Update Umbrel 1.0
I updated my Umbrel as instructed in the website but now all my apps says not running and can’t figure out why?
Also when I go to the App Store to download the apps again … this is what I see
This is part of the troubleshooting debug report
Jan 26 22:20:14 umbrel umbreld[709]: [server ] GET /trpc/user.get
Jan 26 22:20:14 umbrel umbreld[709]: [server ] GET /trpc/apps.state
Jan 26 22:20:14 umbrel umbreld[709]: [server ] GET /trpc/apps.list
Jan 26 22:20:14 umbrel umbreld[709]: [server ] GET /trpc/system.logs
Jan 26 22:20:18 umbrel umbreld[709]: [server ] GET /trpc/system.cpuTemperature
Jan 26 22:20:21 umbrel umbreld[709]: [server ] GET /trpc/widget.data
Jan 26 22:20:21 umbrel umbreld[709]: [app ] [error] Failed to get memory usage for app bitcoin: Command failed with exit code 1: docker stats --no-stream --format {“container”:“{{.Name}}”,“CPUPerc”:“{{.CPUPerc}}”,“MemPerc”:“{{.MemPerc}}”} bitcoin_app_proxy_1 bitcoin_server_1 bitcoin_bitcoind_1 bitcoin_tor_1 bitcoin_i2pd_daemon_1
Jan 26 22:20:21 umbrel umbreld[709]: Error response from daemon: No such container: bitcoin_app_proxy_1
Jan 26 22:20:21 umbrel umbreld[709]: Error response from daemon: No such container: bitcoin_server_1
Jan 26 22:20:21 umbrel umbreld[709]: Error response from daemon: No such container: bitcoin_bitcoind_1
Jan 26 22:20:21 umbrel umbreld[709]: Error response from daemon: No such container: bitcoin_tor_1
Jan 26 22:20:21 umbrel umbreld[709]: Error response from daemon: No such container: bitcoin_i2pd_daemon_1
Jan 26 22:20:21 umbrel umbreld[709]: [app ] [error] Failed to get memory usage for app lightning: Command failed with exit code 1: docker stats --no-stream --format {“container”:“{{.Name}}”,“CPUPerc”:“{{.CPUPerc}}”,“MemPerc”:“{{.MemPerc}}”} lightning_app_proxy_1 lightning_app_1 lightning_lnd_1 lightning_tor_1
Jan 26 22:20:21 umbrel umbreld[709]: Error response from daemon: No such container: lightning_app_proxy_1
Jan 26 22:20:21 umbrel umbreld[709]: Error response from daemon: No such container: lightning_app_1
Jan 26 22:20:21 umbrel umbreld[709]: Error response from daemon: No such container: lightning_lnd_1
Jan 26 22:20:21 umbrel umbreld[709]: Error response from daemon: No such container: lightning_tor_1
Jan 26 22:20:21 umbrel umbreld[709]: [app ] [error] Failed to get memory usage for app nostr-relay: Command failed with exit code 1: docker stats --no-stream --format {“container”:“{{.Name}}”,“CPUPerc”:“{{.CPUPerc}}”,“MemPerc”:“{{.MemPerc}}”} nostr-relay_app_proxy_1 nostr-relay_web_1 nostr-relay_relay_1 nostr-relay_relay-proxy_1
Jan 26 22:20:21 umbrel umbreld[709]: Error response from daemon: No such container: nostr-relay_app_proxy_1
Jan 26 22:20:21 umbrel umbreld[709]: Error response from daemon: No such container: nostr-relay_web_1
Jan 26 22:20:21 umbrel umbreld[709]: Error response from daemon: No such container: nostr-relay_relay_1
Jan 26 22:20:21 umbrel umbreld[709]: Error response from daemon: No such container: nostr-relay_relay-proxy_1
Jan 26 22:20:21 umbrel umbreld[709]: [app ] [error] Failed to get memory usage for app ride-the-lightning: Command failed with exit code 1: docker stats --no-stream --format {“container”:“{{.Name}}”,“CPUPerc”:“{{.CPUPerc}}”,“MemPerc”:“{{.MemPerc}}”} ride-the-lightning_app_proxy_1 ride-the-lightning_web_1 ride-the-lightning_boltz_1
