Umbrel cannot start apps after upgrade to 1.0
Will do… let me see if my ssh even works … I use 2FA so login is username + 2FA code?
Sorry, I meant password + 2FA code?
SSH password will be umbrel after a reflash or your dashboard password otherwise.
Everything works great now! Thanks for the help.
@scottcronk @Jon @BitcoinKeegan
If this resolves your issue would you mind letting me know if you went from 0.5 > 1.0.3 or 0.5 > 1.0.x > 1.0.3.
This shouldn’t happen to users going direct to 1.0.3 but if it does it means we need to add some more handling for this to prevent it affecting anyone else so would be really helpful if you could let me know. Thanks so much!
I went from 0.5 to 1.0 – problems. Then to 1.3
Tried your sudo commands – still can not load my old apps or install any new.
Here is log:
umbrel@umbrel:~$ sudo systemctl stop umbrel
[sudo] password for umbrel:
umbrel@umbrel:~$ sudo systemctl stop docker docker.socket
umbrel@umbrel:~$ sudo bash -c “rm -rf /var/lib/docker/*”
umbrel@umbrel:~$ sudo systemctl start docker docker.socket
umbrel@umbrel:~$ sudo systemctl start umbrel
umbrel@umbrel:~$ sudo journalctl -u umbrel -b
Mar 23 23:10:03 umbrel systemd[1]: Started umbrel.service - Umbrel daemon.
Mar 23 23:10:18 umbrel umbreld[719]: [umbreld ] :open_umbrella: Starting Umbrel v1.0.3
Mar 23 23:10:18 umbrel umbreld[719]: [umbreld ] dataDirectory: /home/umbrel/umbrel
Mar 23 23:10:18 umbrel umbreld[719]: [umbreld ] port: 80
Mar 23 23:10:18 umbrel umbreld[719]: [umbreld ] logLevel: verbose
Mar 23 23:10:18 umbrel mender[739]: time=“2024-03-23T23:10:18Z” level=info msg=“'UpdateControlMa>
Mar 23 23:10:18 umbrel mender[739]: time=“2024-03-23T23:10:18Z” level=info msg=”'UpdateControlMa>
Mar 23 23:10:18 umbrel mender[739]: time=“2024-03-23T23:10:18Z” level=info msg="No configuration>
Mar 23 23:10:18 umbrel mender[739]: time=“2024-03-23T23:10:18Z” level=warning msg="No server URL>
Mar 23 23:10:18 umbrel mender[739]: time=“2024-03-23T23:10:18Z” level=warning msg="Server entry >
Mar 23 23:10:18 umbrel mender[739]: time=“2024-03-23T23:10:18Z” level=info msg="No dual rootfs c>
Mar 23 23:10:18 umbrel mender[739]: time=“2024-03-23T23:10:18Z” level=error msg=“Could not commi>
Mar 23 23:10:18 umbrel mender[739]: time=“2024-03-23T23:10:18Z” level=warning msg=“There is noth>
Mar 23 23:10:18 umbrel umbreld[719]: [umbreld ] [error] Failed to commit OS partition: Command >
Mar 23 23:10:18 umbrel umbreld[719]: time=“2024-03-23T23:10:18Z” level=info msg=”'UpdateControlM>
Mar 23 23:10:18 umbrel umbreld[719]: time=“2024-03-23T23:10:18Z” level=info msg="No configuratio>
Mar 23 23:10:18 umbrel umbreld[719]: time=“2024-03-23T23:10:18Z” level=warning msg="No server UR>
Mar 23 23:10:18 umbrel umbreld[719]: time=“2024-03-23T23:10:18Z” level=warning msg="Server entry>
Mar 23 23:10:18 umbrel umbreld[719]: time=“2024-03-23T23:10:18Z” level=info msg="No dual rootfs >
Mar 23 23:10:18 umbrel umbreld[719]: time=“2024-03-23T23:10:18Z” level=error msg="Could not comm>
Mar 23 23:10:18 umbrel umbreld[719]: time=“2024-03-23T23:10:18Z” level=warning msg="There is not>
Mar 23 23:10:18 umbrel umbreld[719]: [migration] Found legacy Umbrel data, migrating…
Mar 23 23:10:18 umbrel umbreld[719]: [umbreld ] Set ondemand cpu governor
Mar 23 23:10:19 umbrel umbreld[719]: [apprepository] Checking for update for https://github.com/>
Mar 23 23:10:19 umbrel umbreld[719]: [apprepository] https://github.com/getumbrel/umbrel-apps.gi>
Mar 23 23:10:20 umbrel umbreld[719]: [migration ] [error] Failed to migrate legacy data: dest>
Mar 23 23:10:20 umbrel umbreld[719]: [umbreld ] Checking if system time is synced before co>
Mar 23 23:10:20 umbrel umbreld[719]: [umbreld ] System time is not currently synced, waitin>
Mar 23 23:10:21 umbrel umbreld[719]: [umbreld ] System time is not currently synced, waitin>
Mar 23 23:10:22 umbrel umbreld[719]: [umbreld ] System time is not currently synced, waitin>
Mar 23 23:10:23 umbrel umbreld[719]: [umbreld ] System time is not currently synced, waitin>
Mar 23 23:10:24 umbrel umbreld[719]: [umbreld ] System time is not currently synced, waitin>
Mar 23 23:10:25 umbrel umbreld[719]: [umbreld ] System time is not currently synced, waitin>
Mar 23 23:10:26 umbrel umbreld[719]: [umbreld ] System time is not currently synced, waitin>
Mar 23 23:10:27 umbrel umbreld[719]: [umbreld ] System time is not currently synced, waitin>
Mar 23 23:10:28 umbrel umbreld[719]: [umbreld ] System time is not currently synced, waitin>
Mar 23 23:10:30 umbrel umbreld[719]: [umbreld ] System time is not currently synced, waitin>
Mar 23 23:10:31 umbrel umbreld[719]: [umbreld ] [error] System time is not synced but timeo>
Mar 23 23:10:31 umbrel umbreld[719]: [apps ] Cleaning up old networks…
Mar 23 23:10:31 umbrel umbreld[719]: [appstore ] Initialising app store
Mar 23 23:10:31 umbrel umbreld[719]: [appstore ] Initialising repositories…
Mar 23 23:10:31 umbrel umbreld[719]: [apprepository] Checking for update for https://github.com/>
Mar 23 23:10:31 umbrel umbreld[719]: [server ] Listening on port 80
Mar 23 23:10:31 umbrel umbreld[719]: [apps ] Copying bins to /home/umbrel/umbrel/bin
Mar 23 23:10:31 umbrel umbreld[719]: [apps ] Copying bitcoin-cli
Mar 23 23:10:31 umbrel umbreld[719]: [apps ] Copying lncli
Mar 23 23:10:31 umbrel umbreld[719]: [apps ] Pre-loading local Docker image auth
lines 1-50
@scottcronk would you be able to get the commands by running this on your Mac (not in SSH):
ssh -t umbrel@umbrel.local "sudo journalctl -u umbrel -b > /tmp/umbrel.log" && scp umbrel@umbrel.local:/tmp/umbrel.log ~/Downloads/umbrel.log
It will download the log file to your Downloads folder which you can then upload here. The logs you pasted is only a small excerpt, this will allow me to view the full log file, thanks!
Here you go- log download in full via SSH… well what you support accepts anyway (truncate to some 32k characters).
login as: umbrel
umbrel@umbrel.local’s password:
Last login: Sun Mar 24 22:00:38 2024 from fe80::a94f:72c4:3cdb:87d7%end0
Sorry, try again.
Mar 24 21:57:26 umbrel systemd[1]: Started umbrel.service - Umbrel daemon.
Mar 24 21:57:41 umbrel umbreld[711]: [umbreld ] ?? Starting Umbrel v1.0.3
Mar 24 21:57:41 umbrel umbreld[711]: [umbreld ] dataDirectory: /home/umbrel/umbrel
Mar 24 21:57:41 umbrel umbreld[711]: [umbreld ] port: 80
Mar 24 21:57:41 umbrel umbreld[711]: [umbreld ] logLevel: verbose
Mar 24 21:57:41 umbrel mender[731]: time=“2024-03-24T21:57:41Z” level=info msg=“‘UpdateControlMapExpirationTimeSeconds’ is not set in the Mender configuration file. Falling back to the default of >
Mar 24 21:57:41 umbrel mender[731]: time=“2024-03-24T21:57:41Z” level=info msg=”‘UpdateControlMapBootExpirationTimeSeconds’ is not set in the Mender configuration file. Falling back to the default>
Mar 24 21:57:41 umbrel mender[731]: time=“2024-03-24T21:57:41Z” level=info msg=“No configuration files present. Using defaults”
Mar 24 21:57:41 umbrel mender[731]: time=“2024-03-24T21:57:41Z” level=warning msg=“No server URL(s) specified in mender configuration.”
Mar 24 21:57:41 umbrel mender[731]: time=“2024-03-24T21:57:41Z” level=warning msg=“Server entry 1 has no associated server URL.”
Mar 24 21:57:41 umbrel mender[731]: time=“2024-03-24T21:57:41Z” level=info msg=“No dual rootfs configuration present”
Mar 24 21:57:41 umbrel mender[731]: time=“2024-03-24T21:57:41Z” level=error msg=“Could not commit Artifact: There is nothing to commit”
Mar 24 21:57:41 umbrel mender[731]: time=“2024-03-24T21:57:41Z” level=warning msg=“There is nothing to commit”
Mar 24 21:57:41 umbrel umbreld[711]: [umbreld ] [error] Failed to commit OS partition: Command failed with exit code 2: mender commit
Mar 24 21:57:41 umbrel umbreld[711]: time=“2024-03-24T21:57:41Z” level=info msg=“‘UpdateControlMapExpirationTimeSeconds’ is not set in the Mender configuration file. Falling back to the default of>
Mar 24 21:57:41 umbrel umbreld[711]: time=“2024-03-24T21:57:41Z” level=info msg=”‘UpdateControlMapBootExpirationTimeSeconds’ is not set in the Mender configuration file. Falling back to the defaul>
Mar 24 21:57:41 umbrel umbreld[711]: time=“2024-03-24T21:57:41Z” level=info msg=“No configuration files present. Using defaults”
Mar 24 21:57:41 umbrel umbreld[711]: time=“2024-03-24T21:57:41Z” level=warning msg=“No server URL(s) specified in mender configuration.”
Mar 24 21:57:41 umbrel umbreld[711]: time=“2024-03-24T21:57:41Z” level=warning msg=“Server entry 1 has no associated server URL.”
