Here is the Umbrel logs. Currently I can not sync my node.
0.5.4
Flashed OS version
v0.5.4
Raspberry Pi Model
Revision : d03115
Serial : 100000007decb32e
Firmware
May 9 2023 12:16:34
Copyright (c) 2012 Broadcom
Temperature
temp=54.5’C
Throttling
throttled=0x0
Mem: 7.8G 2.0G 3.9G 18M 1.9G 5.7G
Swap: 4.1G 0B 4.1G
total: 25.8%
electrs: 5.4%
lightning: 4.8%
mempool: 3.6%
bitcoin: 3.2%
system: 2.7%
lnbits: 2.4%
core-lightning: 2.2%
chatpad-ai: 1.5%
Memory monitor logs
2023-07-02 13:30:57 Memory monitor running!
2023-07-02 14:01:08 Memory monitor running!
3074 ? S 0:00 bash ./scripts/memory-monitor
2023-07-02 15:19:33 Memory monitor running!
2023-07-02 23:40:34 Memory monitor running!
2023-07-03 19:41:13 Memory monitor running!
2023-07-03 19:45:02 Memory monitor running!
2023-07-03 19:51:01 Memory monitor running!
2023-07-03 20:17:24 Memory monitor running!
/dev/root 119G 5.2G 110G 5% /
/dev/sda1 1.8T 624G 1.1T 36% /home/umbrel/umbrel
Startup service logs
Jul 03 20:18:41 umbrel umbrel startup[1070]: Creating bitcoin_bitcoind_1 … done
Jul 03 20:18:41 umbrel umbrel startup[1070]: Creating bitcoin_server_1 …
Jul 03 20:18:43 umbrel umbrel startup[1070]: Creating core-lightning_app_proxy_1 … done
Jul 03 20:18:43 umbrel umbrel startup[1070]: Creating core-lightning_tor_1 … done
Jul 03 20:18:53 umbrel umbrel startup[1070]: Creating chatpad-ai_web_1 … done
Jul 03 20:18:56 umbrel umbrel startup[1070]: Creating core-lightning_app_1 … done
Jul 03 20:19:01 umbrel umbrel startup[1070]: Creating core-lightning_c-lightning-rest_1 … done
Jul 03 20:19:06 umbrel umbrel startup[1070]: Creating lightning_app_1 … done
Jul 03 20:19:11 umbrel umbrel startup[1070]: Creating lightning_app_proxy_1 … done
Jul 03 20:19:14 umbrel umbrel startup[1070]: Creating lnbits_web_1 … done
Jul 03 20:19:14 umbrel umbrel startup[1070]: Creating lightning_lnd_1 … done
Jul 03 20:19:14 umbrel umbrel startup[1070]: Creating electrs_app_proxy_1 … done
Jul 03 20:19:15 umbrel umbrel startup[1070]: Creating electrs_tor_1 … done
Jul 03 20:19:16 umbrel umbrel startup[1070]: Creating bitcoin_tor_1 … done
Jul 03 20:19:17 umbrel umbrel startup[1070]: Creating electrs_electrs_1 … done
Jul 03 20:19:17 umbrel umbrel startup[1070]: Creating electrs_app_1 …
Jul 03 20:19:17 umbrel umbrel startup[1070]: Creating chatpad-ai_app_proxy_1 … done
Jul 03 20:19:23 umbrel umbrel startup[1070]: Creating lightning_tor_1 … done
Jul 03 20:19:24 umbrel umbrel startup[1070]: Creating lnbits_app_proxy_1 … done
Jul 03 20:19:35 umbrel umbrel startup[1070]: Creating mempool_web_1 … done
Jul 03 20:19:35 umbrel umbrel startup[1070]: Creating mempool_mariadb_1 … done
Jul 03 20:19:39 umbrel umbrel startup[1070]: Creating bitcoin_i2pd_daemon_1 … done
Jul 03 20:19:40 umbrel umbrel startup[1070]: Creating core-lightning_lightningd_1 … done
Jul 03 20:19:41 umbrel umbrel startup[1070]: Creating bitcoin_server_1 … done
Jul 03 20:19:54 umbrel umbrel startup[1070]: Creating mempool_api_1 … done
Jul 03 20:20:28 umbrel umbrel startup[1070]: Creating electrs_app_1 … done
Jul 03 20:20:28 umbrel umbrel startup[1070]: Umbrel is now accessible at
Jul 03 20:20:28 umbrel umbrel startup[1070]: http://umbrel.local
Jul 03 20:20:28 umbrel umbrel startup[1070]: http://192.168.0.168
Jul 03 20:20:28 umbrel systemd[1]: Started Umbrel Startup Service.