Jan 26 22:20:21 umbrel umbreld[709]: Error response from daemon: No such container: ride-the-lightning_app_proxy_1
Jan 26 22:20:21 umbrel umbreld[709]: Error response from daemon: No such container: ride-the-lightning_web_1
Jan 26 22:20:21 umbrel umbreld[709]: Error response from daemon: No such container: ride-the-lightning_boltz_1
Jan 26 22:20:21 umbrel umbreld[709]: [app ] [error] Failed to get memory usage for app robosats: Command failed with exit code 1: docker stats --no-stream --format {“container”:“{{.Name}}”,“CPUPerc”:“{{.CPUPerc}}”,“MemPerc”:“{{.MemPerc}}”} robosats_app_proxy_1 robosats_web_1
Jan 26 22:20:21 umbrel umbreld[709]: Error response from daemon: No such container: robosats_app_proxy_1
Jan 26 22:20:21 umbrel umbreld[709]: Error response from daemon: No such container: robosats_web_1
Jan 26 22:20:23 umbrel umbreld[709]: [server ] GET /trpc/system.status
Jan 26 22:20:23 umbrel umbreld[709]: [server ] GET /trpc/system.cpuTemperature
Jan 26 22:20:26 umbrel umbreld[709]: [server ] GET /trpc/widget.data
Jan 26 22:20:26 umbrel umbreld[709]: [app ] [error] Failed to get CPU usage for app bitcoin: Command failed with exit code 1: docker stats --no-stream --format {“container”:“{{.Name}}”,“CPUPerc”:“{{.CPUPerc}}”,“MemPerc”:“{{.MemPerc}}”} bitcoin_app_proxy_1 bitcoin_server_1 bitcoin_bitcoind_1 bitcoin_tor_1 bitcoin_i2pd_daemon_1
Jan 26 22:20:26 umbrel umbreld[709]: Error response from daemon: No such container: bitcoin_app_proxy_1
Jan 26 22:20:26 umbrel umbreld[709]: Error response from daemon: No such container: bitcoin_server_1
Jan 26 22:20:26 umbrel umbreld[709]: Error response from daemon: No such container: bitcoin_bitcoind_1
Jan 26 22:20:26 umbrel umbreld[709]: Error response from daemon: No such container: bitcoin_tor_1
Jan 26 22:20:26 umbrel umbreld[709]: Error response from daemon: No such container: bitcoin_i2pd_daemon_1
Jan 26 22:20:26 umbrel umbreld[709]: [app ] [error] Failed to get CPU usage for app lightning: Command failed with exit code 1: docker stats --no-stream --format {“container”:“{{.Name}}”,“CPUPerc”:“{{.CPUPerc}}”,“MemPerc”:“{{.MemPerc}}”} lightning_app_proxy_1 lightning_app_1 lightning_lnd_1 lightning_tor_1
Jan 26 22:20:26 umbrel umbreld[709]: Error response from daemon: No such container: lightning_app_proxy_1
Jan 26 22:20:26 umbrel umbreld[709]: Error response from daemon: No such container: lightning_app_1
Jan 26 22:20:26 umbrel umbreld[709]: Error response from daemon: No such container: lightning_lnd_1
Jan 26 22:20:26 umbrel umbreld[709]: Error response from daemon: No such container: lightning_tor_1
Jan 26 22:20:26 umbrel umbreld[709]: [app ] [error] Failed to get CPU usage for app nostr-relay: Command failed with exit code 1: docker stats --no-stream --format {“container”:“{{.Name}}”,“CPUPerc”:“{{.CPUPerc}}”,“MemPerc”:“{{.MemPerc}}”} nostr-relay_app_proxy_1 nostr-relay_web_1 nostr-relay_relay_1 nostr-relay_relay-proxy_1
Jan 26 22:20:26 umbrel umbreld[709]: Error response from daemon: No such container: nostr-relay_app_proxy_1
Jan 26 22:20:26 umbrel umbreld[709]: Error response from daemon: No such container: nostr-relay_web_1
Jan 26 22:20:26 umbrel umbreld[709]: Error response from daemon: No such container: nostr-relay_relay_1
