs/hooks/pre-start
Creating electrs_tor_1 …
Creating electrs_app_proxy_1 …
Creating electrs_electrs_1 …
Host is already in use by another container
Creating electrs_app_proxy_1 … error
ERROR: for electrs_app_proxy_1 Cannot start service app_proxy: driver failed programming external connectivity on endpoint electrs_app_proxy_1 (2b821880c487e468f670a5481a4222cba0c7a3b4796fb46f582eda002ec39b3a): Bind for 0.0.0.0:2102 failed: port is already allocated
Creating electrs_tor_1 … done
Creating electrs_electrs_1 … done
Creating electrs_app_1 …
Creating electrs_app_1 … done
ERROR: for app_proxy Cannot start service app_proxy: driver failed programming external connectivity on endpoint electrs_app_proxy_1 (2b821880c487e468f670a5481a4222cba0c7a3b4796fb46f582eda002ec39b3a): Bind for 0.0.0.0:2102 failed: port is already allocated
Hi @Andreas
Weird, it looks like a double up is happening during the install, in which both app proxies try to use the same port.
Can you please share the full log output. Also, had you tried installing electrs prior to this incident?
kind of yes.
I had similar Issues with my Umbrel before, so i reinstalled on a new microSD, but used the same HDD.
After i started installing electr i waited for 30 min and after nothing happened, i restarted Umbrel. When i am going to the appStore, it still indicates that electr is installing.
0.5.4
Flashed OS version
v0.5.4
Raspberry Pi Model
Revision        : c03112
Serial          : 10000000d82b3068
Model           : Raspberry Pi 4 Model B Rev 1.2
Firmware
May  9 2023 12:16:34
Copyright (c) 2012 Broadcom
Temperature
temp=34.0'C
Throttling
throttled=0x0
Mem:           3.8G        2.0G        674M        3.0M        1.1G        1.6G
Swap:          4.1G        173M        3.9G
total: 53.0%
bitcoin: 28.5%
system: 24.5%
Memory monitor logs
15032 ?        S      1:01 bash ./scripts/memory-monitor
2023-07-31 19:22:43 Memory monitor running!
2023-09-09 21:46:53 Memory monitor running!
/dev/root       119G  5.0G  109G   5% /
/dev/sda1       916G  649G  222G  75% /home/umbrel/umbrel
Startup service logs
Sep 09 21:46:53 umbrel umbrel startup[1102]: Starting Docker services...
Sep 09 21:46:57 umbrel umbrel startup[1102]: Creating tor_proxy ...
Sep 09 21:46:57 umbrel umbrel startup[1102]: Creating auth      ...
Sep 09 21:46:57 umbrel umbrel startup[1102]: Creating dashboard ...
Sep 09 21:46:57 umbrel umbrel startup[1102]: Creating manager   ...
Sep 09 21:47:00 umbrel umbrel startup[1102]: Creating tor_proxy ... done
Sep 09 21:47:00 umbrel umbrel startup[1102]: Creating dashboard ... done
Sep 09 21:47:01 umbrel umbrel startup[1102]: Creating manager   ... done
Sep 09 21:47:01 umbrel umbrel startup[1102]: Creating nginx     ...
Sep 09 21:47:01 umbrel umbrel startup[1102]: Creating auth      ... done
Sep 09 21:47:02 umbrel umbrel startup[1102]: Creating nginx     ... done
Sep 09 21:47:02 umbrel umbrel startup[1102]: Removing status server iptables entry...
Sep 09 21:47:02 umbrel umbrel startup[1102]: Removed existing iptables entry.
Sep 09 21:47:02 umbrel umbrel startup[1102]: Starting installed apps...
Sep 09 21:47:02 umbrel umbrel startup[1102]: Starting app bitcoin...
Sep 09 21:47:02 umbrel umbrel startup[1102]: Executing hook: /home/umbrel/umbrel/app-data/bitcoin/hooks/pre-start
Sep 09 21:47:05 umbrel umbrel startup[1102]: Creating bitcoin_bitcoind_1 ...
Sep 09 21:47:05 umbrel umbrel startup[1102]: Creating bitcoin_tor_1      ...
Sep 09 21:47:05 umbrel umbrel startup[1102]: Creating bitcoin_app_proxy_1 ...
Sep 09 21:47:05 umbrel umbrel startup[1102]: Creating bitcoin_i2pd_daemon_1 ...
