Umbrel Node Stuck in Block Loop
Hello everyone,
So I have just recently installed umbrel and began syncing the blockchain in order to setup my own Bitcoin node. However, when I reached around 380GB of data, the sync began looping through blocks. I restarted the container and the machine to no avail. I have tried the troubleshooting guide and removed peers.dat and even reindex=1 after I noticed that I was get messages indicating the chain was corrupt. However, each time either the sync started looping, or the container got stuck in a boot loop. This has happened three times and I am very confused. Any ideas? Should I try a complete fresh install of Umbrel? I have included a copy of my machine logs and the bitcoin app logs. Thanks!
0.5.4
Mem:             15G        1.0G        558M         17M         14G         14G
Swap:           4.1G        331M        3.8G
total: 6.4%
system: 3.7%
bitcoin: 1%
ghostfolio: 0.8%
uptime-kuma: 0.7%
tailscale: 0.2%
Memory monitor logs
2023-08-14 22:32:05 Memory monitor running!
2023-08-14 22:52:35 Memory monitor running!
   1127 ?        R      0:00 bash ./scripts/memory-monitor
   1128 ?        R      0:00 bash ./scripts/memory-monitor
   1129 ?        R      0:00 bash ./scripts/memory-monitor
   1130 ?        R      0:00 bash ./scripts/memory-monitor
2023-08-15 03:09:41 Memory monitor running!
2023-08-15 12:02:08 Memory monitor running!
2023-08-15 12:06:43 Memory monitor running!
Filesystem                         Size  Used Avail Use% Mounted on
/dev/mapper/ubuntu--vg-ubuntu--lv  914G  145G  731G  17% /
Karen logs
Saving app ghostfolio in DB...
Successfully installed app ghostfolio
Got signal: debug
karen is getting triggered!
Debug result file generated
Got signal: debug
Got signal: change-password
This script must only be run on Umbrel OS
Got signal: debug
Got signal: debug
Got signal: debug
Got signal: backup
Deriving keys...
Creating backup...
Adding random padding...
1+0 records in
1+0 records out
8587 bytes (8.6 kB, 8.4 KiB) copied, 0.00020626 s, 41.6 MB/s
Creating encrypted tarball...
backup/
backup/.padding
Uploading backup...
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
  0     0    0     0    0     0      0      0 --:--:--  0:00:01 --:--:--     0
  0     0    0     0    0     0      0      0 --:--:--  0:00:02 --:--:--     0
100  9272  100   146  100  9126     48   3043  0:00:03  0:00:02  0:00:01  3091
100  9272  100   146  100  9126     48   3042  0:00:03  0:00:02  0:00:01  3090
{"message":"Successfully uploaded backup 1692134088705.tar.gz.pgp for backup ID bc81dc59e68b5fc9a2333db2f40bd1321cb3798f37946e4ad10d369e79abdfce"}
====== Backup success =======
Got signal: debug
Docker containers
NAMES                     STATUS
ghostfolio_server_1       Up 9 hours
ghostfolio_redis_1        Up 9 hours
ghostfolio_postgres_1     Up 9 hours
ghostfolio_app_proxy_1    Up 9 hours
bitcoin_server_1          Up 10 hours
bitcoin_bitcoind_1        Up 2 seconds
bitcoin_i2pd_daemon_1     Up 10 hours
bitcoin_app_proxy_1       Up 10 hours
bitcoin_tor_1             Up 10 hours
uptime-kuma_server_1      Up 10 hours (healthy)
uptime-kuma_app_proxy_1   Up 10 hours
tailscale_web_1           Up 10 hours
nginx                     Up 10 hours
