Umbrel seems to crash frequently
My Bitcoin node seems to crash at least daily if not multiple times daily. When this happens I can’t connect to Umbrel.local and need to unplug and reset it. I’m not certain if this is true, but it may be when connected to my Sparrow wallet… I have received the message once about my SD card may be failing, but not again. It resets fine and resumes function, but crashes again. I bought the official Rasperry Pi 4 power supply in case the after market power supply was the issue, but this didn’t stop the situation.
I’m trying to paste in my logs, but it won’t allow it. It say’s I’m only allowed 2 link in a post…
Hi @Sats68 feel free to just paste in straight into the thread, otherwise you should be able to download it, and add it as an attachment.
Is this a new issue, or has it been persistent since you set it up?
I’ve tried several time and it gives me an error saying that new users only get to put 2 links in a post… It’s just my logs. I’ll try sending it in chunks.
Persistent issue
0.5.4
Flashed OS version
v0.5.4
Raspberry Pi Model
Revision : c03115
Serial : 100000001d3f0d71
Firmware
May 9 2023 12:16:34
Copyright (c) 2012 Broadcom
Temperature
temp=36.5’C
Throttling
throttled=0x0
Mem: 3.8G 2.3G 40M 1.0M 1.4G 1.4G
Swap: 4.1G 841M 3.3G
total: 61.8%
bitcoin: 29.9%
mempool: 17.1%
electrs: 8.5%
system: 6.3%
Memory monitor logs
2023-10-15 16:08:36 Memory monitor running!
2023-10-16 22:08:37 Memory monitor running!
2023-10-17 05:17:24 Memory monitor running!
2023-10-17 20:17:26 Memory monitor running!
2023-10-18 02:17:24 Memory monitor running!
2023-10-18 16:17:57 Memory monitor running!
2023-10-21 02:41:48 Memory monitor running!
2023-10-21 17:36:12 Memory monitor running!
2023-10-22 13:59:48 Memory monitor running!
2023-10-22 21:32:19 Memory monitor running!
/dev/root 30G 3.6G 25G 13% /
/dev/sda1 1.8T 660G 1.1T 38% /home/umbrel/umbrel
Startup service logs
Oct 22 21:37:54 umbrel umbrel startup[1524]: Creating electrs_app_proxy_1 …
Oct 22 21:37:54 umbrel umbrel startup[1524]: Creating mempool_tor_server_1 …
Oct 22 21:37:54 umbrel umbrel startup[1524]: Creating mempool_mariadb_1 …
Oct 22 21:37:54 umbrel umbrel startup[1524]: Creating mempool_api_1 …
Oct 22 21:37:55 umbrel umbrel startup[1524]: Creating mempool_app_proxy_1 …
Oct 22 21:37:55 umbrel umbrel startup[1524]: Creating mempool_web_1 …
Oct 22 21:37:58 umbrel umbrel startup[1524]: Creating electrs_tor_1 … done
Oct 22 21:37:58 umbrel umbrel startup[1524]: Creating bitcoin_tor_1 … done
Oct 22 21:37:58 umbrel umbrel startup[1524]: Creating electrs_electrs_1 … done
Oct 22 21:37:58 umbrel umbrel startup[1524]: Creating electrs_app_1 …
Oct 22 21:37:59 umbrel umbrel startup[1524]: Creating bitcoin_tor_server_1 … done
Oct 22 21:37:59 umbrel umbrel startup[1524]: Creating electrs_app_proxy_1 … done
Oct 22 21:37:59 umbrel umbrel startup[1524]: Creating bitcoin_i2pd_daemon_1 … done
Oct 22 21:38:00 umbrel umbrel startup[1524]: Creating bitcoin_app_proxy_1 … done
Oct 22 21:38:00 umbrel umbrel startup[1524]: Creating mempool_tor_server_1 … done
Oct 22 21:38:00 umbrel umbrel startup[1524]: Creating mempool_app_proxy_1 … done
Oct 22 21:38:00 umbrel umbrel startup[1524]: Creating electrs_tor_server_1 … done
Oct 22 21:38:00 umbrel umbrel startup[1524]: Creating mempool_mariadb_1 … done
Oct 22 21:38:00 umbrel umbrel startup[1524]: Creating mempool_web_1 … done
Oct 22 21:38:01 umbrel umbrel startup[1524]: Creating mempool_api_1 … done
Oct 22 21:38:01 umbrel umbrel startup[1524]: Creating bitcoin_bitcoind_1 … done
Oct 22 21:38:01 umbrel umbrel startup[1524]: Creating bitcoin_server_1 …
Oct 22 21:38:01 umbrel umbrel startup[1524]: Creating electrs_app_1 … done
Oct 22 21:38:03 umbrel umbrel startup[1524]: Creating bitcoin_server_1 … done
Oct 22 21:38:03 umbrel umbrel startup[1524]: Umbrel is now accessible at
Oct 22 21:38:03 umbrel umbrel startup[1524]: http://umbrel.local
Oct 22 21:38:03 umbrel umbrel startup[1524]: http://192.168.4.114
Oct 22 21:38:03 umbrel systemd[1]: Started Umbrel Startup Service.