Sep 09 21:47:07 umbrel umbrel startup[1102]: Creating bitcoin_tor_1         ... done
Sep 09 21:47:07 umbrel umbrel startup[1102]: Creating bitcoin_app_proxy_1   ... done
Sep 09 21:47:07 umbrel umbrel startup[1102]: Creating bitcoin_i2pd_daemon_1 ... done
Sep 09 21:47:07 umbrel umbrel startup[1102]: Creating bitcoin_bitcoind_1    ... done
Sep 09 21:47:07 umbrel umbrel startup[1102]: Creating bitcoin_server_1      ...
Sep 09 21:47:08 umbrel umbrel startup[1102]: Creating bitcoin_server_1      ... done
Sep 09 21:47:09 umbrel umbrel startup[1102]: Umbrel is now accessible at
Sep 09 21:47:09 umbrel umbrel startup[1102]:   http://umbrel.local
Sep 09 21:47:09 umbrel umbrel startup[1102]:   http://192.168.132.20
Sep 09 21:47:09 umbrel systemd[1]: Started Umbrel Startup Service.
External storage service logs
Sep 09 21:46:39 umbrel systemd[1]: Starting External Storage Mounter...
Sep 09 21:46:39 umbrel external storage mounter[484]: Running external storage mount script...
Sep 09 21:46:39 umbrel external storage mounter[484]: Found device "SABRENT "
Sep 09 21:46:39 umbrel external storage mounter[484]: Blacklisting USB device IDs against UAS driver...
Sep 09 21:46:39 umbrel external storage mounter[484]: Rebinding USB drivers...
Sep 09 21:46:39 umbrel external storage mounter[484]: Checking USB devices are back...
Sep 09 21:46:39 umbrel external storage mounter[484]: Waiting for USB devices...
Sep 09 21:46:40 umbrel external storage mounter[484]: Waiting for USB devices...
Sep 09 21:46:41 umbrel external storage mounter[484]: Checking if the device is ext4...
Sep 09 21:46:41 umbrel external storage mounter[484]: Yes, it is ext4
Sep 09 21:46:41 umbrel external storage mounter[484]: Checking filesystem for corruption...
Sep 09 21:46:41 umbrel external storage mounter[484]: e2fsck 1.44.5 (15-Dec-2018)
Sep 09 21:46:42 umbrel external storage mounter[484]: umbrel: clean, 318720/61054976 files, 174440394/244190208 blocks
Sep 09 21:46:42 umbrel external storage mounter[484]: Mounting partition...
Sep 09 21:46:42 umbrel external storage mounter[484]: Checking if device contains an Umbrel install...
Sep 09 21:46:42 umbrel external storage mounter[484]: Yes, it contains an Umbrel install
Sep 09 21:46:42 umbrel external storage mounter[484]: Bind mounting external storage over local Umbrel installation...
Sep 09 21:46:42 umbrel external storage mounter[484]: Bind mounting external storage over local Docker data dir...
Sep 09 21:46:42 umbrel external storage mounter[484]: Bind mounting external storage to /swap
Sep 09 21:46:42 umbrel external storage mounter[484]: Bind mounting SD card root at /sd-card...
Sep 09 21:46:42 umbrel external storage mounter[484]: Checking Umbrel root is now on external storage...
Sep 09 21:46:43 umbrel external storage mounter[484]: Checking /var/lib/docker is now on external storage...
Sep 09 21:46:43 umbrel external storage mounter[484]: Checking /swap is now on external storage...
Sep 09 21:46:43 umbrel external storage mounter[484]: Setting up swapfile
Sep 09 21:46:43 umbrel external storage mounter[484]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
Sep 09 21:46:43 umbrel external storage mounter[484]: no label, UUID=acc2f607-c006-4b3c-b3a9-ed41c1fc90de
Sep 09 21:46:43 umbrel external storage mounter[484]: Checking SD Card root is bind mounted at /sd-root...
Sep 09 21:46:43 umbrel external storage mounter[484]: Starting external drive mount monitor...
Sep 09 21:46:43 umbrel external storage mounter[484]: Mount script completed successfully!
Sep 09 21:46:43 umbrel systemd[1]: Started External Storage Mounter.
-- Logs begin at Thu 2019-02-14 10:11:59 UTC, end at Sun 2023-09-10 13:48:48 UTC. --
Sep 09 21:46:53 umbrel systemd[1]: Starting External Storage SDcard Updater...
Sep 09 21:46:53 umbrel external storage updater[1024]: Checking if SD card Umbrel is newer than external storage...
