Reflashed microSD, but still will not work
I was unable to even open up the umbrel app from my onion address. I reflashed, and now am at least able to run umbrel and use the apps, however, both my bitcoin node & lightning node apps will not open. I would like to view my wallet to transfer funds but have not been able to for 2 weeks now!
any help would be greatly appreciated.
LOG PASTED HERE:
0.5.4
Flashed OS version
v0.5.4
Raspberry Pi Model
Revision : d03114
Serial : 1000000064f19306
Firmware
May 9 2023 12:16:34
Copyright (c) 2012 Broadcom
Temperature
temp=50.6’C
Throttling
throttled=0x0
Mem: 7.8G 2.5G 2.9G 19M 2.4G 5.2G
Swap: 4.1G 0B 4.1G
total: 31.5%
mempool: 13%
electrs: 7.3%
lightning: 6.1%
bitcoin: 4%
vaultwarden: 2.5%
lightning-terminal: 2.4%
snowflake: 2%
system: 0%
Memory monitor logs
2022-10-13 17:32:35 Warning memory usage at 95%
2022-10-13 17:33:38 Warning memory usage at 95%
2022-12-12 22:07:07 Memory monitor running!
2022-12-12 22:15:17 Memory monitor running!
2022-12-27 18:33:41 Memory monitor running!
2023-04-10 00:13:42 Memory monitor running!
3058 ? S 2:57 bash ./scripts/memory-monitor
2023-06-21 23:07:51 Memory monitor running!
2023-07-03 20:39:27 Memory monitor running!
/dev/root 29G 3.2G 25G 12% /
/dev/sda1 916G 623G 247G 72% /home/umbrel/umbrel
Startup service logs
Jul 03 20:40:03 umbrel umbrel startup[1337]: Creating snowflake_web_1 … done
Jul 03 20:40:03 umbrel umbrel startup[1337]: Creating mempool_mariadb_1 … done
Jul 03 20:40:04 umbrel umbrel startup[1337]: Creating snowflake_app_proxy_1 … done
Jul 03 20:40:04 umbrel umbrel startup[1337]: Creating vaultwarden_app_proxy_1 … done
Jul 03 20:40:05 umbrel umbrel startup[1337]: Creating bitcoin_i2pd_daemon_1 … done
Jul 03 20:40:05 umbrel umbrel startup[1337]: Creating lightning_tor_1 … done
Jul 03 20:40:06 umbrel umbrel startup[1337]: Creating electrs_electrs_1 … done
Jul 03 20:40:07 umbrel umbrel startup[1337]: Creating electrs_app_1 …
Jul 03 20:40:07 umbrel umbrel startup[1337]: Creating lightning_tor_server_1 … done
Jul 03 20:40:08 umbrel umbrel startup[1337]: Creating electrs_app_proxy_1 … done
Jul 03 20:40:08 umbrel umbrel startup[1337]: Creating bitcoin_tor_1 … done
Jul 03 20:40:09 umbrel umbrel startup[1337]: Creating lightning_app_1 … done
Jul 03 20:40:09 umbrel umbrel startup[1337]: Creating electrs_tor_1 … done
Jul 03 20:40:09 umbrel umbrel startup[1337]: Creating lightning_app_proxy_1 … done
Jul 03 20:40:10 umbrel umbrel startup[1337]: Creating lightning_lnd_1 … done
Jul 03 20:40:11 umbrel umbrel startup[1337]: Creating bitcoin_app_proxy_1 … done
Jul 03 20:40:11 umbrel umbrel startup[1337]: Creating bitcoin_bitcoind_1 … done
Jul 03 20:40:11 umbrel umbrel startup[1337]: Creating bitcoin_tor_server_1 … done
Jul 03 20:40:11 umbrel umbrel startup[1337]: Creating bitcoin_server_1 …
Jul 03 20:40:11 umbrel umbrel startup[1337]: Creating electrs_tor_server_1 … done
Jul 03 20:40:13 umbrel umbrel startup[1337]: Creating electrs_app_1 … done
Jul 03 20:40:17 umbrel umbrel startup[1337]: Creating bitcoin_server_1 … done
Jul 03 20:40:18 umbrel umbrel startup[1337]: Umbrel is now accessible at
Jul 03 20:40:18 umbrel umbrel startup[1337]: http://umbrel.local
Jul 03 20:40:18 umbrel umbrel startup[1337]: http://10.0.0.190
Jul 03 20:40:18 umbrel systemd[1]: Started Umbrel Startup Service.
