Node crash. Umbrel restored
Hi. Suddenly after more than a year, my node crashed.
I´ve installed Umbrel on a new SD card and changed the power supply. Also checked if power is ok by running vcgencmd get_throttled command, and result is ok (throttled=0x0).
I can´t access though web browser, but I´ve followed Darth´s guide to SSH and get a log (pasted down)
¿Is there anything else I can do?
Linux umbrel 5.10.103-v8+ #1529 SMP PREEMPT Tue Mar 8 12:26:46 GMT 2022 aarch64
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Sat Oct 22 11:42:55 2022 from 192.168.0.19
umbrel@umbrel:~ $ ls -la
total 32
drwxr-xr-x 4 umbrel umbrel 4096 Oct 22 11:35 .
drwxr-xr-x 5 root root 4096 Jul 15 08:40 ..
-rw------- 1 umbrel umbrel 1918 Oct 22 11:48 .bash_history
-rw-r–r-- 1 umbrel umbrel 220 Jul 15 08:27 .bash_logout
-rw-r–r-- 1 umbrel umbrel 3523 Jul 15 08:27 .bashrc
drwx------ 3 umbrel umbrel 4096 Oct 22 11:29 .gnupg
-rw-r–r-- 1 umbrel umbrel 807 Jul 15 08:27 .profile
drwxr-xr-x 20 umbrel umbrel 4096 Sep 7 07:49 umbrel
umbrel@umbrel:~ $ cd umbrel
umbrel@umbrel:~/umbrel $ ls -la
total 128
drwxr-xr-x 20 umbrel umbrel 4096 Sep 7 07:49 .
drwxr-xr-x 4 umbrel umbrel 4096 Oct 22 11:35 ..
drwxrwxr-x 5 umbrel umbrel 4096 Jun 9 10:14 app-data
drwxrwxr-x 48 umbrel umbrel 4096 Jun 7 13:00 apps
drwxr-xr-x 2 umbrel umbrel 4096 Jul 15 05:55 .backup
drwxrwxr-x 2 umbrel umbrel 4096 Jun 7 13:00 bin
drwxrwxr-x 2 umbrel umbrel 4096 Jun 7 13:00 build
-rw-rw-r-- 1 umbrel umbrel 3940 Jun 7 13:00 CONTRIBUTING.md
drwxrwxr-x 4 umbrel umbrel 4096 Jun 9 10:15 db
drwxrwxr-x 4 umbrel umbrel 4096 Jun 7 13:00 deps
-rw-rw-r-- 1 umbrel umbrel 7109 Jun 7 13:00 docker-compose.yml
-rw-r–r-- 1 umbrel umbrel 1015 Jun 9 10:10 .env
drwxrwxr-x 4 umbrel umbrel 4096 Jun 7 13:00 events
drwxrwxr-x 3 umbrel umbrel 4096 May 3 2021 .github
-rw-rw-r-- 1 umbrel umbrel 584 Jun 7 13:00 .gitignore
-rw-rw-r-- 1 umbrel umbrel 459 Jun 7 13:00 info.json
-rwxrwxr-x 1 umbrel umbrel 1562 Jun 7 13:00 karen
-rw-rw-r-- 1 umbrel umbrel 4798 Jun 7 13:00 LICENSE.md
drwxrwxr-x 2 umbrel umbrel 4096 Jun 7 13:00 logs
drwxrwxr-x 2 umbrel umbrel 4096 Jun 9 10:10 nginx
-rw-rw-r-- 1 umbrel umbrel 7235 Jun 7 13:00 README.md
drwxrwxr-x 3 umbrel umbrel 4096 Jun 9 10:13 repos
drwxrwxr-x 7 umbrel umbrel 4096 Jun 7 13:00 scripts
-rw-rw-r-- 1 umbrel umbrel 3018 Jun 7 13:00 SECURITY.md
drwxrwxr-x 2 umbrel umbrel 4096 Sep 7 07:49 statuses
drwxrwxr-x 2 umbrel umbrel 4096 Jun 9 10:10 templates
drwxrwxr-x 4 umbrel umbrel 4096 Jun 9 10:10 tor
-rw-rw-r-- 1 umbrel umbrel 0 May 3 2021 .umbrel
drwxr-xr-x 15 umbrel umbrel 4096 Sep 7 07:49 .umbrel-backup
drwxr-xr-x 16 umbrel umbrel 4096 Sep 7 07:49 .umbrel-v0.5.1
umbrel@umbrel:~/umbrel $ ~/umbrel/scripts/debug
0.5.0
Flashed OS version
v0.5.1
Raspberry Pi Model
Revision : d03114
Serial : 10000000681f6831
Firmware
Dec 1 2021 15:01:54
Copyright (c) 2012 Broadcom
Temperature
temp=53.0’C
Throttling
throttled=0x0
Mem: 7.8G 166M 7.2G 8.0M 490M 7.5G
Swap: 4.1G 0B 4.1G
total: 2.1%
system: 2.1%
tor: 0%
lnd: 0%
lightning: 0%
electrs: 0%
electrs: 0%
bitcoin: 0%
bitcoin: 0%
Memory monitor logs
2022-05-16 09:37:05 Memory monitor running!