manager                   Up 10 hours
tor_proxy                 Up 10 hours
auth                      Up 10 hours
dashboard                 Up 10 hours
Umbrel logs
Attaching to manager
manager      | ::ffff:10.21.0.4 - - [Tue, 15 Aug 2023 21:43:11 GMT] "GET /v1/account/token?token=925593d138dbe0deb083b9001038d018e1a6e5dcc8e62063ef2c4c0127bf5892 HTTP/1.1" 200 16 "-" "app-proxy/0.0.1"
manager      |
manager      | umbrel-manager
manager      |
manager      | ::ffff:10.21.21.2 - - [Tue, 15 Aug 2023 21:43:12 GMT] "GET /v1/system/debug-result HTTP/1.0" 304 - "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/115.0.0.0 Safari/537.36"
manager      |
manager      | ::ffff:10.21.21.2 - - [Tue, 15 Aug 2023 21:43:12 GMT] "GET /v1/apps?installed=1 HTTP/1.0" 304 - "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/115.0.0.0 Safari/537.36"
manager      |
manager      | ::ffff:10.21.21.2 - - [Tue, 15 Aug 2023 21:43:12 GMT] "GET /v1/apps HTTP/1.0" 304 - "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/115.0.0.0 Safari/537.36"
manager      |
manager      | ::ffff:10.21.21.2 - - [Tue, 15 Aug 2023 21:43:12 GMT] "GET /v1/system/storage HTTP/1.0" 200 619 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/115.0.0.0 Safari/537.36"
manager      |
manager      | ::ffff:10.21.21.2 - - [Tue, 15 Aug 2023 21:43:12 GMT] "GET /v1/system/memory HTTP/1.0" 304 - "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/115.0.0.0 Safari/537.36"
manager      |
manager      | ::ffff:10.21.0.4 - - [Tue, 15 Aug 2023 21:43:12 GMT] "GET /v1/account/token?token=925593d138dbe0deb083b9001038d018e1a6e5dcc8e62063ef2c4c0127bf5892 HTTP/1.1" 200 16 "-" "app-proxy/0.0.1"
manager      |
manager      | ::ffff:10.21.21.2 - - [Tue, 15 Aug 2023 21:43:12 GMT] "GET /v1/system/get-update HTTP/1.0" 304 - "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/115.0.0.0 Safari/537.36"
manager      |
manager      | ::ffff:10.21.21.2 - - [Tue, 15 Aug 2023 21:43:13 GMT] "GET /v1/system/debug-result HTTP/1.0" 304 - "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/115.0.0.0 Safari/537.36"
manager      |
Tor Proxy logs
Attaching to tor_proxy
tor_proxy    | Aug 15 12:07:19.000 [notice] Bootstrapped 80% (ap_conn): Connecting to a relay to build circuits
tor_proxy    | Aug 15 12:07:19.000 [notice] Bootstrapped 85% (ap_conn_done): Connected to a relay to build circuits
tor_proxy    | Aug 15 12:07:19.000 [notice] Bootstrapped 89% (ap_handshake): Finishing handshake with a relay to build circuits
tor_proxy    | Aug 15 12:07:19.000 [notice] Bootstrapped 90% (ap_handshake_done): Handshake finished with a relay to build circuits
tor_proxy    | Aug 15 12:07:19.000 [notice] Bootstrapped 95% (circuit_create): Establishing a Tor circuit
tor_proxy    | Aug 15 12:07:20.000 [notice] Bootstrapped 100% (done): Done
tor_proxy    | Aug 15 17:19:17.000 [warn] Received http status code 404 ("Not found") from server 92.205.129.7:21 while fetching "/tor/keys/fp/EFCBE720AB3A82B99F9E953CD5BF50F7EEFC7B97".
tor_proxy    | Aug 15 18:07:11.000 [notice] Heartbeat: Tor's uptime is 6:00 hours, with 0 circuits open. I've sent 1.14 MB and received 12.67 MB. I've received 0 connections on IPv4 and 0 on IPv6. I've made 11 connections with IPv4 and 0 with IPv6.