Jul 03 20:52:34 umbrel passwd[19621]: pam_unix(passwd:chauthtok): password changed for umbrel
Jul 03 20:53:40 umbrel passwd[22979]: pam_unix(passwd:chauthtok): password changed for umbrel
Jul 03 21:02:19 umbrel passwd[21120]: pam_unix(passwd:chauthtok): password changed for umbrel
External storage service logs
Jun 22 16:44:12 umbrel external storage mounter[506]: Checking if the device is ext4…
Jun 22 16:44:13 umbrel external storage mounter[506]: Yes, it is ext4
Jun 22 16:44:13 umbrel external storage mounter[506]: Checking filesystem for corruption…
Jun 22 16:44:13 umbrel external storage mounter[506]: e2fsck 1.44.5 (15-Dec-2018)
Jun 22 16:44:14 umbrel external storage mounter[506]: Superblock last write time (Sat Jul 1 02:00:10 2023,
Jun 22 16:44:14 umbrel external storage mounter[506]: now = Thu Jun 22 16:44:13 2023) is in the future.
Jun 22 16:44:14 umbrel external storage mounter[506]: Fix? yes
Jun 22 16:44:14 umbrel external storage mounter[506]: Pass 1: Checking inodes, blocks, and sizes
Jun 22 16:44:21 umbrel external storage mounter[506]: Pass 2: Checking directory structure
Jun 22 16:44:24 umbrel external storage mounter[506]: Pass 3: Checking directory connectivity
Jun 22 16:44:25 umbrel external storage mounter[506]: Pass 4: Checking reference counts
Jun 22 16:44:30 umbrel external storage mounter[506]: Pass 5: Checking group summary information
Jun 22 16:44:30 umbrel external storage mounter[506]: umbrel: 286988/61054976 files (6.5% non-contiguous), 167321830/244190208 blocks
Jun 22 16:44:31 umbrel external storage mounter[506]: Mounting partition…
Jun 22 16:44:31 umbrel external storage mounter[506]: Checking if device contains an Umbrel install…
Jun 22 16:44:31 umbrel external storage mounter[506]: Yes, it contains an Umbrel install
Jun 22 16:44:31 umbrel external storage mounter[506]: Bind mounting external storage over local Umbrel installation…
Jun 22 16:44:31 umbrel external storage mounter[506]: Bind mounting external storage over local Docker data dir…
Jun 22 16:44:31 umbrel external storage mounter[506]: Bind mounting external storage to /swap
Jun 22 16:44:31 umbrel external storage mounter[506]: Bind mounting SD card root at /sd-card…
Jun 22 16:44:31 umbrel external storage mounter[506]: Checking Umbrel root is now on external storage…
Jul 03 20:39:21 umbrel external storage mounter[506]: Checking /var/lib/docker is now on external storage…
Jul 03 20:39:21 umbrel external storage mounter[506]: Checking /swap is now on external storage…
Jul 03 20:39:21 umbrel external storage mounter[506]: Setting up swapfile
Jul 03 20:39:22 umbrel external storage mounter[506]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
Jul 03 20:39:22 umbrel external storage mounter[506]: no label, UUID=b1435d9c-d0f9-47df-9221-2208cb770f9c
Jul 03 20:39:22 umbrel external storage mounter[506]: Checking SD Card root is bind mounted at /sd-root…
Jul 03 20:39:22 umbrel external storage mounter[506]: Starting external drive mount monitor…
Jul 03 20:39:22 umbrel external storage mounter[506]: Mount script completed successfully!
