Hello there dear community. Will anyone help me? My new installation has been stuck for days now and I don’t know what to do - I tried following a couple of directions provided here at the forum without success. Ill include the log bellow:
0.5.4
Flashed OS version
v0.5.3
Raspberry Pi Model
Revision : c03114
Serial : 1000000063c185cf
Firmware
May 9 2023 12:16:34
Copyright (c) 2012 Broadcom
Temperature
temp=63.7'C
Throttling
throttled=0x0
Mem: 3.8G 1.4G 926M 34M 1.5G 2.4G
Swap: 4.1G 0B 4.1G
total: 36.0%
lightning: 11.6%
thunderhub: 10.3%
electrs: 9.5%
bitcoin: 8.9%
system: 0%
Memory monitor logs
2023-07-17 02:25:41 Memory monitor running!
2023-07-17 02:27:21 Memory monitor running!
2023-07-17 02:40:15 Memory monitor running!
2023-07-17 03:53:37 Memory monitor running!
2023-07-17 04:00:25 Memory monitor running!
2023-07-17 04:05:10 Memory monitor running!
2023-07-17 04:20:49 Memory monitor running!
2023-07-17 13:16:13 Memory monitor running!
2023-07-17 13:30:44 Memory monitor running!
2023-07-18 04:18:59 Memory monitor running!
/dev/root 58G 3.3G 52G 6% /
/dev/sda1 916G 424G 446G 49% /home/umbrel/umbrel
Startup service logs
Jul 18 04:19:45 umbrel umbrel startup[1704]: Creating bitcoin_bitcoind_1 ...
Jul 18 04:19:45 umbrel umbrel startup[1704]: Creating bitcoin_tor_1 ...
Jul 18 04:19:45 umbrel umbrel startup[1704]: Creating bitcoin_i2pd_daemon_1 ...
Jul 18 04:20:07 umbrel umbrel startup[1704]: Creating electrs_electrs_1 ... done
Jul 18 04:20:07 umbrel umbrel startup[1704]: Creating electrs_app_1 ...
Jul 18 04:20:12 umbrel umbrel startup[1704]: Creating lightning_app_proxy_1 ... done
Jul 18 04:20:16 umbrel umbrel startup[1704]: Creating bitcoin_i2pd_daemon_1 ... done
Jul 18 04:20:18 umbrel umbrel startup[1704]: Creating thunderhub_tor_server_1 ... done
Jul 18 04:20:41 umbrel umbrel startup[1704]: Creating lightning_lnd_1 ... done
Jul 18 04:20:47 umbrel umbrel startup[1704]: Creating thunderhub_web_1 ... done
Jul 18 04:21:00 umbrel umbrel startup[1704]: Creating electrs_tor_server_1 ... done
Jul 18 04:21:10 umbrel umbrel startup[1704]: Creating lightning_app_1 ... done
Jul 18 04:21:25 umbrel umbrel startup[1704]: Creating lightning_tor_server_1 ... done
Jul 18 04:21:27 umbrel umbrel startup[1704]: Creating bitcoin_tor_server_1 ... done
Jul 18 04:21:30 umbrel umbrel startup[1704]: Creating bitcoin_bitcoind_1 ... done
Jul 18 04:21:30 umbrel umbrel startup[1704]: Creating bitcoin_server_1 ...
Jul 18 04:21:55 umbrel umbrel startup[1704]: Creating lightning_tor_1 ... done
Jul 18 04:21:55 umbrel umbrel startup[1704]: Creating electrs_app_proxy_1 ... done
Jul 18 04:21:56 umbrel umbrel startup[1704]: Creating electrs_tor_1 ... done
Jul 18 04:21:57 umbrel umbrel startup[1704]: Creating bitcoin_tor_1 ... done
Jul 18 04:22:01 umbrel umbrel startup[1704]: Creating thunderhub_app_proxy_1 ... done
Jul 18 04:22:01 umbrel umbrel startup[1704]: Creating bitcoin_app_proxy_1 ... done
Jul 18 04:22:14 umbrel umbrel startup[1704]: Creating electrs_app_1 ... done
Jul 18 04:25:52 umbrel umbrel startup[1704]: Creating bitcoin_server_1 ... done
Jul 18 04:25:53 umbrel umbrel startup[1704]: Umbrel is now accessible at
Jul 18 04:25:53 umbrel umbrel startup[1704]: http://umbrel.local
Jul 18 04:25:53 umbrel umbrel startup[1704]: http://192.168.0.114
Jul 18 04:25:53 umbrel systemd[1]: Started Umbrel Startup Service.