2022-05-16 09:41:51 Memory monitor running!
2022-05-16 13:50:12 Memory monitor running!
2571 ? S 0:55 bash ./scripts/memory-monitor
2022-06-09 10:16:28 Memory monitor running!
2022-09-04 08:18:05 Memory monitor running!
2022-09-04 09:09:33 Memory monitor running!
2022-09-07 07:47:45 Memory monitor running!
/dev/root 29G 2.9G 25G 11% /
/dev/sda1 916G 533G 338G 62% /home/umbrel/umbrel
Startup service logs
– Logs begin at Sat 2022-10-22 10:50:59 UTC, end at Sat 2022-10-22 11:50:44 UTC. –
Oct 22 10:59:39 umbrel systemd[1]: Dependency failed for Umbrel Startup Service.
Oct 22 10:59:39 umbrel systemd[1]: umbrel-startup.service: Job umbrel-startup.service/start failed with result ‘dependency’.
External storage service logs
Oct 22 10:59:22 umbrel systemd[1]: Starting External Storage Mounter…
Oct 22 10:59:22 umbrel external storage mounter[498]: Running external storage mount script…
Oct 22 10:59:22 umbrel external storage mounter[498]: Found device “External USB3.0”
Oct 22 10:59:22 umbrel external storage mounter[498]: Blacklisting USB device IDs against UAS driver…
Oct 22 10:59:22 umbrel external storage mounter[498]: Rebinding USB drivers…
Oct 22 10:59:23 umbrel external storage mounter[498]: Checking USB devices are back…
Oct 22 10:59:23 umbrel external storage mounter[498]: Waiting for USB devices…
Oct 22 10:59:24 umbrel external storage mounter[498]: Waiting for USB devices…
Oct 22 10:59:25 umbrel external storage mounter[498]: Waiting for USB devices…
Oct 22 10:59:26 umbrel external storage mounter[498]: Checking if the device is ext4…
Oct 22 10:59:26 umbrel external storage mounter[498]: Yes, it is ext4
Oct 22 10:59:26 umbrel external storage mounter[498]: Checking if device contains an Umbrel install…
Oct 22 10:59:26 umbrel external storage mounter[498]: Yes, it contains an Umbrel install
Oct 22 10:59:26 umbrel external storage mounter[498]: Bind mounting external storage over local Umbrel installation…
Oct 22 10:59:26 umbrel external storage mounter[498]: Bind mounting external storage over local Docker data dir…
Oct 22 10:59:26 umbrel external storage mounter[498]: Bind mounting external storage to /swap
Oct 22 10:59:26 umbrel external storage mounter[498]: Bind mounting SD card root at /sd-card…
Oct 22 10:59:26 umbrel external storage mounter[498]: Checking Umbrel root is now on external storage…
Oct 22 10:59:27 umbrel external storage mounter[498]: Checking /var/lib/docker is now on external storage…
Oct 22 10:59:27 umbrel external storage mounter[498]: Checking /swap is now on external storage…
Oct 22 10:59:27 umbrel external storage mounter[498]: Setting up swapfile
Oct 22 10:59:27 umbrel external storage mounter[498]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
Oct 22 10:59:27 umbrel external storage mounter[498]: no label, UUID=dc1d5443-cfb8-416d-86fa-44002778158e
Oct 22 10:59:27 umbrel external storage mounter[498]: Checking SD Card root is bind mounted at /sd-root…
Oct 22 10:59:27 umbrel external storage mounter[498]: Starting external drive mount monitor…
Oct 22 10:59:27 umbrel external storage mounter[498]: Mount script completed successfully!
