Hi all!
I’m lost here…
Been using Umbrel for +1 year without issues. After moving my node to a different place (done many times without problems due to remore work) I suddenly noticed that syncing back to 100% didn’t happen anymore. Node is syncing to 98.85% but then stops and re-starts syncing at 98.33% and so on…(jumps back from block 858.541 to 857.077 and starts syncing in the same loop)
I re-flashed several times, and tried downloading the blockchain from scratch - but problem remains.
What can I do? Is the SSD faulty?
Thanks!