Jul 18 16:33:10 umbrel passwd[32058]: pam_unix(passwd:chauthtok): password changed for umbrel
External storage service logs
Jul 18 04:18:11 umbrel external storage mounter[475]: Rebinding USB drivers...
Jul 18 04:18:11 umbrel external storage mounter[475]: Checking USB devices are back...
Jul 18 04:18:11 umbrel external storage mounter[475]: Waiting for USB devices...
Jul 18 04:18:12 umbrel external storage mounter[475]: Waiting for USB devices...
Jul 18 04:18:13 umbrel external storage mounter[475]: Waiting for USB devices...
Jul 18 04:18:14 umbrel external storage mounter[475]: Checking if the device is ext4...
Jul 18 04:18:14 umbrel external storage mounter[475]: Yes, it is ext4
Jul 18 04:18:14 umbrel external storage mounter[475]: Checking filesystem for corruption...
Jul 18 04:18:14 umbrel external storage mounter[475]: e2fsck 1.44.5 (15-Dec-2018)
Jul 18 04:18:15 umbrel external storage mounter[475]: umbrel: recovering journal
Jul 18 04:18:17 umbrel external storage mounter[475]: Setting free inodes count to 60748783 (was 60751577)
Jul 18 04:18:17 umbrel external storage mounter[475]: Setting free blocks count to 128984908 (was 129034418)
Jul 18 04:18:17 umbrel external storage mounter[475]: umbrel: clean, 306193/61054976 files, 115205300/244190208 blocks
Jul 18 04:18:17 umbrel external storage mounter[475]: Mounting partition...
Jul 18 04:18:17 umbrel external storage mounter[475]: Checking if device contains an Umbrel install...
Jul 18 04:18:17 umbrel external storage mounter[475]: Yes, it contains an Umbrel install
Jul 18 04:18:17 umbrel external storage mounter[475]: Bind mounting external storage over local Umbrel installation...
Jul 18 04:18:17 umbrel external storage mounter[475]: Bind mounting external storage over local Docker data dir...
Jul 18 04:18:17 umbrel external storage mounter[475]: Bind mounting external storage to /swap
Jul 18 04:18:17 umbrel external storage mounter[475]: Bind mounting SD card root at /sd-card...
Jul 18 04:18:17 umbrel external storage mounter[475]: Checking Umbrel root is now on external storage...
Jul 18 04:18:18 umbrel external storage mounter[475]: Checking /var/lib/docker is now on external storage...
Jul 18 04:18:18 umbrel external storage mounter[475]: Checking /swap is now on external storage...
Jul 18 04:18:18 umbrel external storage mounter[475]: Setting up swapfile
Jul 18 04:18:24 umbrel external storage mounter[475]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
Jul 18 04:18:24 umbrel external storage mounter[475]: no label, UUID=cf497a87-c627-423a-98e0-da5d631974fc
Jul 18 04:18:24 umbrel external storage mounter[475]: Checking SD Card root is bind mounted at /sd-root...
Jul 18 04:18:24 umbrel external storage mounter[475]: Starting external drive mount monitor...
Jul 18 04:18:24 umbrel external storage mounter[475]: Mount script completed successfully!
Jul 18 04:18:24 umbrel systemd[1]: Started External Storage Mounter.
-- Logs begin at Tue 2023-07-18 04:17:01 UTC, end at Tue 2023-07-18 16:36:16 UTC. --
Jul 18 04:18:59 umbrel systemd[1]: Starting External Storage SDcard Updater...
Jul 18 04:18:59 umbrel external storage updater[1655]: Checking if SD card Umbrel is newer than external storage...
Jul 18 04:18:59 umbrel external storage updater[1655]: No, SD version is not newer, exiting.
Jul 18 04:18:59 umbrel systemd[1]: Started External Storage SDcard Updater.
Karen logs
Got signal:
karen is getting triggered!
Got signal:
Got signal: backup
Deriving keys...
Creating backup...
Adding random padding...