External storage service logs
Jul 03 20:16:45 umbrel external storage mounter[489]: Running external storage mount script…
Jul 03 20:16:45 umbrel external storage mounter[489]: Found device “WD My Passport 2626”
Jul 03 20:16:45 umbrel external storage mounter[489]: Blacklisting USB device IDs against UAS driver…
Jul 03 20:16:45 umbrel external storage mounter[489]: Rebinding USB drivers…
Jul 03 20:16:46 umbrel external storage mounter[489]: Checking USB devices are back…
Jul 03 20:16:46 umbrel external storage mounter[489]: Waiting for USB devices…
Jul 03 20:16:47 umbrel external storage mounter[489]: Waiting for USB devices…
Jul 03 20:16:48 umbrel external storage mounter[489]: Waiting for USB devices…
Jul 03 20:16:49 umbrel external storage mounter[489]: Checking if the device is ext4…
Jul 03 20:16:49 umbrel external storage mounter[489]: Yes, it is ext4
Jul 03 20:16:49 umbrel external storage mounter[489]: Checking filesystem for corruption…
Jul 03 20:16:49 umbrel external storage mounter[489]: e2fsck 1.44.5 (15-Dec-2018)
Jul 03 20:16:50 umbrel external storage mounter[489]: umbrel: clean, 380787/122093568 files, 171338666/488369920 blocks
Jul 03 20:16:50 umbrel external storage mounter[489]: Mounting partition…
Jul 03 20:16:50 umbrel external storage mounter[489]: Checking if device contains an Umbrel install…
Jul 03 20:16:50 umbrel external storage mounter[489]: Yes, it contains an Umbrel install
Jul 03 20:16:51 umbrel external storage mounter[489]: Bind mounting external storage over local Umbrel installation…
Jul 03 20:16:51 umbrel external storage mounter[489]: Bind mounting external storage over local Docker data dir…
Jul 03 20:16:51 umbrel external storage mounter[489]: Bind mounting external storage to /swap
Jul 03 20:16:51 umbrel external storage mounter[489]: Bind mounting SD card root at /sd-card…
Jul 03 20:16:51 umbrel external storage mounter[489]: Checking Umbrel root is now on external storage…
Jul 03 20:16:52 umbrel external storage mounter[489]: Checking /var/lib/docker is now on external storage…
Jul 03 20:16:52 umbrel external storage mounter[489]: Checking /swap is now on external storage…
Jul 03 20:16:52 umbrel external storage mounter[489]: Setting up swapfile
Jul 03 20:16:59 umbrel external storage mounter[489]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
Jul 03 20:16:59 umbrel external storage mounter[489]: no label, UUID=020d0283-a2bc-4568-87b5-a7d2e0f07520
Jul 03 20:16:59 umbrel external storage mounter[489]: Checking SD Card root is bind mounted at /sd-root…
Jul 03 20:16:59 umbrel external storage mounter[489]: Starting external drive mount monitor…
Jul 03 20:16:59 umbrel external storage mounter[489]: Mount script completed successfully!
Jul 03 20:16:59 umbrel systemd[1]: Started External Storage Mounter.
– Logs begin at Mon 2023-07-03 20:16:40 UTC, end at Mon 2023-07-03 21:07:26 UTC. –
Jul 03 20:17:11 umbrel systemd[1]: Starting External Storage SDcard Updater…
Jul 03 20:17:11 umbrel external storage updater[991]: Checking if SD card Umbrel is newer than external storage…
Jul 03 20:17:11 umbrel external storage updater[991]: No, SD version is not newer, exiting.
Jul 03 20:17:11 umbrel systemd[1]: Started External Storage SDcard Updater.