tor_proxy    | Aug 15 18:07:11.000 [notice] While bootstrapping, fetched this many bytes: 679838 (consensus network-status fetch); 14104 (authority cert fetch); 11224359 (microdescriptor fetch)
tor_proxy    | Aug 15 18:07:11.000 [notice] While not bootstrapping, fetched this many bytes: 159952 (consensus network-status fetch); 5388 (authority cert fetch)
App logs
bitcoin
Attaching to bitcoin_server_1, bitcoin_bitcoind_1, bitcoin_i2pd_daemon_1, bitcoin_app_proxy_1, bitcoin_tor_1
bitcoind_1     | 2023-08-15T21:43:11Z * Using 610.1 MiB for transaction index database
bitcoind_1     | 2023-08-15T21:43:11Z * Using 533.9 MiB for basic block filter index database
bitcoind_1     | 2023-08-15T21:43:11Z * Using 8.0 MiB for chain state database
bitcoind_1     | 2023-08-15T21:43:11Z * Using 3729.0 MiB for in-memory UTXO set (plus up to 286.1 MiB of unused mempool space)
bitcoind_1     | 2023-08-15T21:43:11Z init message: Loading block index…
bitcoind_1     | 2023-08-15T21:43:11Z Assuming ancestors of block 000000000000000000035c3f0d31e71a5ee24c5aaf3354689f65bd7b07dee632 have valid signatures.
bitcoind_1     | 2023-08-15T21:43:11Z Setting nMinimumChainWork=000000000000000000000000000000000000000044a50fe819c39ad624021859
bitcoind_1     | 2023-08-15T21:43:11Z Opening LevelDB in /data/.bitcoin/blocks/index
bitcoind_1     | 2023-08-15T21:43:11Z Opened LevelDB successfully
bitcoind_1     | 2023-08-15T21:43:11Z Using obfuscation key for /data/.bitcoin/blocks/index: 0000000000000000
i2pd_daemon_1  | 21:07:44@140/error - Garlic: Can't handle ECIES-X25519-AEAD-Ratchet message
i2pd_daemon_1  | 21:11:57@94/error - Garlic: Can't handle ECIES-X25519-AEAD-Ratchet message
i2pd_daemon_1  | 21:12:28@94/error - Garlic: Can't handle ECIES-X25519-AEAD-Ratchet message
i2pd_daemon_1  | 21:21:43@94/error - Garlic: Can't handle ECIES-X25519-AEAD-Ratchet message
i2pd_daemon_1  | 21:27:02@880/error - SSU2: RelayIntro unknown router to introduce
i2pd_daemon_1  | 21:29:54@880/error - SSU2: RelayIntro unknown router to introduce
i2pd_daemon_1  | 21:31:51@849/error - Tunnel: Tunnel with id 549600294 already exists
i2pd_daemon_1  | 21:31:52@849/error - Tunnel: Tunnel with id 549600294 already exists
i2pd_daemon_1  | 21:35:28@94/error - Garlic: Can't handle ECIES-X25519-AEAD-Ratchet message
i2pd_daemon_1  | 21:38:04@140/error - Garlic: Can't handle ECIES-X25519-AEAD-Ratchet message
server_1       | BitcoindError: Unable to obtain peer info
server_1       |     at /app/services/bitcoind.js:23:18
server_1       |     at IncomingMessage.<anonymous> (/app/node_modules/bitcoind-rpc/lib/index.js:107:7)
server_1       |     at IncomingMessage.emit (events.js:326:22)
server_1       |     at endReadableNT (_stream_readable.js:1241:12)
server_1       |     at /app/node_modules/async-listener/glue.js:188:31
server_1       |     at processTicksAndRejections (internal/process/task_queues.js:84:21)
server_1       | ::ffff:10.21.0.4 - - [Tue, 15 Aug 2023 21:43:14 GMT] "GET /v1/bitcoind/info/sync HTTP/1.1" 500 28 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/115.0.0.0 Safari/537.36"
server_1       |
server_1       | umbrel-middleware
tor_1          | Aug 15 12:09:33.000 [notice] Bootstrapped 89% (ap_handshake): Finishing handshake with a relay to build circuits
tor_1          | Aug 15 12:09:34.000 [notice] Bootstrapped 90% (ap_handshake_done): Handshake finished with a relay to build circuits
tor_1          | Aug 15 12:09:34.000 [notice] Bootstrapped 95% (circuit_create): Establishing a Tor circuit
tor_1          | Aug 15 12:09:35.000 [notice] Bootstrapped 100% (done): Done
tor_1          | Aug 15 15:46:32.000 [notice] No circuits are opened. Relaxed timeout for circuit 359 (a Hidden service: Uploading HS descriptor 4-hop circuit in state doing handshakes with channel state open) to 60000ms. However, it appears the circuit has timed out anyway.