Jan 26 22:20:26 umbrel umbreld[709]: Error response from daemon: No such container: nostr-relay_relay-proxy_1
Jan 26 22:20:26 umbrel umbreld[709]: [app ] [error] Failed to get CPU usage for app ride-the-lightning: Command failed with exit code 1: docker stats --no-stream --format {“container”:“{{.Name}}”,“CPUPerc”:“{{.CPUPerc}}”,“MemPerc”:“{{.MemPerc}}”} ride-the-lightning_app_proxy_1 ride-the-lightning_web_1 ride-the-lightning_boltz_1
Jan 26 22:20:26 umbrel umbreld[709]: Error response from daemon: No such container: ride-the-lightning_app_proxy_1
Jan 26 22:20:26 umbrel umbreld[709]: Error response from daemon: No such container: ride-the-lightning_web_1
Jan 26 22:20:26 umbrel umbreld[709]: Error response from daemon: No such container: ride-the-lightning_boltz_1
Jan 26 22:20:26 umbrel umbreld[709]: [app ] [error] Failed to get CPU usage for app robosats: Command failed with exit code 1: docker stats --no-stream --format {“container”:“{{.Name}}”,“CPUPerc”:“{{.CPUPerc}}”,“MemPerc”:“{{.MemPerc}}”} robosats_app_proxy_1 robosats_web_1
Jan 26 22:20:26 umbrel umbreld[709]: Error response from daemon: No such container: robosats_app_proxy_1
Jan 26 22:20:26 umbrel umbreld[709]: Error response from daemon: No such container: robosats_web_1
Jan 26 22:20:26 umbrel umbreld[709]: [app ] [error] Failed to get memory usage for app bitcoin: Command failed with exit code 1: docker stats --no-stream --format {“container”:“{{.Name}}”,“CPUPerc”:“{{.CPUPerc}}”,“MemPerc”:“{{.MemPerc}}”} bitcoin_app_proxy_1 bitcoin_server_1 bitcoin_bitcoind_1 bitcoin_tor_1 bitcoin_i2pd_daemon_1
Jan 26 22:20:26 umbrel umbreld[709]: [app ] [error] Failed to get memory usage for app lightning: Command failed with exit code 1: docker stats --no-stream --format {“container”:“{{.Name}}”,“CPUPerc”:“{{.CPUPerc}}”,“MemPerc”:“{{.MemPerc}}”} lightning_app_proxy_1 lightning_app_1 lightning_lnd_1 lightning_tor_1
Jan 26 22:20:26 umbrel umbreld[709]: [app ] [error] Failed to get memory usage for app nostr-relay: Command failed with exit code 1: docker stats --no-stream --format {“container”:“{{.Name}}”,“CPUPerc”:“{{.CPUPerc}}”,“MemPerc”:“{{.MemPerc}}”} nostr-relay_app_proxy_1 nostr-relay_web_1 nostr-relay_relay_1 nostr-relay_relay-proxy_1
Jan 26 22:20:26 umbrel umbreld[709]: [app ] [error] Failed to get memory usage for app ride-the-lightning: Command failed with exit code 1: docker stats --no-stream --format {“container”:“{{.Name}}”,“CPUPerc”:“{{.CPUPerc}}”,“MemPerc”:“{{.MemPerc}}”} ride-the-lightning_app_proxy_1 ride-the-lightning_web_1 ride-the-lightning_boltz_1
Jan 26 22:20:26 umbrel umbreld[709]: [app ] [error] Failed to get memory usage for app robosats: Command failed with exit code 1: docker stats --no-stream --format {“container”:“{{.Name}}”,“CPUPerc”:“{{.CPUPerc}}”,“MemPerc”:“{{.MemPerc}}”} robosats_app_proxy_1 robosats_web_1
Jan 26 22:20:29 umbrel umbreld[709]: [server ] GET /trpc/system.cpuTemperature
Jan 26 22:20:30 umbrel umbreld[709]: [server ] GET /trpc/widget.data
Jan 26 22:20:31 umbrel umbreld[709]: [server ] GET /trpc/widget.data
Jan 26 22:20:31 umbrel umbreld[709]: [app ] [error] Failed to get memory usage for app bitcoin: Command failed with exit code 1: docker stats --no-stream --format {“container”:“{{.Name}}”,“CPUPerc”:“{{.CPUPerc}}”,“MemPerc”:“{{.MemPerc}}”} bitcoin_app_proxy_1 bitcoin_server_1 bitcoin_bitcoind_1 bitcoin_tor_1 bitcoin_i2pd_daemon_1