1+0 records in
1+0 records out
1319 bytes (1.3 kB, 1.3 KiB) copied, 0.000180196 s, 7.3 MB/s
Creating encrypted tarball...
backup/
backup/.padding
Uploading backup...
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:03 --:--:-- 0
100 1849 0 0 100 1849 0 430 0:00:04 0:00:04 --:--:-- 430
100 1995 100 146 100 1849 27 352 0:00:05 0:00:05 --:--:-- 380
{"message":"Successfully uploaded backup 1689660163488.tar.gz.pgp for backup ID e53bf8af297da5518177a51c3d1c7b225649dd0874896cd880980cba1e3aab93"}
====== Backup success =======
Got signal: backup
Deriving keys...
Creating backup...
1+0 records in
1+0 records out
8324 bytes (8.3 kB, 8.1 KiB) copied, 0.000523012 s, 15.9 MB/s
backup/
backup/.padding
Uploading backup...
0 0 0 0 0 0 0 0 --:--:-- 0:00:04 --:--:-- 0
100 8865 0 0 100 8865 0 1770 0:00:05 0:00:05 --:--:-- 1771
100 9011 100 146 100 8865 25 1549 0:00:05 0:00:05 --:--:-- 1574
100 9011 100 146 100 8865 25 1548 0:00:05 0:00:05 --:--:-- 1573
{"message":"Successfully uploaded backup 1689686968291.tar.gz.pgp for backup ID e53bf8af297da5518177a51c3d1c7b225649dd0874896cd880980cba1e3aab93"}
Got signal: change-password
Got signal: debug
Docker containers
NAMES STATUS
bitcoin_server_1 Up 12 hours
electrs_app_1 Up 12 hours
bitcoin_i2pd_daemon_1 Up 12 hours
bitcoin_tor_1 Up 12 hours
bitcoin_app_proxy_1 Up 12 hours
bitcoin_bitcoind_1 Restarting (1) 10 seconds ago
bitcoin_tor_server_1 Up 12 hours
lightning_app_proxy_1 Up 12 hours
lightning_app_1 Up 12 hours
lightning_tor_1 Up 12 hours
lightning_lnd_1 Up 12 hours
lightning_tor_server_1 Up 12 hours
electrs_electrs_1 Restarting (1) 11 seconds ago
electrs_tor_server_1 Up 12 hours
electrs_tor_1 Up 12 hours
electrs_app_proxy_1 Up 12 hours
thunderhub_tor_server_1 Up 12 hours
thunderhub_web_1 Up 12 hours
thunderhub_app_proxy_1 Up 12 hours
nginx Up 12 hours
auth Up 12 hours
tor_proxy Up 12 hours
dashboard Up 12 hours
tor_server Up 12 hours
manager Up 12 hours
Umbrel logs
Attaching to manager
manager | ::ffff:10.21.21.2 - - [Tue, 18 Jul 2023 16:36:17 GMT] "GET /v1/system/debug-result HTTP/1.0" 304 - "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/16.5.2 Safari/605.1.15"
manager |
manager | umbrel-manager
manager | ::ffff:10.21.21.2 - - [Tue, 18 Jul 2023 16:36:18 GMT] "GET /v1/system/debug-result HTTP/1.0" 304 - "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/16.5.2 Safari/605.1.15"
manager |
manager | ::ffff:10.21.21.2 - - [Tue, 18 Jul 2023 16:36:19 GMT] "GET /v1/system/debug-result HTTP/1.0" 304 - "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/16.5.2 Safari/605.1.15"
manager |
manager | ::ffff:10.21.21.2 - - [Tue, 18 Jul 2023 16:36:20 GMT] "GET /v1/system/debug-result HTTP/1.0" 304 - "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/16.5.2 Safari/605.1.15"
manager |
manager | ::ffff:10.21.21.2 - - [Tue, 18 Jul 2023 16:36:21 GMT] "GET /v1/system/debug-result HTTP/1.0" 304 - "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/16.5.2 Safari/605.1.15"
manager |
manager | ::ffff:10.21.21.2 - - [Tue, 18 Jul 2023 16:36:22 GMT] "GET /v1/system/debug-result HTTP/1.0" 304 - "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/16.5.2 Safari/605.1.15"
manager |
