My simple node!
My personal bank
Pi 4gb
SanDisk SD card
Western digital blue 1tb ssd
Cheap usb 3.0 to sata adapter
Don’t remember the case name
Ice box rpi fan x2(DO NOT BUY, SUCKS, BROKE)
Amazon ethernet cable
Cable matters usb cable(2 foot shorty)
Anker 5 port smart charging brick for power
Only issue I had was the fan broke so I’m going to replace it with an Argon fan hat which I’ve heard good things about.
This is the node battle command station or something. I love it!
What’s the top number?
Love this!
It’s the block number
Yes, as DarthCoin says, its the block number, read out updates every minute or so…
It’s also buried behind a table/desk with only power and Ethernet ran to it but ill see if I can do something.
Awesome! Whats your LN public key?
Hi! Thank you. It is:
030c2f9e17a1e8af4bcb0f88f5b84ded0cb09b2f1985c8069d2cc7bae04a1b5e41@kk7nmfs4henxcoostowezis5deroovf6wp2b2d2ei2u6lfymw4cwcsad.onion:9735
I had a drive doing roughly that. It was the usb to sata cable (or enclosure) constantly resetting. Fixed it in 0.3.8 by moving the drive to a black usb 2 port but then 0.3.9 fixed it entirely and after a reflash of microsd and format of ssd.
To view this I watched the logs in settings or can ssh in and use:
dmesg -w
Was able to see repeating usb reset entries popping up which clued me in. But port change did work until it was no longer needed.
I think I understood that
Will ssh into my wee little beast and see what that observational command presents, thanks sirmatt!
