I installed Umbrel in a different disk (RAID 1) and it presents the KeyError: 'ContainerConfig'
I installed Umbrel on a different disk (RAID 1), and it presents the KeyError: ‘ContainerConfig’. When I start Umbrel, it presents the following message. This happens after I restart the computer.
Can someone help me?
============= STARTING ===============
============== UMBREL ================
Setting environment variables…
Starting karen…
Starting status monitors…
Starting memory monitor…
Starting backup monitor…
Starting decoy backup trigger…
Starting umbreld…
Starting Docker services…
Recreating 73cdd8af0e44_auth …
dashboard is up-to-date
Recreating 88ac0e3e768b_tor_proxy …
Recreating 5285a2d4e18f_manager …
ERROR: for 73cdd8af0e44_auth ‘ContainerConfig’
ERROR: for 88ac0e3e768b_tor_proxy ‘ContainerConfig’
ERROR: for 5285a2d4e18f_manager ‘ContainerConfig’
ERROR: for auth ‘ContainerConfig’
ERROR: for tor_proxy ‘ContainerConfig’
ERROR: for manager ‘ContainerConfig’
File “docker-compose”, line 3, in
File “compose/cli/main.py”, line 81, in main
File “compose/cli/main.py”, line 203, in perform_command
File “compose/metrics/decorator.py”, line 18, in wrapper
File “compose/cli/main.py”, line 1186, in up
File “compose/cli/main.py”, line 1182, in up
File “compose/project.py”, line 702, in up
File “compose/parallel.py”, line 108, in parallel_execute
File “compose/parallel.py”, line 206, in producer
File “compose/project.py”, line 688, in do
File “compose/service.py”, line 581, in execute_convergence_plan
File “compose/service.py”, line 503, in _execute_convergence_recreate
File “compose/service.py”, line 496, in recreate
File “compose/service.py”, line 615, in recreate_container
File “compose/service.py”, line 334, in create_container
File “compose/service.py”, line 922, in _get_container_create_options
File “compose/service.py”, line 962, in _build_container_volume_options
File “compose/service.py”, line 1549, in merge_volume_bindings
File “compose/service.py”, line 1579, in get_container_data_volumes
[105925] Failed to execute script docker-compose
Failed to start containers