Mar 24 21:57:41 umbrel umbreld[711]: time=“2024-03-24T21:57:41Z” level=info msg=“No dual rootfs configuration present”
Mar 24 21:57:41 umbrel umbreld[711]: time=“2024-03-24T21:57:41Z” level=error msg=“Could not commit Artifact: There is nothing to commit”
Mar 24 21:57:41 umbrel umbreld[711]: time=“2024-03-24T21:57:41Z” level=warning msg=“There is nothing to commit”
Mar 24 21:57:41 umbrel umbreld[711]: [migration] Found legacy Umbrel data, migrating…
Mar 24 21:57:41 umbrel umbreld[711]: [umbreld ] Set ondemand cpu governor
Mar 24 21:57:41 umbrel umbreld[711]: [apprepository] Checking for update for GitHub - getumbrel/umbrel-apps: The official app repository of the Umbrel App Store. Submit apps and updates here. Learn how → https://github.com/getumbrel/umbrel-apps#readme
Mar 24 21:57:42 umbrel umbreld[711]: [apprepository] GitHub - getumbrel/umbrel-apps: The official app repository of the Umbrel App Store. Submit apps and updates here. Learn how → https://github.com/getumbrel/umbrel-apps#readme is already up to date
Mar 24 21:57:43 umbrel umbreld[711]: [migration ] [error] Failed to migrate legacy data: dest already exists.
Mar 24 21:57:43 umbrel umbreld[711]: [umbreld ] Checking if system time is synced before continuing…
Mar 24 21:57:43 umbrel umbreld[711]: [umbreld ] System time is not currently synced, waiting…
Mar 24 21:57:44 umbrel umbreld[711]: [umbreld ] System time is not currently synced, waiting…
Mar 24 21:57:45 umbrel umbreld[711]: [umbreld ] System time is not currently synced, waiting…
Mar 24 21:57:46 umbrel umbreld[711]: [umbreld ] System time is not currently synced, waiting…
Mar 24 21:57:47 umbrel umbreld[711]: [umbreld ] System time is not currently synced, waiting…
Mar 24 21:57:48 umbrel umbreld[711]: [umbreld ] System time is not currently synced, waiting…
Mar 24 21:57:49 umbrel umbreld[711]: [umbreld ] System time is not currently synced, waiting…
Mar 24 21:57:50 umbrel umbreld[711]: [umbreld ] System time is not currently synced, waiting…
Mar 24 21:57:51 umbrel umbreld[711]: [umbreld ] System time is not currently synced, waiting…
Mar 24 21:57:52 umbrel umbreld[711]: [umbreld ] System time is not currently synced, waiting…
Mar 24 21:57:53 umbrel umbreld[711]: [umbreld ] [error] System time is not synced but timeout was reached. Continuing…
Mar 24 21:57:54 umbrel umbreld[711]: [apps ] Cleaning up old networks…
Mar 24 21:57:54 umbrel umbreld[711]: [appstore ] Initialising app store
Mar 24 21:57:54 umbrel umbreld[711]: [appstore ] Initialising repositories…
Mar 24 21:57:54 umbrel umbreld[711]: [apprepository] Checking for update for GitHub - getumbrel/umbrel-apps: The official app repository of the Umbrel App Store. Submit apps and updates here. Learn how → https://github.com/getumbrel/umbrel-apps#readme
Mar 24 21:57:54 umbrel umbreld[711]: [server ] Listening on port 80
Mar 24 21:57:54 umbrel umbreld[711]: [apps ] Copying bins to /home/umbrel/umbrel/bin
Mar 24 21:57:54 umbrel umbreld[711]: [apps ] Copying bitcoin-cli
Mar 24 21:57:54 umbrel umbreld[711]: [apps ] Copying lncli
Mar 24 21:57:54 umbrel umbreld[711]: [apps ] Pre-loading local Docker image auth
Mar 24 21:57:54 umbrel umbreld[711]: [apps ] Pre-loading local Docker image tor
Mar 24 21:57:55 umbrel umbreld[711]: [apprepository] GitHub - getumbrel/umbrel-apps: The official app repository of the Umbrel App Store. Submit apps and updates here. Learn how → https://github.com/getumbrel/umbrel-apps#readme is already up to date
Mar 24 21:57:56 umbrel umbreld[711]: [apprepository] Checking for update for GitHub - getumbrel/umbrel-apps: The official app repository of the Umbrel App Store. Submit apps and updates here. Learn how → https://github.com/getumbrel/umbrel-apps#readme
Mar 24 21:57:56 umbrel umbreld[711]: [apprepository] GitHub - getumbrel/umbrel-apps: The official app repository of the Umbrel App Store. Submit apps and updates here. Learn how → https://github.com/getumbrel/umbrel-apps#readme is already up to date
Mar 24 21:57:57 umbrel umbreld[711]: [appstore ] Repositories initialised!
Mar 24 21:57:57 umbrel umbreld[711]: [appstore ] Checking repositories for updates every 5m
Mar 24 21:57:59 umbrel umbreld[711]: [server ] GET /
Mar 24 21:57:59 umbrel umbreld[711]: [server ] GET /assets/index-4d6edbf6.js
Mar 24 21:57:59 umbrel umbreld[711]: [server ] GET /assets/react-b8fd6adb.js
Mar 24 21:57:59 umbrel umbreld[711]: [server ] GET /assets/index-cb25441d.css
Mar 24 21:57:59 umbrel umbreld[711]: [server ] GET /assets/css-a1feef3f.js
Mar 24 21:57:59 umbrel umbreld[711]: [server ] GET /assets/fetch-589e3ac6.js
Mar 24 21:57:59 umbrel umbreld[711]: [server ] GET /assets/reactRouter-beb45e27.js
Mar 24 21:57:59 umbrel umbreld[711]: [server ] GET /assets/i18n-aed50e3a.js
Mar 24 21:57:59 umbrel umbreld[711]: [server ] GET /assets/dev-262e6365.js
Mar 24 21:57:59 umbrel umbreld[711]: [server ] GET /locales/en.json
Mar 24 21:57:59 umbrel umbreld[711]: [server ] GET /favicon/favicon-32x32.png
Mar 24 21:57:59 umbrel umbreld[711]: [server ] GET /site.webmanifest
Mar 24 21:57:59 umbrel umbreld[711]: [server ] GET /android-chrome-192x192.png
Mar 24 21:57:59 umbrel umbreld[711]: [server ] GET /trpc/user.wallpaper
Mar 24 21:57:59 umbrel umbreld[711]: [server ] GET /trpc/system.status
Mar 24 21:57:59 umbrel umbreld[711]: [server ] GET /android-chrome-512x512.png
Mar 24 21:57:59 umbrel umbreld[711]: [server ] GET /trpc/user.isLoggedIn
Mar 24 21:57:59 umbrel umbreld[711]: [server ] GET /wallpapers/17.jpg
Mar 24 21:57:59 umbrel umbreld[711]: [server ] GET /trpc/appStore.registry
Mar 24 21:57:59 umbrel umbreld[711]: [server ] GET /wallpapers/generated-thumbs/17.jpg
Mar 24 21:58:00 umbrel umbreld[711]: [server ] GET /assets/segmented-control-c7c10d3e.js
Mar 24 21:58:00 umbrel umbreld[711]: [server ] GET /assets/icon-button-2ca71435.js
Mar 24 21:58:00 umbrel umbreld[711]: [server ] GET /assets/pretty-bytes-902e39bd.js
Mar 24 21:58:00 umbrel umbreld[711]: [server ] GET /assets/index-5eb460d8.js
Mar 24 21:58:00 umbrel umbreld[711]: [server ] GET /assets/live-usage-ef591679.js
Mar 24 21:58:00 umbrel umbreld[711]: [server ] GET /assets/immersive-dialog-015be2a7.js
Mar 24 21:58:00 umbrel umbreld[711]: [server ] GET /assets/use-memory-4dd64f7b.js
Mar 24 21:58:00 umbrel umbreld[711]: [server ] GET /trpc/apps.list
Mar 24 21:58:00 umbrel umbreld[711]: [server ] GET /trpc/user.get
Mar 24 21:58:00 umbrel umbreld[711]: [server ] GET /assets/Inter-roman.var-17fe38ab.woff2
Mar 24 21:58:00 umbrel umbreld[711]: [server ] GET /figma-exports/dock-app-store.png
Mar 24 21:58:00 umbrel umbreld[711]: [server ] GET /figma-exports/dock-settings.png
Mar 24 21:58:00 umbrel umbreld[711]: [server ] GET /figma-exports/dock-widgets.png
Mar 24 21:58:00 umbrel umbreld[711]: [server ] GET /figma-exports/dock-home.png
Mar 24 21:58:00 umbrel umbreld[711]: [server ] GET /figma-exports/dock-live-usage.png
Mar 24 21:58:00 umbrel umbreld[711]: [server ] GET /trpc/system.checkUpdate
Mar 24 21:58:00 umbrel umbreld[711]: [server ] GET /trpc/system.cpuTemperature
Mar 24 21:58:00 umbrel umbreld[711]: [server ] GET /trpc/system.memoryUsage
Mar 24 21:58:00 umbrel umbreld[711]: [server ] GET /trpc/system.diskUsage
Mar 24 21:58:00 umbrel umbreld[711]: [server ] GET /figma-exports/app-icon-placeholder.svg
Mar 24 21:58:00 umbrel umbreld[711]: [server ] GET /assets/index-4d6edbf6.js
Mar 24 21:58:00 umbrel umbreld[711]: [server ] GET /assets/react-b8fd6adb.js
Mar 24 21:58:00 umbrel umbreld[711]: [server ] GET /assets/reactRouter-beb45e27.js
Mar 24 21:58:00 umbrel umbreld[711]: [server ] GET /assets/i18n-aed50e3a.js
Mar 24 21:58:00 umbrel umbreld[711]: [server ] GET /assets/css-a1feef3f.js
Mar 24 21:58:00 umbrel umbreld[711]: [server ] GET /assets/fetch-589e3ac6.js
Mar 24 21:58:00 umbrel umbreld[711]: [server ] GET /assets/index-cb25441d.css
Mar 24 21:58:00 umbrel umbreld[711]: [server ] GET /assets/dev-262e6365.js
Mar 24 21:58:01 umbrel umbreld[711]: [server ] GET /locales/en.json
Mar 24 21:58:01 umbrel umbreld[711]: [server ] GET /trpc/user.wallpaper
Mar 24 21:58:01 umbrel umbreld[711]: [server ] GET /trpc/system.status
Mar 24 21:58:01 umbrel umbreld[711]: [server ] GET /site.webmanifest
Mar 24 21:58:01 umbrel umbreld[711]: [server ] GET /trpc/user.isLoggedIn
Mar 24 21:58:01 umbrel umbreld[711]: [server ] GET /android-chrome-192x192.png
Mar 24 21:58:01 umbrel umbreld[711]: [server ] GET /wallpapers/17.jpg
Mar 24 21:58:01 umbrel umbreld[711]: [server ] GET /android-chrome-512x512.png
Mar 24 21:58:01 umbrel umbreld[711]: [server ] GET /wallpapers/generated-thumbs/17.jpg
