Newly installed umbrel since pi4 crash so using new mini pc just finish synchronizing bitcoin node, …installed some blue wallet, ride the lightning, thunderhub and robosats for now so all 4 stuck on starting just looping. I uninstall and reinstall the app still no luck. anyone has fix for this problem? thanks.
Here’s debuglog:
0.5.4
Mem: 15G 4.8G 1.0G 3.0M 9.3G 10G
Swap: 4.1G 15M 4.1G
total: 31.8%
lightning: 7.9%
mempool: 7.6%
bitcoin: 7.5%
electrs: 5.5%
thunderhub: 3.3%
tailscale: 0.4%
system: 0%
Memory monitor logs
2023-11-13 16:43:37 Memory monitor running!
2023-11-13 16:48:18 Memory monitor running!
2023-11-13 17:06:08 Memory monitor running!
2023-11-14 00:38:14 Memory monitor running!
2023-11-14 01:48:10 Memory monitor running!
2023-11-14 17:10:29 Memory monitor running!
2023-11-14 17:17:46 Memory monitor running!
2023-11-15 04:45:32 Memory monitor running!
2023-11-15 19:51:10 Memory monitor running!
2023-11-15 20:21:18 Memory monitor running!
/dev/sda2 1.8T 675G 1.1T 39% /
Karen logs
time=“2023-11-15T20:58:21Z” level=warning msg=“network default: network.external.name is deprecated. Please set network.name with external: true”
time=“2023-11-15T20:58:22Z” level=warning msg=“network default: network.external.name is deprecated. Please set network.name with external: true”
time=“2023-11-15T20:58:23Z” level=warning msg=“network default: network.external.name is deprecated. Please set network.name with external: true”
time=“2023-11-15T20:58:24Z” level=warning msg=“network default: network.external.name is deprecated. Please set network.name with external: true”
Debug result file generated
Got signal: debug
karen is getting triggered!
thunderhub
thunderhub-web-1 | {
thunderhub-web-1 | message: ‘UnableToConnectToAnyNode’,
thunderhub-web-1 | level: ‘error’,
thunderhub-web-1 | timestamp: ‘2023-11-15T20:22:46.354Z’
thunderhub-web-1 | }
thunderhub-web-1 | message: 'Initiating subscriptions failed: ',
thunderhub-tor_server-1 | Nov 15 20:23:49.000 [notice] Bootstrapped 56% (loading_descriptors): Loading relay descriptors
thunderhub-tor_server-1 | Nov 15 20:23:51.000 [notice] Bootstrapped 61% (loading_descriptors): Loading relay descriptors
thunderhub-tor_server-1 | Nov 15 20:23:52.000 [notice] Bootstrapped 70% (loading_descriptors): Loading relay descriptors
thunderhub-tor_server-1 | Nov 15 20:23:52.000 [notice] Bootstrapped 75% (enough_dirinfo): Loaded enough directory info to build circuits
thunderhub-tor_server-1 | Nov 15 20:23:52.000 [notice] Bootstrapped 80% (ap_conn): Connecting to a relay to build circuits
thunderhub-tor_server-1 | Nov 15 20:23:53.000 [notice] Bootstrapped 85% (ap_conn_done): Connected to a relay to build circuits
thunderhub-tor_server-1 | Nov 15 20:23:53.000 [notice] Bootstrapped 89% (ap_handshake): Finishing handshake with a relay to build circuits
thunderhub-tor_server-1 | Nov 15 20:23:53.000 [notice] Bootstrapped 90% (ap_handshake_done): Handshake finished with a relay to build circuits
thunderhub-tor_server-1 | Nov 15 20:23:53.000 [notice] Bootstrapped 95% (circuit_create): Establishing a Tor circuit
thunderhub-tor_server-1 | Nov 15 20:23:55.000 [notice] Bootstrapped 100% (done): Done
thunderhub-app_proxy-1 | Retrying…
thunderhub-web-1 | timestamp: ‘2023-11-15T20:22:46.355Z’
thunderhub-app_proxy-1 | Error wating for port: “getaddrinfo EAI_AGAIN thunderhub_web_1”