Oct 22 10:59:27 umbrel systemd[1]: Started External Storage Mounter.
Oct 22 10:59:39 umbrel systemd[1]: Starting External Storage SDcard Updater…
Oct 22 10:59:39 umbrel external storage updater[1151]: Checking if SD card Umbrel is newer than external storage…
Oct 22 10:59:39 umbrel external storage updater[1151]: Yes, SD version is newer.
Oct 22 10:59:39 umbrel external storage updater[1151]: Checking if the external storage version “0.5.0” satisfies update requirement “>=0.5.0”…
Oct 22 10:59:39 umbrel external storage updater[1151]: Yes, it does, attempting an automatic update…
Oct 22 10:59:39 umbrel external storage updater[1151]: =======================================
Oct 22 10:59:39 umbrel external storage updater[1151]: =============== UPDATE ================
Oct 22 10:59:39 umbrel external storage updater[1151]: ========== Stage: Download ============
Oct 22 10:59:39 umbrel external storage updater[1151]: An update is already in progress. Exiting now.
Oct 22 10:59:39 umbrel systemd[1]: umbrel-external-storage-sdcard-update.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
Oct 22 10:59:39 umbrel systemd[1]: umbrel-external-storage-sdcard-update.service: Failed with result ‘exit-code’.
Oct 22 10:59:39 umbrel systemd[1]: Failed to start External Storage SDcard Updater.
Karen logs
Pulling auth … extracting (75.4%)
Pulling auth … extracting (76.5%)
Pulling auth … extracting (77.5%)
Pulling auth … extracting (79.7%)
Pulling auth … extracting (80.7%)
Pulling auth … extracting (81.8%)
Pulling auth … extracting (82.9%)
Pulling auth … extracting (83.9%)
Pulling auth … extracting (85.0%)
Pulling auth … extracting (86.0%)
Pulling auth … extracting (87.1%)
Pulling auth … extracting (88.2%)
Pulling auth … extracting (89.2%)
Pulling auth … extracting (90.3%)
Pulling auth … extracting (91.4%)
Pulling auth … extracting (92.4%)
Pulling auth … extracting (93.5%)
Pulling auth … extracting (94.5%)
Pulling auth … extracting (95.6%)
Pulling auth … extracting (96.7%)
Pulling auth … extracting (97.7%)
Pulling auth … extracting (98.8%)
Pulling auth … extracting (99.9%)
Pulling auth … extracting (100.0%)
Pulling auth … pull complete
Pulling auth … digest: sha256:afcd9065eab02f98ee…
Pulling auth … status: downloaded newer image fo…
Pulling auth … done
Stopping existing containers
Stopping installed apps…
Stopping app bitcoin…
Stopping app electrs…
Stopping app lightning…
Stopping bitcoin_server_1 …
Stopping bitcoin_tor_server_1 …
Stopping bitcoin_bitcoind_1 …
Stopping bitcoin_app_proxy_1 …
Stopping lightning_app_1 …
Stopping lightning_lnd_1 …
Stopping lightning_tor_server_1 …
Stopping lightning_app_proxy_1 …
Stopping electrs_app_1 …
Stopping electrs_tor_server_1 …
Stopping electrs_app_proxy_1 …
Stopping electrs_electrs_1 …
Docker containers
NAMES STATUS
electrs_electrs_1 Restarting (1) 40 seconds ago
Umbrel logs
Attaching to manager
manager | ::ffff:10.21.21.2 - - [Wed, 07 Sep 2022 07:52:32 GMT] “GET /v1/system/update-status HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/105.0.0.0 Safari/537.36”
manager |
manager | umbrel-manager
manager | ::ffff:10.21.21.2 - - [Wed, 07 Sep 2022 07:52:34 GMT] “GET /v1/system/update-status HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/105.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Wed, 07 Sep 2022 07:52:36 GMT] “GET /v1/system/update-status HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/105.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Wed, 07 Sep 2022 07:52:38 GMT] “GET /v1/system/update-status HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/105.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Wed, 07 Sep 2022 07:52:40 GMT] “GET /v1/system/update-status HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/105.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Wed, 07 Sep 2022 07:52:42 GMT] “GET /v1/system/update-status HTTP/1.0” 200 101 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/105.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Wed, 07 Sep 2022 07:52:44 GMT] “GET /v1/system/update-status HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/105.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Wed, 07 Sep 2022 07:52:46 GMT] “GET /v1/system/update-status HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/105.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Wed, 07 Sep 2022 07:52:48 GMT] “GET /v1/system/update-status HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/105.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Wed, 07 Sep 2022 07:52:50 GMT] “GET /v1/system/update-status HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/105.0.0.0 Safari/537.36”
manager |
Tor logs
Attaching to tor
tor | Sep 07 07:48:03.000 [notice] Bootstrapped 25% (requesting_status): Asking for networkstatus consensus
tor | Sep 07 07:48:03.000 [notice] Bootstrapped 30% (loading_status): Loading networkstatus consensus
tor | Sep 07 07:48:06.000 [notice] I learned some more directory information, but not enough to build a circuit: We’re missing descriptors for 1/3 of our primary entry guards (total microdescriptors: 5923/6610). That’s ok. We will try to fetch missing descriptors soon.
