All apps stuck at "Starting..."
All apps are hung up at “Starting…”, including an app I just installed as well as some old favourites including Bitcoin Core.
Re-flashed the SD with the newest OS and the problem persists.
Logs:
0.5.4
Flashed OS version
v0.5.4-patch-1
Raspberry Pi Model
Revision : c03112
Serial : [xxx]
Model : Raspberry Pi 4 Model B Rev 1.2
Firmware
May 9 2023 12:16:34
Copyright (c) 2012 Broadcom
Temperature
temp=40.9’C
Throttling
throttled=0x0
Mem: 3.8G 1.3G 535M 25M 2.0G 2.4G
Swap: 4.1G 0.0K 4.1G
total: 34.0%
bitcoin: 18.1%
electrs: 5.2%
btc-rpc-explorer: 4.1%
photoprism: 3.7%
system: 2.9%
mempool: 0%
Memory monitor logs
2023-08-09 14:17:26 Memory monitor running!
2023-08-17 09:17:30 Memory monitor running!
2023-11-04 11:17:35 Memory monitor running!
2023-11-11 08:21:16 Memory monitor running!
2023-11-21 20:17:33 Memory monitor running!
2023-12-20 02:17:32 Memory monitor running!
1653 ? S 0:16 bash ./scripts/memory-monitor
2023-12-28 20:08:32 Memory monitor running!
2023-12-28 21:22:14 Memory monitor running!
/dev/root 59G 3.3G 53G 6% /
/dev/sda1 916G 630G 240G 73% /home/umbrel/umbrel
Startup service logs
Dec 28 21:22:38 umbrel umbrel startup[1520]: Creating electrs_electrs_1 …
Dec 28 21:22:38 umbrel umbrel startup[1520]: Creating electrs_app_proxy_1 …
Dec 28 21:22:42 umbrel umbrel startup[1520]: Creating mempool_web_1 … done
Dec 28 21:22:42 umbrel umbrel startup[1520]: Creating btc-rpc-explorer_web_1 … done
Dec 28 21:22:42 umbrel umbrel startup[1520]: Creating bitcoin_bitcoind_1 …
Dec 28 21:22:42 umbrel umbrel startup[1520]: Creating bitcoin_app_proxy_1 …
Dec 28 21:22:42 umbrel umbrel startup[1520]: Creating photoprism_web_1 … done
Dec 28 21:22:42 umbrel umbrel startup[1520]: Creating bitcoin_tor_1 …
Dec 28 21:22:42 umbrel umbrel startup[1520]: Creating bitcoin_i2pd_daemon_1 …
Dec 28 21:22:43 umbrel umbrel startup[1520]: Creating photoprism_db_1 … done
Dec 28 21:22:43 umbrel umbrel startup[1520]: Creating mempool_mariadb_1 … done
Dec 28 21:22:44 umbrel umbrel startup[1520]: Creating mempool_api_1 … done
Dec 28 21:22:46 umbrel umbrel startup[1520]: Creating photoprism_app_proxy_1 … done
Dec 28 21:22:46 umbrel umbrel startup[1520]: Creating btc-rpc-explorer_app_proxy_1 … done
Dec 28 21:22:46 umbrel umbrel startup[1520]: Creating mempool_app_proxy_1 … done
Dec 28 21:22:47 umbrel umbrel startup[1520]: Creating electrs_app_proxy_1 … done
Dec 28 21:22:48 umbrel umbrel startup[1520]: Creating electrs_tor_1 … done
Dec 28 21:22:49 umbrel umbrel startup[1520]: Creating bitcoin_tor_1 … done
Dec 28 21:22:49 umbrel umbrel startup[1520]: Creating bitcoin_app_proxy_1 … done
Dec 28 21:22:52 umbrel umbrel startup[1520]: Creating bitcoin_bitcoind_1 … done
Dec 28 21:22:52 umbrel umbrel startup[1520]: Creating bitcoin_server_1 …
Dec 28 21:22:53 umbrel umbrel startup[1520]: Creating electrs_electrs_1 … done
Dec 28 21:22:53 umbrel umbrel startup[1520]: Creating electrs_app_1 …
Dec 28 21:22:53 umbrel umbrel startup[1520]: Creating bitcoin_i2pd_daemon_1 … done
Dec 28 21:23:02 umbrel umbrel startup[1520]: Creating bitcoin_server_1 … done
Dec 28 21:23:04 umbrel umbrel startup[1520]: Creating electrs_app_1 … done
Dec 28 21:23:05 umbrel umbrel startup[1520]: Umbrel is now accessible at
Dec 28 21:23:05 umbrel umbrel startup[1520]: http://umbrel.local
Dec 28 21:23:05 umbrel umbrel startup[1520]: http://192.168.132.131
Dec 28 21:23:05 umbrel systemd[1]: Started Umbrel Startup Service.