Mar 24 21:58:01 umbrel umbreld[711]: [server ] GET /trpc/user.exists
Mar 24 21:58:01 umbrel umbreld[711]: [server ] GET /assets/login-76e25493.js
Mar 24 21:58:05 umbrel umbreld[711]: [server ] POST /trpc/user.login
Mar 24 21:58:05 umbrel umbreld[711]: [server ] [error] POST /user.login Missing 2FA code
Mar 24 21:58:09 umbrel umbreld[794]: Loaded image ID: sha256:105438dd043f4ec97aac88826fb53eef1769daa38bfe21fe929cf63bc204a7bc
Mar 24 21:58:10 umbrel umbreld[711]: [server ] POST /trpc/user.login
Mar 24 21:58:11 umbrel umbreld[711]: [server ] GET /trpc/system.status
Mar 24 21:58:11 umbrel umbreld[711]: [server ] GET /assets/index-4d6edbf6.js
Mar 24 21:58:11 umbrel umbreld[711]: [server ] GET /assets/react-b8fd6adb.js
Mar 24 21:58:11 umbrel umbreld[711]: [server ] GET /assets/reactRouter-beb45e27.js
Mar 24 21:58:11 umbrel umbreld[711]: [server ] GET /assets/index-cb25441d.css
Mar 24 21:58:11 umbrel umbreld[711]: [server ] GET /assets/dev-262e6365.js
Mar 24 21:58:11 umbrel umbreld[711]: [server ] GET /assets/i18n-aed50e3a.js
Mar 24 21:58:11 umbrel umbreld[711]: [server ] GET /assets/fetch-589e3ac6.js
Mar 24 21:58:11 umbrel umbreld[711]: [server ] GET /assets/css-a1feef3f.js
Mar 24 21:58:11 umbrel umbreld[711]: [server ] GET /locales/en.json
Mar 24 21:58:11 umbrel umbreld[711]: [server ] GET /site.webmanifest
Mar 24 21:58:11 umbrel umbreld[711]: [server ] GET /trpc/user.wallpaper
Mar 24 21:58:11 umbrel umbreld[711]: [server ] GET /android-chrome-192x192.png
Mar 24 21:58:11 umbrel umbreld[711]: [server ] GET /trpc/user.isLoggedIn
Mar 24 21:58:11 umbrel umbreld[711]: [server ] GET /android-chrome-512x512.png
Mar 24 21:58:11 umbrel umbreld[711]: [server ] GET /wallpapers/17.jpg
Mar 24 21:58:11 umbrel umbreld[711]: [server ] GET /wallpapers/generated-thumbs/17.jpg
Mar 24 21:58:11 umbrel umbreld[711]: [server ] GET /trpc/appStore.registry
Mar 24 21:58:11 umbrel chpasswd[832]: pam_unix(chpasswd:chauthtok): password changed for umbrel
Mar 24 21:58:11 umbrel umbreld[711]: [server ] GET /assets/live-usage-ef591679.js
Mar 24 21:58:11 umbrel umbreld[711]: [server ] GET /assets/immersive-dialog-015be2a7.js
Mar 24 21:58:11 umbrel umbreld[711]: [server ] GET /assets/icon-button-2ca71435.js
Mar 24 21:58:11 umbrel umbreld[711]: [server ] GET /assets/segmented-control-c7c10d3e.js
Mar 24 21:58:11 umbrel umbreld[711]: [server ] GET /assets/use-memory-4dd64f7b.js
Mar 24 21:58:11 umbrel umbreld[711]: [server ] GET /assets/pretty-bytes-902e39bd.js
Mar 24 21:58:11 umbrel umbreld[711]: [server ] GET /trpc/user.get
Mar 24 21:58:11 umbrel umbreld[711]: [server ] GET /trpc/apps.list
Mar 24 21:58:11 umbrel umbreld[711]: [server ] GET /assets/index-5eb460d8.js
Mar 24 21:58:11 umbrel umbreld[711]: [server ] GET /figma-exports/dock-app-store.png
Mar 24 21:58:11 umbrel umbreld[711]: [server ] GET /figma-exports/dock-widgets.png
Mar 24 21:58:11 umbrel umbreld[711]: [server ] GET /figma-exports/dock-home.png
Mar 24 21:58:11 umbrel umbreld[711]: [server ] GET /figma-exports/dock-settings.png
Mar 24 21:58:11 umbrel umbreld[711]: [server ] GET /figma-exports/dock-live-usage.png
Mar 24 21:58:11 umbrel umbreld[711]: [server ] GET /trpc/system.checkUpdate
Mar 24 21:58:11 umbrel umbreld[711]: [server ] GET /trpc/system.cpuTemperature
Mar 24 21:58:11 umbrel umbreld[711]: [server ] GET /trpc/system.memoryUsage
Mar 24 21:58:11 umbrel umbreld[711]: [server ] GET /trpc/system.diskUsage
Mar 24 21:58:11 umbrel umbreld[711]: [server ] GET /figma-exports/app-icon-placeholder.svg
Mar 24 21:58:13 umbrel umbreld[793]: Loaded image ID: sha256:f83765bcb6ce3c0da9f9f2738b19d3e7defc000acd977344219fb6d634b328e7
Mar 24 21:58:14 umbrel umbreld[711]: [server ] GET /wallpapers/generated-thumbs/17.jpg
Mar 24 21:58:14 umbrel umbreld[876]: time=“2024-03-24T21:58:14Z” level=warning msg=“/usr/local/lib/node_modules/umbreld/source/modules/apps/legacy-compat/docker-compose.yml: version is obsolete”
Mar 24 21:58:15 umbrel umbreld[876]: Network umbrel_main_network Creating
Mar 24 21:58:15 umbrel umbreld[876]: Network umbrel_main_network Created
Mar 24 21:58:15 umbrel umbreld[876]: Container tor_proxy Creating
Mar 24 21:58:15 umbrel umbreld[876]: Container auth Creating
Mar 24 21:58:15 umbrel umbreld[876]: Container tor_proxy Created
Mar 24 21:58:15 umbrel umbreld[876]: Container auth Created
Mar 24 21:58:15 umbrel umbreld[876]: Container auth Starting
Mar 24 21:58:15 umbrel umbreld[876]: Container tor_proxy Starting
Mar 24 21:58:16 umbrel umbreld[876]: Container auth Started
Mar 24 21:58:16 umbrel umbreld[876]: Container tor_proxy Started
Mar 24 21:58:16 umbrel umbreld[1127]: time=“2024-03-24T21:58:16Z” level=warning msg=“/usr/local/lib/node_modules/umbreld/source/modules/apps/legacy-compat/docker-compose.yml: version is obsolete”
Mar 24 21:58:17 umbrel umbreld[1127]: Container tor_proxy Running
Mar 24 21:58:17 umbrel umbreld[1127]: Container auth Running
Mar 24 21:58:17 umbrel sudo[1141]: root : PWD=/ ; USER=root ; COMMAND=/usr/bin/chown -R 1000:1000 /home/umbrel/umbrel/tor
Mar 24 21:58:17 umbrel sudo[1141]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=0)
Mar 24 21:58:17 umbrel sudo[1141]: pam_unix(sudo:session): session closed for user root
Mar 24 21:58:17 umbrel umbreld[711]: [apps ] Starting apps
Mar 24 21:58:21 umbrel umbreld[711]: [server ] GET /trpc/system.status
Mar 24 21:58:23 umbrel umbreld[711]: [server ] GET /assets/index-bdb34577.js
Mar 24 21:58:23 umbrel umbreld[711]: [server ] GET /assets/top-header-04552d85.js
Mar 24 21:58:23 umbrel umbreld[711]: [server ] GET /assets/install-these-first-dialog-878d40f9.js
Mar 24 21:58:23 umbrel umbreld[711]: [server ] GET /assets/isString-f5bd4dc1.js
Mar 24 21:58:23 umbrel umbreld[711]: [server ] GET /assets/animated-number-6e11a8da.js
Mar 24 21:58:23 umbrel umbreld[711]: [server ] GET /assets/gallery-section-ff405c3d.css
Mar 24 21:58:23 umbrel umbreld[711]: [server ] GET /android-chrome-192x192.png
Mar 24 21:58:23 umbrel umbreld[711]: [server ] GET /assets/gallery-section-268322de.js
Mar 24 21:58:23 umbrel umbreld[711]: [server ] GET /assets/badge-b99f300b.js
Mar 24 21:58:23 umbrel umbreld[711]: [server ] GET /android-chrome-512x512.png
Mar 24 21:58:24 umbrel umbreld[711]: [server ] GET /trpc/apps.state
Mar 24 21:58:24 umbrel umbreld[711]: [server ] GET /trpc/apps.list
Mar 24 21:58:24 umbrel umbreld[711]: [server ] GET /trpc/user.get
Mar 24 21:58:25 umbrel umbreld[711]: [server ] POST /trpc/apps.install
Mar 24 21:58:25 umbrel umbreld[711]: [apps ] Installing app bitcoin
Mar 24 21:58:26 umbrel umbreld[711]: [apps ] Setting up data directory for bitcoin
Mar 24 21:58:26 umbrel umbreld[1177]: time=“2024-03-24T21:58:26Z” level=warning msg=“/usr/local/lib/node_modules/umbreld/source/modules/apps/legacy-compat/docker-compose.yml: version is obsolete”
Mar 24 21:58:26 umbrel umbreld[1177]: Container tor_proxy Running
Mar 24 21:58:26 umbrel umbreld[1177]: Container auth Running
Mar 24 21:58:26 umbrel umbreld[711]: [apps ] [error] Failed to install app bitcoin: (HTTP code 500) server error - Get “https://registry-1.docker.io/v2/”: dial tcp [2600:1f18:2148:bc02:445>
Mar 24 21:58:26 umbrel umbreld[711]: [server ] GET /trpc/apps.state
Mar 24 21:58:26 umbrel umbreld[711]: [server ] GET /trpc/apps.list
Mar 24 21:58:26 umbrel umbreld[711]: [server ] GET /trpc/user.get
Mar 24 21:58:28 umbrel umbreld[711]: [server ] GET /figma-exports/app-icon-placeholder.svg
Mar 24 21:58:28 umbrel umbreld[711]: [server ] GET /android-chrome-192x192.png
Mar 24 21:58:28 umbrel umbreld[711]: [server ] GET /android-chrome-512x512.png
Mar 24 21:58:30 umbrel umbreld[711]: [server ] GET /android-chrome-192x192.png
Mar 24 21:58:30 umbrel umbreld[711]: [server ] GET /android-chrome-512x512.png
Mar 24 21:58:30 umbrel umbreld[711]: [server ] GET /assets/settings-content-0239bbcf.js
Mar 24 21:58:30 umbrel umbreld[711]: [server ] GET /assets/storage-card-content-0554bb8f.js
Mar 24 21:58:30 umbrel umbreld[711]: [server ] GET /assets/cpu-temp-card-content-2cf2c2d3.js
Mar 24 21:58:30 umbrel umbreld[711]: [server ] GET /assets/useMount-8ca2479b.js
Mar 24 21:58:30 umbrel umbreld[711]: [server ] GET /assets/useEffectOnce-6d31aa22.js
Mar 24 21:58:30 umbrel umbreld[711]: [server ] GET /assets/language-dropdown-8e8318ef.js
Mar 24 21:58:30 umbrel umbreld[711]: [server ] GET /assets/use-tor-enabled-e64a32a3.js
Mar 24 21:58:30 umbrel umbreld[711]: [server ] GET /assets/switch-5120300c.js
Mar 24 21:58:30 umbrel umbreld[711]: [server ] GET /assets/use-device-info-69b4c472.js
Mar 24 21:58:30 umbrel umbreld[711]: [server ] GET /assets/use-software-update-6f1c7d8a.js
