Starting New Services, Running Migrations, or Stuck Starting/Failed Update Screen
If you received one of these screens and it’s not changing:
Then first, it’s OK to try navigate away from the page after a few mins and reload a new tab, to see if your dashboard is now accessible.
If it’s still not accessible, we can follow steps on How to SSH here and try to simply reboot with command:
sudo reboot
If issues persist or it’s one of these screens we can continue:
Firstly can we confirm are we using an official Raspberry Pi 4 Power Supply?
It’s identified these issues are caused by intermittent power, or an interruption during update, or commonly a MicroSD card that is now full due to a corruption,
Often there can be other corruptions related to various hardware setups, or if there is an underlying issue we can work to debug it and resolve to get you up and running ASAP!
And specifically, a root cause we identified for the issue is if you’re running out of space on the MicroSD card - it may not be clear this is occurring but it’s usually due to a MicroSD card that has been in use for a longer duration,
If you’re on Pi 4 you can follow steps to reflash, no data is lost when reflashing:
If reflashing has not helped then we can move on to providing the output of these logs:
sudo ~/umbrel/scripts/debug
If you can provide both the debug log and the output of this command too this helps us resolve these issues:
tail -n 100 ~/umbrel/logs/karen.log
You can paste them each to their own text file and provide them here, or via www.pastebin.com and share a link here, or in the Telegram for review
Or feel free to conveniently contact us on an of our support channels you prefer detailing the issue: https://www.umbrel.com/support
Feel free to post below and ping me or in the Telegram same name @usernameisJim and happy to assist getting you updated
Hi @usernameisJim , I’m stuck on an upload
0.5.4
Flashed OS version
v0.5.4-patch-1
Raspberry Pi Model
Revision : d03114
Serial : 100000001fdceb78
Firmware
May 9 2023 12:16:34
Copyright (c) 2012 Broadcom
Temperature
temp=51.6’C
Throttling
throttled=0x0
Mem: 7.8G 1.7G 129M 10M 6.0G 6.0G
Swap: 4.1G 9.0M 4.1G
total: 21.7%
bitcoin: 10.6%
lightning: 9.9%
ride-the-lightning: 2.9%
lightning-terminal: 2.3%
system: 0%
Memory monitor logs
2024-02-08 05:49:06 Memory monitor running!
2024-02-09 06:42:31 Memory monitor running!
2024-02-09 07:06:03 Memory monitor running!
2024-02-09 07:33:19 Memory monitor running!
2024-02-09 07:38:33 Memory monitor running!
2024-02-09 23:06:43 Memory monitor running!
2024-02-09 23:34:45 Memory monitor running!
2024-02-09 23:54:03 Memory monitor running!
2024-02-10 00:08:55 Memory monitor running!
/dev/root 30G 3.6G 25G 13% /
/dev/sda1 916G 655G 215G 76% /home/umbrel/umbrel
Startup service logs
Feb 10 00:09:26 umbrel umbrel startup[1073]: Creating lightning-terminal_app_proxy_1 …
Feb 10 00:09:26 umbrel umbrel startup[1073]: Creating lightning_app_1 …
Feb 10 00:09:26 umbrel umbrel startup[1073]: Creating lightning-terminal_web_1 …
Feb 10 00:09:26 umbrel umbrel startup[1073]: Creating lightning_tor_1 …
Feb 10 00:09:26 umbrel umbrel startup[1073]: Creating lightning_app_proxy_1 …
Feb 10 00:09:26 umbrel umbrel startup[1073]: Creating lightning-terminal_tor_server_1 …
Feb 10 00:09:28 umbrel umbrel startup[1073]: Creating ride-the-lightning_boltz_1 … done
Feb 10 00:09:29 umbrel umbrel startup[1073]: Creating ride-the-lightning_web_1 … done
Feb 10 00:09:29 umbrel umbrel startup[1073]: Creating ride-the-lightning_tor_server_1 … done
Feb 10 00:09:29 umbrel umbrel startup[1073]: Creating ride-the-lightning_app_proxy_1 … done
Feb 10 00:09:30 umbrel umbrel startup[1073]: Creating bitcoin_i2pd_daemon_1 … done
Feb 10 00:09:30 umbrel umbrel startup[1073]: Creating bitcoin_app_proxy_1 … done
Feb 10 00:09:31 umbrel umbrel startup[1073]: Creating bitcoin_tor_server_1 … done
Feb 10 00:09:31 umbrel umbrel startup[1073]: Creating lightning-terminal_web_1 … done