External storage service logs
Oct 16 13:26:14 umbrel external storage mounter[510]: now = Mon Oct 16 13:26:08 2023) is in the future.
Oct 16 13:26:14 umbrel external storage mounter[510]: Fix? yes
Oct 16 13:26:14 umbrel external storage mounter[510]: Pass 1: Checking inodes, blocks, and sizes
Dec 28 21:21:38 umbrel external storage mounter[510]: Pass 2: Checking directory structure
Dec 28 21:21:46 umbrel external storage mounter[510]: Pass 3: Checking directory connectivity
Dec 28 21:21:47 umbrel external storage mounter[510]: Pass 4: Checking reference counts
Dec 28 21:21:51 umbrel external storage mounter[510]: Pass 5: Checking group summary information
Dec 28 21:21:52 umbrel external storage mounter[510]: Free blocks count wrong (75116647, counted=75132251).
Dec 28 21:21:52 umbrel external storage mounter[510]: Fix? yes
Dec 28 21:21:52 umbrel external storage mounter[510]: Free inodes count wrong (60710346, counted=60710215).
Dec 28 21:21:52 umbrel external storage mounter[510]: umbrel: ***** FILE SYSTEM WAS MODIFIED *****
Dec 28 21:21:52 umbrel external storage mounter[510]: umbrel: 344761/61054976 files (4.9% non-contiguous), 169058469/244190720 blocks
Dec 28 21:21:52 umbrel external storage mounter[510]: Mounting partition…
Dec 28 21:21:52 umbrel external storage mounter[510]: Checking if device contains an Umbrel install…
Dec 28 21:21:52 umbrel external storage mounter[510]: Yes, it contains an Umbrel install
Dec 28 21:21:52 umbrel external storage mounter[510]: Bind mounting external storage over local Umbrel installation…
Dec 28 21:21:52 umbrel external storage mounter[510]: Bind mounting external storage over local Docker data dir…
Dec 28 21:21:52 umbrel external storage mounter[510]: Bind mounting external storage to /swap
Dec 28 21:21:52 umbrel external storage mounter[510]: Bind mounting SD card root at /sd-card…
Dec 28 21:21:52 umbrel external storage mounter[510]: Checking Umbrel root is now on external storage…
Dec 28 21:21:55 umbrel external storage mounter[510]: Checking /var/lib/docker is now on external storage…
Dec 28 21:21:55 umbrel external storage mounter[510]: Checking /swap is now on external storage…
Dec 28 21:21:55 umbrel external storage mounter[510]: Setting up swapfile
Dec 28 21:21:57 umbrel external storage mounter[510]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
Dec 28 21:21:57 umbrel external storage mounter[510]: no label, UUID=0ab91e55-bce0-435c-94a1-8868ce7e3129
Dec 28 21:21:57 umbrel external storage mounter[510]: Checking SD Card root is bind mounted at /sd-root…
Dec 28 21:21:57 umbrel external storage mounter[510]: Starting external drive mount monitor…
Dec 28 21:21:57 umbrel external storage mounter[510]: Mount script completed successfully!