Sep 09 21:46:53 umbrel external storage updater[1024]: No, SD version is not newer, exiting.
Sep 09 21:46:53 umbrel systemd[1]: Started External Storage SDcard Updater.
Karen logs
Creating electrs_app_proxy_1 ... error
Creating electrs_tor_1       ... done
Creating electrs_electrs_1   ... done
Creating electrs_app_1       ...
Creating electrs_app_1       ... done
Got signal: backup
Deriving keys...
Creating backup...
Adding random padding...
1+0 records in
1+0 records out
6364 bytes (6.4 kB, 6.2 KiB) copied, 0.000303977 s, 20.9 MB/s
Creating encrypted tarball...
backup/
backup/channel.backup
backup/.padding
Uploading backup...
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100  7141  100   146  100  6995     72   3495  0:00:02  0:00:02 --:--:--  3568
{"message":"Successfully uploaded backup 1694301270352.tar.gz.pgp for backup ID 36d5bf168c03c870a094e5704c13ec694401be7d6d1ebc43146d74464c8024f6"}
====== Backup success =======
Got signal: backup
Deriving keys...
Creating backup...
1+0 records in
1+0 records out
9054 bytes (9.1 kB, 8.8 KiB) copied, 0.000580825 s, 15.6 MB/s
backup/
backup/.padding
Uploading backup...
100  9868  100   146  100  9722    133   8919  0:00:01  0:00:01 --:--:--  9053
{"message":"Successfully uploaded backup 1694331913565.tar.gz.pgp for backup ID 36d5bf168c03c870a094e5704c13ec694401be7d6d1ebc43146d74464c8024f6"}
Docker containers
NAMES                   STATUS
electrs_app_1           Up 15 hours
electrs_electrs_1       Up 15 hours
electrs_tor_1           Up 15 hours
bitcoin_server_1        Up 16 hours
bitcoin_i2pd_daemon_1   Up 16 hours
bitcoin_tor_1           Up 16 hours
bitcoin_app_proxy_1     Up 16 hours
bitcoin_bitcoind_1      Up 16 hours
nginx                   Up 16 hours
manager                 Up 16 hours
dashboard               Up 16 hours
auth                    Up 16 hours
tor_proxy               Up 16 hours
Umbrel logs
Attaching to manager
manager      | ::ffff:10.21.0.2 - - [Sat, 09 Sep 2023 22:36:04 GMT] "GET /v1/account/token?token=19eee0c131e7af00ea08da8a0929da69ae58108123054c278c0ded44f27fa6e3 HTTP/1.1" 200 16 "-" "app-proxy/0.0.1"manager      | ::ffff:10.21.0.2 - - [Sat, 09 Sep 2023 22:36:04 GMT] "GET /v1/account/token?token=19eee0c131e7af00ea08da8a0929da69ae58108123054c278c0ded44f27fa6e3 HTTP/1.1" 200 16 "-" "app-proxy/0.0.1"
manager      |
manager      | umbrel-manager
manager      | ::ffff:10.21.21.2 - - [Sat, 09 Sep 2023 22:36:06 GMT] "GET /v1/system/is-sd-card-failing HTTP/1.0" 304 - "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/116.0.0.0 Safari/537.36"
manager      |
manager      | ::ffff:10.21.21.2 - - [Sat, 09 Sep 2023 22:36:06 GMT] "GET /v1/system/temperature HTTP/1.0" 200 2 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/116.0.0.0 Safari/537.36"
manager      |
manager      | ::ffff:10.21.21.2 - - [Sat, 09 Sep 2023 22:36:06 GMT] "GET /v1/apps?installed=1 HTTP/1.0" 304 - "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/116.0.0.0 Safari/537.36"
manager      |
manager      | ::ffff:10.21.21.2 - - [Sat, 09 Sep 2023 22:36:06 GMT] "GET /v1/apps HTTP/1.0" 304 - "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/116.0.0.0 Safari/537.36"
manager      |
manager      | ::ffff:10.21.21.2 - - [Sat, 09 Sep 2023 22:36:06 GMT] "GET /v1/system/info HTTP/1.0" 304 - "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/116.0.0.0 Safari/537.36"
manager      |
manager      | ::ffff:10.21.21.2 - - [Sat, 09 Sep 2023 22:36:06 GMT] "GET /v1/system/storage HTTP/1.0" 200 224 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/116.0.0.0 Safari/537.36"
manager      |
manager      | ::ffff:10.21.21.2 - - [Sat, 09 Sep 2023 22:36:06 GMT] "GET /v1/system/memory HTTP/1.0" 200 215 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/116.0.0.0 Safari/537.36"
manager      |
manager      |
manager      | ::ffff:10.21.21.2 - - [Sat, 09 Sep 2023 22:36:07 GMT] "GET /v1/system/get-update HTTP/1.0" 304 - "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/116.0.0.0 Safari/537.36"
manager      |
Tor Proxy logs
Attaching to tor_proxy
tor_proxy    | Sep 10 03:47:17.000 [notice] While not bootstrapping, fetched this many bytes: 45159 (consensus network-status fetch); 252 (authority cert fetch); 15892 (microdescriptor fetch)
tor_proxy    | Sep 10 04:42:23.000 [warn] Received http status code 404 ("Not found") from server 51.81.57.125:9001 while fetching "/tor/keys/fp/EFCBE720AB3A82B99F9E953CD5BF50F7EEFC7B97".