manager | ::ffff:10.21.21.2 - - [Tue, 18 Jul 2023 16:36:23 GMT] "GET /v1/system/debug-result HTTP/1.0" 304 - "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/16.5.2 Safari/605.1.15"
manager |
manager | ::ffff:10.21.21.2 - - [Tue, 18 Jul 2023 16:36:24 GMT] "GET /v1/system/debug-result HTTP/1.0" 304 - "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/16.5.2 Safari/605.1.15"
manager |
manager | ::ffff:10.21.21.2 - - [Tue, 18 Jul 2023 16:36:25 GMT] "GET /v1/system/debug-result HTTP/1.0" 304 - "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/16.5.2 Safari/605.1.15"
manager |
manager | ::ffff:10.21.21.2 - - [Tue, 18 Jul 2023 16:36:26 GMT] "GET /v1/system/debug-result HTTP/1.0" 304 - "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/16.5.2 Safari/605.1.15"
manager |
Tor Proxy logs
Attaching to tor_proxy
tor_proxy | Jul 18 04:26:09.000 [notice] Bootstrapped 90% (ap_handshake_done): Handshake finished with a relay to build circuits
tor_proxy | Jul 18 04:26:09.000 [notice] Bootstrapped 95% (circuit_create): Establishing a Tor circuit
tor_proxy | Jul 18 04:26:11.000 [notice] Bootstrapped 100% (done): Done
tor_proxy | Jul 18 10:22:44.000 [notice] Heartbeat: Tor's uptime is 6:00 hours, with 0 circuits open. I've sent 1.34 MB and received 11.39 MB. I've received 1 connections on IPv4 and 0 on IPv6. I've made 27 connections with IPv4 and 0 with IPv6.
tor_proxy | Jul 18 10:22:44.000 [notice] While bootstrapping, fetched this many bytes: 636658 (consensus network-status fetch); 14102 (authority cert fetch); 9749275 (microdescriptor fetch)
tor_proxy | Jul 18 10:22:44.000 [notice] While not bootstrapping, fetched this many bytes: 133965 (consensus network-status fetch); 7100 (authority cert fetch); 15544 (microdescriptor fetch)
tor_proxy | Jul 18 15:39:58.000 [warn] Received http status code 404 ("Not found") from server 95.214.54.70:8444 while fetching "/tor/keys/fp/EFCBE720AB3A82B99F9E953CD5BF50F7EEFC7B97".
tor_proxy | Jul 18 16:22:44.000 [notice] Heartbeat: Tor's uptime is 12:00 hours, with 0 circuits open. I've sent 1.58 MB and received 11.98 MB. I've received 2 connections on IPv4 and 0 on IPv6. I've made 34 connections with IPv4 and 0 with IPv6.
tor_proxy | Jul 18 16:22:44.000 [notice] While bootstrapping, fetched this many bytes: 636658 (consensus network-status fetch); 14102 (authority cert fetch); 9749275 (microdescriptor fetch)
tor_proxy | Jul 18 16:22:44.000 [notice] While not bootstrapping, fetched this many bytes: 293903 (consensus network-status fetch); 12487 (authority cert fetch); 194494 (microdescriptor fetch)
App logs
bitcoin
Attaching to bitcoin_server_1, bitcoin_i2pd_daemon_1, bitcoin_tor_1, bitcoin_app_proxy_1, bitcoin_bitcoind_1, bitcoin_tor_server_1
bitcoind_1 | Error: Settings file could not be read:
bitcoind_1 | - Unable to parse settings file /data/.bitcoin/settings.json
i2pd_daemon_1 | 16:30:21@448/error - Garlic: Can't handle ECIES-X25519-AEAD-Ratchet message
i2pd_daemon_1 | 16:30:23@448/error - Garlic: Can't handle ECIES-X25519-AEAD-Ratchet message
i2pd_daemon_1 | 16:30:56@448/error - Garlic: Can't handle ECIES-X25519-AEAD-Ratchet message
i2pd_daemon_1 | 16:33:26@661/error - Tunnel: Tunnel with id 1329609449 already exists
app_proxy_1 | Validating token: f4d50064c841 ...