Dec 28 21:21:58 umbrel systemd[1]: Started External Storage Mounter.
– Logs begin at Thu 2019-02-14 10:11:58 UTC, end at Thu 2023-12-28 21:25:53 UTC. –
Dec 28 21:22:14 umbrel systemd[1]: Starting External Storage SDcard Updater…
Dec 28 21:22:14 umbrel external storage updater[1374]: Checking if SD card Umbrel is newer than external storage…
Dec 28 21:22:14 umbrel external storage updater[1374]: No, SD version is not newer, exiting.
Dec 28 21:22:14 umbrel systemd[1]: Started External Storage SDcard Updater.
Karen logs
Removing bitcoin_i2pd_daemon_1 …
Removing bitcoin_app_proxy_1 …
Removing bitcoin_bitcoind_1 …
Removing bitcoin_app_proxy_1 … done
Removing bitcoin_i2pd_daemon_1 … done
Removing bitcoin_tor_1 … done
Removing bitcoin_server_1 … done
Removing bitcoin_bitcoind_1 … done
Going to remove bitcoin_server_1, bitcoin_tor_1, bitcoin_i2pd_daemon_1, bitcoin_app_proxy_1, bitcoin_bitcoind_1
Stopping Docker services…
Stopping dashboard …
Stopping manager …
Stopping nginx …
Stopping auth …
Stopping tor_proxy …
Stopping tor_proxy … done
Stopping nginx … done
Stopping manager … done
Stopping dashboard … done
Stopping auth … done
Removing dashboard …
Removing manager …
Removing nginx …
Removing auth …
Removing tor_proxy …
Removing tor_proxy … done
Removing dashboard … done
Removing auth … done
Removing nginx … done
Removing manager … done
error while removing network: network umbrel_main_network id 6d6d44ea857e6ba3874525bf9d0f6a3eb514c16fa2aeaf25c3f5da7f505cc9bb has active endpoints
Got signal:
karen is getting triggered!
Got signal:
Got signal:
Got signal:
Got signal: debug
Docker containers
NAMES STATUS
electrs_app_1 Up 2 minutes
bitcoin_server_1 Up 2 minutes
bitcoin_i2pd_daemon_1 Up 3 minutes
bitcoin_tor_1 Up 3 minutes
bitcoin_app_proxy_1 Restarting (135) 37 seconds ago
bitcoin_bitcoind_1 Up 3 minutes
electrs_tor_1 Up 3 minutes
electrs_electrs_1 Up 8 seconds
electrs_app_proxy_1 Restarting (135) 32 seconds ago
mempool_api_1 Up 3 minutes
mempool_mariadb_1 Restarting (1) 10 seconds ago
mempool_web_1 Up 3 minutes
mempool_app_proxy_1 Restarting (135) 6 seconds ago
btc-rpc-explorer_web_1 Up 3 minutes
btc-rpc-explorer_app_proxy_1 Restarting (135) 36 seconds ago
photoprism_db_1 Restarting (1) 6 seconds ago
photoprism_web_1 Up 3 minutes
photoprism_app_proxy_1 Restarting (135) 32 seconds ago
nginx Up 3 minutes
auth Up 3 minutes
manager Up 3 minutes
dashboard Up 3 minutes
tor_proxy Up 3 minutes
Umbrel logs
Attaching to manager
manager | ::ffff:10.21.21.2 - - [Thu, 28 Dec 2023 21:25:57 GMT] “GET /v1/system/memory HTTP/1.0” 304 - “-” “Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36”
manager |
manager | umbrel-manager
manager | ::ffff:10.21.21.2 - - [Thu, 28 Dec 2023 21:25:57 GMT] “GET /v1/system/info HTTP/1.0” 304 - “-” “Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Thu, 28 Dec 2023 21:25:57 GMT] “GET /v1/system/debug-result HTTP/1.0” 304 - “-” “Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Thu, 28 Dec 2023 21:25:57 GMT] “GET /v1/system/temperature HTTP/1.0” 200 2 “-” “Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Thu, 28 Dec 2023 21:25:58 GMT] “GET /v1/system/get-update HTTP/1.0” 304 - “-” “Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Thu, 