tor_proxy    | Sep 10 06:31:23.000 [warn] Received http status code 404 ("Not found") from server 31.133.1.108:443 while fetching "/tor/keys/fp/EFCBE720AB3A82B99F9E953CD5BF50F7EEFC7B97".
tor_proxy    | Sep 10 08:00:23.000 [warn] Received http status code 404 ("Not found") from server 31.133.1.108:443 while fetching "/tor/keys/fp/EFCBE720AB3A82B99F9E953CD5BF50F7EEFC7B97".
tor_proxy    | Sep 10 09:17:23.000 [warn] Received http status code 404 ("Not found") from server 31.133.1.108:443 while fetching "/tor/keys/fp/EFCBE720AB3A82B99F9E953CD5BF50F7EEFC7B97".
tor_proxy    | Sep 10 09:47:17.000 [notice] Heartbeat: Tor's uptime is 12:00 hours, with 0 circuits open. I've sent 1.85 MB and received 14.11 MB. I've received 2 connections on IPv4 and 0 on IPv6. I've made 23 connections with IPv4 and 0 with IPv6.
tor_proxy    | Sep 10 09:47:17.000 [notice] While bootstrapping, fetched this many bytes: 671222 (consensus network-status fetch); 14102 (authority cert fetch); 11973029 (microdescriptor fetch)
tor_proxy    | Sep 10 09:47:17.000 [notice] While not bootstrapping, fetched this many bytes: 92591 (consensus network-status fetch); 504 (authority cert fetch); 154743 (microdescriptor fetch)
tor_proxy    | Sep 10 11:03:24.000 [warn] Received http status code 404 ("Not found") from server 144.172.73.89:443 while fetching "/tor/keys/fp/EFCBE720AB3A82B99F9E953CD5BF50F7EEFC7B97".
tor_proxy    | Sep 10 12:48:24.000 [warn] Received http status code 404 ("Not found") from server 144.172.73.89:443 while fetching "/tor/keys/fp/EFCBE720AB3A82B99F9E953CD5BF50F7EEFC7B97".
App logs
bitcoin
Attaching to bitcoin_server_1, bitcoin_i2pd_daemon_1, bitcoin_tor_1, bitcoin_app_proxy_1, bitcoin_bitcoind_1
app_proxy_1    | Validating token: 19eee0c131e7 ...