app_proxy_1 | [HPM] Error occurred while proxying request umbrel.local:2100/v1/bitcoind/info/status to http://10.21.22.2:3005/ [ECONNRESET] (https://nodejs.org/api/errors.html#errors_common_system_errors)
server_1 | umbrel-middleware
server_1 | ::ffff:10.21.0.4 - - [Tue, 18 Jul 2023 16:34:11 GMT] "GET /v1/bitcoind/info/status HTTP/1.1" 304 - "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/16.5.2 Safari/605.1.15"
server_1 |
server_1 | ::ffff:10.21.0.4 - - [Tue, 18 Jul 2023 16:36:13 GMT] "GET /v1/bitcoind/info/status HTTP/1.1" - - "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/16.5.2 Safari/605.1.15"
server_1 |
server_1 | ::ffff:10.21.0.4 - - [Tue, 18 Jul 2023 16:36:15 GMT] "GET /v1/bitcoind/info/status HTTP/1.1" 200 21 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/16.5.2 Safari/605.1.15"
server_1 |
tor_1 | Jul 18 10:25:20.000 [notice] While bootstrapping, fetched this many bytes: 636658 (consensus network-status fetch); 14102 (authority cert fetch); 9749275 (microdescriptor fetch)
tor_1 | Jul 18 10:25:20.000 [notice] While not bootstrapping, fetched this many bytes: 127498 (consensus network-status fetch); 5322 (authority cert fetch); 86978 (microdescriptor fetch)
tor_1 | Jul 18 10:54:47.000 [notice] No circuits are opened. Relaxed timeout for circuit 526 (a Hidden service: Uploading HS descriptor 4-hop circuit in state doing handshakes with channel state open) to 60000ms. However, it appears the circuit has timed out anyway. [2 similar message(s) suppressed in last 10980 seconds]
tor_1 | Jul 18 11:57:42.000 [notice] Your network connection speed appears to have changed. Resetting timeout to 60000ms after 18 timeouts and 240 buildtimes.
tor_1 | Jul 18 15:24:42.000 [warn] Received http status code 404 ("Not found") from server 162.19.171.180:9000 while fetching "/tor/keys/fp/EFCBE720AB3A82B99F9E953CD5BF50F7EEFC7B97".
tor_1 | Jul 18 16:25:20.000 [notice] Heartbeat: Tor's uptime is 12:00 hours, with 15 circuits open. I've sent 11.04 MB and received 18.15 MB. I've received 0 connections on IPv4 and 0 on IPv6. I've made 10 connections with IPv4 and 0 with IPv6.
tor_1 | Jul 18 16:25:20.000 [notice] While bootstrapping, fetched this many bytes: 636658 (consensus network-status fetch); 14102 (authority cert fetch); 9749275 (microdescriptor fetch)
tor_1 | Jul 18 16:25:20.000 [notice] While not bootstrapping, fetched this many bytes: 285536 (consensus network-status fetch); 10707 (authority cert fetch); 207574 (microdescriptor fetch)
electrs
Attaching to electrs_app_1, electrs_electrs_1, electrs_tor_server_1, electrs_tor_1, electrs_app_proxy_1
app_1 | > umbrel-electrs@1.0.1 dev:backend
app_1 | > npm run start -w umbrel-electrs-backend
app_1 |
app_1 |
app_1 | > umbrel-electrs-backend@0.1.12 start
app_1 | > node ./bin/www
app_1 |
app_1 | Tue, 18 Jul 2023 04:27:33 GMT morgan deprecated morgan(options): use morgan("default", options) instead at app.js:28:9
app_1 | Tue, 18 Jul 2023 04:27:33 GMT morgan deprecated default format: use combined format at app.js:28:9
app_1 | Listening on port 3006
electrs_1 | Starting electrs 0.9.14 on aarch64 linux with Config { network: Bitcoin, db_path: "/data/db/bitcoin", daemon_dir: "/data/.bitcoin", daemon_auth: CookieFile("/data/.bitcoin/.cookie"), daemon_rpc_addr: 10.21.21.8:8332, daemon_p2p_addr: 10.21.21.8:8333, electrum_rpc_addr: 0.0.0.0:50001, monitoring_addr: 127.0.0.1:4224, wait_duration: 10s, jsonrpc_timeout: 15s, index_batch_size: 10, index_lookup_limit: None, reindex_last_blocks: 0, auto_reindex: true, ignore_mempool: false, sync_once: false, skip_block_download_wait: false, disable_electrum_rpc: false, server_banner: "Umbrel Electrs (0.9.14)", signet_magic: f9beb4d9, args: [] }
electrs_1 | [2023-07-18T16:36:12.510Z INFO electrs::metrics::metrics_impl] serving Prometheus metrics on 127.0.0.1:4224
electrs_1 | [2023-07-18T16:36:12.510Z INFO electrs::server] serving Electrum RPC on 0.0.0.0:50001
electrs_1 | [2023-07-18T16:36:12.879Z INFO electrs::db] "/data/db/bitcoin": 2271 SST files, 0.001828155 GB, 0.000000021 Grows
electrs_1 | [2023-07-18T16:36:12.951Z INFO electrs::db] closing DB at /data/db/bitcoin
electrs_1 | Error: electrs failed
electrs_1 |
electrs_1 | Caused by:
electrs_1 | 0: failed to open bitcoind cookie file: /data/.bitcoin/.cookie
electrs_1 | 1: No such file or directory (os error 2)
app_proxy_1 | [HPM] Proxy created: / -> http://10.21.22.4:3006
app_proxy_1 | Waiting for 10.21.22.4:3006 to open...