tor | Sep 07 07:48:06.000 [notice] Bootstrapped 75% (enough_dirinfo): Loaded enough directory info to build circuits
tor | Sep 07 07:48:06.000 [notice] Bootstrapped 90% (ap_handshake_done): Handshake finished with a relay to build circuits
tor | Sep 07 07:48:06.000 [notice] Bootstrapped 95% (circuit_create): Establishing a Tor circuit
tor | Sep 07 07:48:06.000 [notice] Bootstrapped 100% (done): Done
tor | Sep 07 07:48:26.000 [notice] Your network connection speed appears to have changed. Resetting timeout to 60000ms after 18 timeouts and 657 buildtimes.
tor | Sep 07 07:52:02.000 [notice] Closed 1 streams for service [scrubbed].onion for reason resolve failed. Fetch status: No more HSDir available to query.
tor | Sep 07 07:52:48.000 [notice] New control connection opened from 10.21.21.9.
App logs
bitcoin
tor_server_1 | Sep 05 00:29:27.000 [warn] 13 connections have failed:
tor_server_1 | Sep 05 00:29:27.000 [warn] 12 connections died in state connect()ing with SSL state (No SSL object)
tor_server_1 | Sep 05 00:29:27.000 [warn] 1 connections died in state handshaking (TLS) with SSL state SSLv3/TLS write client hello in HANDSHAKE
tor_server_1 | Sep 05 00:29:27.000 [notice] Bootstrapped 14% (handshake): Handshaking with a relay
tor_server_1 | Sep 05 00:29:27.000 [notice] Bootstrapped 15% (handshake_done): Handshake with a relay done
tor_server_1 | Sep 05 00:29:27.000 [notice] Bootstrapped 75% (enough_dirinfo): Loaded enough directory info to build circuits
tor_server_1 | Sep 05 00:29:27.000 [notice] Bootstrapped 90% (ap_handshake_done): Handshake finished with a relay to build circuits
tor_server_1 | Sep 05 00:29:27.000 [notice] Bootstrapped 95% (circuit_create): Establishing a Tor circuit
tor_server_1 | Sep 05 00:29:27.000 [notice] Bootstrapped 100% (done): Done
tor_server_1 | Sep 05 00:30:01.000 [notice] Unexpected path length 4 for exit circuit 188, purpose 5
tor_server_1 | Sep 05 00:30:33.000 [notice] No circuits are opened. Relaxed timeout for circuit 25 (a Measuring circuit timeout 4-hop circuit in state doing handshakes with channel state open) to 60000ms. However, it appears the circuit has timed out anyway.
tor_server_1 | Sep 07 07:48:36.744 [notice] Tor 0.4.7.7 running on Linux with Libevent 2.1.12-stable, OpenSSL 1.1.1n, Zlib 1.2.11, Liblzma N/A, Libzstd N/A and Glibc 2.31 as libc.
tor_server_1 | Sep 07 07:48:36.744 [notice] Tor can’t help you if you use it wrong! Learn how to be safe at Tor Browser best practices - Security - Tor Browser — Tor
tor_server_1 | Sep 07 07:48:36.744 [notice] Read configuration file “/etc/tor/torrc”.