Feb 10 00:09:31 umbrel umbrel startup[1073]: Creating bitcoin_tor_1 … done
Feb 10 00:09:31 umbrel umbrel startup[1073]: Creating bitcoin_bitcoind_1 … done
Feb 10 00:09:31 umbrel umbrel startup[1073]: Creating bitcoin_server_1 …
Feb 10 00:09:32 umbrel umbrel startup[1073]: Creating lightning-terminal_tor_server_1 … done
Feb 10 00:09:32 umbrel umbrel startup[1073]: Creating lightning-terminal_app_proxy_1 … done
Feb 10 00:09:32 umbrel umbrel startup[1073]: Creating lightning_tor_server_1 … done
Feb 10 00:09:32 umbrel umbrel startup[1073]: Creating lightning_app_proxy_1 … done
Feb 10 00:09:33 umbrel umbrel startup[1073]: Creating lightning_tor_1 … done
Feb 10 00:09:33 umbrel umbrel startup[1073]: Creating lightning_lnd_1 … done
Feb 10 00:09:33 umbrel umbrel startup[1073]: Creating lightning_app_1 … done
Feb 10 00:09:34 umbrel umbrel startup[1073]: Creating bitcoin_server_1 … done
Feb 10 00:09:34 umbrel umbrel startup[1073]: Umbrel is now accessible at
Feb 10 00:09:34 umbrel umbrel startup[1073]: http://umbrel.local
Feb 10 00:09:34 umbrel umbrel startup[1073]: http://192.168.1.164
Feb 10 00:09:34 umbrel systemd[1]: Started Umbrel Startup Service.
External storage service logs
Feb 10 00:08:40 umbrel external storage mounter[507]: Running external storage mount script…
Feb 10 00:08:40 umbrel external storage mounter[507]: Found device “CT1000BX 500SSD1”
Feb 10 00:08:40 umbrel external storage mounter[507]: Blacklisting USB device IDs against UAS driver…
Feb 10 00:08:41 umbrel external storage mounter[507]: Rebinding USB drivers…
Feb 10 00:08:41 umbrel external storage mounter[507]: Checking USB devices are back…
Feb 10 00:08:41 umbrel external storage mounter[507]: Waiting for USB devices…
Feb 10 00:08:42 umbrel external storage mounter[507]: Waiting for USB devices…
Feb 10 00:08:43 umbrel external storage mounter[507]: Waiting for USB devices…
Feb 10 00:08:44 umbrel external storage mounter[507]: Checking if the device is ext4…
Feb 10 00:08:44 umbrel external storage mounter[507]: Yes, it is ext4
Feb 10 00:08:44 umbrel external storage mounter[507]: Checking filesystem for corruption…
Feb 10 00:08:44 umbrel external storage mounter[507]: e2fsck 1.44.5 (15-Dec-2018)
Feb 10 00:08:44 umbrel external storage mounter[507]: umbrel: clean, 236906/61054976 files, 175652115/244190208 blocks
Feb 10 00:08:45 umbrel external storage mounter[507]: Mounting partition…
Feb 10 00:08:45 umbrel external storage mounter[507]: Checking if device contains an Umbrel install…
Feb 10 00:08:45 umbrel external storage mounter[507]: Yes, it contains an Umbrel install
Feb 10 00:08:45 umbrel external storage mounter[507]: Bind mounting external storage over local Umbrel installation…
Feb 10 00:08:45 umbrel external storage mounter[507]: Bind mounting external storage over local Docker data dir…
Feb 10 00:08:45 umbrel external storage mounter[507]: Bind mounting external storage to /swap
Feb 10 00:08:45 umbrel external storage mounter[507]: Bind mounting SD card root at /sd-card…
Feb 10 00:08:45 umbrel external storage mounter[507]: Checking Umbrel root is now on external storage…
Feb 10 00:08:46 umbrel external storage mounter[507]: Checking /var/lib/docker is now on external storage…
Feb 10 00:08:46 umbrel external storage mounter[507]: Checking /swap is now on external storage…
Feb 10 00:08:46 umbrel external storage mounter[507]: Setting up swapfile
Feb 10 00:08:46 umbrel external storage mounter[507]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
Feb 10 00:08:46 umbrel external storage mounter[507]: no label, UUID=393ec39b-718e-448a-8191-3ad9934c1a09
Feb 10 00:08:46 umbrel external storage mounter[507]: Checking SD Card root is bind mounted at /sd-root…
Feb 10 00:08:46 umbrel external storage mounter[507]: Starting external drive mount monitor…
Feb 10 00:08:46 umbrel external storage mounter[507]: Mount script completed successfully!