app_proxy_1 | Electrs is now ready...
app_proxy_1 | Listening on port: 2102
tor_1 | Jul 18 07:37:47.000 [notice] No circuits are opened. Relaxed timeout for circuit 206 (a Hidden service: Uploading HS descriptor 4-hop circuit in state doing handshakes with channel state open) to 60000ms. However, it appears the circuit has timed out anyway.
tor_1 | Jul 18 10:25:18.000 [notice] Heartbeat: Tor's uptime is 6:00 hours, with 10 circuits open. I've sent 3.88 MB and received 14.35 MB. I've received 0 connections on IPv4 and 0 on IPv6. I've made 15 connections with IPv4 and 0 with IPv6.
tor_1 | Jul 18 10:25:18.000 [notice] While bootstrapping, fetched this many bytes: 636658 (consensus network-status fetch); 14102 (authority cert fetch); 9749275 (microdescriptor fetch)
tor_1 | Jul 18 10:25:18.000 [notice] While not bootstrapping, fetched this many bytes: 133869 (consensus network-status fetch); 7104 (authority cert fetch); 86772 (microdescriptor fetch)
tor_1 | Jul 18 14:28:51.000 [notice] No circuits are opened. Relaxed timeout for circuit 428 (a Hidden service: Uploading HS descriptor 4-hop circuit in state doing handshakes with channel state open) to 60000ms. However, it appears the circuit has timed out anyway. [1 similar message(s) suppressed in last 24720 seconds]
tor_1 | Jul 18 16:25:18.000 [notice] Heartbeat: Tor's uptime is 12:00 hours, with 25 circuits open. I've sent 7.15 MB and received 17.77 MB. I've received 0 connections on IPv4 and 0 on IPv6. I've made 17 connections with IPv4 and 0 with IPv6.
tor_1 | Jul 18 16:25:18.000 [notice] While bootstrapping, fetched this many bytes: 636658 (consensus network-status fetch); 14102 (authority cert fetch); 9749275 (microdescriptor fetch)
tor_1 | Jul 18 16:25:18.000 [notice] While not bootstrapping, fetched this many bytes: 325111 (consensus network-status fetch); 14208 (authority cert fetch); 262690 (microdescriptor fetch)
lightning
Attaching to lightning_app_proxy_1, lightning_app_1, lightning_tor_1, lightning_lnd_1, lightning_tor_server_1
app_proxy_1 | [HPM] Proxy created: / -> http://10.21.22.3:3006
app_proxy_1 | Waiting for 10.21.22.3:3006 to open...
app_proxy_1 | Lightning Node is now ready...
app_proxy_1 | Listening on port: 2101
app_1 | Waiting for LND...
app_1 | Checking LND status...
app_1 | [backup-monitor] Checking channel backup...
app_1 | [backup-monitor] Error: ENOENT: no such file or directory, open '/data/.lnd/data/chain/bitcoin/mainnet/channel.backup'
app_1 | [backup-monitor] Sleeping...
tor_1 | Jul 18 12:09:00.000 [warn] Received http status code 404 ("Not found") from server 77.73.69.128:443 while fetching "/tor/keys/fp/EFCBE720AB3A82B99F9E953CD5BF50F7EEFC7B97".
