Get Umbrel running again
Hi there,
I am a relative newbie and not that familiar with unix.
Some time ago I got Umbrel installed and running successfully on a Raspberry Pi, using Tor to connect.
I subsequently moved cities and office location and when I re-plugged my RPi into the local LAN I could not longer connect to Umbrel using Tor.
I finally figured out how to use Terminal on my Mac to ssh to the RPi and ran the debug script - output pasted below.
I would really appreciate some help or guidance as to how to get my Umbrel Bitcoin node running again and accessible via Tor! :pray:t3:
Or do I need to reinstall the whole thing again?
umbrel@umbrel:~/umbrel $ ~/umbrel/scripts/debug
0.5.1
Flashed OS version
v0.4.8
Raspberry Pi Model
Revision : d03114
Serial : 10000000753fb5b7
Firmware
Oct 29 2021 10:47:33
Copyright © 2012 Broadcom
version b8a114e5a9877e91ca8f26d1a5ce904b2ad3cf13 (clean) (release) (start)
Temperature
temp=47.2’C
Throttling
throttled=0x0
Mem: 7.8G 211M 7.2G 16M 382M 7.5G
Swap: 4.1G 0B 4.1G
total: 2.7%
system: 2.7%
tor: 0%
thunderhub: 0%
syncthing: 0%
samourai-server: 0%
ride-the-lightning: 0%
mempool: 0%
lnmarkets: 0%
lnd: 0%
lightning: 0%
lightning-terminal: 0%
electrs: 0%
electrs: 0%
btc-rpc-explorer: 0%
bluewallet: 0%
bitcoin: 0%
bitcoin: 0%
Memory monitor logs
ps: error while loading shared libraries: hyrppocps?{n.7: cannot open shared object file: No such file or directory
2023-06-14 13:23:07 Memory monitor running!
2023-06-14 13:23:19 Memory monitor running!
2023-06-14 13:23:31 Memory monitor running!
2023-06-14 13:23:44 Memory monitor running!
2023-06-14 13:24:03 Memory monitor running!
/dev/root 59G 4.0G 53G 8% /
/dev/sda1 916G 623G 248G 72% /home/umbrel/umbrel
Startup service logs
Jun 14 13:24:05 umbrel umbrel startup[32208]: File “/usr/lib/python3/dist-packages/requests/sessions.py”, line 646, in send
Jun 14 13:24:05 umbrel umbrel startup[32208]: r = adapter.send(request, **kwargs)
Jun 14 13:24:05 umbrel umbrel startup[32208]: File “/usr/lib/python3/dist-packages/requests/adapters.py”, line 498, in send
Jun 14 13:24:05 umbrel umbrel startup[32208]: raise ConnectionError(err, request=request)
Jun 14 13:24:05 umbrel umbrel startup[32208]: requests.exceptions.ConnectionError: (‘Connection aborted.’, ConnectionRefusedError(111, ‘Connection refused’))
Jun 14 13:24:05 umbrel umbrel startup[32208]: During handling of the above exception, another exception occurred:
Jun 14 13:24:05 umbrel umbrel startup[32208]: Traceback (most recent call last):
Jun 14 13:24:05 umbrel umbrel startup[32208]: File “/usr/local/bin/docker-compose”, line 10, in
Jun 14 13:24:05 umbrel umbrel startup[32208]: sys.exit(main())
Jun 14 13:24:05 umbrel umbrel startup[32208]: File “/usr/local/lib/python3.7/dist-packages/compose/cli/main.py”, line 81, in main
Jun 14 13:24:05 umbrel umbrel startup[32208]: command_func()
Jun 14 13:24:05 umbrel umbrel startup[32208]: File “/usr/local/lib/python3.7/dist-packages/compose/cli/main.py”, line 200, in perform_command
Jun 14 13:24:05 umbrel umbrel startup[32208]: project = project_from_options(’.’, options)
Jun 14 13:24:05 umbrel umbrel startup[32208]: File “/usr/local/lib/python3.7/dist-packages/compose/cli/command.py”, line 70, in project_from_options
Jun 14 13:24:05 umbrel umbrel startup[32208]: enabled_profiles=get_profiles_from_options(options, environment)
Jun 14 13:24:05 umbrel umbrel startup[32208]: File “/usr/local/lib/python3.7/dist-packages/compose/cli/command.py”, line 153, in get_project
Jun 14 13:24:05 umbrel umbrel startup[32208]: verbose=verbose, version=api_version, context=context, environment=environment
Jun 14 13:24:05 umbrel umbrel startup[32208]: File “/usr/local/lib/python3.7/dist-packages/compose/cli/docker_client.py”, line 43, in get_client
Jun 14 13:24:05 umbrel umbrel startup[32208]: environment=environment, tls_version=get_tls_version(environment)
Jun 14 13:24:05 umbrel umbrel startup[32208]: File “/usr/local/lib/python3.7/dist-packages/compose/cli/docker_client.py”, line 170, in docker_client
Jun 14 13:24:05 umbrel umbrel startup[32208]: client = APIClient(use_ssh_client=not use_paramiko_ssh, **kwargs)
Jun 14 13:24:05 umbrel umbrel startup[32208]: File “/usr/local/lib/python3.7/dist-packages/docker/api/client.py”, line 197, in init
Jun 14 13:24:05 umbrel umbrel startup[32208]: self._version = self._retrieve_server_version()
Jun 14 13:24:05 umbrel umbrel startup[32208]: File “/usr/local/lib/python3.7/dist-packages/docker/api/client.py”, line 222, in _retrieve_server_version
Jun 14 13:24:05 umbrel umbrel startup[32208]: f’Error while fetching server API version: {e}’
Jun 14 13:24:05 umbrel umbrel startup[32208]: docker.errors.DockerException: Error while fetching server API version: (‘Connection aborted.’, ConnectionRefusedError(111, ‘Connection refused’))
Jun 14 13:24:05 umbrel umbrel startup[32208]: Failed to start containers
Jun 14 13:24:05 umbrel systemd[1]: umbrel-startup.service: Control process exited, code=exited, status=1/FAILURE
Jun 14 13:24:05 umbrel systemd[1]: umbrel-startup.service: Failed with result ‘exit-code’.