Karen logs
Removing electrs_electrs_1 … done
Removing electrs_app_1 … done
Removing electrs_app_proxy_1 … done
Removing electrs_tor_1 … done
Going to remove electrs_app_1, electrs_electrs_1, electrs_app_proxy_1, electrs_tor_1
Stopping core-lightning_app_1 … done
Removing core-lightning_app_1 …
Removing core-lightning_c-lightning-rest_1 …
Removing core-lightning_tor_1 …
Removing core-lightning_app_proxy_1 …
Removing core-lightning_lightningd_1 …
Removing core-lightning_tor_1 … done
Removing core-lightning_lightningd_1 … done
Removing core-lightning_app_1 … done
Removing core-lightning_app_proxy_1 … done
Removing core-lightning_c-lightning-rest_1 … done
Going to remove core-lightning_app_1, core-lightning_c-lightning-rest_1, core-lightning_tor_1, core-lightning_app_proxy_1, core-lightning_lightningd_1
Stopping Docker services…
Stopping nginx …
Stopping auth …
Stopping dashboard …
Stopping tor_proxy …
Stopping manager …
Stopping tor_proxy … done
Stopping auth … done
Stopping nginx … done
Stopping dashboard … done
Stopping manager … done
Removing nginx …
Removing auth …
Removing dashboard …
Removing tor_proxy …
Removing manager …
Removing auth … done
Removing nginx … done
Removing manager … done
Removing tor_proxy … done
Removing dashboard … done
Got signal:
karen is getting triggered!
Got signal:
Got signal: debug
Docker containers
NAMES STATUS
electrs_app_1 Up 46 minutes
bitcoin_server_1 Up 47 minutes
core-lightning_lightningd_1 Restarting (1) Less than a second ago
core-lightning_c-lightning-rest_1 Restarting (1) 1 second ago
mempool_app_proxy_1 Up 48 minutes
mempool_web_1 Up 47 minutes
mempool_api_1 Up 47 minutes
core-lightning_app_proxy_1 Up 48 minutes
mempool_mariadb_1 Up 47 minutes
core-lightning_tor_1 Up 48 minutes
core-lightning_app_1 Up 48 minutes
lightning_lnd_1 Up 48 minutes
bitcoin_i2pd_daemon_1 Up 47 minutes
bitcoin_bitcoind_1 Restarting (1) Less than a second ago
bitcoin_tor_1 Up 48 minutes
bitcoin_app_proxy_1 Up 48 minutes
electrs_app_proxy_1 Up 48 minutes
electrs_electrs_1 Restarting (1) Less than a second ago
electrs_tor_1 Up 48 minutes
lnbits_app_proxy_1 Up 48 minutes
lnbits_web_1 Up 48 minutes
chatpad-ai_app_proxy_1 Up 48 minutes
chatpad-ai_web_1 Up 48 minutes
nginx Up 49 minutes
auth Up 49 minutes
manager Up 49 minutes
dashboard Up 49 minutes
tor_proxy Up 49 minutes
Umbrel logs
Attaching to manager
manager | ::ffff:10.21.21.2 - - [Mon, 03 Jul 2023 21:07:23 GMT] “GET /v1/system/debug-result HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/114.0.0.0 Safari/537.36”
manager |
manager | umbrel-manager
manager | ::ffff:10.21.21.2 - - [Mon, 03 Jul 2023 21:07:24 GMT] “GET /v1/system/debug-result HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/114.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.0.3 - - [Mon, 03 Jul 2023 21:07:24 GMT] “GET /v1/account/token?token=1e1e15655236213d2a79730a4293cae13fb3d25cf39a4cd9542623852a9c7760 HTTP/1.1” 200 16 “-” “app-proxy/0.0.1”
manager |
manager | ::ffff:10.21.21.2 - - [Mon, 03 Jul 2023 21:07:25 GMT] “GET /v1/system/debug-result HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/114.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Mon, 03 Jul 2023 21:07:26 GMT] “GET /v1/system/update-status HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/114.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.0.3 - - [Mon, 03 Jul 2023 21:07:26 GMT] “GET /v1/account/token?token=1e1e15655236213d2a79730a4293cae13fb3d25cf39a4cd9542623852a9c7760 HTTP/1.1” 200 16 “-” “app-proxy/0.0.1”
manager |
manager | ::ffff:10.21.21.2 - - [Mon, 03 Jul 2023 21:07:26 GMT] “GET /v1/system/debug-result HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/114.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Mon, 03 Jul 2023 21:07:27 GMT] “GET /v1/system/debug-result HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/114.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.0.3 - - [Mon, 03 Jul 2023 21:07:28 GMT] “GET /v1/account/token?token=1e1e15655236213d2a79730a4293cae13fb3d25cf39a4cd9542623852a9c7760 HTTP/1.1” 200 16 “-” “app-proxy/0.0.1”
manager |
manager | ::ffff:10.21.21.2 - - [Mon, 03 Jul 2023 21:07:28 GMT] “GET /v1/system/debug-result HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/114.0.0.0 Safari/537.36”
manager |
Tor Proxy logs
Attaching to tor_proxy
tor_proxy | Jul 03 21:04:19.000 [notice] New control connection opened from 10.21.21.96.