tor_1 | Jul 18 14:18:05.000 [notice] No circuits are opened. Relaxed timeout for circuit 685 (a Hidden service: Uploading HS descriptor 4-hop circuit in state doing handshakes with channel state open) to 60000ms. However, it appears the circuit has timed out anyway. [3 similar message(s) suppressed in last 20760 seconds]
tor_1 | Jul 18 15:20:01.000 [warn] Received http status code 404 ("Not found") from server 77.73.69.128:443 while fetching "/tor/keys/fp/EFCBE720AB3A82B99F9E953CD5BF50F7EEFC7B97".
tor_1 | Jul 18 16:23:02.000 [warn] Received http status code 404 ("Not found") from server 77.73.69.128:443 while fetching "/tor/keys/fp/EFCBE720AB3A82B99F9E953CD5BF50F7EEFC7B97".
tor_1 | Jul 18 16:24:06.000 [notice] No circuits are opened. Relaxed timeout for circuit 822 (a Hidden service: Uploading HS descriptor 4-hop circuit in state doing handshakes with channel state open) to 60000ms. However, it appears the circuit has timed out anyway. [1 similar message(s) suppressed in last 7560 seconds]
tor_1 | Jul 18 16:25:18.000 [notice] Heartbeat: Tor's uptime is 11:59 hours, with 52 circuits open. I've sent 10.99 MB and received 18.64 MB. I've received 0 connections on IPv4 and 0 on IPv6. I've made 16 connections with IPv4 and 0 with IPv6.
tor_1 | Jul 18 16:25:18.000 [notice] While bootstrapping, fetched this many bytes: 636658 (consensus network-status fetch); 14102 (authority cert fetch); 9750648 (microdescriptor fetch)
tor_1 | Jul 18 16:25:18.000 [notice] While not bootstrapping, fetched this many bytes: 337022 (consensus network-status fetch); 10896 (authority cert fetch); 257534 (microdescriptor fetch)
lnd_1 | 2023-07-18 04:21:36.297 [INF] RPCS: RPC server listening on 0.0.0.0:10009
lnd_1 | 2023-07-18 04:21:37.262 [INF] RPCS: gRPC proxy started at 0.0.0.0:8080
lnd_1 | 2023-07-18 04:21:37.262 [INF] LTND: Opening the main database, this might take a few minutes...
lnd_1 | 2023-07-18 04:21:37.262 [INF] LTND: Opening bbolt database, sync_freelist=false, auto_compact=false
lnd_1 | 2023-07-18 04:21:38.328 [INF] LTND: Creating local graph and channel state DB instances
lnd_1 | 2023-07-18 04:21:39.070 [INF] CHDB: Checking for schema update: latest_version=29, db_version=29
lnd_1 | 2023-07-18 04:21:39.070 [INF] CHDB: Checking for optional update: prune_revocation_log=false, db_version=empty
lnd_1 | 2023-07-18 04:21:39.070 [INF] LTND: Database(s) now open (time_to_open=1.807853776s)!
lnd_1 | 2023-07-18 04:21:39.070 [INF] LTND: We're not running within systemd or the service type is not 'notify'
lnd_1 | 2023-07-18 04:21:39.071 [INF] LTND: Waiting for wallet encryption password. Use `lncli create` to create a wallet, `lncli unlock` to unlock an existing wallet, or `lncli changepassword` to change the password of an existing wallet and unlock it.
thunderhub
Attaching to thunderhub_tor_server_1, thunderhub_web_1, thunderhub_app_proxy_1
app_proxy_1 | [HPM] Proxy created: / -> http://thunderhub_web_1:3000
app_proxy_1 | Waiting for thunderhub_web_1:3000 to open...
app_proxy_1 | ThunderHub is now ready...
app_proxy_1 | Listening on port: 3000
web_1 | message: 'Initiating subscriptions failed: ',
web_1 | timestamp: '2023-07-18T04:28:08.458Z'
web_1 | }
web_1 | {
web_1 | context: 'NestApplication',
web_1 | level: 'info',
web_1 | message: 'Nest application successfully started',
web_1 | timestamp: '2023-07-18T04:28:08.463Z'
web_1 | }
web_1 | Application is running on: http://[::1]:3000
==== Result ====