Feb 10 00:08:46 umbrel systemd[1]: Started External Storage Mounter.
– Logs begin at Thu 2019-02-14 10:11:58 UTC, end at Sat 2024-02-10 00:37:16 UTC. –
Feb 10 00:08:55 umbrel systemd[1]: Starting External Storage SDcard Updater…
Feb 10 00:08:55 umbrel external storage updater[996]: Checking if SD card Umbrel is newer than external storage…
Feb 10 00:08:55 umbrel external storage updater[996]: No, SD version is not newer, exiting.
Feb 10 00:08:55 umbrel systemd[1]: Started External Storage SDcard Updater.
Karen logs
Got signal: backup
karen is getting triggered!
Deriving keys…
Creating backup…
Adding random padding…
1+0 records in
1+0 records out
10224 bytes (10 kB, 10 KiB) copied, 0.000401679 s, 25.5 MB/s
Creating encrypted tarball…
backup/
backup/channel.backup
backup/.padding
gpg: directory ‘/root/.gnupg’ created
gpg: keybox ‘/root/.gnupg/pubring.kbx’ created
Uploading backup…
100 16967 100 146 100 16821 52 6092 0:00:02 0:00:02 --:–:-- 6147
{“message”:“Successfully uploaded backup 1707505771730.tar.gz.pgp for backup ID 428bb520d9a1f18e19deb9e768a7eccc00768f508a872c343db8befad26eac35”}
====== Backup success =======
Got signal:
Got signal:
Got signal:
Got signal:
Got signal:
Got signal:
Got signal:
Got signal:
Docker containers
NAMES STATUS
bitcoin_server_1 Up 27 minutes
lightning_lnd_1 Up 27 minutes
lightning-terminal_web_1 Up 28 minutes
lightning_app_proxy_1 Up 28 minutes
lightning_app_1 Up 27 minutes
lightning_tor_1 Up 27 minutes
lightning_tor_server_1 Up 28 minutes
lightning-terminal_tor_server_1 Up 28 minutes
lightning-terminal_app_proxy_1 Up 28 minutes
bitcoin_tor_server_1 Up 28 minutes
bitcoin_tor_1 Up 28 minutes
bitcoin_i2pd_daemon_1 Up 28 minutes
bitcoin_bitcoind_1 Up 28 minutes
bitcoin_app_proxy_1 Up 28 minutes
ride-the-lightning_tor_server_1 Up 28 minutes
ride-the-lightning_app_proxy_1 Up 28 minutes
ride-the-lightning_web_1 Up 28 minutes
ride-the-lightning_boltz_1 Up 28 minutes
nginx Up 28 minutes
auth Up 28 minutes
tor_server Up 28 minutes
manager Up 28 minutes
tor_proxy Up 28 minutes
dashboard Up 28 minutes
Umbrel logs
Attaching to manager
manager | ::ffff:10.21.21.2 - - [Sat, 10 Feb 2024 00:37:14 GMT] “GET /v1/system/update-status HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; rv:91.0) Gecko/20100101 Firefox/91.0”
manager |
manager | umbrel-manager
manager | ::ffff:10.21.21.2 - - [Sat, 10 Feb 2024 00:37:16 GMT] “GET /v1/system/update-status HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; rv:91.0) Gecko/20100101 Firefox/91.0”
manager |
manager | ::ffff:10.21.21.2 - - [Sat, 10 Feb 2024 00:37:19 GMT] “GET /v1/system/update-status HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; rv:91.0) Gecko/20100101 Firefox/91.0”
manager |
manager | ::ffff:10.21.21.2 - - [Sat, 10 Feb 2024 00:37:20 GMT] “GET /v1/system/update-status HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; rv:91.0) Gecko/20100101 Firefox/91.0”