Mar 24 21:58:30 umbrel umbreld[711]: [server ] GET /assets/chevron-down-84b79f89.js
Mar 24 21:58:30 umbrel umbreld[711]: [server ] GET /wallpapers/generated-thumbs/1.jpg
Mar 24 21:58:30 umbrel umbreld[711]: [server ] GET /wallpapers/generated-thumbs/3.jpg
Mar 24 21:58:30 umbrel umbreld[711]: [server ] GET /wallpapers/generated-thumbs/2.jpg
Mar 24 21:58:30 umbrel umbreld[711]: [server ] GET /wallpapers/generated-thumbs/4.jpg
Mar 24 21:58:30 umbrel umbreld[711]: [server ] GET /wallpapers/generated-thumbs/5.jpg
Mar 24 21:58:30 umbrel umbreld[711]: [server ] GET /wallpapers/generated-thumbs/6.jpg
Mar 24 21:58:30 umbrel umbreld[711]: [server ] GET /wallpapers/generated-thumbs/9.jpg
Mar 24 21:58:30 umbrel umbreld[711]: [server ] GET /wallpapers/generated-thumbs/11.jpg
Mar 24 21:58:30 umbrel umbreld[711]: [server ] GET /wallpapers/generated-thumbs/10.jpg
Mar 24 21:58:30 umbrel umbreld[711]: [server ] GET /wallpapers/generated-thumbs/12.jpg
Mar 24 21:58:30 umbrel umbreld[711]: [server ] GET /wallpapers/generated-thumbs/7.jpg
Mar 24 21:58:30 umbrel umbreld[711]: [server ] GET /wallpapers/generated-thumbs/8.jpg
Mar 24 21:58:30 umbrel umbreld[711]: [server ] GET /trpc/widget.enabled
Mar 24 21:58:30 umbrel umbreld[711]: [server ] GET /trpc/system.cpuUsage
Mar 24 21:58:30 umbrel umbreld[711]: [server ] GET /wallpapers/generated-thumbs/13.jpg
Mar 24 21:58:30 umbrel umbreld[711]: [server ] GET /trpc/system.diskUsage
Mar 24 21:58:30 umbrel umbreld[711]: [server ] GET /trpc/system.memoryUsage
Mar 24 21:58:30 umbrel umbreld[711]: [server ] GET /trpc/system.checkUpdate
Mar 24 21:58:30 umbrel umbreld[711]: [server ] GET /trpc/system.version
Mar 24 21:58:30 umbrel umbreld[711]: [server ] GET /trpc/apps.getTorEnabled
Mar 24 21:58:30 umbrel umbreld[711]: [server ] GET /trpc/system.cpuTemperature
Mar 24 21:58:30 umbrel umbreld[711]: [server ] GET /trpc/user.is2faEnabled
Mar 24 21:58:30 umbrel umbreld[711]: [server ] GET /trpc/system.hiddenService
Mar 24 21:58:30 umbrel umbreld[711]: [server ] GET /trpc/system.device
Mar 24 21:58:30 umbrel umbreld[711]: [server ] GET /trpc/system.uptime
Mar 24 21:58:30 umbrel umbreld[711]: [server ] GET /wallpapers/generated-thumbs/14.jpg
Mar 24 21:58:30 umbrel umbreld[711]: [server ] GET /wallpapers/generated-thumbs/15.jpg
Mar 24 21:58:30 umbrel umbreld[711]: [server ] GET /wallpapers/generated-thumbs/16.jpg
Mar 24 21:58:30 umbrel umbreld[711]: [server ] GET /wallpapers/generated-thumbs/18.jpg
Mar 24 21:58:30 umbrel umbreld[711]: [server ] GET /wallpapers/generated-thumbs/19.jpg
Mar 24 21:58:30 umbrel umbreld[711]: [server ] GET /wallpapers/generated-thumbs/20.jpg
Mar 24 21:58:30 umbrel umbreld[711]: [server ] GET /wallpapers/generated-small/17.jpg
Mar 24 21:58:30 umbrel umbreld[711]: [server ] GET /wallpapers/generated-thumbs/21.jpg
Mar 24 21:58:31 umbrel umbreld[711]: [server ] GET /trpc/system.status
Mar 24 21:58:32 umbrel umbreld[711]: [server ] GET /assets/troubleshoot-1e321779.js
Mar 24 21:58:32 umbrel umbreld[711]: [server ] GET /assets/format-2b6dad33.js
Mar 24 21:58:32 umbrel umbreld[711]: [server ] GET /android-chrome-192x192.png
Mar 24 21:58:32 umbrel umbreld[711]: [server ] GET /trpc/system.logs
Mar 24 21:58:32 umbrel umbreld[711]: [server ] GET /android-chrome-512x512.png
Mar 24 21:58:35 umbrel umbreld[711]: [server ] GET /trpc/system.cpuTemperature
Mar 24 21:58:40 umbrel umbreld[711]: [server ] GET /trpc/system.cpuTemperature
Mar 24 21:58:41 umbrel umbreld[711]: [server ] GET /trpc/system.status
Mar 24 21:58:45 umbrel umbreld[711]: [server ] GET /trpc/system.cpuTemperature
Mar 24 21:58:50 umbrel umbreld[711]: [server ] GET /trpc/system.cpuTemperature
Mar 24 21:58:51 umbrel umbreld[711]: [server ] GET /trpc/system.status
Mar 24 21:58:53 umbrel umbreld[711]: [server ] GET /android-chrome-192x192.png
Mar 24 21:58:53 umbrel umbreld[711]: [server ] GET /android-chrome-512x512.png
Mar 24 21:58:56 umbrel umbreld[711]: [server ] GET /trpc/system.cpuTemperature
Mar 24 21:59:01 umbrel umbreld[711]: [server ] GET /trpc/system.cpuTemperature
Mar 24 21:59:01 umbrel umbreld[711]: [server ] GET /trpc/system.status
Mar 24 21:59:06 umbrel umbreld[711]: [server ] GET /trpc/system.cpuTemperature
Mar 24 21:59:11 umbrel umbreld[711]: [server ] GET /trpc/system.cpuTemperature
Mar 24 21:59:11 umbrel umbreld[711]: [server ] GET /trpc/system.status
Mar 24 21:59:16 umbrel umbreld[711]: [server ] GET /trpc/system.cpuTemperature
Mar 24 21:59:21 umbrel umbreld[711]: [server ] GET /trpc/system.cpuTemperature
Mar 24 21:59:21 umbrel umbreld[711]: [server ] GET /trpc/system.status
Mar 24 21:59:26 umbrel umbreld[711]: [server ] GET /trpc/system.cpuTemperature
Mar 24 21:59:31 umbrel umbreld[711]: [server ] GET /trpc/system.status
Mar 24 21:59:31 umbrel umbreld[711]: [server ] GET /trpc/system.cpuTemperature
Mar 24 21:59:36 umbrel umbreld[711]: [server ] GET /trpc/system.cpuTemperature
Mar 24 21:59:41 umbrel umbreld[711]: [server ] GET /trpc/system.status
Mar 24 21:59:41 umbrel umbreld[711]: [server ] GET /trpc/system.cpuTemperature
Mar 24 21:59:46 umbrel umbreld[711]: [server ] GET /trpc/system.cpuTemperature
Mar 24 21:59:51 umbrel umbreld[711]: [server ] GET /trpc/system.status
Mar 24 21:59:51 umbrel umbreld[711]: [server ] GET /trpc/system.cpuTemperature
Mar 24 21:59:56 umbrel umbreld[711]: [server ] GET /trpc/system.cpuTemperature
Mar 24 22:00:01 umbrel umbreld[711]: [server ] GET /trpc/system.status
Mar 24 22:00:01 umbrel umbreld[711]: [server ] GET /trpc/system.cpuTemperature
Mar 24 22:00:07 umbrel umbreld[711]: [server ] GET /trpc/system.cpuTemperature
Mar 24 22:00:10 umbrel umbreld[711]: [server ] GET /trpc/user.wallpaper
Mar 24 22:00:10 umbrel umbreld[711]: [server ] GET /trpc/user.isLoggedIn
Mar 24 22:00:10 umbrel umbreld[711]: [server ] GET /trpc/apps.list
Mar 24 22:00:10 umbrel umbreld[711]: [server ] GET /trpc/system.version
Mar 24 22:00:10 umbrel umbreld[711]: [server ] GET /trpc/apps.getTorEnabled
Mar 24 22:00:10 umbrel umbreld[711]: [server ] GET /trpc/user.get
Mar 24 22:00:10 umbrel umbreld[711]: [server ] GET /trpc/system.device
Mar 24 22:00:10 umbrel umbreld[711]: [server ] GET /trpc/system.uptime
Mar 24 22:00:10 umbrel umbreld[711]: [server ] GET /trpc/user.is2faEnabled
Mar 24 22:00:10 umbrel umbreld[711]: [server ] GET /trpc/system.hiddenService
Mar 24 22:00:10 umbrel umbreld[711]: [server ] GET /trpc/widget.enabled
Mar 24 22:00:10 umbrel umbreld[711]: [server ] GET /trpc/system.diskUsage
Mar 24 22:00:10 umbrel umbreld[711]: [server ] GET /trpc/system.memoryUsage
Mar 24 22:00:10 umbrel umbreld[711]: [server ] GET /trpc/system.cpuUsage
Mar 24 22:00:11 umbrel umbreld[711]: [server ] GET /trpc/system.status
Mar 24 22:00:12 umbrel umbreld[711]: [server ] GET /trpc/system.cpuTemperature
Mar 24 22:00:17 umbrel umbreld[711]: [server ] GET /trpc/system.cpuTemperature
Mar 24 22:00:21 umbrel umbreld[711]: [server ] GET /trpc/system.status
Mar 24 22:00:22 umbrel umbreld[711]: [server ] GET /trpc/system.cpuTemperature
Mar 24 22:00:27 umbrel umbreld[711]: [server ] GET /trpc/system.cpuTemperature
Mar 24 22:00:31 umbrel umbreld[711]: [server ] GET /trpc/system.status
Mar 24 22:00:32 umbrel umbreld[711]: [server ] GET /trpc/system.cpuTemperature
Mar 24 22:00:37 umbrel umbreld[711]: [server ] GET /trpc/system.cpuTemperature
Mar 24 22:00:41 umbrel umbreld[711]: [server ] GET /trpc/system.status
Mar 24 22:00:42 umbrel umbreld[711]: [server ] GET /trpc/system.cpuTemperature
Mar 24 22:01:44 umbrel systemd[1]: Stopping umbrel.service - Umbrel daemon…
Mar 24 22:01:44 umbrel umbreld[711]: [umbreld ] Received SIGTERM, shutting down cleanly…
Mar 24 22:01:44 umbrel umbreld[711]: [apps ] Stopping apps
Mar 24 22:01:44 umbrel umbreld[711]: [apps ] Stopping app environment
Mar 24 22:01:45 umbrel umbreld[1436]: time=“2024-03-24T22:01:45Z” level=warning msg=“/usr/local/lib/node_modules/umbreld/source/modules/apps/legacy-compat/docker-compose.yml: version is obsolete”
Mar 24 22:01:45 umbrel umbreld[1436]: Container auth Stopping
Mar 24 22:01:45 umbrel umbreld[1436]: Container tor_proxy Stopping
Mar 24 22:01:45 umbrel umbreld[1436]: Container tor_proxy Stopped
Mar 24 22:01:45 umbrel umbreld[1436]: Container tor_proxy Removing
Mar 24 22:01:45 umbrel umbreld[1436]: Container tor_proxy Removed
Mar 24 22:01:45 umbrel umbreld[1436]: Container auth Stopped
Mar 24 22:01:45 umbrel umbreld[1436]: Container auth Removing
Mar 24 22:01:45 umbrel umbreld[1436]: Container auth Removed
@scottcronk we just fixed the issue you’re facing and pushed it out via OTA. You should see the option to update automatically in your Umbrel. Let me know if that works for you!
