Nostr Private Relay over TOR
I installed the Nostr relay app, and I connect to my umbrel over Tor.
In the Relay app, the relay address displayed in the upper right is a Tor address (with no port number at the end).
Can the private relay work over Tor?
As a side note, the address starts with ws://
The other relays I’m connected to start with wss://
Is there a difference?
Thanks!
a big difference that the wss to ws makes. i dont understand it , but it effectively means nostr apps only, not websites.
more of my struggles here. I think it works if you have damus app on an iphone, but you are not that, its very very early alpha days on nostr relays!