Jul 03 20:39:22 umbrel systemd[1]: Started External Storage Mounter.
– Logs begin at Thu 2023-06-22 16:43:58 UTC, end at Mon 2023-07-03 21:23:06 UTC. –
Jul 03 20:39:27 umbrel systemd[1]: Starting External Storage SDcard Updater…
Jul 03 20:39:27 umbrel external storage updater[1250]: Checking if SD card Umbrel is newer than external storage…
Jul 03 20:39:27 umbrel external storage updater[1250]: No, SD version is not newer, exiting.
Jul 03 20:39:27 umbrel systemd[1]: Started External Storage SDcard Updater.
Umbrel logs
Attaching to manager
manager | ::ffff:10.21.21.2 - - [Mon, 03 Jul 2023 21:23:06 GMT] “GET /v1/system/get-update HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; rv:102.0) Gecko/20100101 Firefox/102.0”
manager |
manager | umbrel-manager
manager | ::ffff:10.21.21.2 - - [Mon, 03 Jul 2023 21:23:06 GMT] “GET /v1/system/memory HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; rv:102.0) Gecko/20100101 Firefox/102.0”
manager |
manager | ::ffff:10.21.21.2 - - [Mon, 03 Jul 2023 21:23:06 GMT] “GET /v1/system/storage HTTP/1.0” 200 1042 “-” “Mozilla/5.0 (Windows NT 10.0; rv:102.0) Gecko/20100101 Firefox/102.0”
manager |
manager | ::ffff:10.21.21.2 - - [Mon, 03 Jul 2023 21:23:06 GMT] “GET /v1/system/is-sd-card-failing HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; rv:102.0) Gecko/20100101 Firefox/102.0”
manager |
manager | ::ffff:10.21.21.2 - - [Mon, 03 Jul 2023 21:23:06 GMT] “GET /v1/apps HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; rv:102.0) Gecko/20100101 Firefox/102.0”
manager |
manager | ::ffff:10.21.21.2 - - [Mon, 03 Jul 2023 21:23:07 GMT] “GET /v1/system/temperature HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; rv:102.0) Gecko/20100101 Firefox/102.0”
manager |
manager | ::ffff:10.21.21.2 - - [Mon, 03 Jul 2023 21:23:07 GMT] “GET /v1/system/info HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; rv:102.0) Gecko/20100101 Firefox/102.0”
manager |
manager | ::ffff:10.21.21.2 - - [Mon, 03 Jul 2023 21:23:07 GMT] “GET /v1/system/debug-result HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; rv:102.0) Gecko/20100101 Firefox/102.0”
manager |
manager | ::ffff:10.21.21.2 - - [Mon, 03 Jul 2023 21:23:09 GMT] “GET /v1/system/debug-result HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; rv:102.0) Gecko/20100101 Firefox/102.0”
manager |
manager | ::ffff:10.21.21.2 - - [Mon, 03 Jul 2023 21:23:11 GMT] “GET /v1/system/debug-result HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; rv:102.0) Gecko/20100101 Firefox/102.0”
manager |
Tor Proxy logs
Attaching to tor_proxy
tor_proxy | Jul 03 20:39:44.000 [notice] Bootstrapped 55% (loading_descriptors): Loading relay descriptors
tor_proxy | Jul 03 20:39:45.000 [notice] Bootstrapped 60% (loading_descriptors): Loading relay descriptors
tor_proxy | Jul 03 20:39:45.000 [notice] Bootstrapped 69% (loading_descriptors): Loading relay descriptors
tor_proxy | Jul 03 20:39:45.000 [notice] Bootstrapped 75% (enough_dirinfo): Loaded enough directory info to build circuits
tor_proxy | Jul 03 20:39:45.000 [notice] Bootstrapped 80% (ap_conn): Connecting to a relay to build circuits