Fantastic. I am back up. Thanks Luke
Excellent!
Hi!. Can somebody help me?
PS C:\WINDOWS\system32> ssh umbrel@umbrel.local
Linux umbrel 6.6.20+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.6.20-1+rpt1 (2024-03-07) aarch64
Last login: Tue Mar 26 20:53:10 2024 from fe80::edce:5317:ccf0:5b0e%end0
Mar 26 19:46:59 umbrel systemd[1]: Started umbrel.service - Umbrel daemon.
Mar 26 19:47:14 umbrel umbreld[697]: [umbreld ] :open_umbrella: Starting Umbrel v1.0.4
Mar 26 19:47:14 umbrel umbreld[697]: [umbreld ] dataDirectory: /home/umbrel/umbrel
Mar 26 19:47:14 umbrel umbreld[697]: [umbreld ] port: 80
Mar 26 19:47:14 umbrel umbreld[697]: [umbreld ] logLevel: verbose
Mar 26 19:47:14 umbrel mender[717]: time=“2024-03-26T19:47:14Z” level=info msg=“‘UpdateControlMapExpirationTimeSeconds’>Mar 26 19:47:14 umbrel mender[717]: time=“2024-03-26T19:47:14Z” level=info msg=”'UpdateControlMapBootExpirationTimeSeco>Mar 26 19:47:14 umbrel mender[717]: time=“2024-03-26T19:47:14Z” level=info msg="No configuration files present. Using d>Mar 26 19:47:14 umbrel mender[717]: time=“2024-03-26T19:47:14Z” level=warning msg="No server URL(s) specified in mender>Mar 26 19:47:14 umbrel mender[717]: time=“2024-03-26T19:47:14Z” level=warning msg=“Server entry 1 has no associated ser>Mar 26 19:47:14 umbrel mender[717]: time=“2024-03-26T19:47:14Z” level=info msg=“No dual rootfs configuration present”
Mar 26 19:47:14 umbrel mender[717]: time=“2024-03-26T19:47:14Z” level=error msg=“Could not commit Artifact: There is no>Mar 26 19:47:14 umbrel mender[717]: time=“2024-03-26T19:47:14Z” level=warning msg=“There is nothing to commit”
Mar 26 19:47:14 umbrel umbreld[697]: [umbreld ] [error] Failed to commit OS partition: Command failed with exit code 2>Mar 26 19:47:14 umbrel umbreld[697]: time=“2024-03-26T19:47:14Z” level=info msg=”'UpdateControlMapExpirationTimeSeconds>Mar 26 19:47:14 umbrel umbreld[697]: time=“2024-03-26T19:47:14Z” level=info msg=”'UpdateControlMapBootExpirationTimeSec>Mar 26 19:47:14 umbrel umbreld[697]: time=“2024-03-26T19:47:14Z” level=info msg="No configuration files present. Using >Mar 26 19:47:14 umbrel umbreld[697]: time=“2024-03-26T19:47:14Z” level=warning msg="No server URL(s) specified in mende>Mar 26 19:47:14 umbrel umbreld[697]: time=“2024-03-26T19:47:14Z” level=warning msg="Server entry 1 has no associated se>Mar 26 19:47:14 umbrel umbreld[697]: time=“2024-03-26T19:47:14Z” level=info msg=“No dual rootfs configuration present”
Mar 26 19:47:14 umbrel umbreld[697]: time=“2024-03-26T19:47:14Z” level=error msg="Could not commit Artifact: There is n>Mar 26 19:47:14 umbrel umbreld[697]: time=“2024-03-26T19:47:14Z” level=warning msg=“There is nothing to commit”
Mar 26 19:47:15 umbrel umbreld[697]: [umbreld ] Set ondemand cpu governor
Mar 26 19:47:15 umbrel umbreld[697]: [umbreld ] Checking if system time is synced before continuing…
Mar 26 19:47:15 umbrel umbreld[697]: [umbreld ] System time is not currently synced, waiting…
Mar 26 19:47:24 umbrel umbreld[697]: [umbreld ] System time is synced. Continuing…
Mar 26 19:47:25 umbrel umbreld[697]: [apps ] Cleaning up old networks…
Mar 26 19:47:25 umbrel umbreld[697]: [appstore ] Initialising app store
Mar 26 19:47:25 umbrel umbreld[697]: [appstore ] Initialising repositories…
Mar 26 19:47:25 umbrel umbreld[697]: [apprepository] Checking for update for https://github.com/getumbrel/umbrel-apps.g>Mar 26 19:47:25 umbrel umbreld[697]: [server ] Listening on port 80
Mar 26 19:47:25 umbrel umbreld[697]: [apps ] Copying bins to /home/umbrel/umbrel/bin
Mar 26 19:47:25 umbrel umbreld[697]: [apps ] Copying bitcoin-cli
Mar 26 19:47:25 umbrel umbreld[697]: [apps ] Copying lncli
Mar 26 19:47:25 umbrel umbreld[697]: [apps ] Pre-loading local Docker image auth
Mar 26 19:47:25 umbrel umbreld[697]: [apps ] Pre-loading local Docker image tor
Mar 26 19:47:36 umbrel umbreld[697]: [apprepository] Newer version of GitHub - getumbrel/umbrel-apps: The official app repository of the Umbrel App Store. Submit apps and updates here. Learn how → https://github.com/getumbrel/umbrel-apps#readme avai>Mar 26 19:47:39 umbrel umbreld[781]: Loaded image ID: sha256:105438dd043f4ec97aac88826fb53eef1769daa38bfe21fe929cf63bc2>Mar 26 19:47:42 umbrel umbreld[780]: Loaded image ID: sha256:f83765bcb6ce3c0da9f9f2738b19d3e7defc000acd977344219fb6d634>lines 1-49…skipping…
Mar 26 19:47:14 umbrel mender[717]: time=“2024-03-26T19:47:14Z” level=info msg=“‘UpdateControlMapExpirationTimeSeconds’ is not set in the Mender configuration file. Falling back to the defaul>
Mar 26 19:47:14 umbrel mender[717]: time=“2024-03-26T19:47:14Z” level=info msg=”‘UpdateControlMapBootExpirationTimeSeconds’ is not set in the Mender configuration file. Falling back to the de>
Mar 26 19:47:14 umbrel mender[717]: time=“2024-03-26T19:47:14Z” level=info msg=“No configuration files present. Using defaults”
Mar 26 19:47:14 umbrel mender[717]: time=“2024-03-26T19:47:14Z” level=warning msg=“No server URL(s) specified in mender configuration.”
Mar 26 19:47:14 umbrel mender[717]: time=“2024-03-26T19:47:14Z” level=warning msg=“Server entry 1 has no associated server URL.”
Mar 26 19:47:14 umbrel mender[717]: time=“2024-03-26T19:47:14Z” level=error msg=“Could not commit Artifact: There is nothing to commit”
Mar 26 19:47:14 umbrel umbreld[697]: [umbreld ] [error] Failed to commit OS partition: Command failed with exit code 2: mender commit
Mar 26 19:47:14 umbrel umbreld[697]: time=“2024-03-26T19:47:14Z” level=info msg=“‘UpdateControlMapExpirationTimeSeconds’ is not set in the Mender configuration file. Falling back to the defau>
Mar 26 19:47:14 umbrel umbreld[697]: time=“2024-03-26T19:47:14Z” level=info msg=”‘UpdateControlMapBootExpirationTimeSeconds’ is not set in the Mender configuration file. Falling back to the d>
Mar 26 19:47:14 umbrel umbreld[697]: time=“2024-03-26T19:47:14Z” level=info msg=“No configuration files present. Using defaults”
Mar 26 19:47:14 umbrel umbreld[697]: time=“2024-03-26T19:47:14Z” level=warning msg=“No server URL(s) specified in mender configuration.”
Mar 26 19:47:14 umbrel umbreld[697]: time=“2024-03-26T19:47:14Z” level=warning msg=“Server entry 1 has no associated server URL.”