Jun 14 13:24:05 umbrel systemd[1]: Failed to start Umbrel Startup Service.
External storage service logs
– Logs begin at Wed 2023-06-14 13:05:54 UTC, end at Wed 2023-06-14 13:24:05 UTC. –
Jun 14 13:06:00 umbrel systemd[1]: Starting External Storage Mounter…
Jun 14 13:06:00 umbrel external storage mounter[504]: Running external storage mount script…
Jun 14 13:06:00 umbrel external storage mounter[504]: Found device “Micron Crucial X6 SSD”
Jun 14 13:06:00 umbrel external storage mounter[504]: Blacklisting USB device IDs against UAS driver…
Jun 14 13:06:00 umbrel external storage mounter[504]: Rebinding USB drivers…
Jun 14 13:06:00 umbrel external storage mounter[504]: Checking USB devices are back…
Jun 14 13:06:00 umbrel external storage mounter[504]: Waiting for USB devices…
Jun 14 13:06:01 umbrel external storage mounter[504]: Waiting for USB devices…
Jun 14 13:06:02 umbrel external storage mounter[504]: Waiting for USB devices…
Jun 14 13:06:03 umbrel external storage mounter[504]: Checking if the device is ext4…
Jun 14 13:06:03 umbrel external storage mounter[504]: Yes, it is ext4
Jun 14 13:06:03 umbrel external storage mounter[504]: Checking if device contains an Umbrel install…
Jun 14 13:06:03 umbrel external storage mounter[504]: Yes, it contains an Umbrel install
Jun 14 13:06:03 umbrel external storage mounter[504]: Bind mounting external storage over local Umbrel installation…
Jun 14 13:06:03 umbrel external storage mounter[504]: Bind mounting external storage over local Docker data dir…
Jun 14 13:06:03 umbrel external storage mounter[504]: Bind mounting external storage to /swap
Jun 14 13:06:03 umbrel external storage mounter[504]: Bind mounting SD card root at /sd-card…
Jun 14 13:06:03 umbrel external storage mounter[504]: Checking Umbrel root is now on external storage…
Jun 14 13:06:05 umbrel external storage mounter[504]: Checking /var/lib/docker is now on external storage…
Jun 14 13:06:05 umbrel external storage mounter[504]: Checking /swap is now on external storage…
Jun 14 13:06:05 umbrel external storage mounter[504]: Setting up swapfile
Jun 14 13:06:05 umbrel external storage mounter[504]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
Jun 14 13:06:05 umbrel external storage mounter[504]: no label, UUID=11a68dc3-015b-4a7c-a05a-d1f43e2a9815
Jun 14 13:06:05 umbrel external storage mounter[504]: Checking SD Card root is bind mounted at /sd-root…
Jun 14 13:06:05 umbrel external storage mounter[504]: Starting external drive mount monitor…
Jun 14 13:06:05 umbrel external storage mounter[504]: Mount script completed successfully!
Jun 14 13:06:05 umbrel systemd[1]: Started External Storage Mounter.
Jun 14 13:06:05 umbrel external storage mounter[504]: [115B blob data]
Jun 14 13:06:13 umbrel systemd[1]: Starting External Storage SDcard Updater…
Jun 14 13:06:13 umbrel external storage updater[921]: Checking if SD card Umbrel is newer than external storage…
Jun 14 13:06:13 umbrel external storage updater[921]: No, SD version is not newer, exiting.
Jun 14 13:06:13 umbrel systemd[1]: Started External Storage SDcard Updater.