tor_proxy | Jul 03 20:39:46.000 [notice] Bootstrapped 85% (ap_conn_done): Connected to a relay to build circuits
tor_proxy | Jul 03 20:39:46.000 [notice] Bootstrapped 89% (ap_handshake): Finishing handshake with a relay to build circuits
tor_proxy | Jul 03 20:39:46.000 [notice] Bootstrapped 90% (ap_handshake_done): Handshake finished with a relay to build circuits
tor_proxy | Jul 03 20:39:46.000 [notice] Bootstrapped 95% (circuit_create): Establishing a Tor circuit
tor_proxy | Jul 03 20:39:46.000 [notice] Bootstrapped 100% (done): Done
App logs
bitcoin
Attaching to bitcoin_server_1, bitcoin_i2pd_daemon_1, bitcoin_tor_server_1, bitcoin_tor_1, bitcoin_bitcoind_1, bitcoin_app_proxy_1
app_proxy_1 | Validating token: afff8d0a4bb7 …
bitcoind_1 | Error: Settings file could not be read:
bitcoind_1 | - Unable to parse settings file /data/.bitcoin/settings.json
server_1 | umbrel-middleware
server_1 | ::ffff:10.21.0.15 - - [Mon, 03 Jul 2023 21:20:17 GMT] “GET /v1/bitcoind/info/status HTTP/1.1” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; rv:102.0) Gecko/20100101 Firefox/102.0”
server_1 |
server_1 | ::ffff:10.21.0.15 - - [Mon, 03 Jul 2023 21:22:20 GMT] “GET /v1/bitcoind/info/status HTTP/1.1” - - “-” “Mozilla/5.0 (Windows NT 10.0; rv:102.0) Gecko/20100101 Firefox/102.0”
server_1 |
server_1 | ::ffff:10.21.0.15 - - [Mon, 03 Jul 2023 21:22:25 GMT] “GET /v1/bitcoind/info/status HTTP/1.1” 200 21 “-” “Mozilla/5.0 (Windows NT 10.0; rv:102.0) Gecko/20100101 Firefox/102.0”
server_1 |
i2pd_daemon_1 | 21:01:31@605/error - Tunnels: Can’t create inbound tunnel, no peers available
i2pd_daemon_1 | 21:04:31@605/error - Tunnels: Can’t select next hop for wtoKX6F2Z2K~USWY2qQwM-iUYZ4PPKf5HIgNsL1CwA0=
i2pd_daemon_1 | 21:04:31@605/error - Tunnels: Can’t create inbound tunnel, no peers available
i2pd_daemon_1 | 21:10:56@605/error - Tunnels: Can’t select next hop for rul0s-8GDCpm5xMcdq0IReHIJYwkMqSvGsuw6hSRtuk=
i2pd_daemon_1 | 21:10:56@605/error - Tunnels: Can’t create inbound tunnel, no peers available
i2pd_daemon_1 | 21:11:26@605/error - Tunnels: Can’t select next hop for Pzn5G~pNVxv2PBd-KLvwkMLpBmvUa~u9DpXY0YZzmaI=
i2pd_daemon_1 | 21:11:26@605/error - Tunnels: Can’t create inbound tunnel, no peers available
i2pd_daemon_1 | 21:14:56@605/error - Tunnels: Can’t select next hop for QGWIAAybxcU~zps6YmGGNEklZNaf6CJn5PSrs~zfWkQ=
i2pd_daemon_1 | 21:14:56@605/error - Tunnels: Can’t create inbound tunnel, no peers available
i2pd_daemon_1 | 21:17:32@314/error - Garlic: Can’t handle ECIES-X25519-AEAD-Ratchet message
tor_1 | Jul 03 20:40:41.000 [notice] Bootstrapped 55% (loading_descriptors): Loading relay descriptors
tor_1 | Jul 03 20:40:43.000 [notice] Bootstrapped 61% (loading_descriptors): Loading relay descriptors
tor_1 | Jul 03 20:40:45.000 [notice] Bootstrapped 69% (loading_descriptors): Loading relay descriptors
tor_1 | Jul 03 20:40:46.000 [notice] Bootstrapped 75% (enough_dirinfo): Loaded enough directory info to build circuits
tor_1 | Jul 03 20:40:47.000 [notice] Bootstrapped 80% (ap_conn): Connecting to a relay to build circuits