tor_proxy | Jul 03 21:04:39.000 [notice] New control connection opened from 10.21.21.96.
tor_proxy | Jul 03 21:04:59.000 [notice] New control connection opened from 10.21.21.96.
tor_proxy | Jul 03 21:05:22.000 [notice] New control connection opened from 10.21.21.96.
tor_proxy | Jul 03 21:05:42.000 [notice] New control connection opened from 10.21.21.96.
tor_proxy | Jul 03 21:06:02.000 [notice] New control connection opened from 10.21.21.96.
tor_proxy | Jul 03 21:06:23.000 [notice] New control connection opened from 10.21.21.96.
tor_proxy | Jul 03 21:06:44.000 [notice] New control connection opened from 10.21.21.96.
tor_proxy | Jul 03 21:07:06.000 [notice] New control connection opened from 10.21.21.96.
tor_proxy | Jul 03 21:07:29.000 [notice] New control connection opened from 10.21.21.96.
App logs
bitcoin
Attaching to bitcoin_server_1, bitcoin_i2pd_daemon_1, bitcoin_bitcoind_1, bitcoin_tor_1, bitcoin_app_proxy_1
app_proxy_1 | Validating token: 1e1e15655236 …
server_1 | umbrel-middleware
server_1 | ::ffff:10.21.0.3 - - [Mon, 03 Jul 2023 21:07:28 GMT] “GET /v1/bitcoind/info/status HTTP/1.1” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/114.0.0.0 Safari/537.36”
server_1 |
server_1 | ::ffff:10.21.0.3 - - [Mon, 03 Jul 2023 21:07:30 GMT] “GET /v1/bitcoind/info/status HTTP/1.1” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/114.0.0.0 Safari/537.36”
server_1 |
server_1 | ::ffff:10.21.0.3 - - [Mon, 03 Jul 2023 21:07:32 GMT] “GET /v1/bitcoind/info/status HTTP/1.1” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/114.0.0.0 Safari/537.36”
server_1 |
tor_1 | Jul 03 20:20:43.000 [notice] Bootstrapped 56% (loading_descriptors): Loading relay descriptors
tor_1 | Jul 03 20:20:43.000 [notice] Bootstrapped 63% (loading_descriptors): Loading relay descriptors
tor_1 | Jul 03 20:20:43.000 [notice] Bootstrapped 68% (loading_descriptors): Loading relay descriptors
tor_1 | Jul 03 20:20:44.000 [notice] Bootstrapped 75% (enough_dirinfo): Loaded enough directory info to build circuits
tor_1 | Jul 03 20:20:44.000 [notice] Bootstrapped 80% (ap_conn): Connecting to a relay to build circuits
tor_1 | Jul 03 20:20:44.000 [notice] Bootstrapped 85% (ap_conn_done): Connected to a relay to build circuits
tor_1 | Jul 03 20:20:46.000 [notice] Bootstrapped 89% (ap_handshake): Finishing handshake with a relay to build circuits
tor_1 | Jul 03 20:20:46.000 [notice] Bootstrapped 90% (ap_handshake_done): Handshake finished with a relay to build circuits
tor_1 | Jul 03 20:20:46.000 [notice] Bootstrapped 95% (circuit_create): Establishing a Tor circuit
tor_1 | Jul 03 20:20:48.000 [notice] Bootstrapped 100% (done): Done
bitcoind_1 | 2023-07-03T21:07:28Z * Using 53.4 MiB for transaction index database
bitcoind_1 | 2023-07-03T21:07:28Z * Using 46.7 MiB for basic block filter index database
bitcoind_1 | 2023-07-03T21:07:28Z * Using 8.0 MiB for chain state database
bitcoind_1 | 2023-07-03T21:07:28Z * Using 318.9 MiB for in-memory UTXO set (plus up to 286.1 MiB of unused mempool space)
bitcoind_1 | 2023-07-03T21:07:28Z init message: Loading block index…
bitcoind_1 | 2023-07-03T21:07:28Z Assuming ancestors of block 000000000000000000035c3f0d31e71a5ee24c5aaf3354689f65bd7b07dee632 have valid signatures.