Jan 26 22:20:31 umbrel umbreld[709]: Error response from daemon: No such container: bitcoin_app_proxy_1
Jan 26 22:20:31 umbrel umbreld[709]: Error response from daemon: No such container: bitcoin_server_1
Jan 26 22:20:31 umbrel umbreld[709]: Error response from daemon: No such container: bitcoin_bitcoind_1
Jan 26 22:20:31 umbrel umbreld[709]: Error response from daemon: No such container: bitcoin_tor_1
Jan 26 22:20:31 umbrel umbreld[709]: Error response from daemon: No such container: bitcoin_i2pd_daemon_1
Jan 26 22:20:31 umbrel umbreld[709]: [app ] [error] Failed to get memory usage for app lightning: Command failed with exit code 1: docker stats --no-stream --format {“container”:“{{.Name}}”,“CPUPerc”:“{{.CPUPerc}}”,“MemPerc”:“{{.MemPerc}}”} lightning_app_proxy_1 lightning_app_1 lightning_lnd_1 lightning_tor_1
Jan 26 22:20:31 umbrel umbreld[709]: Error response from daemon: No such container: lightning_app_proxy_1
Jan 26 22:20:31 umbrel umbreld[709]: Error response from daemon: No such container: lightning_app_1
Jan 26 22:20:31 umbrel umbreld[709]: Error response from daemon: No such container: lightning_lnd_1
Jan 26 22:20:31 umbrel umbreld[709]: Error response from daemon: No such container: lightning_tor_1
Jan 26 22:20:31 umbrel umbreld[709]: [app ] [error] Failed to get memory usage for app nostr-relay: Command failed with exit code 1: docker stats --no-stream --format {“container”:“{{.Name}}”,“CPUPerc”:“{{.CPUPerc}}”,“MemPerc”:“{{.MemPerc}}”} nostr-relay_app_proxy_1 nostr-relay_web_1 nostr-relay_relay_1 nostr-relay_relay-proxy_1
Jan 26 22:20:31 umbrel umbreld[709]: Error response from daemon: No such container: nostr-relay_app_proxy_1
Jan 26 22:20:31 umbrel umbreld[709]: Error response from daemon: No such container: nostr-relay_web_1
Jan 26 22:20:31 umbrel umbreld[709]: Error response from daemon: No such container: nostr-relay_relay_1
Jan 26 22:20:31 umbrel umbreld[709]: Error response from daemon: No such container: nostr-relay_relay-proxy_1
Jan 26 22:20:31 umbrel umbreld[709]: [app ] [error] Failed to get memory usage for app ride-the-lightning: Command failed with exit code 1: docker stats --no-stream --format {“container”:“{{.Name}}”,“CPUPerc”:“{{.CPUPerc}}”,“MemPerc”:“{{.MemPerc}}”} ride-the-lightning_app_proxy_1 ride-the-lightning_web_1 ride-the-lightning_boltz_1
Jan 26 22:20:31 umbrel umbreld[709]: Error response from daemon: No such container: ride-the-lightning_app_proxy_1
Jan 26 22:20:31 umbrel umbreld[709]: Error response from daemon: No such container: ride-the-lightning_web_1
Jan 26 22:20:31 umbrel umbreld[709]: Error response from daemon: No such container: ride-the-lightning_boltz_1
Jan 26 22:20:31 umbrel umbreld[709]: [app ] [error] Failed to get memory usage for app robosats: Command failed with exit code 1: docker stats --no-stream --format {“container”:“{{.Name}}”,“CPUPerc”:“{{.CPUPerc}}”,“MemPerc”:“{{.MemPerc}}”} robosats_app_proxy_1 robosats_web_1
Jan 26 22:20:31 umbrel umbreld[709]: Error response from daemon: No such container: robosats_app_proxy_1
Jan 26 22:20:31 umbrel umbreld[709]: Error response from daemon: No such container: robosats_web_1
Jan 26 22:20:33 umbrel umbreld[709]: [server ] GET /trpc/system.status
Jan 26 22:20:34 umbrel umbreld[709]: [server ] GET /trpc/system.cpuTemperature