tor_1 | Jul 03 20:40:47.000 [notice] Bootstrapped 85% (ap_conn_done): Connected to a relay to build circuits
tor_1 | Jul 03 20:40:47.000 [notice] Bootstrapped 89% (ap_handshake): Finishing handshake with a relay to build circuits
tor_1 | Jul 03 20:40:47.000 [notice] Bootstrapped 90% (ap_handshake_done): Handshake finished with a relay to build circuits
tor_1 | Jul 03 20:40:47.000 [notice] Bootstrapped 95% (circuit_create): Establishing a Tor circuit
tor_1 | Jul 03 20:40:48.000 [notice] Bootstrapped 100% (done): Done
electrs
Attaching to electrs_app_1, electrs_tor_server_1, electrs_tor_1, electrs_electrs_1, electrs_app_proxy_1
app_1 | Electrum attempting reconnect…
app_proxy_1 | Validating token: fd1a8c9b7ff5 …
tor_1 | Jul 03 20:40:43.000 [notice] Bootstrapped 57% (loading_descriptors): Loading relay descriptors
tor_1 | Jul 03 20:40:44.000 [notice] Bootstrapped 64% (loading_descriptors): Loading relay descriptors
tor_1 | Jul 03 20:40:48.000 [notice] Bootstrapped 90% (ap_handshake_done): Handshake finished with a relay to build circuits
tor_1 | Jul 03 20:40:48.000 [notice] Bootstrapped 95% (circuit_create): Establishing a Tor circuit
electrs_1 | [2023-07-03T21:23:17.926Z INFO electrs::db] closing DB at /data/db/bitcoin
electrs_1 | Error: electrs failed
electrs_1 |
electrs_1 | Caused by:
electrs_1 | 0: failed to open bitcoind cookie file: /data/.bitcoin/.cookie
electrs_1 | 1: No such file or directory (os error 2)
electrs_1 | Starting electrs 0.9.10 on aarch64 linux with Config { network: Bitcoin, db_path: “/data/db/bitcoin”, daemon_dir: “/data/.bitcoin”, daemon_auth: CookieFile(“/data/.bitcoin/.cookie”), daemon_rpc_addr: 10.21.21.8:8332, daemon_p2p_addr: 10.21.21.8:8333, electrum_rpc_addr: 0.0.0.0:50001, monitoring_addr: 127.0.0.1:4224, wait_duration: 10s, jsonrpc_timeout: 15s, index_batch_size: 10, index_lookup_limit: None, reindex_last_blocks: 0, auto_reindex: true, ignore_mempool: false, sync_once: false, disable_electrum_rpc: false, server_banner: “Umbrel Electrs (0.9.10)”, signet_magic: 3652501241, args: }
electrs_1 | [2023-07-03T21:23:19.301Z INFO electrs::metrics::metrics_impl] serving Prometheus metrics on 127.0.0.1:4224
electrs_1 | [2023-07-03T21:23:19.301Z INFO electrs::server] serving Electrum RPC on 0.0.0.0:50001
electrs_1 | [2023-07-03T21:23:19.374Z INFO electrs::db] “/data/db/bitcoin”: 171 SST files, 41.249790401 GB, 5.17023436 Grows
lightning
Attaching to lightning_lnd_1, lightning_app_proxy_1, lightning_app_1, lightning_tor_server_1, lightning_tor_1
app_1 | Waiting for LND…
app_1 | Checking LND status…
app_proxy_1 | Validating token: 724f16d0dfff …
lnd_1 | 2023-07-03 21:21:31.758 [ERR] RPCS: [/lnrpc.Lightning/DescribeGraph]: wallet locked, unlock it to enable full RPC access
lnd_1 | 2023-07-03 21:21:31.783 [ERR] RPCS: [/lnrpc.Lightning/DescribeGraph]: wallet locked, unlock it to enable full RPC access
lnd_1 | 2023-07-03 21:21:53.288 [ERR] RPCS: [/lnrpc.Lightning/DescribeGraph]: wallet locked, unlock it to enable full RPC access
lnd_1 | 2023-07-03 21:21:53.304 [ERR] RPCS: [/lnrpc.Lightning/DescribeGraph]: wallet locked, unlock it to enable full RPC access
