Socks5() connect to ... failed: general failure
Hi there,
I already had this problem about 10 days ago. Now it happend for the second time. It went like this:
The node cant be reached via umbrel.local on Chrome anymore and apps are not reachable (thats the browser i have the mempool app and the umbrel site always open on)
When I open the same links in another browser I’m able to login/show the mempool. But it seems to have gotten stuck some hours ago. The node shows 0 peers.
If I produce the logs the following is listed under Bitcoin Core logs:
bitcoin              | 2021-06-10T12:57:45Z Socks5() connect to ...:8333 failed: general failure
bitcoin              | 2021-06-10T13:00:06Z UpdateTip: new best=0000000000000000000c315079c9390cd0df9fc3c21151372b619ead840b4fbf height=687059 version=0x3fffe004 log2_work=92.931823 tx=648287437 date='2021-06-10T12:59:54Z' progress=1.000000 cache=120.4MiB(848897txo)
bitcoin              | 2021-06-10T13:07:26Z UpdateTip: new best=000000000000000000018ac8360de976c4af0eec504754c6ae15f84c5b81cca0 height=687060 version=0x20c00004 log2_work=92.931837 tx=648288902 date='2021-06-10T13:07:11Z' progress=1.000000 cache=120.9MiB(852795txo)
bitcoin              | 2021-06-10T13:16:03Z UpdateTip: new best=000000000000000000007b1adb713bec946ef2f25527220aab48c370f1f69a2e height=687061 version=0x20000004 log2_work=92.931851 tx=648290286 date='2021-06-10T13:15:41Z' progress=1.000000 cache=121.1MiB(854364txo)
bitcoin              | 2021-06-10T13:16:03Z Pre-allocating up to position 0x700000 in fltr00404.dat
bitcoin              | 2021-06-10T13:46:35Z Socks5() connect to ...:8333 failed: connection refused
bitcoin              | 2021-06-10T13:47:23Z Pre-allocating up to position 0x1000000 in rev02615.dat
bitcoin              | 2021-06-10T13:47:23Z UpdateTip: new best=00000000000000000001ee66ebf42ed5561a6afb6b14a4b32df5c9ce241b1ccf height=687062 version=0x20c00004 log2_work=92.931864 tx=648293064 date='2021-06-10T13:46:45Z' progress=1.000000 cache=122.7MiB(867800txo)
bitcoin              | 2021-06-10T13:47:23Z BlockUntilSyncedToCurrentChain: txindex is catching up on block notifications
bitcoin              | 2021-06-10T13:52:49Z Socks5() connect to ...:8333 failed: general failure
bitcoin              | 2021-06-10T14:22:41Z Potential stale tip detected, will try using extra outbound peer (last tip update: 2118 seconds
The Tor logs show the following:
tor                  | Jun 10 17:22:18.000 [notice] Tried for 120 seconds to get a connection to [scrubbed]:9735. Giving up. (waiting for circuit)
tor                  | Jun 10 17:22:36.000 [warn] Failed to find node for hop #1 of our path. Discarding this circuit.
Any ideas how to fix that? Sure rebooting seems to fix it, but thats no long time solution.
Is Tor simply down for everyone?
Thank you! :grin:
Hi, did you get any fix here?
I have the same issue.
thanks