tor_server_1 | Sep 07 07:48:36.924 [notice] Opening Socks listener on 127.0.0.1:9050
tor_server_1 | Sep 07 07:48:36.924 [notice] Opened Socks listener connection (ready) on 127.0.0.1:9050
tor_server_1 | Sep 07 07:48:37.000 [notice] Bootstrapped 0% (starting): Starting
tor_server_1 | Sep 07 07:48:43.000 [notice] Starting with guard context “default”
tor_server_1 | Sep 07 07:48:44.000 [notice] Bootstrapped 5% (conn): Connecting to a relay
tor_server_1 | Sep 07 07:48:45.000 [notice] Bootstrapped 10% (conn_done): Connected to a relay
tor_server_1 | Sep 07 07:48:47.000 [notice] Bootstrapped 14% (handshake): Handshaking with a relay
tor_server_1 | Sep 07 07:48:47.000 [notice] Bootstrapped 15% (handshake_done): Handshake with a relay done
tor_server_1 | Sep 07 07:48:47.000 [notice] Bootstrapped 20% (onehop_create): Establishing an encrypted directory connection
tor_server_1 | Sep 07 07:48:47.000 [notice] Bootstrapped 25% (requesting_status): Asking for networkstatus consensus
tor_server_1 | Sep 07 07:48:47.000 [notice] Bootstrapped 30% (loading_status): Loading networkstatus consensus
tor_server_1 | Sep 07 07:48:52.000 [notice] Bootstrapped 75% (enough_dirinfo): Loaded enough directory info to build circuits
tor_server_1 | Sep 07 07:48:52.000 [notice] Bootstrapped 90% (ap_handshake_done): Handshake finished with a relay to build circuits
tor_server_1 | Sep 07 07:48:52.000 [notice] Bootstrapped 95% (circuit_create): Establishing a Tor circuit
tor_server_1 | Sep 07 07:48:52.000 [notice] Bootstrapped 100% (done): Done
tor_server_1 | Sep 07 07:52:46.000 [notice] Catching signal TERM, exiting cleanly.
electrs
electrs_1 | [2022-10-22T11:48:24.363Z INFO electrs::db] closing DB at /data/db/bitcoin
electrs_1 | Error: electrs failed
electrs_1 |
electrs_1 | Caused by:
electrs_1 | 0: failed to open bitcoind cookie file: /data/.bitcoin/.cookie
electrs_1 | 1: No such file or directory (os error 2)
electrs_1 | Starting electrs 0.9.4 on aarch64 linux with Config { network: Bitcoin, db_path: “/data/db/bitcoin”, daemon_dir: “/data/.bitcoin”, daemon_auth: CookieFile(“/data/.bitcoin/.cookie”), daemon_rpc_addr: 10.21.21.8:8332, daemon_p2p_addr: 10.21.21.8:8333, electrum_rpc_addr: 0.0.0.0:50001, monitoring_addr: 127.0.0.1:4224, wait_duration: 10s, jsonrpc_timeout: 15s, index_batch_size: 10, index_lookup_limit: None, reindex_last_blocks: 0, auto_reindex: true, ignore_mempool: false, sync_once: false, disable_electrum_rpc: false, server_banner: “Umbrel Electrs (0.9.4-build-2)”, args: }
electrs_1 | [2022-10-22T11:49:25.321Z INFO electrs::metrics::metrics_impl] serving Prometheus metrics on 127.0.0.1:4224
electrs_1 | [2022-10-22T11:49:25.321Z INFO electrs::server] serving Electrum RPC on 0.0.0.0:50001
electrs_1 | [2022-10-22T11:49:25.371Z INFO electrs::db] “/data/db/bitcoin”: 149 SST files, 35.948513893 GB, 4.494010803 Grows
electrs_1 | [2022-10-22T11:49:29.789Z INFO electrs::chain] loading 745064 headers, tip=000000000000000000084653ef142a1b67e4fdf706c7c2b7a8d59acb9c3490e2
electrs_1 | [2022-10-22T11:49:34.047Z INFO electrs::chain] chain updated: tip=000000000000000000084653ef142a1b67e4fdf706c7c2b7a8d59acb9c3490e2, height=745064
electrs_1 | [2022-10-22T11:49:34.078Z INFO electrs::db] closing DB at /data/db/bitcoin
electrs_1 |
electrs_1 | [2022-10-22T11:50:35.055Z INFO electrs::metrics::metrics_impl] serving Prometheus metrics on 127.0.0.1:4224
electrs_1 | [2022-10-22T11:50:35.056Z INFO electrs::server] serving Electrum RPC on 0.0.0.0:50001
electrs_1 | [2022-10-22T11:50:35.106Z INFO electrs::db] “/data/db/bitcoin”: 150 SST files, 35.948514697 GB, 4.494010804 Grows
electrs_1 | [2022-10-22T11:50:39.526Z INFO electrs::chain] loading 745064 headers, tip=000000000000000000084653ef142a1b67e4fdf706c7c2b7a8d59acb9c3490e2
electrs_1 | [2022-10-22T11:50:43.784Z INFO electrs::chain] chain updated: tip=000000000000000000084653ef142a1b67e4fdf706c7c2b7a8d59acb9c3490e2, height=745064
electrs_1 | [2022-10-22T11:50:43.815Z INFO electrs::db] closing DB at /data/db/bitcoin
electrs_1 |
lightning