Oct 22 22:26:17 umbrel passwd[754]: pam_unix(passwd:chauthtok): password changed for umbrel
External storage service logs
Oct 22 21:32:03 umbrel external storage mounter[482]: Waiting for USB devices…
Oct 22 21:32:04 umbrel external storage mounter[482]: Checking if the device is ext4…
Oct 22 21:32:04 umbrel external storage mounter[482]: Yes, it is ext4
Oct 22 21:32:04 umbrel external storage mounter[482]: Checking filesystem for corruption…
Oct 22 21:32:04 umbrel external storage mounter[482]: e2fsck 1.44.5 (15-Dec-2018)
Oct 22 21:32:05 umbrel external storage mounter[482]: umbrel: recovering journal
Oct 22 21:32:11 umbrel external storage mounter[482]: Clearing orphaned inode 80481883 (uid=1000, gid=1000, mode=0100600, size=0)
Oct 22 21:32:11 umbrel external storage mounter[482]: Clearing orphaned inode 80481848 (uid=1000, gid=1000, mode=0100600, size=0)
Oct 22 21:32:11 umbrel external storage mounter[482]: Clearing orphaned inode 80478247 (uid=1000, gid=1000, mode=0100600, size=0)
Oct 22 21:32:11 umbrel external storage mounter[482]: Clearing orphaned inode 80478246 (uid=1000, gid=1000, mode=0100600, size=0)
Oct 22 21:32:11 umbrel external storage mounter[482]: Setting free inodes count to 121844593 (was 121844987)
Oct 22 21:32:11 umbrel external storage mounter[482]: Setting free blocks count to 307570621 (was 307581983)
Oct 22 21:32:11 umbrel external storage mounter[482]: umbrel: clean, 257167/122101760 files, 180807747/488378368 blocks
Oct 22 21:32:12 umbrel external storage mounter[482]: Mounting partition…
Oct 22 21:32:12 umbrel external storage mounter[482]: Checking if device contains an Umbrel install…
Oct 22 21:32:12 umbrel external storage mounter[482]: Yes, it contains an Umbrel install
Oct 22 21:32:12 umbrel external storage mounter[482]: Bind mounting external storage over local Umbrel installation…
Oct 22 21:32:12 umbrel external storage mounter[482]: Bind mounting external storage over local Docker data dir…
Oct 22 21:32:12 umbrel external storage mounter[482]: Bind mounting external storage to /swap
Oct 22 21:32:12 umbrel external storage mounter[482]: Bind mounting SD card root at /sd-card…
Oct 22 21:32:12 umbrel external storage mounter[482]: Checking Umbrel root is now on external storage…
Oct 22 21:32:13 umbrel external storage mounter[482]: Checking /var/lib/docker is now on external storage…
Oct 22 21:32:13 umbrel external storage mounter[482]: Checking /swap is now on external storage…
Oct 22 21:32:13 umbrel external storage mounter[482]: Setting up swapfile
Oct 22 21:32:13 umbrel external storage mounter[482]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
Oct 22 21:32:13 umbrel external storage mounter[482]: no label, UUID=c7618594-12cf-4400-878b-b5ddd16b16a0
Oct 22 21:32:13 umbrel external storage mounter[482]: Checking SD Card root is bind mounted at /sd-root…
Oct 22 21:32:13 umbrel external storage mounter[482]: Starting external drive mount monitor…
Oct 22 21:32:13 umbrel external storage mounter[482]: Mount script completed successfully!
