Starting Umbrel Issue
I am stuck on this screen. Ho long should it be loading? I have been waiting a couple hours.
same here…
My Raspi4 crashed… Just got a new one and plugged the disk to it… I try to start again (newst version of Umbrel) and got this when I run debug commands Can you help me… Or point me to someone? thanks
here is the debug output
Sep 20 20:02:48 umbrel systemd[1]: umbrel-startup.service: Failed with result ‘exit-code’.
Sep 20 20:02:48 umbrel systemd[1]: Failed to start Umbrel Startup Service.
Sep 20 20:02:58 umbrel systemd[1]: umbrel-startup.service: Service RestartSec=10s expired, scheduling restart.
Sep 20 20:02:58 umbrel systemd[1]: umbrel-startup.service: Scheduled restart job, restart counter is at 87.
Sep 20 20:02:58 umbrel systemd[1]: Stopped Umbrel Startup Service.
Sep 20 20:02:58 umbrel systemd[1]: Starting Umbrel Startup Service…
Sep 20 20:02:58 umbrel umbrel startup[27283]: ======================================
Sep 20 20:02:58 umbrel umbrel startup[27283]: ============ CONFIGURING =============
Sep 20 20:02:58 umbrel umbrel startup[27283]: ========= UMBREL (mainnet) ===========
Sep 20 20:03:01 umbrel umbrel startup[27283]: Skipping lnd.conf update to preserve user changes…
Sep 20 20:03:01 umbrel umbrel startup[27283]: Generating hidden services…
Sep 20 20:03:03 umbrel umbrel startup[27283]: stat /var/lib/docker/overlay2/6c457c36eedf94f0e93b098fb8d91d842e9fa94becfb45aa3449dcb38b37fa97: no such file or directory
Sep 20 20:03:03 umbrel systemd[1]: umbrel-startup.service: Control process exited, code=exited, status=1/FAILURE
Sep 20 20:03:03 umbrel systemd[1]: umbrel-startup.service: Failed with result ‘exit-code’.
Sep 20 20:03:03 umbrel systemd[1]: Failed to start Umbrel Startup Service.
Sep 20 20:03:13 umbrel systemd[1]: umbrel-startup.service: Service RestartSec=10s expired, scheduling restart.
Sep 20 20:03:13 umbrel systemd[1]: umbrel-startup.service: Scheduled restart job, restart counter is at 88.
Sep 20 20:03:13 umbrel systemd[1]: Stopped Umbrel Startup Service.
Sep 20 20:03:13 umbrel systemd[1]: Starting Umbrel Startup Service…
Sep 20 20:03:13 umbrel umbrel startup[28324]: ======================================
Sep 20 20:03:13 umbrel umbrel startup[28324]: ============ CONFIGURING =============
Sep 20 20:03:13 umbrel umbrel startup[28324]: ========= UMBREL (mainnet) ===========
Sep 20 20:03:16 umbrel umbrel startup[28324]: Skipping lnd.conf update to preserve user changes…
Sep 20 20:03:16 umbrel umbrel startup[28324]: Generating hidden services…
Sep 20 20:03:18 umbrel umbrel startup[28324]: stat /var/lib/docker/overlay2/6c457c36eedf94f0e93b098fb8d91d842e9fa94becfb45aa3449dcb38b37fa97: no such file or directory
Sep 20 20:03:18 umbrel systemd[1]: umbrel-startup.service: Control process exited, code=exited, status=1/FAILURE
Sep 20 20:03:18 umbrel systemd[1]: umbrel-startup.service: Failed with result ‘exit-code’.
Sep 20 20:03:18 umbrel systemd[1]: Failed to start Umbrel Startup Service.
I tried another SD case, a different SD card, flashed many times, still am stuck on the loading screen since hours. I am stuck. Also would love some advice.