bitcoind_1 | 2023-07-03T21:07:28Z Setting nMinimumChainWork=000000000000000000000000000000000000000044a50fe819c39ad624021859
bitcoind_1 | 2023-07-03T21:07:28Z Opening LevelDB in /data/.bitcoin/blocks/index
bitcoind_1 | 2023-07-03T21:07:28Z Opened LevelDB successfully
bitcoind_1 | 2023-07-03T21:07:28Z Using obfuscation key for /data/.bitcoin/blocks/index: 0000000000000000
i2pd_daemon_1 | 20:38:07@158/error - Tunnel: Tunnel with id 672967073 already exists
i2pd_daemon_1 | 20:40:04@502/error - SSU2: RelayIntro unknown router to introduce
i2pd_daemon_1 | 20:41:37@55/error - Garlic: Can’t handle ECIES-X25519-AEAD-Ratchet message
i2pd_daemon_1 | 20:43:31@55/error - Garlic: Can’t handle ECIES-X25519-AEAD-Ratchet message
i2pd_daemon_1 | 20:56:39@55/error - Garlic: Can’t handle ECIES-X25519-AEAD-Ratchet message
i2pd_daemon_1 | 20:56:58@55/error - Streaming: No packets have been received yet
i2pd_daemon_1 | 20:57:06@55/error - Garlic: Can’t handle ECIES-X25519-AEAD-Ratchet message
i2pd_daemon_1 | 21:05:59@502/error - SSU2: RelayIntro unknown router to introduce
i2pd_daemon_1 | 21:06:46@158/error - Tunnels: Can’t select next hop for JAUAarUxr65F776Npkst1kpzN12OuiH~EMDX-lC0j24=
i2pd_daemon_1 | 21:06:46@158/error - Tunnels: Can’t create inbound tunnel, no peers available
core-lightning
Attaching to core-lightning_lightningd_1, core-lightning_c-lightning-rest_1, core-lightning_app_proxy_1, core-lightning_tor_1, core-lightning_app_1
app_1 | 2023/07/03 21:07:37 socat[29403] E connect(5, AF=1 “/root/.lightning/bitcoin/lightning-rpc”, 40): Connection refused
app_1 |
app_1 | Waiting for lightningd
app_1 | 2023/07/03 21:07:37 socat[29408] E connect(5, AF=1 “/root/.lightning/bitcoin/lightning-rpc”, 40): Connection refused
app_1 |
app_1 | 2023/07/03 21:07:38 socat[29414] E connect(5, AF=1 “/root/.lightning/bitcoin/lightning-rpc”, 40): Connection refused
app_1 |
app_1 | 2023/07/03 21:07:38 socat[29419] E connect(5, AF=1 “/root/.lightning/bitcoin/lightning-rpc”, 40): Connection refused
app_proxy_1 | [HPM] Proxy created: / → http://10.21.21.94:2103
app_proxy_1 | Waiting for 10.21.21.94:2103 to open…
c-lightning-rest_1 | at Socket. (/usr/src/app/lightning-client-js.js:82:23)
c-lightning-rest_1 | at Socket.emit (node:events:513:28)
c-lightning-rest_1 | at emitErrorNT (node:internal/streams/destroy:157:8)
c-lightning-rest_1 | at emitErrorCloseNT (node:internal/streams/destroy:122:3)
c-lightning-rest_1 | at processTicksAndRejections (node:internal/process/task_queues:83:21) {
c-lightning-rest_1 | errno: -111,
c-lightning-rest_1 | code: ‘ECONNREFUSED’,
c-lightning-rest_1 | syscall: ‘connect’,
c-lightning-rest_1 | address: ‘/root/.lightning/bitcoin/lightning-rpc’
c-lightning-rest_1 | }
lightningd_1 |
lightningd_1 | You can verify that your Bitcoin Core installation is ready for use by running:
lightningd_1 |
lightningd_1 | $ bitcoin-cli -rpcconnect=10.21.21.8 -rpcuser=… -stdinrpcpass echo ‘hello world’
lightningd_1 | 2023-07-03T21:07:25.921Z UNUSUAL plugin-bcli: Waiting for bitcoind to warm up…
lightningd_1 | 2023-07-03T21:07:25.921Z BROKEN plugin-bcli: \nCould not connect to bitcoind using bitcoin-cli. Is bitcoind running?\n\nMake sure you have bitcoind running and that bitcoin-cli is able to connect to bitcoind.\n\nYou can verify that your Bitcoin Core installation is ready for use by running:\n\n $ bitcoin-cli -rpcconnect=10.21.21.8 -rpcuser=… -stdinrpcpass echo ‘hello world’\n
lightningd_1 | The Bitcoin backend died.