manager |
manager | ::ffff:10.21.21.2 - - [Sat, 10 Feb 2024 00:37:22 GMT] “GET /v1/system/update-status HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; rv:91.0) Gecko/20100101 Firefox/91.0”
manager |
manager | ::ffff:10.21.21.2 - - [Sat, 10 Feb 2024 00:37:25 GMT] “GET /v1/system/update-status HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; rv:91.0) Gecko/20100101 Firefox/91.0”
manager |
manager | ::ffff:10.21.21.2 - - [Sat, 10 Feb 2024 00:37:26 GMT] “GET /v1/system/update-status HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; rv:91.0) Gecko/20100101 Firefox/91.0”
manager |
manager | ::ffff:10.21.21.2 - - [Sat, 10 Feb 2024 00:37:28 GMT] “GET /v1/system/update-status HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; rv:91.0) Gecko/20100101 Firefox/91.0”
manager |
manager | ::ffff:10.21.21.2 - - [Sat, 10 Feb 2024 00:37:30 GMT] “GET /v1/system/update-status HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; rv:91.0) Gecko/20100101 Firefox/91.0”
manager |
manager | ::ffff:10.21.21.2 - - [Sat, 10 Feb 2024 00:37:32 GMT] “GET /v1/system/update-status HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; rv:91.0) Gecko/20100101 Firefox/91.0”
manager |
Tor Proxy logs
Attaching to tor_proxy
tor_proxy | Feb 10 00:21:33.000 [notice] Closed 1 streams for service [scrubbed].onion for reason resolve failed. Fetch status: No more HSDir available to query.
tor_proxy | Feb 10 00:22:54.000 [notice] Closed 1 streams for service [scrubbed].onion for reason resolve failed. Fetch status: No more HSDir available to query.
tor_proxy | Feb 10 00:24:17.000 [notice] Closed 1 streams for service [scrubbed].onion for reason resolve failed. Fetch status: No more HSDir available to query.
tor_proxy | Feb 10 00:25:47.000 [notice] Closed 1 streams for service [scrubbed].onion for reason resolve failed. Fetch status: No more HSDir available to query.
tor_proxy | Feb 10 00:27:20.000 [notice] Closed 1 streams for service [scrubbed].onion for reason resolve failed. Fetch status: No more HSDir available to query.
tor_proxy | Feb 10 00:29:01.000 [notice] Closed 1 streams for service [scrubbed].onion for reason resolve failed. Fetch status: No more HSDir available to query.
tor_proxy | Feb 10 00:30:45.000 [notice] Closed 1 streams for service [scrubbed].onion for reason resolve failed. Fetch status: No more HSDir available to query.
tor_proxy | Feb 10 00:32:35.000 [notice] Closed 1 streams for service [scrubbed].onion for reason resolve failed. Fetch status: No more HSDir available to query.
tor_proxy | Feb 10 00:34:29.000 [notice] Closed 1 streams for service [scrubbed].onion for reason resolve failed. Fetch status: No more HSDir available to query.
tor_proxy | Feb 10 00:36:27.000 [notice] Closed 1 streams for service [scrubbed].onion for reason resolve failed. Fetch status: No more HSDir available to query.
