Umbrel installation failed - "Error: System service failed"
Hello,
I hope you are well.
I just tried to install Umbrel but while trying to connect to Umbrel local I got the message “Error: System service failed”.
Here is my setup:
  • Raspberry Pi 4 modèle B - 8GB
  • Official Raspberry Pi power cable USB-C 5.1V 3A
  • Crucial MX500 SSD - CT1000MX500SSD1 - 1 To - Serial ATA - SATA 6.0 Gb/s recommended by Umbrel
  • 32 Go microSDHC card SanDisk Extreme PRO 32 Go 100 Mo/s, Class 10, U3, V30, A1
I went to this support webpage Troubleshooting - UmbrelInfo
I am able to connect to my Umbrel through SSH using Putty but didn’t achieve to get the debug file.
Could you provide me some guidelines and help?
Thanks a lot!
lo
  1. That gitlab page is NOT Umbrel support page. It was in the past but is not anymore. Here you have all guides and troubleshooting for Umbrel
  2. to run the debug log, you need to be in the “umbrel” folder so first run cd umbrel.
Thanks for your answer and your help :+1:
I just did cd umbrel but I still can’t access to /umbrel/scripts/debug --upload
tail -f ~/umbrel/bitcoin/debug.log
tail -f ~/umbrel/lnd/logs/bitcoin/mainnet/lnd.log
docker ps
Thanks
Here is my debug file
0.4.8
Flashed OS version
v0.4.8
Raspberry Pi Model
Revision : d03114
Serial : 100000002b679549
Firmware
Oct 29 2021 10:47:33
Copyright © 2012 Broadcom
version b8a114e5a9877e91ca8f26d1a5ce904b2ad3cf13 (clean) (release) (start)
Temperature
temp=44.3’C
Throttling
throttled=0x0
Mem: 7.8G 127M 7.5G 8.0M 208M 7.6G
Swap: 0B 0B 0B
total: 1.6%
system: 1.6%
tor: 0%
lnd: 0%
electrs: 0%
bitcoin: 0%
Memory monitor logs
/dev/root 29G 3.1G 25G 11% /
Startup service logs
– Logs begin at Sun 2021-11-28 14:41:03 UTC, end at Sun 2021-11-28 16:54:10 UTC. –
Nov 28 14:41:09 umbrel systemd[1]: Dependency failed for Umbrel Startup Service.
Nov 28 14:41:09 umbrel systemd[1]: umbrel-startup.service: Job umbrel-startup.service/start failed with result ‘dependency’.
External storage service logs
Nov 28 14:41:07 umbrel systemd[1]: Starting External Storage Mounter…
Nov 28 14:41:07 umbrel external storage mounter[490]: Running external storage mount script…
Nov 28 14:41:07 umbrel external storage mounter[490]: Found device “ASMT 2235”
Nov 28 14:41:07 umbrel external storage mounter[490]: Blacklisting USB device IDs against UAS driver…
Nov 28 14:41:07 umbrel external storage mounter[490]: Rebinding USB drivers…
Nov 28 14:41:07 umbrel external storage mounter[490]: Checking USB devices are back…
Nov 28 14:41:07 umbrel external storage mounter[490]: Waiting for USB devices…
Nov 28 14:41:08 umbrel external storage mounter[490]: Waiting for USB devices…
Nov 28 14:41:09 umbrel external storage mounter[490]: Checking if the device is ext4…
Nov 28 14:41:09 umbrel external storage mounter[490]: No, it’s not ext4
Nov 28 14:41:09 umbrel external storage mounter[490]: Formatting device…
Nov 28 14:41:09 umbrel external storage mounter[490]: wipefs: error: /dev/sda: probing initialization failed: No medium found
Nov 28 14:41:09 umbrel systemd[1]: umbrel-external-storage.service: Main process exited, code=exited, status=1/FAILURE
Nov 28 14:41:09 umbrel systemd[1]: umbrel-external-storage.service: Failed with result ‘exit-code’.
Nov 28 14:41:09 umbrel systemd[1]: Failed to start External Storage Mounter.
Nov 28 14:41:09 umbrel systemd[1]: Dependency failed for External Storage SDcard Updater.
Nov 28 14:41:09 umbrel systemd[1]: umbrel-external-storage-sdcard-update.service: Job umbrel-external-storage-sdcard-update.service/start failed with result ‘dependency’.
Karen logs
Docker containers
NAMES STATUS
Umbrel logs
services.tor.ports contains an invalid type, it should be a number, or an object
Bitcoin Core logs
LND logs
electrs logs
Tor logs
==== Result ====
Can you help me to well exploit it?
Best
The answer is right there.
You had formatted the SSD in other format than ext4 or is simple damaged drive and / or cable is failing.
Start from scratch, with well connected drive, not formatted, just wipe the partition (umbrel installation will do it). Also re-.flash mSD card with latest Umbrel version
I just check the SSD and it was just in fact not enough push into its case :man_facepalming:
Oh, good that was just that. You were lucky.
Yeah not complicate at the end
The issue was between the screen and the keyboard ^^
Synchronized at 35% yet :slightly_smiling_face:
Thanks for your advices!
