Hello,
I am trying to sync the bitcoin blockchain for the second time now. The first time, the synchronization stopped at about 50 percent and had not changed even after several days. You can’t see a progress bar or a current status anymore. I then restarted Umbrel and was already close to the end at about 86 percent and now have the same problem. Slowly I am annoyed.
I have already tried the following:
- Reboot
- Updated to version 0.5.0
- Power off everything
- Changed SSD cable
- Reboot my Router
What is the cause and how can I fix it? A third time I will not start from scratch.
I use a raspberry pi with the offical image and a 1TB SSD. I’m connectet with Ethernet.