Mar 26 19:47:14 umbrel umbreld[697]: time=“2024-03-26T19:47:14Z” level=error msg=“Could not commit Artifact: There is nothing to commit”
Mar 26 19:47:25 umbrel umbreld[697]: [apprepository] Checking for update for GitHub - getumbrel/umbrel-apps: The official app repository of the Umbrel App Store. Submit apps and updates here. Learn how → https://github.com/getumbrel/umbrel-apps#readme
Mar 26 19:47:36 umbrel umbreld[697]: [apprepository] Newer version of GitHub - getumbrel/umbrel-apps: The official app repository of the Umbrel App Store. Submit apps and updates here. Learn how → https://github.com/getumbrel/umbrel-apps#readme available, updating
Mar 26 19:47:39 umbrel umbreld[781]: Loaded image ID: sha256:105438dd043f4ec97aac88826fb53eef1769daa38bfe21fe929cf63bc204a7bc
Mar 26 19:47:42 umbrel umbreld[780]: Loaded image ID: sha256:f83765bcb6ce3c0da9f9f2738b19d3e7defc000acd977344219fb6d634b328e7
Mar 26 19:47:43 umbrel umbreld[811]: time=“2024-03-26T19:47:43Z” level=warning msg=“/usr/local/lib/node_modules/umbreld/source/modules/apps/legacy-compat/docker-compose.yml: version is obso>
Mar 26 19:47:43 umbrel umbreld[811]: Network umbrel_main_network Creating
Mar 26 19:47:43 umbrel umbreld[811]: Network umbrel_main_network Created
lines 1-52
Mar 26 19:47:14 umbrel mender[717]: time=“2024-03-26T19:47:14Z” level=info msg=”‘UpdateControlMapExpirationTimeSeconds’ is not set in the Mender configuration file. Falling back to the defaul>
Mar 26 19:47:14 umbrel mender[717]: time=“2024-03-26T19:47:14Z” level=info msg=“‘UpdateControlMapBootExpirationTimeSeconds’ is not set in the Mender configuration file. Falling back to the de>
Mar 26 19:47:14 umbrel umbreld[697]: time=“2024-03-26T19:47:14Z” level=info msg=”‘UpdateControlMapExpirationTimeSeconds’ is not set in the Mender configuration file. Falling back to the defau>
Mar 26 19:47:14 umbrel umbreld[697]: time=“2024-03-26T19:47:14Z” level=info msg=“‘UpdateControlMapBootExpirationTimeSeconds’ is not set in the Mender configuration file. Falling back to the d>
Mar 26 19:47:43 umbrel umbreld[811]: time=“2024-03-26T19:47:43Z” level=warning msg=”/usr/local/lib/node_modules/umbreld/source/modules/apps/legacy-compat/docker-compose.yml: version is obso>
Mar 26 19:47:43 umbrel umbreld[811]: Container tor_proxy Creating
Mar 26 19:47:43 umbrel umbreld[811]: Container auth Creating
Mar 26 19:47:44 umbrel umbreld[811]: Container tor_proxy Created
Mar 26 19:47:44 umbrel umbreld[811]: Container auth Created
Mar 26 19:47:44 umbrel umbreld[811]: Container auth Starting
Mar 26 19:47:44 umbrel umbreld[811]: Container tor_proxy Starting
Mar 26 19:47:46 umbrel umbreld[811]: Container tor_proxy Started
Mar 26 19:47:46 umbrel umbreld[811]: Container auth Started
Mar 26 19:47:46 umbrel umbreld[1057]: time=“2024-03-26T19:47:46Z” level=warning msg=“/usr/local/lib/node_modules/umbreld/source/modules/apps/legacy-compat/docker-compose.yml: version is obs>
Mar 26 19:47:46 umbrel umbreld[1057]: Container tor_proxy Running
Mar 26 19:47:46 umbrel umbreld[1057]: Container auth Running
Mar 26 19:47:46 umbrel sudo[1066]: root : PWD=/ ; USER=root ; COMMAND=/usr/bin/chown -R 1000:1000 /home/umbrel/umbrel/tor
Mar 26 19:47:46 umbrel sudo[1066]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=0)
Mar 26 19:47:47 umbrel sudo[1066]: pam_unix(sudo:session): session closed for user root
Mar 26 19:47:47 umbrel umbreld[697]: [apps ] Starting apps
Mar 26 19:47:47 umbrel umbreld[697]: [app ] Starting app bitcoin
Mar 26 19:47:47 umbrel umbreld[697]: [app ] Starting app electrs
Mar 26 19:47:47 umbrel umbreld[697]: [app ] Starting app lightning
Mar 26 19:47:48 umbrel umbreld[1079]: Starting app bitcoin…
Mar 26 19:47:48 umbrel umbreld[1078]: Starting app lightning…
Mar 26 19:47:48 umbrel umbreld[1081]: Starting app electrs…
Mar 26 19:47:50 umbrel umbreld[1079]: Executing hook: /home/umbrel/umbrel/app-data/bitcoin/hooks/pre-start
Mar 26 19:47:50 umbrel umbreld[1078]: Executing hook: /home/umbrel/umbrel/app-data/lightning/hooks/pre-start
Mar 26 19:47:50 umbrel umbreld[1081]: Executing hook: /home/umbrel/umbrel/app-data/electrs/hooks/pre-start
Mar 26 19:47:51 umbrel umbreld[1496]: time=“2024-03-26T19:47:51Z” level=warning msg=”/usr/local/lib/node_modules/umbreld/source/modules/apps/legacy-compat/docker-compose.app_proxy.yml: versi> Mar 26 19:47:51 umbrel umbreld[1496]: time="2024-03-26T19:47:51Z" level=warning msg="/usr/local/lib/node_modules/umbreld/source/modules/apps/legacy-compat/docker-compose.common.yml: version> Mar 26 19:47:51 umbrel umbreld[1496]: time="2024-03-26T19:47:51Z" level=warning msg="/home/umbrel/umbrel/app-data/electrs/docker-compose.yml: versionis obsolete" Mar 26 19:47:51 umbrel umbreld[1496]: time="2024-03-26T19:47:51Z" level=warning msg="networks.default: external.name is deprecated. Please set name and external: true" Mar 26 19:47:51 umbrel umbreld[1511]: time="2024-03-26T19:47:51Z" level=warning msg="/usr/local/lib/node_modules/umbreld/source/modules/apps/legacy-compat/docker-compose.app_proxy.yml:versi>
Mar 26 19:47:51 umbrel umbreld[1511]: time=“2024-03-26T19:47:51Z” level=warning msg=“/usr/local/lib/node_modules/umbreld/source/modules/apps/legacy-compat/docker-compose.common.yml: version>
Mar 26 19:47:51 umbrel umbreld[1511]: time=“2024-03-26T19:47:51Z” level=warning msg=”/home/umbrel/umbrel/app-data/bitcoin/docker-compose.yml: version is obsolete"
Mar 26 19:47:51 umbrel umbreld[1511]: time=“2024-03-26T19:47:51Z” level=warning msg=“networks.default: external.name is deprecated. Please set name and external: true”
Mar 26 19:47:52 umbrel umbreld[1530]: time=“2024-03-26T19:47:51Z” level=warning msg=“/usr/local/lib/node_modules/umbreld/source/modules/apps/legacy-compat/docker-compose.app_proxy.yml: versi> Mar 26 19:47:52 umbrel umbreld[1496]: Container electrs_electrs_1 Creating Mar 26 19:47:52 umbrel umbreld[1496]: Container electrs_tor_1 Creating Mar 26 19:47:52 umbrel umbreld[1496]: Container electrs_app_proxy_1 Creating Mar 26 19:47:52 umbrel umbreld[1530]: time="2024-03-26T19:47:52Z" level=warning msg="/usr/local/lib/node_modules/umbreld/source/modules/apps/legacy-compat/docker-compose.common.yml: version> Mar 26 19:47:52 umbrel umbreld[1530]: time="2024-03-26T19:47:52Z" level=warning msg="The \"APP_MEMPOOL_HIDDEN_SERVICE\" variable is not set. Defaulting to a blank string." Mar 26 19:47:52 umbrel umbreld[1530]: time="2024-03-26T19:47:52Z" level=warning msg="The \"APP_MEMPOOL_PORT\" variable is not set. Defaulting to a blank string." Mar 26 19:47:52 umbrel umbreld[1511]: Container bitcoin_bitcoind_1 Creating Mar 26 19:47:52 umbrel umbreld[1511]: Container bitcoin_i2pd_daemon_1 Creating Mar 26 19:47:52 umbrel umbreld[1511]: Container bitcoin_app_proxy_1 Creating Mar 26 19:47:52 umbrel umbreld[1511]: Container bitcoin_tor_1 Creating Mar 26 19:47:52 umbrel umbreld[1530]: time="2024-03-26T19:47:52Z" level=warning msg="/home/umbrel/umbrel/app-data/lightning/docker-compose.yml: version` is obsolete”
Mar 26 19:47:52 umbrel umbreld[1530]: time=“2024-03-26T19:47:52Z” level=warning msg=“networks.default: external.name is deprecated. Please set name and external: true”
Mar 26 19:47:52 umbrel umbreld[1530]: Container lightning_lnd_1 Creating
Mar 26 19:47:52 umbrel umbreld[1530]: Container lightning_app_proxy_1 Creating
Mar 26 19:47:52 umbrel umbreld[1530]: Container lightning_app_1 Creating
Mar 26 19:47:52 umbrel umbreld[1530]: Container lightning_tor_1 Creating
Mar 26 19:47:53 umbrel umbreld[1530]: Container lightning_app_proxy_1 Created
Mar 26 19:47:53 umbrel umbreld[1530]: Container lightning_tor_1 Created
Mar 26 19:47:53 umbrel umbreld[1511]: Container bitcoin_app_proxy_1 Created
Mar 26 19:47:53 umbrel umbreld[1511]: Container bitcoin_i2pd_daemon_1 Created
Mar 26 19:47:53 umbrel umbreld[1511]: Container bitcoin_tor_1 Created
Mar 26 19:47:53 umbrel umbreld[1530]: Container lightning_app_1 Created
Mar 26 19:47:53 umbrel umbreld[1496]: Container electrs_electrs_1 Created
Mar 26 19:47:53 umbrel umbreld[1496]: Container electrs_app_1 Creating
Mar 26 19:47:53 umbrel umbreld[1511]: Container bitcoin_bitcoind_1 Created
Mar 26 19:47:53 umbrel umbreld[1511]: Container bitcoin_server_1 Creating
Mar 26 19:47:53 umbrel umbreld[1530]: Container lightning_lnd_1 Created
Mar 26 19:47:53 umbrel umbreld[1496]: Container electrs_app_proxy_1 Created
Mar 26 19:47:53 umbrel umbreld[1530]: Container lightning_lnd_1 Starting
Mar 26 19:47:53 umbrel umbreld[1530]: Container lightning_tor_1 Starting
Mar 26 19:47:53 umbrel umbreld[1530]: Container lightning_app_proxy_1 Starting
Mar 26 19:47:53 umbrel umbreld[1530]: Container lightning_app_1 Starting
Mar 26 19:47:53 umbrel umbreld[1496]: Container electrs_tor_1 Created
Mar 26 19:47:53 umbrel umbreld[1496]: Container electrs_app_1 Created
Mar 26 19:47:53 umbrel umbreld[1511]: Container bitcoin_server_1 Created
Mar 26 19:47:53 umbrel umbreld[1496]: Container electrs_electrs_1 Starting
Mar 26 19:47:53 umbrel umbreld[1496]: Container electrs_app_proxy_1 Starting
Mar 26 19:47:53 umbrel umbreld[1496]: Container electrs_tor_1 Starting
Mar 26 19:47:53 umbrel umbreld[1511]: Container bitcoin_tor_1 Starting
Mar 26 19:47:53 umbrel umbreld[1511]: Container bitcoin_i2pd_daemon_1 Starting
Mar 26 19:47:53 umbrel umbreld[1511]: Container bitcoin_app_proxy_1 Starting
Mar 26 19:47:53 umbrel umbreld[1511]: Container bitcoin_bitcoind_1 Starting
Mar 26 19:47:55 umbrel umbreld[1530]: Container lightning_app_1 Started
Mar 26 19:47:55 umbrel umbreld[1530]: Container lightning_lnd_1 Started
Mar 26 19:47:56 umbrel umbreld[1530]: Container lightning_tor_1 Started
Mar 26 19:47:56 umbrel umbreld[1530]: Container lightning_app_proxy_1 Started
Mar 26 19:47:56 umbrel umbreld[1496]: Container electrs_tor_1 Started
Mar 26 19:47:56 umbrel umbreld[1496]: Container electrs_electrs_1 Started
Mar 26 19:47:56 umbrel umbreld[1496]: Container electrs_app_1 Starting
Mar 26 19:47:56 umbrel umbreld[1496]: Container electrs_app_proxy_1 Started
Mar 26 19:47:57 umbrel umbreld[1511]: Container bitcoin_tor_1 Started
Mar 26 19:47:57 umbrel umbreld[1511]: Container bitcoin_app_proxy_1 Started
Mar 26 19:47:57 umbrel umbreld[697]: [apprepository] Updated GitHub - getumbrel/umbrel-apps: The official app repository of the Umbrel App Store. Submit apps and updates here. Learn how → https://github.com/getumbrel/umbrel-apps#readme!