bitcoind_1     | 2023-09-10T13:06:17Z Socks5() connect to 2a01:4f9:6b:14ec::2:8333 failed: general failure
bitcoind_1     | 2023-09-10T13:22:52Z Saw new header hash=00000000000000000004915a4c6c1560f95d73b45a35b5fb5652c4327a9ce1a8 height=807037
bitcoind_1     | 2023-09-10T13:22:52Z [net] Saw new cmpctblock header hash=00000000000000000004915a4c6c1560f95d73b45a35b5fb5652c4327a9ce1a8 peer=592
bitcoind_1     | 2023-09-10T13:22:53Z UpdateTip: new best=00000000000000000004915a4c6c1560f95d73b45a35b5fb5652c4327a9ce1a8 height=807037 version=0x20e00000 log2_work=94.409573 tx=892134311 date='2023-09-10T13:22:42Z' progress=1.000000 cache=167.2MiB(1225129txo)
bitcoind_1     | 2023-09-10T13:25:29Z Socks5() connect to 31.18.82.201:8333 failed: general failure
bitcoind_1     | 2023-09-10T13:31:44Z Socks5() connect to 137.184.186.227:8333 failed: general failure
bitcoind_1     | 2023-09-10T13:39:19Z Socks5() connect to 2a03:4000:21:8a8:dead:beef:ca1f:1337:8333 failed: general failure
bitcoind_1     | 2023-09-10T13:48:10Z Saw new header hash=0000000000000000000485380504697455e33fe6759f9ab2735b02da46cc0dae height=807038
bitcoind_1     | 2023-09-10T13:48:10Z [net] Saw new cmpctblock header hash=0000000000000000000485380504697455e33fe6759f9ab2735b02da46cc0dae peer=592
bitcoind_1     | 2023-09-10T13:48:10Z UpdateTip: new best=0000000000000000000485380504697455e33fe6759f9ab2735b02da46cc0dae height=807038 version=0x2e5a4000 log2_work=94.409586 tx=892138081 date='2023-09-10T13:47:35Z' progress=1.000000 cache=168.4MiB(1235142txo)
i2pd_daemon_1  | 13:47:12@122/error - Garlic: Failed to decrypt message
i2pd_daemon_1  | 13:47:21@122/error - Garlic: Failed to decrypt message
i2pd_daemon_1  | 13:47:23@122/error - Garlic: Failed to decrypt message
i2pd_daemon_1  | 13:47:43@122/error - Garlic: Failed to decrypt message
i2pd_daemon_1  | 13:47:56@683/error - Garlic: Can't handle ECIES-X25519-AEAD-Ratchet message
i2pd_daemon_1  | 13:48:16@122/error - Garlic: Failed to decrypt message
i2pd_daemon_1  | 13:48:23@122/error - Garlic: Failed to decrypt message
i2pd_daemon_1  | 13:48:25@122/error - Garlic: Failed to decrypt message
i2pd_daemon_1  | 13:48:25@122/error - SAM: Read error: End of file
i2pd_daemon_1  | 13:48:31@122/error - Garlic: Failed to decrypt message
tor_1          | Sep 10 12:50:33.000 [notice] Have tried resolving or connecting to address '[scrubbed]' at 3 different places. Giving up.
tor_1          | Sep 10 12:53:25.000 [notice] Have tried resolving or connecting to address '[scrubbed]' at 3 different places. Giving up.
tor_1          | Sep 10 12:54:02.000 [notice] Closed 1 streams for service [scrubbed].onion for reason resolve failed. Fetch status: No more HSDir available to query.
tor_1          | Sep 10 12:57:12.000 [notice] Have tried resolving or connecting to address '[scrubbed]' at 3 different places. Giving up.
tor_1          | Sep 10 12:58:10.000 [notice] Have tried resolving or connecting to address '[scrubbed]' at 3 different places. Giving up.
tor_1          | Sep 10 12:59:30.000 [warn] Received http status code 404 ("Not found") from server 144.172.73.44:443 while fetching "/tor/keys/fp/EFCBE720AB3A82B99F9E953CD5BF50F7EEFC7B97".
tor_1          | Sep 10 12:59:33.000 [notice] Your network connection speed appears to have changed. Resetting timeout to 60000ms after 18 timeouts and 284 buildtimes.
tor_1          | Sep 10 13:25:29.000 [notice] Have tried resolving or connecting to address '[scrubbed]' at 3 different places. Giving up.
tor_1          | Sep 10 13:31:44.000 [notice] Have tried resolving or connecting to address '[scrubbed]' at 3 different places. Giving up.
tor_1          | Sep 10 13:39:19.000 [notice] Have tried resolving or connecting to address '[scrubbed]' at 3 different places. Giving up.
server_1       | umbrel-middleware
server_1       | ::ffff:10.21.0.2 - - [Sat, 09 Sep 2023 22:36:04 GMT] "GET /v1/bitcoind/info/stats HTTP/1.1" 200 123 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/116.0.0.0 Safari/537.36"
server_1       |
server_1       | ::ffff:10.21.0.2 - - [Sat, 09 Sep 2023 22:36:04 GMT] "GET /v1/bitcoind/info/connections HTTP/1.1" 304 - "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/116.0.0.0 Safari/537.36"
server_1       |
server_1       | ::ffff:10.21.0.2 - - [Sat, 09 Sep 2023 22:36:04 GMT] "GET /v1/bitcoind/info/sync HTTP/1.1" 200 103 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/116.0.0.0 Safari/537.36"
server_1       |
==== Result ====
umbrel@umbrel:~ $
In that case, I would suggest trying the following after SSHing into your Umbrel.
sudo ~/umbrel/scripts/app uninstall electrs
sudo ~/umbrel/scripts/stop && sudo ~/umbrel/scripts/start
sudo ~/umbrel/scripts/app install electrs
umbrel@umbrel:~ $ sudo ~/umbrel/scripts/app uninstall electrs
[sudo] password for umbrel:
**Error: app "electrs" is not installed yet**
umbrel@umbrel:~ $ sudo ~/umbrel/scripts/stop && sudo ~/umbrel/scripts/start
Killing background services
Stopping installed apps...