lnd_1 | 2023-07-03 21:22:14.185 [ERR] RPCS: [/lnrpc.Lightning/DescribeGraph]: wallet locked, unlock it to enable full RPC access
lnd_1 | 2023-07-03 21:22:14.203 [ERR] RPCS: [/lnrpc.Lightning/DescribeGraph]: wallet locked, unlock it to enable full RPC access
lnd_1 | 2023-07-03 21:22:35.080 [ERR] RPCS: [/lnrpc.Lightning/DescribeGraph]: wallet locked, unlock it to enable full RPC access
lnd_1 | 2023-07-03 21:22:35.097 [ERR] RPCS: [/lnrpc.Lightning/DescribeGraph]: wallet locked, unlock it to enable full RPC access
lnd_1 | 2023-07-03 21:23:01.518 [ERR] RPCS: [/lnrpc.Lightning/DescribeGraph]: wallet locked, unlock it to enable full RPC access
lnd_1 | 2023-07-03 21:23:01.541 [ERR] RPCS: [/lnrpc.Lightning/DescribeGraph]: wallet locked, unlock it to enable full RPC access
tor_1 | Jul 03 20:40:43.000 [notice] Bootstrapped 60% (loading_descriptors): Loading relay descriptors
tor_1 | Jul 03 20:40:44.000 [notice] Bootstrapped 69% (loading_descriptors): Loading relay descriptors
tor_1 | Jul 03 20:40:45.000 [notice] Bootstrapped 75% (enough_dirinfo): Loaded enough directory info to build circuits
tor_1 | Jul 03 20:40:45.000 [notice] Bootstrapped 80% (ap_conn): Connecting to a relay to build circuits
tor_1 | Jul 03 20:40:45.000 [notice] Bootstrapped 85% (ap_conn_done): Connected to a relay to build circuits
tor_1 | Jul 03 20:40:46.000 [notice] Bootstrapped 89% (ap_handshake): Finishing handshake with a relay to build circuits
tor_1 | Jul 03 20:40:46.000 [notice] Bootstrapped 90% (ap_handshake_done): Handshake finished with a relay to build circuits
tor_1 | Jul 03 20:40:46.000 [notice] Bootstrapped 95% (circuit_create): Establishing a Tor circuit
tor_1 | Jul 03 20:40:50.000 [notice] Bootstrapped 100% (done): Done
lightning-terminal
Attaching to lightning-terminal_web_1, lightning-terminal_app_proxy_1, lightning-terminal_tor_server_1
app_proxy_1 | [HPM] Proxy created: / → http://lightning-terminal_web_1:3004
app_proxy_1 | Waiting for lightning-terminal_web_1:3004 to open…
app_proxy_1 | Lightning Terminal is now ready…
app_proxy_1 | Listening on port: 3004
web_1 | LiT Version 0.10.1-alpha commit=v0.10.1-alpha
web_1 | Web interface 127.0.0.1:8443, 0.0.0.0:3004 (open https://127.0.0.1:8443 or http://localhost:3004 in your browser)
web_1 | ----------------------------------------------------------
web_1 | 2023-07-03 20:40:17.439 [INF] LITD: Connecting basic lnd client
web_1 | 2023-07-03 20:40:17.643 [INF] LITD: Connecting full lnd client
web_1 | 2023-07-03 20:40:17.643 [INF] LNDC: Creating lnd connection to 10.21.21.9:10009
web_1 | 2023-07-03 20:40:17.656 [INF] LNDC: Connected to lnd
web_1 | 2023-07-03 20:40:17.779 [INF] LNDC: Waiting for lnd to unlock
web_1 | 2023-07-03 20:40:17.900 [INF] LNDC: Wallet state of lnd is now: Lnd is waiting to start
web_1 | 2023-07-03 20:40:36.816 [INF] LNDC: Wallet state of lnd is now: Wallet is locked
mempool
Attaching to mempool_api_1, mempool_web_1, mempool_mariadb_1, mempool_tor_server_1, mempool_app_proxy_1
app_proxy_1 | [HPM] Upgrading to WebSocket
app_proxy_1 | [HPM] Client disconnected
