We’re not able to get data from the bitcoin node via a Tor connection. The error’s output is : Socks5 proxy rejected connection - HostUnreachable.
Umbrel is running latest version 0.4.11
Credentials are the same as showed in Bitcoin Core RPC.
Pinging @louneskmt on this - user is trying to connect from a remote server to gather data from his node.
umbrel_tor_server_1 was down. Restarting the container didn’t work. Erasing it and restarting the Umbrel created the container from scratch. Issue has been solved this way for now.