Karen logs
Docker containers
Umbrel logs
File “/usr/lib/python3/dist-packages/urllib3/connectionpool.py”, line 600, in urlopen
chunked=chunked)
File “/usr/lib/python3/dist-packages/urllib3/connectionpool.py”, line 354, in _make_request
conn.request(method, url, **httplib_request_kw)
File “/usr/lib/python3.7/http/client.py”, line 1260, in request
self._send_request(method, url, body, headers, encode_chunked)
File “/usr/lib/python3.7/http/client.py”, line 1306, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File “/usr/lib/python3.7/http/client.py”, line 1255, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File “/usr/lib/python3.7/http/client.py”, line 1030, in _send_output
self.send(msg)
File “/usr/lib/python3.7/http/client.py”, line 970, in send
self.connect()
File “/usr/local/lib/python3.7/dist-packages/docker/transport/unixconn.py”, line 30, in connect
sock.connect(self.unix_socket)
ConnectionRefusedError: [Errno 111] Connection refused
File “/usr/lib/python3/dist-packages/requests/adapters.py”, line 449, in send
timeout=timeout
File “/usr/lib/python3/dist-packages/urllib3/connectionpool.py”, line 638, in urlopen
_stacktrace=sys.exc_info()[2])
File “/usr/lib/python3/dist-packages/urllib3/util/retry.py”, line 367, in increment
raise six.reraise(type(error), error, _stacktrace)
File “/usr/lib/python3/dist-packages/six.py”, line 692, in reraise
raise value.with_traceback(tb)
chunked=chunked)
self.send(msg)
self.connect()
urllib3.exceptions.ProtocolError: (‘Connection aborted.’, ConnectionRefusedError(111, ‘Connection refused’))
File “/usr/local/lib/python3.7/dist-packages/docker/api/client.py”, line 214, in _retrieve_server_version
return self.version(api_version=False)[“ApiVersion”]
File “/usr/local/lib/python3.7/dist-packages/docker/api/daemon.py”, line 181, in version
return self._result(self._get(url), json=True)
File “/usr/local/lib/python3.7/dist-packages/docker/utils/decorators.py”, line 46, in inner
return f(self, *args, **kwargs)
File “/usr/local/lib/python3.7/dist-packages/docker/api/client.py”, line 237, in _get
return self.get(url, **self._set_request_timeout(kwargs))
File “/usr/lib/python3/dist-packages/requests/sessions.py”, line 546, in get
return self.request(‘GET’, url, **kwargs)
File “/usr/lib/python3/dist-packages/requests/sessions.py”, line 533, in request
resp = self.send(prep, **send_kwargs)
sys.exit(main())
command_func()
Tor logs
chunked=chunked)
self.send(msg)
self.connect()
timeout=timeout
chunked=chunked)
self.send(msg)
self.connect()
sys.exit(main())
command_func()
App logs
bitcoin
chunked=chunked)
self.send(msg)
self.connect()
timeout=timeout
chunked=chunked)
self.send(msg)
self.connect()
Here’s the rest of the debug output:
sys.exit(main())
command_func()
bluewallet
chunked=chunked)
self.send(msg)
self.connect()
timeout=timeout
chunked=chunked)
self.send(msg)
self.connect()
sys.exit(main())
command_func()
btc-rpc-explorer
chunked=chunked)
self.send(msg)
self.connect()
timeout=timeout
chunked=chunked)
self.send(msg)
self.connect()
sys.exit(main())
command_func()
electrs
chunked=chunked)
self.send(msg)
self.connect()
timeout=timeout
chunked=chunked)
self.send(msg)
self.connect()
sys.exit(main())
command_func()
lightning
chunked=chunked)
self.send(msg)
self.connect()
timeout=timeout
chunked=chunked)
self.send(msg)
self.connect()
sys.exit(main())
command_func()
lightning-terminal
chunked=chunked)
self.send(msg)
self.connect()
timeout=timeout
chunked=chunked)
self.send(msg)
self.connect()
sys.exit(main())
command_func()
lnmarkets
chunked=chunked)
self.send(msg)
self.connect()
timeout=timeout
chunked=chunked)
self.send(msg)
self.connect()
sys.exit(main())
command_func()
mempool
chunked=chunked)
self.send(msg)
self.connect()
timeout=timeout
chunked=chunked)
self.send(msg)
self.connect()
sys.exit(main())
command_func()
ride-the-lightning
chunked=chunked)
self.send(msg)
self.connect()
timeout=timeout
chunked=chunked)
self.send(msg)
self.connect()
sys.exit(main())
command_func()
samourai-server
chunked=chunked)
self.send(msg)
self.connect()
timeout=timeout
chunked=chunked)
self.send(msg)
self.connect()
sys.exit(main())
command_func()
syncthing
chunked=chunked)
self.send(msg)
self.connect()
timeout=timeout
chunked=chunked)
self.send(msg)
self.connect()
sys.exit(main())
command_func()
thunderhub
chunked=chunked)
self.send(msg)
self.connect()
timeout=timeout
chunked=chunked)
self.send(msg)
self.connect()
sys.exit(main())
command_func()
==== Result ====
The Result part is the hardest to get for me. I hope someone who understands this data comes to rescue you.
I also have an Umbrel currently unable to start while hoping for support from the community here.