Mar 26 19:47:57 umbrel umbreld[1511]: Container bitcoin_i2pd_daemon_1 Started
Mar 26 19:47:58 umbrel umbreld[1511]: Container bitcoin_bitcoind_1 Started
Mar 26 19:47:58 umbrel umbreld[1511]: Container bitcoin_server_1 Starting
Mar 26 19:47:59 umbrel umbreld[1496]: Container electrs_app_1 Started
Mar 26 19:48:00 umbrel umbreld[1511]: Container bitcoin_server_1 Started
Mar 26 19:48:09 umbrel umbreld[697]: [apprepository] Checking for update for GitHub - getumbrel/umbrel-apps: The official app repository of the Umbrel App Store. Submit apps and updates here. Learn how → https://github.com/getumbrel/umbrel-apps#readme
Mar 26 19:48:20 umbrel umbreld[697]: [apprepository] GitHub - getumbrel/umbrel-apps: The official app repository of the Umbrel App Store. Submit apps and updates here. Learn how → https://github.com/getumbrel/umbrel-apps#readme is already up to date
Mar 26 19:48:31 umbrel umbreld[697]: [appstore ] Repositories initialised!
Mar 26 19:48:31 umbrel umbreld[697]: [appstore ] Checking repositories for updates every 5m
Mar 26 19:53:31 umbrel umbreld[697]: [apprepository] Checking for update for GitHub - getumbrel/umbrel-apps: The official app repository of the Umbrel App Store. Submit apps and updates here. Learn how → https://github.com/getumbrel/umbrel-apps#readme
Mar 26 19:53:48 umbrel umbreld[697]: [apprepository] GitHub - getumbrel/umbrel-apps: The official app repository of the Umbrel App Store. Submit apps and updates here. Learn how → https://github.com/getumbrel/umbrel-apps#readme is already up to date
Mar 26 19:58:31 umbrel umbreld[697]: [apprepository] Checking for update for GitHub - getumbrel/umbrel-apps: The official app repository of the Umbrel App Store. Submit apps and updates here. Learn how → https://github.com/getumbrel/umbrel-apps#readme
Mar 26 19:58:32 umbrel umbreld[697]: [apprepository] GitHub - getumbrel/umbrel-apps: The official app repository of the Umbrel App Store. Submit apps and updates here. Learn how → https://github.com/getumbrel/umbrel-apps#readme is already up to date
Mar 26 20:03:31 umbrel umbreld[697]: [apprepository] Checking for update for GitHub - getumbrel/umbrel-apps: The official app repository of the Umbrel App Store. Submit apps and updates here. Learn how → https://github.com/getumbrel/umbrel-apps#readme
Mar 26 20:03:32 umbrel umbreld[697]: [apprepository] GitHub - getumbrel/umbrel-apps: The official app repository of the Umbrel App Store. Submit apps and updates here. Learn how → https://github.com/getumbrel/umbrel-apps#readme is already up to date
Mar 26 20:08:31 umbrel umbreld[697]: [apprepository] Checking for update for GitHub - getumbrel/umbrel-apps: The official app repository of the Umbrel App Store. Submit apps and updates here. Learn how → https://github.com/getumbrel/umbrel-apps#readme
Mar 26 20:08:32 umbrel umbreld[697]: [apprepository] GitHub - getumbrel/umbrel-apps: The official app repository of the Umbrel App Store. Submit apps and updates here. Learn how → https://github.com/getumbrel/umbrel-apps#readme is already up to date
Mar 26 20:13:31 umbrel umbreld[697]: [apprepository] Checking for update for GitHub - getumbrel/umbrel-apps: The official app repository of the Umbrel App Store. Submit apps and updates here. Learn how → https://github.com/getumbrel/umbrel-apps#readme
Mar 26 20:13:32 umbrel umbreld[697]: [apprepository] GitHub - getumbrel/umbrel-apps: The official app repository of the Umbrel App Store. Submit apps and updates here. Learn how → https://github.com/getumbrel/umbrel-apps#readme is already up to date
Mar 26 20:18:31 umbrel umbreld[697]: [apprepository] Checking for update for GitHub - getumbrel/umbrel-apps: The official app repository of the Umbrel App Store. Submit apps and updates here. Learn how → https://github.com/getumbrel/umbrel-apps#readme
Mar 26 20:18:32 umbrel umbreld[697]: [apprepository] GitHub - getumbrel/umbrel-apps: The official app repository of the Umbrel App Store. Submit apps and updates here. Learn how → https://github.com/getumbrel/umbrel-apps#readme is already up to date
Mar 26 20:23:31 umbrel umbreld[697]: [apprepository] Checking for update for GitHub - getumbrel/umbrel-apps: The official app repository of the Umbrel App Store. Submit apps and updates here. Learn how → https://github.com/getumbrel/umbrel-apps#readme
Mar 26 20:23:32 umbrel umbreld[697]: [apprepository] GitHub - getumbrel/umbrel-apps: The official app repository of the Umbrel App Store. Submit apps and updates here. Learn how → https://github.com/getumbrel/umbrel-apps#readme is already up to date
Mar 26 20:28:31 umbrel umbreld[697]: [apprepository] Checking for update for GitHub - getumbrel/umbrel-apps: The official app repository of the Umbrel App Store. Submit apps and updates here. Learn how → https://github.com/getumbrel/umbrel-apps#readme
Mar 26 20:28:32 umbrel umbreld[697]: [apprepository] GitHub - getumbrel/umbrel-apps: The official app repository of the Umbrel App Store. Submit apps and updates here. Learn how → https://github.com/getumbrel/umbrel-apps#readme is already up to date
Mar 26 20:33:31 umbrel umbreld[697]: [apprepository] Checking for update for GitHub - getumbrel/umbrel-apps: The official app repository of the Umbrel App Store. Submit apps and updates here. Learn how → https://github.com/getumbrel/umbrel-apps#readme
Mar 26 20:33:32 umbrel umbreld[697]: [apprepository] GitHub - getumbrel/umbrel-apps: The official app repository of the Umbrel App Store. Submit apps and updates here. Learn how → https://github.com/getumbrel/umbrel-apps#readme is already up to date
@gschaco what is the problem you’re having? everything looks ok from your logs.
Excellent. So the errors don’t mean anything? My problem is that the Bitcoin app does not sync. It did not work to update SD, migrate to 1.0, 1.03 and 1.04, restart or reboot.
Bitcoin Logs
bitcoin_app_proxy_1 | yarn run v1.22.19
bitcoin_app_proxy_1 | $ node ./bin/www
bitcoin_tor_1 | Mar 26 20:55:22.594 [notice] Tor 0.4.7.8 running on Linux with Libevent 2.1.12-stable, OpenSSL 1.1.1n, Zlib 1.2.11, Liblzma N/A, Libzstd N/A and Glibc 2.31 as libc.
bitcoin_tor_1 | Mar 26 20:55:22.594 [notice] Tor can’t help you if you use it wrong! Learn how to be safe at Am I totally anonymous if I use Tor? | Tor Project | Support
bitcoin_tor_1 | Mar 26 20:55:22.595 [notice] Read configuration file “/etc/tor/torrc”.
bitcoin_tor_1 | Mar 26 20:55:22.598 [warn] You have a ControlPort set to accept connections from a non-local address. This means that programs not running on your computer can reconfigure your Tor. That’s pretty bad, since the controller protocol isn’t encrypted! Maybe you should just listen on 127.0.0.1 and use a tool like stunnel or ssh to encrypt remote connections to your control port.
bitcoin_tor_1 | Mar 26 20:55:22.598 [warn] CookieAuthFileGroupReadable is set, but will have no effect: you must specify an explicit CookieAuthFile to have it group-readable.
bitcoin_tor_1 | Mar 26 20:55:22.607 [warn] You specified a public address ‘0.0.0.0:9050’ for SocksPort. Other people on the Internet might find your computer and use it as an open proxy. Please don’t allow this unless you have a good reason.
bitcoin_tor_1 | Mar 26 20:55:22.607 [warn] You have a ControlPort set to accept connections from a non-local address. This means that programs not running on your computer can reconfigure your Tor. That’s pretty bad, since the controller protocol isn’t encrypted! Maybe you should just listen on 127.0.0.1 and use a tool like stunnel or ssh to encrypt remote connections to your control port.