Oct 22 21:32:13 umbrel systemd[1]: Started External Storage Mounter.
– Logs begin at Thu 2019-02-14 10:11:58 UTC, end at Sun 2023-10-22 22:26:17 UTC. –
Oct 22 21:32:18 umbrel systemd[1]: Starting External Storage SDcard Updater…
Oct 22 21:32:18 umbrel external storage updater[1440]: Checking if SD card Umbrel is newer than external storage…
Oct 22 21:32:18 umbrel external storage updater[1440]: No, SD version is not newer, exiting.
Oct 22 21:32:18 umbrel systemd[1]: Started External Storage SDcard Updater.
Karen logs
backup/.padding
Uploading backup…
0 0 0 0 0 0 0 0 --:–:-- 0:00:01 --:–:-- 0
100 3787 0 0 100 3787 0 1224 0:00:03 0:00:03 --:–:-- 1224
100 3787 0 0 100 3787 0 964 0:00:03 0:00:03 --:–:-- 964
100 3933 100 146 100 3787 33 879 0:00:04 0:00:04 --:–:-- 912
{“message”:“Successfully uploaded backup 1697947817247.tar.gz.pgp for backup ID 75fce87dbbde057d972df28836ed01fbffa97e48a6eb54a393fb3026af209b9f”}
====== Backup success =======
Got signal: backup
karen is getting triggered!
Deriving keys…
Creating backup…
Adding random padding…
1+0 records in
1+0 records out
5648 bytes (5.6 kB, 5.5 KiB) copied, 0.00028222 s, 20.0 MB/s
Creating encrypted tarball…
backup/
backup/.padding
Uploading backup…
0 0 0 0 0 0 0 0 --:–:-- 0:00:03 --:–:-- 0
100 6166 0 0 100 6166 0 1194 0:00:05 0:00:05 --:–:-- 1194
100 6312 100 146 100 6166 25 1078 0:00:05 0:00:05 --:–:-- 1104
{“message”:“Successfully uploaded backup 1697967371593.tar.gz.pgp for backup ID 75fce87dbbde057d972df28836ed01fbffa97e48a6eb54a393fb3026af209b9f”}
Got signal:
Got signal:
Got signal: change-password
Got signal:
Got signal:
Got signal: debug
Docker containers
NAMES STATUS
bitcoin_server_1 Up 48 minutes
electrs_app_1 Up 48 minutes
mempool_api_1 Up 48 minutes
mempool_web_1 Up 48 minutes
mempool_app_proxy_1 Up 48 minutes
mempool_mariadb_1 Up 48 minutes
mempool_tor_server_1 Up 48 minutes
bitcoin_tor_server_1 Up 48 minutes
electrs_app_proxy_1 Up 48 minutes
bitcoin_app_proxy_1 Up 48 minutes
electrs_tor_server_1 Up 48 minutes
bitcoin_bitcoind_1 Up 48 minutes
electrs_tor_1 Up 48 minutes
bitcoin_i2pd_daemon_1 Up 48 minutes
bitcoin_tor_1 Up 48 minutes
electrs_electrs_1 Up 31 minutes
nginx Up 49 minutes
dashboard Up 54 minutes
auth Up 49 minutes
manager Up 54 minutes
tor_proxy Up 54 minutes
tor_server Up 54 minutes
Umbrel logs
Attaching to manager
manager | ::ffff:10.21.21.2 - - [Sun, 22 Oct 2023 22:26:43 GMT] “GET /v1/system/debug-result HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/118.0.0.0 Safari/537.36”
manager |
manager | umbrel-manager
manager | ::ffff:10.21.21.2 - - [Sun, 22 Oct 2023 22:26:44 GMT] “GET /v1/system/debug-result HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/118.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Sun, 22 Oct 2023 22:26:45 GMT] “GET /v1/system/debug-result HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/118.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Sun, 22 Oct 2023 22:26:46 GMT] “GET /v1/system/debug-result HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/118.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Sun, 22 Oct 2023 22:26:47 GMT] “GET /v1/system/debug-result HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/118.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Sun, 22 Oct 2023 22:26:48 GMT] “GET /v1/system/debug-result HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/118.