App logs
bitcoin
Attaching to bitcoin_server_1, bitcoin_tor_server_1, bitcoin_tor_1, bitcoin_i2pd_daemon_1, bitcoin_bitcoind_1, bitcoin_app_proxy_1
bitcoind_1 | 2024-02-10T00:23:32Z Imported mempool transactions from disk: 9495 succeeded, 622 failed, 0 expired, 1 already there, 1 waiting for initial broadcast
bitcoind_1 | 2024-02-10T00:23:32Z initload thread exit
bitcoind_1 | 2024-02-10T00:23:45Z New block-relay-only v1 peer connected: version: 70016, blocks=829747, peer=13
bitcoind_1 | 2024-02-10T00:25:06Z Socks5() connect to 2402:800:6173:bb78:183b:3cfc:b000:dbc0:8335 failed: general failure
bitcoind_1 | 2024-02-10T00:30:04Z Saw new header hash=000000000000000000011b7079c2384a3d9bf86b3399d15adab7f118cf54a31f height=829748
bitcoind_1 | 2024-02-10T00:31:42Z Socks5() connect to crlzyjip3gprhdrtwcicoow3popi4rmetlkp676xhlrvf52f2sntsrqd.onion:8333 failed: host unreachable
bitcoind_1 | 2024-02-10T00:33:42Z UpdateTip: new best=000000000000000000011b7079c2384a3d9bf86b3399d15adab7f118cf54a31f height=829748 version=0x2000e000 log2_work=94.721878 tx=963946519 date=‘2024-02-10T00:29:44Z’ progress=0.999999 cache=14.6MiB(127569txo)
bitcoind_1 | 2024-02-10T00:34:43Z Socks5() connect to 2605:8600:906:ff1e:63f2:df8:339a:861a:8333 failed: general failure
bitcoind_1 | 2024-02-10T00:34:51Z Saw new header hash=00000000000000000000d3ee00bead3689ea901aa1c210ba9880089e0b35bcae height=829749
bitcoind_1 | 2024-02-10T00:37:37Z UpdateTip: new best=00000000000000000000d3ee00bead3689ea901aa1c210ba9880089e0b35bcae height=829749 version=0x323ea000 log2_work=94.721892 tx=963947470 date=‘2024-02-10T00:34:03Z’ progress=0.999999 cache=15.3MiB(135334txo)
app_proxy_1 | [HPM] Proxy created: / → http://10.21.22.2:3005
app_proxy_1 | Waiting for 10.21.22.2:3005 to open…
app_proxy_1 | Bitcoin Node is now ready…
app_proxy_1 | Listening on port: 2100
i2pd_daemon_1 | 00:20:13@342/error - Tunnels: Can’t create inbound tunnel, no peers available
i2pd_daemon_1 | 00:21:14@764/error - Garlic: Can’t handle ECIES-X25519-AEAD-Ratchet message
i2pd_daemon_1 | 00:24:56@61/error - SAM: Destination to connect not found
i2pd_daemon_1 | 00:28:06@619/error - Addressbook: LeaseSet for address reg.i2p not found
i2pd_daemon_1 | 00:30:23@834/error - Garlic: Can’t handle ECIES-X25519-AEAD-Ratchet message
i2pd_daemon_1 | 00:34:24@61/error - Destination: Can’t send LeaseSet request, no outbound tunnels found
i2pd_daemon_1 | 00:34:24@61/error - SAM: Destination to connect not found
i2pd_daemon_1 | 00:36:21@61/error - SAM: Stream read error: Operation canceled
i2pd_daemon_1 | 00:36:21@61/error - SAM: Read error: Operation canceled
i2pd_daemon_1 | 00:37:37@61/error - SAM: Read error: End of file
tor_1 | Feb 10 00:10:48.000 [notice] Closed 1 streams for service [scrubbed].onion for reason resolve failed. Fetch status: No more HSDir available to query.
tor_1 | Feb 10 00:11:58.000 [notice] Closed 1 streams for service [scrubbed].onion for reason resolve failed. Fetch status: No more HSDir available to query.
tor_1 | Feb 10 00:20:35.000 [notice] Application asked to connect to port 0. Refusing.
