Have you already added the following line to your /etc/hosts file?
192.168.x.x umbrel.local
Make sure to replace “192.168.x.x” with the local IP address of your node.
how to transfer the mined btc to the wallet?
not working,do i need to use my wifi ip?
What isn’t working? Can you be more specific?
is the port correct 2018? also do i need to use my wifi ip or my ip