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Sun, 22 Oct 2023 22:26:49 GMT] “GET /v1/system/debug-result HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/118.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Sun, 22 Oct 2023 22:26:50 GMT] “GET /v1/system/debug-result HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/118.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Sun, 22 Oct 2023 22:26:51 GMT] “GET /v1/system/debug-result HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/118.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Sun, 22 Oct 2023 22:26:52 GMT] “GET /v1/system/debug-result HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/118.0.0.0 Safari/537.36”
manager |
Tor Proxy logs
Attaching to tor_proxy
tor_proxy | Oct 22 21:37:54.000 [notice] Bootstrapped 55% (loading_descriptors): Loading relay descriptors
tor_proxy | Oct 22 21:37:54.000 [notice] Bootstrapped 60% (loading_descriptors): Loading relay descriptors
tor_proxy | Oct 22 21:37:55.000 [notice] Bootstrapped 67% (loading_descriptors): Loading relay descriptors
tor_proxy | Oct 22 21:37:56.000 [notice] Bootstrapped 75% (enough_dirinfo): Loaded enough directory info to build circuits
tor_proxy | Oct 22 21:37:56.000 [notice] Bootstrapped 80% (ap_conn): Connecting to a relay to build circuits
tor_proxy | Oct 22 21:37:56.000 [notice] Bootstrapped 85% (ap_conn_done): Connected to a relay to build circuits
tor_proxy | Oct 22 21:37:56.000 [notice] Bootstrapped 89% (ap_handshake): Finishing handshake with a relay to build circuits
tor_proxy | Oct 22 21:37:57.000 [notice] Bootstrapped 90% (ap_handshake_done): Handshake finished with a relay to build circuits
tor_proxy | Oct 22 21:37:57.000 [notice] Bootstrapped 95% (circuit_create): Establishing a Tor circuit
tor_proxy | Oct 22 21:37:58.000 [notice] Bootstrapped 100% (done): Done
App logs
bitcoin
Attaching to bitcoin_server_1, bitcoin_tor_server_1, bitcoin_app_proxy_1, bitcoin_bitcoind_1, bitcoin_i2pd_daemon_1, bitcoin_tor_1
bitcoind_1 | 2023-10-22T22:07:37Z loadblk thread exit
bitcoind_1 | 2023-10-22T22:08:12Z New outbound peer connected: version: 70016, blocks=813394, peer=27 (outbound-full-relay)
bitcoind_1 | 2023-10-22T22:12:35Z New outbound peer connected: version: 70016, blocks=813394, peer=28 (block-relay-only)
bitcoind_1 | 2023-10-22T22:14:07Z Saw new header hash=00000000000000000000327742a64b3b4f485a2e6ea1279e2584bca617c35fe2 height=813395
bitcoind_1 | 2023-10-22T22:14:07Z [net] Saw new cmpctblock header hash=00000000000000000000327742a64b3b4f485a2e6ea1279e2584bca617c35fe2 peer=14
bitcoind_1 | 2023-10-22T22:14:07Z UpdateTip: new best=00000000000000000000327742a64b3b4f485a2e6ea1279e2584bca617c35fe2 height=813395 version=0x21586000 log2_work=94.492672 tx=908011612 date=‘2023-10-22T22:14:05Z’ progress=1.000000 cache=315.3MiB(2289719txo)
bitcoind_1 | 2023-10-22T22:14:07Z BlockUntilSyncedToCurrentChain: txindex is catching up on block notifications
bitcoind_1 | 2023-10-22T22:20:51Z New outbound peer connected: version: 70016, blocks=813395, peer=29 (block-relay-only)
bitcoind_1 | 2023-10-22T22:21:06Z Saw new header hash=000000000000000000044c0680ebd7db7ebd550909859bbaca4d9158d6626706 height=813396
bitcoind_1 | 2023-10-22T22:21:08Z UpdateTip: new best=000000000000000000044c0680ebd7db7ebd550909859bbaca4d9158d6626706 height=813396 version=0x2495a000 log2_work=94.492685 tx=908013621 date=‘2023-10-22T22:21:02Z’ progress=1.000000 cache=315.6MiB(2291918txo)
