Failed install of Umbrel 1.0 on fresh Ubuntu 22.04 LTS
Background:
  • Fresh install of Ubuntu 22.04 LTS on a PC
  • Updated all packages
  • Attempt to install Umbrel OS 1.0 with “curl -L https://umbrel.sh | bash -s – --install-path /media/Data/umbrel”
Result:
============ CONFIGURING =============
=============== UMBREL ===============
Generating auth credentials
Generating Tor password
docker: Cannot connect to the Docker daemon at unix:///var/run/docker.sock. Is the docker daemon running?.
See 'docker run --help'.
Output of “sudo umbrel/scripts/debug”
0.5.4
Mem:             63G        1.8G         58G        574M        3.4G         60G
Swap:           2.0G          0B        2.0G
total: 2.8%
system: 2.8%
Memory monitor logs
tail: cannot open '/media/Data/umbrel/scripts/../logs/memory-monitor.log' for reading: No such file or directory
/dev/nvme0n1p2  457G   12G  422G   3% /
/dev/nvme1n1    3.6T  798G  2.7T  23% /media/Data
Karen logs
tail: cannot open 'logs/karen.log' for reading: No such file or directory
Docker containers
Umbrel logs
ERROR: The Compose file './docker-compose.yml' is invalid because:
Tor Proxy logs
==== Result ====
==== END =====
From a fresh install - I wouldn’t have expected it to be broken right out of the gate - any ideas???
So - previously, the notification at the bottom of the Umbrel OS page said that UmbrelOS 1.0 was going to be available in April for non-PI installs. On top of that, the curl command actually didn’t work and indicated that the “other OS” release was coming in April.
When I looked again on 4/2, the notification was different and listed the curl command and the curl command started working…
but I see now in the debug log that it’s trying to install Umbrel version “0.5.4” - does that mean that it actually is NOT released for non-PI install yet??? If that’s the case, then why did the website change to show the command and why did the curl command start working???