28 Dec 2023 21:25:59 GMT] “GET /v1/system/debug-result HTTP/1.0” 304 - “-” “Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Thu, 28 Dec 2023 21:26:00 GMT] “GET /v1/system/debug-result HTTP/1.0” 304 - “-” “Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Thu, 28 Dec 2023 21:26:01 GMT] “GET /v1/system/debug-result HTTP/1.0” 304 - “-” “Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Thu, 28 Dec 2023 21:26:02 GMT] “GET /v1/system/debug-result HTTP/1.0” 304 - “-” “Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Thu, 28 Dec 2023 21:26:03 GMT] “GET /v1/system/debug-result HTTP/1.0” 304 - “-” “Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36”
manager |
Tor Proxy logs
Attaching to tor_proxy
tor_proxy | Dec 28 21:22:37.000 [notice] Bootstrapped 55% (loading_descriptors): Loading relay descriptors
tor_proxy | Dec 28 21:22:38.000 [notice] Bootstrapped 63% (loading_descriptors): Loading relay descriptors
tor_proxy | Dec 28 21:22:39.000 [notice] Bootstrapped 71% (loading_descriptors): Loading relay descriptors
tor_proxy | Dec 28 21:22:42.000 [notice] Bootstrapped 75% (enough_dirinfo): Loaded enough directory info to build circuits
tor_proxy | Dec 28 21:22:42.000 [notice] Bootstrapped 80% (ap_conn): Connecting to a relay to build circuits
tor_proxy | Dec 28 21:22:42.000 [notice] Bootstrapped 85% (ap_conn_done): Connected to a relay to build circuits
tor_proxy | Dec 28 21:22:43.000 [notice] Bootstrapped 89% (ap_handshake): Finishing handshake with a relay to build circuits
tor_proxy | Dec 28 21:22:43.000 [notice] Bootstrapped 90% (ap_handshake_done): Handshake finished with a relay to build circuits
tor_proxy | Dec 28 21:22:43.000 [notice] Bootstrapped 95% (circuit_create): Establishing a Tor circuit
tor_proxy | Dec 28 21:22:44.000 [notice] Bootstrapped 100% (done): Done
App logs
bitcoin
Attaching to bitcoin_server_1, bitcoin_i2pd_daemon_1, bitcoin_tor_1, bitcoin_app_proxy_1, bitcoin_bitcoind_1
i2pd_daemon_1 | 21:24:52@424/error - Tunnels: Can’t select next hop for -lmnP-3k~N7Pu~Al0egwOPfbcFISCGJ3PQMmrOcs8lQ=
i2pd_daemon_1 | 21:24:52@424/error - Tunnels: Can’t create inbound tunnel, no peers available
i2pd_daemon_1 | 21:25:06@424/error - Tunnels: Can’t select next hop for F0uj0A491am6CvTOWFkLEA1MwnEosiV5XjtybUPeiQo=
i2pd_daemon_1 | 21:25:06@424/error - Tunnels: Can’t create inbound tunnel, no peers available
i2pd_daemon_1 | 21:25:07@424/error - Tunnels: Can’t select next hop for Ww-j8QfGQEc6AEFHPAIkdfcOpkozDQ-vCIfIpvvrNDM=
i2pd_daemon_1 | 21:25:07@424/error - Tunnels: Can’t create inbound tunnel, no peers available
i2pd_daemon_1 | 21:25:23@424/error - Tunnels: Can’t select next hop for cpmWqPCbXtSErUYtHJOvFRgmwAmWi3SEhJu2gWkkA~o=
i2pd_daemon_1 | 21:25:23@424/error - Tunnels: Can’t create inbound tunnel, no peers available
i2pd_daemon_1 | 21:25:36@424/error - Tunnels: Can’t select next hop for fEe50ObmMWwyU9U73W-okFumi0nAzFWwuzpdwOLMqGE=
i2pd_daemon_1 | 21:25:36@424/error - Tunnels: Can’t create inbound tunnel, no peers available
bitcoind_1 | 2023-12-28T21:24:14Z net thread start
bitcoind_1 | 2023-12-28T21:24:14Z dnsseed thread start
bitcoind_1 | 2023-12-28T21:24:14Z Waiting 300 seconds before querying DNS seeds.