app_proxy_1 | Validating token: 44aaa258bc7f …
i2pd_daemon_1 | 22:05:04@641/error - Garlic: Can’t handle ECIES-X25519-AEAD-Ratchet message
i2pd_daemon_1 | 22:05:09@996/error - SSU2: RelayIntro unknown router to introduce
i2pd_daemon_1 | 22:05:17@996/error - SSU2: RelayIntro unknown router to introduce
i2pd_daemon_1 | 22:05:40@996/error - SSU2: RelayIntro unknown router to introduce
i2pd_daemon_1 | 22:05:42@996/error - SSU2: RelayIntro unknown router to introduce
i2pd_daemon_1 | 22:05:43@996/error - SSU2: RelayIntro unknown router to introduce
i2pd_daemon_1 | 22:05:48@996/error - SSU2: RelayIntro unknown router to introduce
i2pd_daemon_1 | 22:07:23@996/error - SSU2: RelayIntro unknown router to introduce
i2pd_daemon_1 | 22:09:08@996/error - SSU2: RelayIntro unknown router to introduce
i2pd_daemon_1 | 22:26:53@300/error - Tunnel: Tunnel with id 2983798253 already exists
server_1 | umbrel-middleware
server_1 | ::ffff:10.21.0.7 - - [Sun, 22 Oct 2023 22:26:33 GMT] “GET /v1/bitcoind/info/connections HTTP/1.1” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/118.0.0.0 Safari/537.36”
server_1 |
server_1 | ::ffff:10.21.0.7 - - [Sun, 22 Oct 2023 22:26:33 GMT] “GET /v1/bitcoind/info/stats HTTP/1.1” 200 126 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/118.0.0.0 Safari/537.36”
server_1 |
server_1 | ::ffff:10.21.0.7 - - [Sun, 22 Oct 2023 22:26:47 GMT] “GET /v1/bitcoind/info/blocks?from=813253&to=813396 HTTP/1.1” 200
The last chunk it won’t let me send… Thank you Smolgrrr
Interesting, there doesn’t appear to be anything on the software side that stands out for such an issue.
Another question, I assume you have a heat sink or fan operating on the Raspberry Pi? (You can check if the Pi is running at a high temp via the settings dashboard)
Also, what SSD/drive are you using with the Pi?
Given you mention it crashes daily, im inclined to think this is not a networking issue where the IP is being reassigned, which may not be recognised by your browser straightaway, but it may also be worth downloading Tailscale from the app-store to hedge this. Tailscale creates a tunnel between your authorised devices, and will let you connect to your Umbrel outside of home, or when your router reassigns IP addresses.
Hi. Yes, I have a cooling tower & fan running. What would you consider high temp? The SSD is a Samsung 870 QVO SATA III 2TB. Hmm I know nothing about Tailscale, but will check into it. Have you heard of any issues of Sparrow wallet causing crashes when connected?
Thank you Smolgrrr for your time and looking into this. Much appreciated. Hopefully it will resolve.
It’s gone down twice since your email. No idea why? Investigating Tailscale, but not sure how it will help as it’s plugged directly into the router. I’m definitely not Tech strong obviously… but love BTC & want this to work seamlessly so bad. Here are mylatest logs if you have the time to look at them.
Hi, I was wondering if you found a fix for this issue?
I re-wrote the OS onto a new SD card and it worked much better.
Thanks for letting me know, much appreciated! I have already done that once but the issues came back :disappointed: I’ll try a different SD card rated for endurance I guess.
is that possible to do on the new umbrel home?