lnd_1 | 2022-09-07 07:52:24.347 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: the RPC server is in the process of starting up, but not yet ready to accept calls
lnd_1 | 2022-09-07 07:52:25.504 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: the RPC server is in the process of starting up, but not yet ready to accept calls
lnd_1 | 2022-09-07 07:52:27.181 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: the RPC server is in the process of starting up, but not yet ready to accept calls
lnd_1 | 2022-09-07 07:52:28.670 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: the RPC server is in the process of starting up, but not yet ready to accept calls
lnd_1 | 2022-09-07 07:52:29.872 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: the RPC server is in the process of starting up, but not yet ready to accept calls
lnd_1 | 2022-09-07 07:52:31.384 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: the RPC server is in the process of starting up, but not yet ready to accept calls
lnd_1 | 2022-09-07 07:52:32.648 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: the RPC server is in the process of starting up, but not yet ready to accept calls
lnd_1 | 2022-09-07 07:52:34.056 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: the RPC server is in the process of starting up, but not yet ready to accept calls
lnd_1 | 2022-09-07 07:52:35.660 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: the RPC server is in the process of starting up, but not yet ready to accept calls
lnd_1 | 2022-09-07 07:52:36.883 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: the RPC server is in the process of starting up, but not yet ready to accept calls
lnd_1 | 2022-09-07 07:52:38.176 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: the RPC server is in the process of starting up, but not yet ready to accept calls
lnd_1 | 2022-09-07 07:52:39.479 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: the RPC server is in the process of starting up, but not yet ready to accept calls
lnd_1 | 2022-09-07 07:52:41.167 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: the RPC server is in the process of starting up, but not yet ready to accept calls
lnd_1 | 2022-09-07 07:52:42.726 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: the RPC server is in the process of starting up, but not yet ready to accept calls
lnd_1 | 2022-09-07 07:52:44.383 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: the RPC server is in the process of starting up, but not yet ready to accept calls
lnd_1 | 2022-09-07 07:52:45.786 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: the RPC server is in the process of starting up, but not yet ready to accept calls
lnd_1 | 2022-09-07 07:52:47.398 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: the RPC server is in the process of starting up, but not yet ready to accept calls
lnd_1 | 2022-09-07 07:52:47.670 [INF] LTND: Received terminated
lnd_1 | 2022-09-07 07:52:47.670 [INF] LTND: Shutting down…
lnd_1 | 2022-09-07 07:52:47.671 [INF] LTND: Gracefully shutting down.
lnd_1 | 2022-09-07 07:52:48.645 [INF] CHRE: LightningWallet opened
lnd_1 | 2022-09-07 07:52:48.656 [INF] SRVR: Proxying all network traffic via Tor (stream_isolation=false)! NOTE: Ensure the backend node is proxying over Tor as well
lnd_1 | 2022-09-07 07:52:48.656 [INF] TORC: Starting tor controller
lnd_1 | 2022-09-07 07:52:48.744 [INF] HSWC: Cleaning circuits from disk for closed channels
lnd_1 | 2022-09-07 07:52:48.745 [INF] HSWC: Finished cleaning: no closed channels found, no actions taken.
lnd_1 | 2022-09-07 07:52:48.745 [INF] HSWC: Restoring in-memory circuit state from disk
lnd_1 | 2022-09-07 07:52:48.789 [INF] HSWC: Payment circuits loaded: num_pending=0, num_open=0
lnd_1 | 2022-09-07 07:52:49.250 [INF] LTND: Channel backup proxy channel notifier starting
lnd_1 | 2022-09-07 07:52:49.251 [INF] ATPL: Instantiating autopilot with active=false, max_channels=5, allocation=0.600000, min_chan_size=20000, max_chan_size=16777215, private=false, min_confs=1, conf_target=3
lnd_1 | 2022-09-07 07:52:49.253 [INF] LTND: We’re not running within systemd
==== Result ====