lightningd_1 | 2023-07-03T21:07:25.928Z INFO plugin-bcli: Killing plugin: exited before we sent init
lightningd_1 | 2023-07-03T21:07:29.952Z UNUSUAL connectd: Bound to websocket 10.21.21.96:2106, but we cannot announce the websocket as we don’t announce anything else!
tor_1 | Jul 03 20:18:53.000 [notice] Bootstrapped 57% (loading_descriptors): Loading relay descriptors
tor_1 | Jul 03 20:19:22.000 [notice] Bootstrapped 64% (loading_descriptors): Loading relay descriptors
tor_1 | Jul 03 20:19:22.000 [notice] Bootstrapped 69% (loading_descriptors): Loading relay descriptors
tor_1 | Jul 03 20:19:23.000 [notice] Bootstrapped 75% (enough_dirinfo): Loaded enough directory info to build circuits
tor_1 | Jul 03 20:19:23.000 [notice] Bootstrapped 80% (ap_conn): Connecting to a relay to build circuits
tor_1 | Jul 03 20:19:23.000 [notice] Bootstrapped 85% (ap_conn_done): Connected to a relay to build circuits
tor_1 | Jul 03 20:19:23.000 [notice] Bootstrapped 89% (ap_handshake): Finishing handshake with a relay to build circuits
tor_1 | Jul 03 20:19:23.000 [notice] Bootstrapped 90% (ap_handshake_done): Handshake finished with a relay to build circuits
tor_1 | Jul 03 20:19:23.000 [notice] Bootstrapped 95% (circuit_create): Establishing a Tor circuit
tor_1 | Jul 03 20:19:23.000 [notice] Bootstrapped 100% (done): Done
lightning
Attaching to lightning_lnd_1, lightning_app_proxy_1, lightning_app_1, lightning_tor_1
app_1 | Checking LND status…
app_1 | Waiting for LND…
app_proxy_1 | [HPM] Proxy created: / → http://10.21.22.3:3006
app_proxy_1 | Waiting for 10.21.22.3:3006 to open…
app_proxy_1 | Lightning Node is now ready…
app_proxy_1 | Listening on port: 2101
lnd_1 | 2023-07-03 20:20:16.270 [INF] RPCS: RPC server listening on 0.0.0.0:10009
lnd_1 | 2023-07-03 20:20:17.324 [INF] RPCS: gRPC proxy started at 0.0.0.0:8080
lnd_1 | 2023-07-03 20:20:17.325 [INF] LTND: Opening the main database, this might take a few minutes…
lnd_1 | 2023-07-03 20:20:17.325 [INF] LTND: Opening bbolt database, sync_freelist=false, auto_compact=false
lnd_1 | 2023-07-03 20:20:18.244 [INF] LTND: Creating local graph and channel state DB instances
lnd_1 | 2023-07-03 20:20:19.243 [INF] CHDB: Checking for schema update: latest_version=29, db_version=29
lnd_1 | 2023-07-03 20:20:19.244 [INF] CHDB: Checking for optional update: prune_revocation_log=false, db_version=empty
lnd_1 | 2023-07-03 20:20:19.244 [INF] LTND: Database(s) now open (time_to_open=1.918579637s)!
lnd_1 | 2023-07-03 20:20:19.244 [INF] LTND: We’re not running within systemd or the service type is not ‘notify’
lnd_1 | 2023-07-03 20:20:19.244 [INF] LTND: Waiting for wallet encryption password. Use lncli create to create a wallet, lncli unlock to unlock an existing wallet, or lncli changepassword to change the password of an existing wallet and unlock it.
