I downloaded the public pool app on my umbrel to try and set up my own solo mining pool. I have a few asics I want to connect to it but none of them connect and say the pool is dead. Tried an s19 and avalon nano 3. I entered the correct stratum address the public pool gave me, entered my wallet address and tryed with and without a worker number and did the password x. Nothing will connect. Is there any troubleshooting guides out there or guides on how to set this up? Please help, im dumb pleb and dont what what to do.
Have you seen the logs? Can you possibly post these?
I would be glad to get you these logs but im a complete noob to running bitcoin nodes, I dont have the first clue of how to find this for you. Thank you for your time and consideration
maybe this is what you’re looking for? I copy pasted what started to happen when I rebooted my s19 and it tried connecting to the node
Dec 16 02:04:49 umbrel mender[540]: time=“2024-12-16T02:04:49Z” level=info msg=“State transition: check-wait [Idle] → inventory-update [Sync]”
Dec 16 02:04:49 umbrel mender[540]: time=“2024-12-16T02:04:49Z” level=info msg=“Device unauthorized; attempting reauthorization”
Dec 16 02:04:49 umbrel mender[540]: time=“2024-12-16T02:04:49Z” level=error msg=“Failed to authorize with "": failed to build authorization request: failed to obtain authorization message data: failed to obtain identity data: failed to call /usr/share/mender/identity/mender-device-identity: fork/exec /usr/share/mender/identity/mender-device-identity: no such file or directory”
Dec 16 02:04:49 umbrel mender[540]: time=“2024-12-16T02:04:49Z” level=warning msg=“Reauthorization failed with error: transient error: authorization request failed”
Dec 16 02:04:49 umbrel mender[540]: time=“2024-12-16T02:04:49Z” level=error msg=“Failed to submit inventory data: transient error: authorization request failed”
Dec 16 02:04:49 umbrel mender[540]: time=“2024-12-16T02:04:49Z” level=error msg=“inventory submit failed: transient error: authorization request failed”
Dec 16 02:04:49 umbrel mender[540]: time=“2024-12-16T02:04:49Z” level=warning msg=“Failed to refresh inventory: failed to submit inventory data: inventory submit failed: transient error: authorization request failed”
Dec 16 02:04:49 umbrel mender[540]: time=“2024-12-16T02:04:49Z” level=info msg=“State transition: inventory-update [Sync] → inventory-update-retry-wait [Sync]”
Dec 16 02:04:49 umbrel mender[540]: time=“2024-12-16T02:04:49Z” level=info msg=“Handle update inventory retry state try: 12”
Dec 16 02:04:49 umbrel mender[540]: time=“2024-12-16T02:04:49Z” level=warning msg=“RetryPollIntervalSeconds is not defined”
Dec 16 02:04:49 umbrel mender[540]: time=“2024-12-16T02:04:49Z” level=info msg=“Handle update inventory retry state: failed to send inventory: Tried maximum amount of times”
Dec 16 02:04:49 umbrel mender[540]: time=“2024-12-16T02:04:49Z” level=info msg=“State transition: inventory-update-retry-wait [Sync] → check-wait [Idle]”
Dec 16 02:04:49 umbrel mender[540]: time=“2024-12-16T02:04:49Z” level=warning msg=“UpdatePollIntervalSeconds is not defined”
Dec 16 02:04:49 umbrel mender[540]: time=“2024-12-16T02:04:49Z” level=warning msg=“InventoryPollIntervalSeconds is not defined”
Dec 16 02:04:49 umbrel mender[540]: time=“2024-12-16T02:04:49Z” level=info msg=“State transition: check-wait [Idle] → update-check [Sync]”
Dec 16 02:04:49 umbrel mender[540]: time=“2024-12-16T02:04:49Z” level=error msg=“Error receiving scheduled update data: update check request failed: transient error: authorization request failed”
Dec 16 02:04:49 umbrel mender[540]: time=“2024-12-16T02:04:49Z” level=error msg=“Update check failed: transient error: update check request failed: transient error: authorization request failed”
Dec 16 02:04:49 umbrel mender[540]: time=“2024-12-16T02:04:49Z” level=info msg=“State transition: update-check [Sync] → error [Error]”
Dec 16 02:04:49 umbrel mender[540]: time=“2024-12-16T02:04:49Z” level=info msg=“Handling error state, current error: transient error: update check request failed: transient error: authorization request failed”
Dec 16 02:04:49 umbrel mender[540]: time=“2024-12-16T02:04:49Z” level=info msg=“State transition: error [Error] → idle [Idle]”
Dec 16 02:04:49 umbrel mender[540]: time=“2024-12-16T02:04:49Z” level=info msg=“State transition: idle [Idle] → check-wait [Idle]”
You get it running?
