umbrelOS 1.0
Raspberry Pi 5
SSD 2TB
microSD 64GB
No matter which version I install, the following error always appears.
Even reinstalling the SSD and SD card doesn’t work.
Debian GNuvLinux 12 umbrel tty1
umbrel login:
29,753289] nacb 1f00100000.ethernet endo: Link is Up- 1Gbps/Full - flou control off32.4611261EXT4-fs (sda1): mounted fllesystem f3a76a3a-?1ea-4f26-8184-b42c03cf64ce rw with ordered data nodc. quota node: none33 .9138111Adding 4194288k swap on /swap/swapfile, Priority:-2 extents:11 across:567609200k ss35 .2430261bridge:filtering ula arp/ip/lp6tables is no longer auailabie by defauit, Update your scripts to load br netfilter if you necd th35.2638031Bridge firewalling registered35.3779061Initializing xFRM netlink socket45.?741261systcmd-journald[1671:ecns buee ddo21: wattneten,nc0ncsrneteire0ds1sum e145.7920961systend-journald[16?1:50.0411531is older than the configur/SUSt#m50.0428581limftsbr-c3284f9a902f:port 1(ueth3424227)cntered disabled state50.0545481veth3424227: enteredallmulticast modc50.0594281ueth3424227:entcredpromiscuous modc50.0643241br-c3284f9a902f:1(ueth3424227)cnteredport50 0709781blocking statebr-c3284f9a902f:1(veth3424227)portcnteredforwarding stat50 .0778831br-c3284190902f:port1(veth3424227)disabledentcredstate50.1046321br-c328419a902f:port2(ueth85eec91)enteredaleabiedstate50.1113391 br-c3284f96902f:2(ucth8seec91)cnteredpor{state50.1181361 ueth85cec91: entcrcdallnulticast node501231191ueth0Sccc91: enteredproniscuou*的odc50.1281401br-c3284f9a902f:port2(uethgSccc91) enteredblocking state50.1347971br-c3284894902r:2(uctha5eec91)Ienteredforwarding stateportport 2(ueth85eec91)cntered50.1418301br-c3284f9a902f:disabled state50.5482541etho: renaned fron vethifcÃbab50 5886011br-c328409a902f:port 1(ucth3424227)entercdIblocking statebr c3284f9a902f:port 1(ucth312422?)entered foruarding state50 .595268130.6022551etho: renaned fron ueth5c46c952(ueth8Sccc91)cntered blocking state.6320291br-c3284f9a902f:portbr-c328419a302f:2(uctha5cec91)foruarding state50.6395011portcntered
