VM on Orbstack
Attempted installing using these commands:
sudo apt-get dist-upgrade
sudo apt-get install docker-compose
curl -L https://umbrel.sh | bash -s – --no-install-docker --no-install-compose
No issues installing but running isn’t working:
============= STARTING ===============
============== UMBREL ================
Setting environment variables...
Starting karen...
Starting status monitors...
Starting memory monitor...
Starting backup monitor...
Starting decoy backup trigger...
Starting umbreld...
Starting Docker services...
dashboard is up-to-date
Recreating 240cd9a7924d_auth ...
tor_proxy is up-to-date
Recreating f666fda7b96c_manager ...
ERROR: for f666fda7b96c_manager 'ContainerConfig'
ERROR: for 240cd9a7924d_auth 'ContainerConfig'
ERROR: for manager 'ContainerConfig'
ERROR: for auth 'ContainerConfig'
File "/usr/bin/docker-compose", line 33, in <module>
sys.exit(load_entry_point('docker-compose==1.29.2', 'console_scripts', 'docker-compose')())
File "/usr/lib/python3/dist-packages/compose/cli/main.py", line 81, in main
command_func()
File "/usr/lib/python3/dist-packages/compose/cli/main.py", line 203, in perform_command
handler(command, command_options)
File "/usr/lib/python3/dist-packages/compose/metrics/decorator.py", line 18, in wrapper
result = fn(*args, **kwargs)
File "/usr/lib/python3/dist-packages/compose/cli/main.py", line 1186, in up
to_attach = up(False)
File "/usr/lib/python3/dist-packages/compose/cli/main.py", line 1166, in up
return self.project.up(
File "/usr/lib/python3/dist-packages/compose/project.py", line 697, in up
results, errors = parallel.parallel_execute(
File "/usr/lib/python3/dist-packages/compose/parallel.py", line 108, in parallel_execute
raise error_to_reraise
File "/usr/lib/python3/dist-packages/compose/parallel.py", line 206, in producer
result = func(obj)
File "/usr/lib/python3/dist-packages/compose/project.py", line 679, in do
return service.execute_convergence_plan(
File "/usr/lib/python3/dist-packages/compose/service.py", line 579, in execute_convergence_plan
return self._execute_convergence_recreate(
File "/usr/lib/python3/dist-packages/compose/service.py", line 499, in _execute_convergence_recreate
containers, errors = parallel_execute(
result = func(obj)
File "/usr/lib/python3/dist-packages/compose/service.py", line 494, in recreate
return self.recreate_container(
File "/usr/lib/python3/dist-packages/compose/service.py", line 612, in recreate_container
new_container = self.create_container(
File "/usr/lib/python3/dist-packages/compose/service.py", line 330, in create_container
container_options = self._get_container_create_options(
File "/usr/lib/python3/dist-packages/compose/service.py", line 921, in _get_container_create_options
container_options, override_options = self._build_container_volume_options(
File "/usr/lib/python3/dist-packages/compose/service.py", line 960, in _build_container_volume_options
binds, affinity = merge_volume_bindings(
File "/usr/lib/python3/dist-packages/compose/service.py", line 1548, in merge_volume_bindings
old_volumes, old_mounts = get_container_data_volumes(
File "/usr/lib/python3/dist-packages/compose/service.py", line 1579, in get_container_data_volumes
container.image_config['ContainerConfig'].get('Volumes') or {}
KeyError: 'ContainerConfig'
Failed to start containers
On very fresh vm install