tor_1 | Feb 10 00:21:09.000 [notice] Have tried resolving or connecting to address ‘[scrubbed]’ at 3 different places. Giving up.
tor_1 | Feb 10 00:21:30.000 [notice] Application asked to connect to port 0. Refusing.
tor_1 | Feb 10 00:23:00.000 [notice] Closed 1 streams for service [scrubbed].onion for reason resolve failed. Fetch status: No more HSDir available to query.
tor_1 | Feb 10 00:23:15.000 [notice] Closed 1 streams for service [scrubbed].onion for reason resolve failed. Fetch status: No more HSDir available to query.
tor_1 | Feb 10 00:25:06.000 [notice] Have tried resolving or connecting to address ‘[scrubbed]’ at 3 different places. Giving up.
tor_1 | Feb 10 00:31:42.000 [notice] Closed 1 streams for service [scrubbed].onion for reason resolve failed. Fetch status: No more HSDir available to query.
tor_1 | Feb 10 00:34:43.000 [notice] Have tried resolving or connecting to address ‘[scrubbed]’ at 3 different places. Giving up.
server_1 | yarn run v1.22.18
server_1 | $ node ./bin/www
server_1 | Sat, 10 Feb 2024 00:09:45 GMT morgan deprecated morgan(options): use morgan(“default”, options) instead at app.js:33:9
server_1 | Sat, 10 Feb 2024 00:09:45 GMT morgan deprecated default format: use combined format at app.js:33:9
server_1 | Listening on port 3005
lightning
Attaching to lightning_lnd_1, lightning_app_proxy_1, lightning_app_1, lightning_tor_1, lightning_tor_server_1
app_1 | Checking LND status…
app_1 | LND already unlocked!
app_1 | [backup-monitor] Checking channel backup…
app_1 | [backup-monitor] Sleeping…
app_proxy_1 | [HPM] Proxy created: / → http://10.21.22.3:3006
app_proxy_1 | Waiting for 10.21.22.3:3006 to open…
app_proxy_1 | Lightning Node is now ready…
app_proxy_1 | Listening on port: 2101
lnd_1 | 2024-02-10 00:35:02.659 [INF] UTXN: Attempting to graduate height=829748: num_kids=0, num_babies=0
lnd_1 | 2024-02-10 00:36:16.152 [INF] CRTR: Pruning channel graph using block 000000000000000000011b7079c2384a3d9bf86b3399d15adab7f118cf54a31f (height=829748)
lnd_1 | 2024-02-10 00:37:34.065 [INF] CHDB: Pruned unconnected node 02506341e3a554758922b246519091cf01557838a4251282c6129fbc53d1bab05d from channel graph
lnd_1 | 2024-02-10 00:37:34.065 [INF] CHDB: Pruned 1 unconnected nodes from the channel graph
lnd_1 | 2024-02-10 00:37:34.092 [INF] CRTR: Block 000000000000000000011b7079c2384a3d9bf86b3399d15adab7f118cf54a31f (height=829748) closed 2 channels
lnd_1 | 2024-02-10 00:37:34.092 [INF] CRTR: Processed channels=0 updates=16 nodes=0 in last 2m36.789998274s
lnd_1 | 2024-02-10 00:37:39.867 [INF] CRTR: Pruning channel graph using block 00000000000000000000d3ee00bead3689ea901aa1c210ba9880089e0b35bcae (height=829749)
lnd_1 | 2024-02-10 00:37:40.092 [INF] NTFN: New block: height=829749, sha=00000000000000000000d3ee00bead3689ea901aa1c210ba9880089e0b35bcae
lnd_1 | 2024-02-10 00:37:40.094 [INF] UTXN: Attempting to graduate height=829749: num_kids=0, num_babies=0
lnd_1 | 2024-02-10 00:37:41.028 [INF] CRTR: Block 00000000000000000000d3ee00bead3689ea901aa1c210ba9880089e0b35bcae (height=829749) closed 2 channels
tor_1 | Feb 10 00:09:50.000 [notice] Bootstrapped 56% (loading_descriptors): Loading relay descriptors
tor_1 | Feb 10 00:09:52.000 [notice] Bootstrapped 62% (loading_descriptors): Loading relay descriptors