bitcoind_1 | 2023-12-28T21:24:15Z New outbound peer connected: version: 70015, blocks=823314, peer=0 (outbound-full-relay)
bitcoind_1 | 2023-12-28T21:24:34Z New outbound peer connected: version: 70016, blocks=823314, peer=1 (outbound-full-relay)
bitcoind_1 | 2023-12-28T21:24:38Z Synchronizing blockheaders, height: 807818 (~98.17%)
bitcoind_1 | 2023-12-28T21:24:41Z Synchronizing blockheaders, height: 809818 (~98.41%)
bitcoind_1 | 2023-12-28T21:26:08Z Socks5() connect to 74.138.51.120:8333 failed: general failure
bitcoind_1 | 2023-12-28T21:26:10Z Socks5() connect to 79.142.69.160:58148 failed: general failure
tor_1 | Dec 28 21:23:10.000 [notice] Bootstrapped 71% (loading_descriptors): Loading relay descriptors
tor_1 | Dec 28 21:23:12.000 [notice] Bootstrapped 75% (enough_dirinfo): Loaded enough directory info to build circuits
tor_1 | Dec 28 21:23:12.000 [notice] Bootstrapped 80% (ap_conn): Connecting to a relay to build circuits
tor_1 | Dec 28 21:23:12.000 [notice] Bootstrapped 85% (ap_conn_done): Connected to a relay to build circuits
tor_1 | Dec 28 21:23:12.000 [notice] Bootstrapped 89% (ap_handshake): Finishing handshake with a relay to build circuits
tor_1 | Dec 28 21:23:13.000 [notice] Bootstrapped 90% (ap_handshake_done): Handshake finished with a relay to build circuits
tor_1 | Dec 28 21:23:13.000 [notice] Bootstrapped 95% (circuit_create): Establishing a Tor circuit
tor_1 | Dec 28 21:23:13.000 [notice] Bootstrapped 100% (done): Done
tor_1 | Dec 28 21:26:08.000 [notice] Have tried resolving or connecting to address ‘[scrubbed]’ at 3 different places. Giving up.
server_1 | yarn run v1.22.18
server_1 | $ node ./bin/www
server_1 | Thu, 28 Dec 2023 21:23:14 GMT morgan deprecated morgan(options): use morgan(“default”, options) instead at app.js:33:9
server_1 | Thu, 28 Dec 2023 21:23:14 GMT morgan deprecated default format: use combined format at app.js:33:9
server_1 | Listening on port 3005
btc-rpc-explorer
Attaching to btc-rpc-explorer_web_1, btc-rpc-explorer_app_proxy_1
web_1 | at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1278:16)
web_1 | 2023-12-28T21:27:48.941Z btcexp:error Error 937gf47dsyde: Error: close connect, json: {}, userData: [object Object] (json: {“host”:“10.21.21.10”,“port”:50001,“protocol”:“tcp”})
web_1 | 2023-12-28T21:27:48.942Z btcexp:errorVerbose Stack: Error: close connect
web_1 | at /data/node_modules/electrum-client/lib/client.js:192:37
web_1 | at Array.forEach ()
web_1 | at ElectrumClient.onClose (/data/node_modules/electrum-client/lib/client.js:191:44)
web_1 | at ElectrumClient.onClose (/data/node_modules/electrum-client/index.js:69:9)
web_1 | at Socket. (/data/node_modules/electrum-client/lib/client.js:68:9)
web_1 | at Socket.emit (node:events:513:28)
web_1 | at TCP. (node:net:301:12)
electrs
Attaching to electrs_app_1, electrs_tor_1, electrs_electrs_1, electrs_app_proxy_1
app_1 | > umbrel-electrs@1.0.1 dev:backend
app_1 | > npm run start -w umbrel-electrs-backend
app_1 |
app_1 |