bitcoin_tor_1 | Mar 26 20:55:22.607 [notice] Opening Socks listener on 0.0.0.0:9050
bitcoin_tor_1 | Mar 26 20:55:22.607 [notice] Opened Socks listener connection (ready) on 0.0.0.0:9050
bitcoin_tor_1 | Mar 26 20:55:22.607 [notice] Opening Control listener on 0.0.0.0:9051
bitcoin_server_1 |
bitcoin_server_1 | umbrel-middleware
bitcoin_tor_1 | Mar 26 20:55:22.607 [notice] Opened Control listener connection (ready) on 0.0.0.0:9051
bitcoin_tor_1 | Mar 26 20:55:22.000 [notice] Bootstrapped 0% (starting): Starting
bitcoin_server_1 | ::ffff:10.21.0.6 - - [Tue, 26 Mar 2024 20:59:10 GMT] “GET /v1/bitcoind/info/status HTTP/1.1” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/123.0.0.0 Safari/537.36”
bitcoin_tor_1 | Mar 26 20:55:22.000 [notice] Starting with guard context “default”
bitcoin_server_1 |
bitcoin_i2pd_daemon_1 | 20:55:22@704/none - i2pd v2.44.0 (0.9.56) starting…
bitcoin_server_1 | ::ffff:10.21.0.6 - - [Tue, 26 Mar 2024 20:59:12 GMT] “GET /v1/bitcoind/info/status HTTP/1.1” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/123.0.0.0 Safari/537.36”
bitcoin_i2pd_daemon_1 | 20:55:31@686/error - Tunnels: Can’t select next hop for 69E3jx2Vspv88k82YFW8jPC-cc~0EZsHyEC5BD3gaZg=
bitcoin_i2pd_daemon_1 | 20:55:31@686/error - Tunnels: Can’t create inbound tunnel, no peers available
bitcoin_server_1
bitcoin_app_proxy_1 | Bitcoin Node is now ready…
bitcoin_app_proxy_1 | Listening on port: 2100
bitcoin_i2pd_daemon_1 | 20:56:46@686/error - Tunnels: Can’t create inbound tunnel, no peers available
bitcoin_i2pd_daemon_1 | 20:56:58@888/error - Garlic: Can’t handle ECIES-X25519-AEAD-Ratchet message
bitcoin_i2pd_daemon_1 | 20:57:03@888/error - Garlic: Can’t handle ECIES-X25519-AEAD-Ratchet message
bitcoin_i2pd_daemon_1 | 20:57:47@686/error - Tunnels: Can’t select next hop for v5Gve2Zx24eNCsac~oZEeMsYqHeqIOK6FvkMGb7svB4=
bitcoin_i2pd_daemon_1 | 20:57:47@686/error - Tunnels: Can’t create inbound tunnel, no peers available
bitcoin_i2pd_daemon_1 | 20:58:01@686/error - Tunnels: Can’t select next hop for bikOGxvvcb6TfAKnjzjUY8Sjm5uhSqzQrY8QviPURyk=
bitcoin_i2pd_daemon_1 | 20:58:01@686/error - Tunnels: Can’t create inbound tunnel, no peers available
bitcoin_i2pd_daemon_1 | 20:58:18@360/error - Garlic: Can’t handle ECIES-X25519-AEAD-Ratchet message
bitcoin_i2pd_daemon_1 | 20:58:26@888/error - Garlic: Can’t handle ECIES-X25519-AEAD-Ratchet message
bitcoin_i2pd_daemon_1 | 20:58:27@888/error - Garlic: Can’t handle ECIES-X25519-AEAD-Ratchet message
bitcoin_i2pd_daemon_1 | 20:58:33@360/error - Garlic: Can’t handle ECIES-X25519-AEAD-Ratchet message
bitcoin_i2pd_daemon_1 | 21:02:50@360/error - ElGamal decrypt hash doesn’t match
bitcoin_i2pd_daemon_1 | 21:02:50@360/error - Garlic: Can’t handle ECIES-X25519-AEAD-Ratchet message
bitcoin_i2pd_daemon_1 | 21:03:27@888/error - Garlic: Can’t handle ECIES-X25519-AEAD-Ratchet message
bitcoin_i2pd_daemon_1 | 21:03:28@888/error - Garlic: Can’t handle ECIES-X25519-AEAD-Ratchet message
bitcoin_i2pd_daemon_1 | 21:03:29@888/error - Garlic: Can’t handle ECIES-X25519-AEAD-Ratchet message
bitcoin_i2pd_daemon_1 | 21:03:34@360/error - Garlic: Can’t handle ECIES-X25519-AEAD-Ratchet message
bitcoin_i2pd_daemon_1 | 21:04:17@360/error - Garlic: Can’t handle ECIES-X25519-AEAD-Ratchet message
bitcoin_i2pd_daemon_1 | 21:05:15@686/error - Tunnel: Tunnel with id 2617377563 already exists
bitcoin_i2pd_daemon_1 | 21:05:27@888/error - Garlic: Can’t handle ECIES-X25519-AEAD-Ratchet message
bitcoin_i2pd_daemon_1 | 21:05:27@360/error - Garlic: Can’t handle ECIES-X25519-AEAD-Ratchet message
bitcoin_server_1 | ::ffff:10.21.0.6 - - [Tue, 26 Mar 2024 20:59:52 GMT] “GET /v1/bitcoind/info/status HTTP/1.1” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/123.0.0.0 Safari/537.36”
bitcoin_server_1 |
bitcoin_i2pd_daemon_1 | 21:05:46@686/error - Tunnels: Can’t select next hop for 27wfI1wBkp-5jDSPmtCiOuIBacgMxFbW0QxYpK1GpII=
bitcoin_i2pd_daemon_1 | 21:05:46@686/error - Tunnels: Can’t create inbound tunnel, no peers available
bitcoin_i2pd_daemon_1 | 21:07:17@888/error - Garlic: Can’t handle ECIES-X25519-AEAD-Ratchet message
bitcoin_i2pd_daemon_1 | 21:07:27@360/error - Garlic: Can’t handle ECIES-X25519-AEAD-Ratchet message
bitcoin_i2pd_daemon_1 | 21:07:42@360/error - Garlic: Can’t handle ECIES-X25519-AEAD-Ratchet message
bitcoin_i2pd_daemon_1 | 21:07:57@360/error - Garlic: Can’t handle ECIES-X25519-AEAD-Ratchet message
bitcoin_server_1 | ::ffff:10.21.0.6 - - [Tue, 26 Mar 2024 21:00:05 GMT] “GET /v1/bitcoind/info/status HTTP/1.1” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/123.0.0.0 Safari/537.36”
bitcoin_server_1 |
bitcoin_server_1 | Unable to obtain peer info
bitcoin_server_1 | /v1/bitcoind/widgets/sync
bitcoin_server_1 | BitcoindError: Unable to obtain peer info
bitcoin_server_1 | at /app/services/bitcoind.js:23:18
bitcoin_server_1 | at IncomingMessage. (/app/node_modules/bitcoind-rpc/lib/index.js:107:7)
bitcoin_server_1 | at IncomingMessage.emit (events.js:326:22)
bitcoin_server_1 | at endReadableNT (_stream_readable.js:1241:12)
bitcoin_server_1 | at /app/node_modules/async-listener/glue.js:188:31
bitcoin_server_1 | at processTicksAndRejections (internal/process/task_queues.js:84:21)
bitcoin_server_1 | ::ffff:10.21.0.1 - - [Tue, 26 Mar 2024 21:02:27 GMT] “GET /v1/bitcoind/widgets/sync HTTP/1.1” 500 28 “-” “node-fetch”
bitcoin_server_1 |
bitcoin_server_1 | Unable to obtain blockchain info
bitcoin_server_1 | /v1/bitcoind/widgets/stats
bitcoin_server_1 | BitcoindError: Unable to obtain blockchain info
bitcoin_server_1 | ::ffff:10.21.0.1 - - [Tue, 26 Mar 2024 21:02:27 GMT] “GET /v1/bitcoind/widgets/stats HTTP/1.1” 500 34 “-” “node-fetch”
bitcoin_server_1 |
bitcoin_bitcoind_1 | 2024-03-26T21:07:52Z Checking all blk files are present…
bitcoin_bitcoind_1 | 2024-03-26T21:07:56Z Initializing chainstate Chainstate [ibd] @ height -1 (null)
bitcoin_bitcoind_1 | 2024-03-26T21:07:56Z Opening LevelDB in /data/.bitcoin/chainstate
bitcoin_bitcoind_1 | 2024-03-26T21:07:56Z Opened LevelDB successfully
bitcoin_bitcoind_1 | 2024-03-26T21:07:56Z Using obfuscation key for /data/.bitcoin/chainstate: c9c3e70fc1cbef91
bitcoin_bitcoind_1 | 2024-03-26T21:07:56Z Loaded best chain: hashBestChain=0000000000000000000242dfdc0095ffb41ba6c7c568022f1674da82b0b3bced height=820217 date=2023-12-08T05:52:37Z progress=0.946858
bitcoin_bitcoind_1 | 2024-03-26T21:07:57Z Opening LevelDB in /data/.bitcoin/chainstate
bitcoin_bitcoind_1 | 2024-03-26T21:07:57Z Opened LevelDB successfully
bitcoin_bitcoind_1 | 2024-03-26T21:07:57Z Using obfuscation key for /data/.bitcoin/chainstate: c9c3e70fc1cbef91
bitcoin_bitcoind_1 | 2024-03-26T21:07:57Z [Chainstate [ibd] @ height 820217 (0000000000000000000242dfdc0095ffb41ba6c7c568022f1674da82b0b3bced)] resized coinsdb cache to 8.0 MiB
bitcoin_bitcoind_1 | 2024-03-26T21:07:57Z [Chainstate [ibd] @ height 820217 (0000000000000000000242dfdc0095ffb41ba6c7c568022f1674da82b0b3bced)] resized coinstip cache to 318.9 MiB
bitcoin_bitcoind_1 | 2024-03-26T21:07:57Z init message: Verifying blocks…
bitcoin_bitcoind_1 | 2024-03-26T21:07:57Z Verifying last 6 blocks at level 3
bitcoin_bitcoind_1 | 2024-03-26T21:07:57Z Verification progress: 0%
bitcoin_bitcoind_1 | 2024-03-26T21:07:59Z Verification progress: 16%
bitcoin_bitcoind_1 | 2024-03-26T21:08:01Z Verification progress: 33%
bitcoin_bitcoind_1 | 2024-03-26T21:08:03Z Verification progress: 50%
bitcoin_bitcoind_1 | 2024-03-26T21:08:05Z Verification progress: 66%
bitcoin_bitcoind_1 | 2024-03-26T21:08:09Z Verification progress: 83%
bitcoin_bitcoind_1 | 2024-03-26T21:08:11Z Verification progress: 99%
bitcoin_bitcoind_1 | 2024-03-26T21:08:11Z Verification: No coin database inconsistencies in last 6 blocks (17142 transactions)
bitcoin_bitcoind_1 | 2024-03-26T21:08:11Z block index 31755ms
bitcoin_bitcoind_1 | 2024-03-26T21:08:11Z Opening LevelDB in /data/.bitcoin/indexes/txindex
bitcoin_bitcoind_1 | 2024-03-26T21:08:13Z Opened LevelDB successfully
bitcoin_bitcoind_1 | 2024-03-26T21:08:13Z Using obfuscation key for /data/.bitcoin/indexes/txindex: 0000000000000000
bitcoin_bitcoind_1 | 2024-03-26T21:08:13Z Opening LevelDB in /data/.bitcoin/indexes/blockfilter/basic/db
Hi lukechilds. Thx for your help. I´m still waiting a solution. Thinking on uninstall LN and install again with my 24 words.
I went from 0.5 to 1.0.4 Killed all my apps.
Trying the above now.
c.
I am having the same issue as @gschaco … I migrate from 0.54 to 1.1.2. It worked for 2 days and now the blockchain does NOT sync.
In the bitcoind logs we see there is some problem with RPC connections with peers:
bitcoin_server_1 | /v1/bitcoind/info/sync
@lukechilds Can you help please?