tor_1          | Aug 15 18:09:25.000 [notice] Heartbeat: Tor's uptime is 6:00 hours, with 15 circuits open. I've sent 6.11 MB and received 16.46 MB. I've received 0 connections on IPv4 and 0 on IPv6. I've made 11 connections with IPv4 and 0 with IPv6.
tor_1          | Aug 15 18:09:25.000 [notice] While bootstrapping, fetched this many bytes: 679838 (consensus network-status fetch); 14357 (authority cert fetch); 11224359 (microdescriptor fetch)
tor_1          | Aug 15 18:09:25.000 [notice] While not bootstrapping, fetched this many bytes: 136874 (consensus network-status fetch); 7100 (authority cert fetch); 221084 (microdescriptor fetch)
tor_1          | Aug 15 20:10:33.000 [notice] No circuits are opened. Relaxed timeout for circuit 613 (a Hidden service: Uploading HS descriptor 4-hop circuit in state doing handshakes with channel state open) to 60000ms. However, it appears the circuit has timed out anyway. [1 similar message(s) suppressed in last 15840 seconds]
app_proxy_1    | Validating token: 925593d138db ...
Can you also share the output of this command too to double check:
~/umbrel/scripts/app compose bitcoin logs --tail 600
And can paste it to www.pastebin.com and share a link, as it will be a very long text either way
Once we added reindex=1 as well, if we reboot during this it will restart the process,
Let me know what else you’ve tried so far and the longer Bitcoin log and happy to help!
Sure! Here is the pastebin link. Traceback (most recent call last): File "/usr/lib/python3/dist-packages/urlli - Pastebin.com
My behavior has changed slightly. I was looking through the debug.log file and noticed that right before the loop began and error was shown indicating corrupt blockchain. So, I tried one more to to enter “reindex=1” to the bitcoin.conf file. Everything seemed fine but when I woke up this morning the container is stuck bootlooping. This pastebin is from the bootloop state not the block loop, however, I think they are closely related. Thank you for your help!
Hi @Megastrik3, sorry to hear this is happening, initial sync can be a bit troublesome sometimes. Another strategy to tackle this is enabling the following settings before reindexing again :sweat_smile: This should help, and may also speed up the sync.
Let me know if you have any questions
Thanks for your response @smolgrrr smolgrrr, I have tried enabling those settings except “Incoming Connections.” However, I found something else. I ran some memory tests on my device and discovered that I have a bad RAM stick. I have just started a reindex and will report back my findings. If that doesn’t work I will enable those settings and try again. I greatly appreciate the help!
Makes sense, good luck :slight_smile:
Problem solved! After much frustration, I ran a bios diagnostic on my machine and discovered that one of the sticks of RAM was bad. After I removed it, I uninstalled and reinstalled the bitcoin app and afterwards the sync finished without any issues. Hopefully this is helpful to anyone else having issues with their node! Thanks for all your help!
I have this exact same issue…What did you do to diagnose the RAM stick? I assume this wasn’t on a raspberry pi?
Correct, this was on a mini Lenovo PC. I booted into the BIOS and ran a system test and a memory test. The memory test came back as failed for one of the RAM sticks.