api_1 | Jul 3 21:23:25 [110] NOTICE: Mempool Server is running on port 8999
api_1 | Jul 3 21:23:25 [110] INFO: Disconnected from Electrum Server at 10.21.21.10:50001
api_1 | Jul 3 21:23:25 [110] ERR: Error connecting to Electrum Server at 10.21.21.10:50001
api_1 | Jul 3 21:23:25 [110] ERR: [Lightning] $runTasks() error: Request failed with status code 500
api_1 | Jul 3 21:23:25 [110] INFO: [Lightning] Starting Lightning Stats service
api_1 | Jul 3 21:23:25 [110] ERR: Exception in $logStatsDaily. Reason: Request failed with status code 500
api_1 | Jul 3 21:23:25 [110] INFO: Starting lightning network forensics service
api_1 | Jul 3 21:23:25 [110] INFO: Running forensics scans
api_1 | Jul 3 21:23:25 [110] INFO: [Lightning] Caching funding txs for currently existing channels
api_1 | Jul 3 21:23:26 [110] INFO: [Mining] Fetching daily price history from exchanges and saving missing ones into the database
web_1 | /var/www/mempool/browser/resources
mariadb_1 | 2023-07-03 21:21:35 199 [Warning] Aborted connection 199 to db: ‘mempool’ user: ‘mempool’ host: ‘10.21.21.27’ (Got an error reading communication packets)
mariadb_1 | 2023-07-03 21:21:36 200 [Warning] Aborted connection 200 to db: ‘unconnected’ user: ‘unauthenticated’ host: ‘10.21.21.27’ (This connection closed normally without authentication)
mariadb_1 | 2023-07-03 21:21:56 201 [Warning] Aborted connection 201 to db: ‘mempool’ user: ‘mempool’ host: ‘10.21.21.27’ (Got an error reading communication packets)
mariadb_1 | 2023-07-03 21:21:57 202 [Warning] Aborted connection 202 to db: ‘unconnected’ user: ‘unauthenticated’ host: ‘10.21.21.27’ (This connection closed normally without authentication)
mariadb_1 | 2023-07-03 21:22:17 203 [Warning] Aborted connection 203 to db: ‘mempool’ user: ‘mempool’ host: ‘10.21.21.27’ (Got an error reading communication packets)
mariadb_1 | 2023-07-03 21:22:18 204 [Warning] Aborted connection 204 to db: ‘unconnected’ user: ‘unauthenticated’ host: ‘10.21.21.27’ (This connection closed normally without authentication)
mariadb_1 | 2023-07-03 21:22:38 205 [Warning] Aborted connection 205 to db: ‘mempool’ user: ‘mempool’ host: ‘10.21.21.27’ (Got an error reading communication packets)
mariadb_1 | 2023-07-03 21:22:39 206 [Warning] Aborted connection 206 to db: ‘unconnected’ user: ‘unauthenticated’ host: ‘10.21.21.27’ (This connection closed normally without authentication)
mariadb_1 | 2023-07-03 21:23:04 207 [Warning] Aborted connection 207 to db: ‘mempool’ user: ‘mempool’ host: ‘10.21.21.27’ (Got an error reading communication packets)
mariadb_1 | 2023-07-03 21:23:06 208 [Warning] Aborted connection 208 to db: ‘unconnected’ user: ‘unauthenticated’ host: ‘10.21.21.27’ (This connection closed normally without authentication)
snowflake
Attaching to snowflake_tor_server_1, snowflake_web_1, snowflake_app_proxy_1, snowflake_proxy_1
app_proxy_1 | Waiting for snowflake_web_1:3800 to open…
app_proxy_1 | Tor Snowflake Proxy is now ready…
app_proxy_1 | Listening on port: 3800
proxy_1 | 2023/07/03 21:14:20 Timed out waiting for client to open data channel.
