FYI:
Running Sparrow on Umbunto and connecting Sparrow wallet to umbrel node
Specter requires torr to be running. Sparrow does not and will start it. So…
If you umbrel auto starts torr you need to turn it off before launching sparrow each session.
on umbunto terminal: sudo systemctl stop tor
re-try to get sparrow to connect. It should start the tor and connect.
you may still see error messages. exit back to main window and see
if it says connected on bottom of sparrow gui.
In my case proxy is not used.
This will break Spectre.
Use ```
sudo systemctl start tor
when running spector.