app_1 | > umbrel-electrs-backend@0.1.12 start
app_1 | > node ./bin/www
app_1 |
app_1 | Thu, 28 Dec 2023 21:23:36 GMT morgan deprecated morgan(options): use morgan(“default”, options) instead at app.js:28:9
app_1 | Thu, 28 Dec 2023 21:23:36 GMT morgan deprecated default format: use combined format at app.js:28:9
app_1 | Listening on port 3006
electrs_1 | Error: electrs failed
electrs_1 |
electrs_1 | Caused by:
electrs_1 | 0: bitcoind RPC polling failed
electrs_1 | 1: daemon not available
electrs_1 | 2: JSON-RPC error: transport error: Couldn’t connect to host: Resource temporarily unavailable (os error 11)
electrs_1 | Starting electrs 0.10.1 on aarch64 linux with Config { network: Bitcoin, db_path: “/data/db/bitcoin”, daemon_dir: “/data/.bitcoin”, daemon_auth: CookieFile(“/data/.bitcoin/.cookie”), daemon_rpc_addr: 10.21.21.8:8332, daemon_p2p_addr: 10.21.21.8:8333, electrum_rpc_addr: 0.0.0.0:50001, monitoring_addr: 127.0.0.1:4224, wait_duration: 10s, jsonrpc_timeout: 15s, index_batch_size: 10, index_lookup_limit: None, reindex_last_blocks: 0, auto_reindex: true, ignore_mempool: false, sync_once: false, skip_block_download_wait: false, disable_electrum_rpc: false, server_banner: “Umbrel Electrs (0.10.1)”, signet_magic: f9beb4d9, args: }
electrs_1 | [2023-12-28T21:27:55.440Z INFO electrs::metrics::metrics_impl] serving Prometheus metrics on 127.0.0.1:4224
electrs_1 | [2023-12-28T21:27:55.443Z INFO electrs::server] serving Electrum RPC on 0.0.0.0:50001
electrs_1 | [2023-12-28T21:27:55.648Z INFO electrs::db] “/data/db/bitcoin”: 173 SST files, 41.66216002 GB, 5.210549306 Grows
tor_1 | Dec 28 21:23:13.000 [notice] Bootstrapped 56% (loading_descriptors): Loading relay descriptors
tor_1 | Dec 28 21:23:18.000 [notice] Bootstrapped 62% (loading_descriptors): Loading relay descriptors
tor_1 | Dec 28 21:23:18.000 [notice] Bootstrapped 71% (loading_descriptors): Loading relay descriptors
tor_1 | Dec 28 21:23:19.000 [notice] Bootstrapped 75% (enough_dirinfo): Loaded enough directory info to build circuits
tor_1 | Dec 28 21:23:21.000 [notice] Bootstrapped 80% (ap_conn): Connecting to a relay to build circuits
tor_1 | Dec 28 21:23:21.000 [notice] Bootstrapped 85% (ap_conn_done): Connected to a relay to build circuits
tor_1 | Dec 28 21:23:22.000 [notice] Bootstrapped 89% (ap_handshake): Finishing handshake with a relay to build circuits
tor_1 | Dec 28 21:23:23.000 [notice] Bootstrapped 90% (ap_handshake_done): Handshake finished with a relay to build circuits
tor_1 | Dec 28 21:23:23.000 [notice] Bootstrapped 95% (circuit_create): Establishing a Tor circuit
tor_1 | Dec 28 21:23:25.000 [notice] Bootstrapped 100% (done): Done
mempool
Attaching to mempool_api_1, mempool_mariadb_1, mempool_web_1, mempool_app_proxy_1
mariadb_1 | command was: mysqld --verbose --help --log-bin-index=/tmp/tmp.NKSxNcWXkV
mariadb_1 |
mariadb_1 | 2023-12-28 21:25:40+00:00 [Note] [Entrypoint]: Entrypoint script for MariaDB Server 1:10.5.12+maria~focal started.