proxy_1 | 2023/07/03 21:15:41 sdp offer successfully received.
proxy_1 | 2023/07/03 21:15:41 Generating answer…
proxy_1 | 2023/07/03 21:16:06 Timed out waiting for client to open data channel.
proxy_1 | 2023/07/03 21:19:39 sdp offer successfully received.
proxy_1 | 2023/07/03 21:19:39 Generating answer…
proxy_1 | 2023/07/03 21:20:04 Timed out waiting for client to open data channel.
proxy_1 | 2023/07/03 21:20:45 sdp offer successfully received.
proxy_1 | 2023/07/03 21:20:45 Generating answer…
proxy_1 | 2023/07/03 21:21:10 Timed out waiting for client to open data channel.
web_1 | 2023/07/03 20:49:01 10.21.0.11:52924 200 GET /js/hterm.js
web_1 | 2023/07/03 20:49:01 10.21.0.11:52926 200 GET /auth_token.js
web_1 | 2023/07/03 20:49:01 10.21.0.11:52928 200 GET /js/gotty.js
web_1 | 2023/07/03 20:49:01 New client connected: 10.21.0.11:52930
web_1 | 2023/07/03 20:49:01 10.21.0.11:52934 200 GET /favicon.png
web_1 | 2023/07/03 20:49:01 Command is running for client 10.21.0.11:52930 with PID 14 (args=“-c tail -n 10000 -f /snowflake/snowflake.log | grep "Traffic Relayed"”), connections: 1
web_1 | 2023/07/03 20:49:01 10.21.0.11:52930 101 GET /ws
web_1 | 2023/07/03 20:49:12 websocket: close 1001
web_1 | 2023/07/03 20:49:12 Connection closed: 10.21.0.11:52930, connections: 0
web_1 | 2023/07/03 20:49:12 Command exited for: 10.21.0.11:52930
vaultwarden
Attaching to vaultwarden_server_1, vaultwarden_app_proxy_1, vaultwarden_tor_server_1
app_proxy_1 | [HPM] Proxy created: / → http://10.21.21.46:8089
app_proxy_1 | Waiting for 10.21.21.46:8089 to open…
app_proxy_1 | Vaultwarden is now ready…
app_proxy_1 | Listening on port: 8089
server_1 | [2023-07-03 20:58:34.143][request][INFO] PUT /api/ciphers/delete
server_1 | [2023-07-03 20:58:34.179][response][INFO] (delete_cipher_selected_put) PUT /api/ciphers/delete => 200 OK
server_1 | [2023-07-03 20:59:03.343][request][INFO] POST /api/ciphers
server_1 | [2023-07-03 20:59:03.349][response][INFO] (post_ciphers) POST /api/ciphers => 200 OK
server_1 | [2023-07-03 20:59:17.919][request][INFO] PUT /api/ciphers/3135df73-f3b7-4971-bd65-e6f067ec1243
server_1 | [2023-07-03 20:59:17.925][response][INFO] (put_cipher) PUT /api/ciphers/ => 200 OK
server_1 | [2023-07-03 20:59:40.452][request][INFO] POST /api/ciphers
server_1 | [2023-07-03 20:59:40.458][response][INFO] (post_ciphers) POST /api/ciphers => 200 OK
server_1 | [2023-07-03 21:00:12.950][request][INFO] DELETE /api/ciphers
server_1 | [2023-07-03 21:00:13.022][response][INFO] (delete_cipher_selected) DELETE /api/ciphers => 200 OK
==== Result ====