tor_1 | Feb 10 00:09:53.000 [notice] Bootstrapped 70% (loading_descriptors): Loading relay descriptors
tor_1 | Feb 10 00:09:53.000 [notice] Bootstrapped 75% (enough_dirinfo): Loaded enough directory info to build circuits
tor_1 | Feb 10 00:09:53.000 [notice] Bootstrapped 80% (ap_conn): Connecting to a relay to build circuits
tor_1 | Feb 10 00:09:53.000 [notice] Bootstrapped 85% (ap_conn_done): Connected to a relay to build circuits
tor_1 | Feb 10 00:09:54.000 [notice] Bootstrapped 89% (ap_handshake): Finishing handshake with a relay to build circuits
tor_1 | Feb 10 00:09:54.000 [notice] Bootstrapped 90% (ap_handshake_done): Handshake finished with a relay to build circuits
tor_1 | Feb 10 00:09:54.000 [notice] Bootstrapped 95% (circuit_create): Establishing a Tor circuit
tor_1 | Feb 10 00:09:55.000 [notice] Bootstrapped 100% (done): Done
lightning-terminal
Attaching to lightning-terminal_web_1, lightning-terminal_tor_server_1, lightning-terminal_app_proxy_1
app_proxy_1 | [HPM] Proxy created: / → http://lightning-terminal_web_1:3004
app_proxy_1 | Waiting for lightning-terminal_web_1:3004 to open…
app_proxy_1 | Lightning Terminal is now ready…
app_proxy_1 | Listening on port: 3004
web_1 | 2024-02-10 00:09:33.679 [INF] LITD: Connecting basic lnd client
web_1 | 2024-02-10 00:09:33.884 [INF] LITD: Connecting full lnd client
web_1 | 2024-02-10 00:09:33.885 [INF] LNDC: Creating lnd connection to 10.21.21.9:10009
web_1 | 2024-02-10 00:09:33.886 [INF] LNDC: Connected to lnd
web_1 | 2024-02-10 00:09:33.888 [WRN] GRPC: [core] [Channel #8 SubChannel #9] grpc: addrConn.createTransport failed to connect to {Addr: “10.21.21.9:10009”, ServerName: “10.21.21.9:10009”, }. Err: connection error: desc = “transport: Error while dialing: dial tcp 10.21.21.9:10009: connect: connection refused”
web_1 | 2024-02-10 00:09:33.888 [ERR] STAT: could not start the lnd sub-server: could not set up LND clients: could not create LND Services client: error subscribing to lnd wallet state: lnd version incompatible, need at least v0.13.0-beta, got error on state subscription: rpc error: code = Unavailable desc = connection error: desc = “transport: Error while dialing: dial tcp 10.21.21.9:10009: connect: connection refused”
web_1 | 2024-02-10 00:09:33.889 [ERR] STAT: could not start the lit sub-server: could not start Lit: could not start LND
web_1 | 2024-02-10 00:09:33.888 [WRN] GRPC: [core] [Channel #6 SubChannel #7] grpc: addrConn.createTransport failed to connect to {Addr: “10.21.21.9:10009”, ServerName: “10.21.21.9:10009”, }. Err: connection error: desc = “transport: Error while dialing: dial tcp 10.21.21.9:10009: connect: connection refused”
web_1 | 2024-02-10 00:09:34.678 [WRN] GRPC: [core] [Channel #2 SubChannel #3] grpc: addrConn.createTransport failed to connect to {Addr: “10.21.21.9:10009”, ServerName: “10.21.21.9:10009”, }. Err: connection error: desc = “transport: Error while dialing: dial tcp 10.21.21.9:10009: connect: connection refused”
web_1 | 2024-02-10 00:09:34.700 [WRN] GRPC: [core] [Channel #4 SubChannel #5] grpc: addrConn.createTransport failed to connect to {Addr: “10.21.21.9:10009”, ServerName: “10.21.21.9:10009”, }. Err: connection error: desc = “transport: Error while dialing: dial tcp 10.21.21.9:10009: connect: connection refused”
ride-the-lightning