Jan 26 22:20:37 umbrel umbreld[709]: [server ] GET /trpc/system.logs
Jan 26 22:20:39 umbrel umbreld[709]: [server ] GET /trpc/system.cpuTemperature
Jan 26 22:20:41 umbrel umbreld[709]: [server ] GET /trpc/widget.data
Jan 26 22:20:41 umbrel umbreld[709]: [app ] [error] Failed to get memory usage for app bitcoin: Command failed with exit code 1: docker stats --no-stream --format {“container”:“{{.Name}}”,“CPUPerc”:“{{.CPUPerc}}”,“MemPerc”:“{{.MemPerc}}”} bitcoin_app_proxy_1 bitcoin_server_1 bitcoin_bitcoind_1 bitcoin_tor_1 bitcoin_i2pd_daemon_1
Jan 26 22:20:41 umbrel umbreld[709]: Error response from daemon: No such container: bitcoin_app_proxy_1
Jan 26 22:20:41 umbrel umbreld[709]: Error response from daemon: No such container: bitcoin_server_1
Jan 26 22:20:41 umbrel umbreld[709]: Error response from daemon: No such container: bitcoin_bitcoind_1
Jan 26 22:20:41 umbrel umbreld[709]: Error response from daemon: No such container: bitcoin_tor_1
Jan 26 22:20:41 umbrel umbreld[709]: Error response from daemon: No such container: bitcoin_i2pd_daemon_1
Jan 26 22:20:41 umbrel umbreld[709]: [app ] [error] Failed to get memory usage for app lightning: Command failed with exit code 1: docker stats --no-stream --format {“container”:“{{.Name}}”,“CPUPerc”:“{{.CPUPerc}}”,“MemPerc”:“{{.MemPerc}}”} lightning_app_proxy_1 lightning_app_1 lightning_lnd_1 lightning_tor_1
Jan 26 22:20:41 umbrel umbreld[709]: Error response from daemon: No such container: lightning_app_proxy_1
Jan 26 22:20:41 umbrel umbreld[709]: Error response from daemon: No such container: lightning_app_1
Jan 26 22:20:41 umbrel umbreld[709]: Error response from daemon: No such container: lightning_lnd_1
Jan 26 22:20:41 umbrel umbreld[709]: Error response from daemon: No such container: lightning_tor_1
Jan 26 22:20:41 umbrel umbreld[709]: [app ] [error] Failed to get memory usage for app nostr-relay: Command failed with exit code 1: docker stats --no-stream --format {“container”:“{{.Name}}”,“CPUPerc”:“{{.CPUPerc}}”,“MemPerc”:“{{.MemPerc}}”} nostr-relay_app_proxy_1 nostr-relay_web_1 nostr-relay_relay_1 nostr-relay_relay-proxy_1
Jan 26 22:20:41 umbrel umbreld[709]: Error response from daemon: No such container: nostr-relay_app_proxy_1
Jan 26 22:20:41 umbrel umbreld[709]: Error response from daemon: No such container: nostr-relay_web_1
Jan 26 22:20:41 umbrel umbreld[709]: Error response from daemon: No such container: nostr-relay_relay_1
Jan 26 22:20:41 umbrel umbreld[709]: Error response from daemon: No such container: nostr-relay_relay-proxy_1
Jan 26 22:20:41 umbrel umbreld[709]: [app ] [error] Failed to get memory usage for app ride-the-lightning: Command failed with exit code 1: docker stats --no-stream --format {“container”:“{{.Name}}”,“CPUPerc”:“{{.CPUPerc}}”,“MemPerc”:“{{.MemPerc}}”} ride-the-lightning_app_proxy_1 ride-the-lightning_web_1 ride-the-lightning_boltz_1
Jan 26 22:20:41 umbrel umbreld[709]: Error response from daemon: No such container: ride-the-lightning_app_proxy_1
Jan 26 22:20:41 umbrel umbreld[709]: Error response from daemon: No such container: ride-the-lightning_web_1
Jan 26 22:20:41 umbrel umbreld[709]: Error response from daemon: No such container: ride-the-lightning_boltz_1