mariadb_1 | 2023-12-28 21:25:41+00:00 [ERROR] [Entrypoint]: mysqld failed while attempting to check config
mariadb_1 | command was: mysqld --verbose --help --log-bin-index=/tmp/tmp.k2zWJmDU5r
mariadb_1 |
mariadb_1 | 2023-12-28 21:27:48+00:00 [Note] [Entrypoint]: Entrypoint script for MariaDB Server 1:10.5.12+maria~focal started.
mariadb_1 | 2023-12-28 21:27:49+00:00 [ERROR] [Entrypoint]: mysqld failed while attempting to check config
mariadb_1 | command was: mysqld --verbose --help --log-bin-index=/tmp/tmp.5CbA7jepxs
mariadb_1 |
api_1 | wait-for-it.sh: waiting 720 seconds for mariadb:3306
web_1 | /var/www/mempool/browser/resources
photoprism
Attaching to photoprism_db_1, photoprism_web_1, photoprism_app_proxy_1
db_1 | command was: mysqld --transaction-isolation=READ-COMMITTED --character-set-server=utf8mb4 --collation-server=utf8mb4_unicode_ci --max-connections=512 --innodb-rollback-on-timeout=OFF --innodb-lock-wait-timeout=50 --verbose --help --log-bin-index=/tmp/tmp.gDqgCFsAtJ
db_1 |
db_1 | 2023-12-28 21:25:35+00:00 [Note] [Entrypoint]: Entrypoint script for MariaDB Server 1:10.5.12+maria~focal started.
db_1 | 2023-12-28 21:25:40+00:00 [ERROR] [Entrypoint]: mysqld failed while attempting to check config
db_1 | command was: mysqld --transaction-isolation=READ-COMMITTED --character-set-server=utf8mb4 --collation-server=utf8mb4_unicode_ci --max-connections=512 --innodb-rollback-on-timeout=OFF --innodb-lock-wait-timeout=50 --verbose --help --log-bin-index=/tmp/tmp.V42GTWoPj5
db_1 |
db_1 | 2023-12-28 21:27:47+00:00 [Note] [Entrypoint]: Entrypoint script for MariaDB Server 1:10.5.12+maria~focal started.
db_1 | 2023-12-28 21:27:47+00:00 [ERROR] [Entrypoint]: mysqld failed while attempting to check config
db_1 | command was: mysqld --transaction-isolation=READ-COMMITTED --character-set-server=utf8mb4 --collation-server=utf8mb4_unicode_ci --max-connections=512 --innodb-rollback-on-timeout=OFF --innodb-lock-wait-timeout=50 --verbose --help --log-bin-index=/tmp/tmp.1A5y5BAYfK
db_1 |
web_1 | import path…: /photoprism/import
web_1 | originals path: /photoprism/originals
web_1 | running as uid 1000
web_1 | /opt/photoprism/bin/photoprism start
web_1 | time=“2023-12-28T21:24:20Z” level=error msg=“dial tcp: lookup photoprism_db_1 on 127.0.0.11:53: no such host”
web_1 | time=“2023-12-28T21:25:37Z” level=error msg=“dial tcp 10.21.0.4:3306: connect: connection refused”
web_1 | time=“2023-12-28T21:26:52Z” level=error msg=“dial tcp: lookup photoprism_db_1 on 127.0.0.11:53: no such host”
==== Result ====
Hi there,
Try this please
For what it’s worth to anyone reading this, in the end I came to the conclusion that the SSHD had become corrupted, perhaps due to power outage. I ended reformatting the HD and starting from scratch.