tor_1 | Jul 03 20:19:32.000 [notice] Bootstrapped 57% (loading_descriptors): Loading relay descriptors
tor_1 | Jul 03 20:19:32.000 [notice] Bootstrapped 64% (loading_descriptors): Loading relay descriptors
tor_1 | Jul 03 20:19:33.000 [notice] Bootstrapped 69% (loading_descriptors): Loading relay descriptors
tor_1 | Jul 03 20:19:33.000 [notice] Bootstrapped 75% (enough_dirinfo): Loaded enough directory info to build circuits
tor_1 | Jul 03 20:19:33.000 [notice] Bootstrapped 80% (ap_conn): Connecting to a relay to build circuits
tor_1 | Jul 03 20:19:33.000 [notice] Bootstrapped 85% (ap_conn_done): Connected to a relay to build circuits
tor_1 | Jul 03 20:19:33.000 [notice] Bootstrapped 89% (ap_handshake): Finishing handshake with a relay to build circuits
tor_1 | Jul 03 20:19:33.000 [notice] Bootstrapped 90% (ap_handshake_done): Handshake finished with a relay to build circuits
tor_1 | Jul 03 20:19:33.000 [notice] Bootstrapped 95% (circuit_create): Establishing a Tor circuit
tor_1 | Jul 03 20:19:36.000 [notice] Bootstrapped 100% (done): Done
mempool
Attaching to mempool_app_proxy_1, mempool_web_1, mempool_api_1, mempool_mariadb_1
api_1 | at IncomingMessage. (/backend/package/rpc-api/jsonrpc.js:125:25)
api_1 | at IncomingMessage.emit (node:events:539:35)
api_1 | at endReadableNT (node:internal/streams/readable:1345:12)
api_1 | at processTicksAndRejections (node:internal/process/task_queues:83:21)
api_1 | Jul 3 21:07:02 [204] INFO: Disconnected from Electrum Server at 10.21.21.10:50001
api_1 | Jul 3 21:07:02 [204] ERR: Electrum error: {}
api_1 | Jul 3 21:07:25 [204] ERR: Electrum error: {}
api_1 | Jul 3 21:07:25 [204] INFO: Disconnected from Electrum Server at 10.21.21.10:50001
api_1 | Jul 3 21:07:47 [204] INFO: Disconnected from Electrum Server at 10.21.21.10:50001
api_1 | Jul 3 21:07:47 [204] ERR: Electrum error: {}
web_1 | /var/www/mempool/browser/resources
app_proxy_1 | [HPM] Proxy created: / → http://10.21.21.26:3006
app_proxy_1 | Waiting for 10.21.21.26:3006 to open…
app_proxy_1 | mempool is now ready…
app_proxy_1 | Listening on port: 3006
mariadb_1 | 2023-07-03 20:20:58 0 [Note] Plugin ‘FEEDBACK’ is disabled.
mariadb_1 | 2023-07-03 20:20:59 0 [Note] Server socket created on IP: ‘::’.
mariadb_1 | 2023-07-03 20:21:03 0 [Warning] ‘proxies_priv’ entry ‘@% root@1237f163a0b8’ ignored in --skip-name-resolve mode.
mariadb_1 | 2023-07-03 20:21:09 0 [Note] Reading of all Master_info entries succeeded
mariadb_1 | 2023-07-03 20:21:09 0 [Note] Added new Master_info ‘’ to hash table
mariadb_1 | 2023-07-03 20:21:09 0 [Note] mysqld: ready for connections.
mariadb_1 | Version: ‘10.5.12-MariaDB-1:10.5.12+maria~focal’ socket: ‘/run/mysqld/mysqld.sock’ port: 3306 mariadb.org binary distribution
mariadb_1 | 2023-07-03 20:21:09 4 [Warning] Aborted connection 4 to db: ‘unconnected’ user: ‘unauthenticated’ host: ‘10.21.21.27’ (This connection closed normally without authentication)
mariadb_1 | 2023-07-03 20:21:09 3 [Warning] Aborted connection 3 to db: ‘unconnected’ user: ‘unauthenticated’ host: ‘10.21.21.26’ (This connection closed normally without authentication)
mariadb_1 | 2023-07-03 20:21:25 0 [Note] InnoDB: Buffer pool(s) load completed at 230703 20:21:25
==== Result ====
I suspect the…