Jan 26 22:20:41 umbrel umbreld[709]: [app ] [error] Failed to get memory usage for app robosats: Command failed with exit code 1: docker stats --no-stream --format {“container”:“{{.Name}}”,“CPUPerc”:“{{.CPUPerc}}”,“MemPerc”:“{{.MemPerc}}”} robosats_app_proxy_1 robosats_web_1
Jan 26 22:20:41 umbrel umbreld[709]: Error response from daemon: No such container: robosats_app_proxy_1
Jan 26 22:20:41 umbrel umbreld[709]: Error response from daemon: No such container: robosats_web_1
Jan 26 22:20:42 umbrel umbreld[709]: [server ] GET /trpc/apps.state
Jan 26 22:20:42 umbrel umbreld[709]: [server ] GET /trpc/apps.list
Jan 26 22:20:42 umbrel umbreld[709]: [server ] GET /trpc/user.get
Jan 26 22:20:43 umbrel umbreld[709]: [server ] GET /trpc/widget.data
Jan 26 22:20:43 umbrel umbreld[709]: [app ] [error] Failed to get CPU usage for app bitcoin: Command failed with exit code 1: docker stats --no-stream --format {“container”:“{{.Name}}”,“CPUPerc”:“{{.CPUPerc}}”,“MemPerc”:“{{.MemPerc}}”} bitcoin_app_proxy_1 bitcoin_server_1 bitcoin_bitcoind_1 bitcoin_tor_1 bitcoin_i2pd_daemon_1
Jan 26 22:20:43 umbrel umbreld[709]: Error response from daemon: No such container: bitcoin_app_proxy_1
Jan 26 22:20:43 umbrel umbreld[709]: Error response from daemon: No such container: bitcoin_server_1
Jan 26 22:20:43 umbrel umbreld[709]: Error response from daemon: No such container: bitcoin_bitcoind_1
Jan 26 22:20:43 umbrel umbreld[709]: Error response from daemon: No such container: bitcoin_tor_1
Jan 26 22:20:43 umbrel umbreld[709]: Error response from daemon: No such container: bitcoin_i2pd_daemon_1
Jan 26 22:20:43 umbrel umbreld[709]: [app ] [error] Failed to get CPU usage for app nostr-relay: Command failed with exit code 1: docker stats --no-stream --format {“container”:“{{.Name}}”,“CPUPerc”:“{{.CPUPerc}}”,“MemPerc”:“{{.MemPerc}}”} nostr-relay_app_proxy_1 nostr-relay_web_1 nostr-relay_relay_1 nostr-relay_relay-proxy_1
Jan 26 22:20:43 umbrel umbreld[709]: Error response from daemon: No such container: nostr-relay_app_proxy_1
Jan 26 22:20:43 umbrel umbreld[709]: Error response from daemon: No such container: nostr-relay_web_1
Jan 26 22:20:43 umbrel umbreld[709]: Error response from daemon: No such container: nostr-relay_relay_1
Jan 26 22:20:43 umbrel umbreld[709]: Error response from daemon: No such container: nostr-relay_relay-proxy_1
Jan 26 22:20:43 umbrel umbreld[709]: [app ] [error] Failed to get CPU usage for app lightning: Command failed with exit code 1: docker stats --no-stream --format {“container”:“{{.Name}}”,“CPUPerc”:“{{.CPUPerc}}”,“MemPerc”:“{{.MemPerc}}”} lightning_app_proxy_1 lightning_app_1 lightning_lnd_1 lightning_tor_1{{.Name}}“,“CPUPerc”:”{{.CPUPerc}}“,“MemPerc”:”{{.MemPerc}}"} ride-the-lightning_app_proxy_1 ride-the-lightning_web_1 ride-the-lightning_boltz_1
Jan 26 22:20:52 umbrel umbreld[709]: Error response from daemon: No such container: ride-the-lightning_app_proxy_1
Jan 26 22:20:52 umbrel umbreld[709]: Error response from daemon: No such container: ride-the-lightning_web_1
Jan 26 22:20:52 umbrel umbreld[709]: Error response from daemon: No such container: ride-the-lightning_boltz_1
Jan 26 22:20:52 umbrel umbreld[709]: [app ] [error] Failed to get memory usage for app robosats: Command failed with exit code 1: docke
Never mind … I’m moving to my node … this is complete shit
I’m thinking of doing the same. Umbrel has been issue after issue.