Attaching to ride-the-lightning_tor_server_1, ride-the-lightning_app_proxy_1, ride-the-lightning_web_1, ride-the-lightning_boltz_1
app_proxy_1 | [HPM] Proxy created: / → http://ride-the-lightning_web_1:3001
app_proxy_1 | Waiting for ride-the-lightning_web_1:3001 to open…
app_proxy_1 | Ride The Lightning is now ready…
app_proxy_1 | Listening on port: 3001
boltz_1 | INFO : 2024/02/10 00:11:27 Connected to LND block epoch stream
boltz_1 | INFO : 2024/02/10 00:11:27 Recovering pending Reverse Swaps
boltz_1 | INFO : 2024/02/10 00:11:27 Loaded TLS certificate and key
boltz_1 | WARN : 2024/02/10 00:11:27 TLS certificate is outdated. Removing files and generating new one
boltz_1 | WARN : 2024/02/10 00:11:27 Could not find TLS certificate or key
boltz_1 | INFO : 2024/02/10 00:11:27 Generating new TLS certificate and key
boltz_1 | INFO : 2024/02/10 00:11:27 Enabling Macaroon authentication
boltz_1 | INFO : 2024/02/10 00:11:27 Starting REST server on: 0.0.0.0:9003
boltz_1 | INFO : 2024/02/10 00:11:27 Starting RPC server on: 127.0.0.1:9002
web_1 | [2/10/2024, 12:09:45 AM] INFO: App => Setting up Application Routes…
web_1 |
web_1 | [2/10/2024, 12:09:45 AM] INFO: App => Application Routes Set.
web_1 |
web_1 | [2/10/2024, 12:09:45 AM] INFO: WebSocketServer => Connecting Websocket Server…
web_1 |
web_1 | [2/10/2024, 12:09:45 AM] INFO: WebSocketServer => Websocket Server Connected.
web_1 |
web_1 | [2/10/2024, 12:09:45 AM] INFO: RTL => Server is up and running, please open the UI at http://localhost:3001 or your proxy configured url.
web_1 |
==== Result ====
Karen
Got signal: backup
Deriving keys…
Creating backup…
1+0 records in
1+0 records out
691 bytes copied, 0.000200867 s, 3.4 MB/s
backup/
backup/.padding
Uploading backup…
100 7405 100 146 100 7259 54 2685 0:00:02 0:00:02 --:–:-- 2738
{“message”:“Successfully uploaded backup 1707427172768.tar.gz.pgp for backup ID 428bb520d9a1f18e19deb9e768a7eccc00768f508a872c343db8befad26eac35”}
Got signal:
Got signal:
Got signal:
Got signal:
Got signal:
Got signal:
Got signal:
Got signal:
Got signal: backup
Deriving keys…
Creating backup…
1+0 records in
1+0 records out
backup/
backup/.padding
Uploading backup…
Got signal:
Got signal:
Got signal:
Got signal:
Got signal:
Got signal:
Got signal:
Got signal:
@usernameisJim Do you have any idea?
Hey friend im not officially on the Umbrel team I’d suggest their discord linked on the official channels https://umbrel.com/support you’re able to create a ticket there too
this issue was historically resolved with reflashing the MicroSD card were you able to reflash or confirm which exact screen you’re stuck on, if refreshing or reloading a new window didn’t work has reflashing helped? or post a support ticket in the discord :slight_smile: the team can see it there too to track likely and will be more knowledgeable on any new fixes, as this forum post may be outdated now soon too with the upcoming release of 1.0! :slight_smile: https://x.com/umbrel/status/1757422669996441741?s=20
Thank you for answering me. I tried reflash it doesn’t change anything.I am stuck on this screen:
Update, I changed my micro SD card but the problem persists. It’s pretty painful and no one seems to have the answer.Why? Umbrel Community please help me!
Any solutions with this? Same issue, and I think the same debug logs