Stopping app bitcoin...
Stopping bitcoin_server_1      ... done
Stopping bitcoin_i2pd_daemon_1 ... done
Stopping bitcoin_tor_1         ... done
Stopping bitcoin_app_proxy_1   ... done
Stopping bitcoin_bitcoind_1    ... done
Going to remove bitcoin_server_1, bitcoin_i2pd_daemon_1, bitcoin_tor_1, bitcoin_app_proxy_1, bitcoin_bitcoind_1
Removing bitcoin_server_1      ... done
Removing bitcoin_i2pd_daemon_1 ... done
Removing bitcoin_tor_1         ... done
Removing bitcoin_app_proxy_1   ... done
Removing bitcoin_bitcoind_1    ... done
Stopping Docker services...
Stopping nginx     ... done
Stopping manager   ... done
Stopping dashboard ... done
Stopping auth      ... done
Stopping tor_proxy ... done
Removing nginx     ... done
Removing manager   ... done
Removing dashboard ... done
Removing auth      ... done
Removing tor_proxy ... done
ERROR: error while removing network: network umbrel_main_network id 0904035b10931d0fb64dc5e20f396a78e1e2ea0d26087764436c7e2c2fbbbfad has active endpoints
umbrel@umbrel:~ $ sudo ~/umbrel/scripts/app install electrs
Installing 'electrs' from: https://github.com/getumbrel/umbrel-apps.git
Setting up data dir for app electrs...
Pulling images for app electrs...
Pulling tor       ... done
Pulling app_proxy ... done
Pulling electrs   ... done
Pulling app       ... done
Starting app electrs...
electrs_tor_1 is up-to-date
electrs_electrs_1 is up-to-date
Starting electrs_app_proxy_1 ...
electrs_app_1 is up-to-date
Starting electrs_app_proxy_1 ... error
ERROR: for electrs_app_proxy_1  Cannot start service app_proxy: driver failed programming external connectivity on endpoint electrs_app_proxy_1 (eea6fbb19865457e4e7a2ae7f0b308fd340c76a5f7a26555386047bbd420fb35): Bind for 0.0.0.0:2102 failed: port is already allocated
**ERROR: for app_proxy  Cannot start service app_proxy: driver failed programming external connectivity on endpoint electrs_app_proxy_1 (eea6fbb19865457e4e7a2ae7f0b308fd340c76a5f7a26555386047bbd420fb35): Bind for 0.0.0.0:2102 failed: port is already allocated**
ERROR: Encountered errors while bringing up the project.
Looks as if it was not installed and the Error is that the port is already used somehow?
:laughing: :joy:
netstat -tulpn
(Not all processes could be identified, non-owned process info
 will not be shown, you would have to be root to see it all.)
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
tcp        0      0 0.0.0.0:2102            0.0.0.0:*               LISTEN      -
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      -
tcp        0      0 0.0.0.0:3006            0.0.0.0:*               LISTEN      -
tcp        0      0 0.0.0.0:8000            0.0.0.0:*               LISTEN      -
tcp6       0      0 :::2102                 :::*                    LISTEN      -
tcp6       0      0 :::22                   :::*                    LISTEN      -
tcp6       0      0 :::3006                 :::*                    LISTEN      -
udp        0      0 0.0.0.0:50063           0.0.0.0:*                           -
udp        0      0 0.0.0.0:5353            0.0.0.0:*                           -
udp        0      0 0.0.0.0:68              0.0.0.0:*                           -
udp6       0      0 :::5353                 :::*                                -
udp6       0      0 :::36324                :::*                                -
grep 2102 /etc/services
zephyr-srv      2102/udp                        # Zephyr server
Not an Linux expert is there probably sth not actually running on 2102 TCP but configured?
Thank you very much :rofl: don’t forget about karen either https://github.com/getumbrel/umbrel/blob/master/karen
I’m just gonna check up with the team on this one- I’ll get back to you shortly.
