Problem at First Install Umbrel OS on Raspberry PI
hello everybody…
i have now tried several times to install umbrel os on my raspberry pi 4 8gb exactly according to the instructions on getumbrel.com…
when accessing the webbrowser i always get the following error message:
“Error: Failed to connect external drive. There was an error connecting your external drive. Please consider using the recommended hardware listed on getumbrel.com”
the logs from “systemctl” via ssh are this:
systemctl
root@umbrel:/home/umbrel# apt systemctl
E: Invalid operation systemctl
root@umbrel:/home/umbrel# systemctl
  • UNIT LOAD ACTIVE SUB DESCRIPTION *
  • proc-sys-fs-binfmt_misc.automount loaded active waiting Arbitrary Executable*
  • sys-devices-platform-emmc2bus-fe340000.mmc-mmc_host-mmc0-mmc0:59b4-block-mmcbl*
  • sys-devices-platform-scb-fd580000.ethernet-net-eth0.device loaded active plugg*
  • sys-devices-platform-soc-fe00b840.mailbox-bcm2835_audio-sound-card0.device loa*
  • sys-devices-platform-soc-fe00b840.mailbox-bcm2835_audio-sound-card1.device loa*
  • sys-devices-platform-soc-fe201000.serial-tty-ttyAMA0-hci0.device loaded active*
  • sys-devices-platform-soc-fe201000.serial-tty-ttyAMA0.device loaded active plug*
  • sys-devices-platform-soc-fe300000.mmcnr-mmc_host-mmc1-mmc1:0001-mmc1:0001:1-ne*
  • sys-devices-virtual-block-ram0.device loaded active plugged /sys/devices/vir*
  • sys-devices-virtual-block-ram1.device loaded active plugged /sys/devices/vir*
  • sys-devices-virtual-block-ram10.device loaded active plugged /sys/devices/vi*
  • sys-devices-virtual-block-ram11.device loaded active plugged /sys/devices/vi*
  • sys-devices-virtual-block-ram12.device loaded active plugged /sys/devices/vi*
  • sys-devices-virtual-block-ram13.device loaded active plugged /sys/devices/vi*
  • sys-devices-virtual-block-ram14.device loaded active plugged /sys/devices/vi*
  • sys-devices-virtual-block-ram15.device loaded active plugged /sys/devices/vi*
  • sys-devices-virtual-block-ram2.device loaded active plugged /sys/devices/vir*
  • sys-devices-virtual-block-ram3.device loaded active plugged /sys/devices/vir*
  • sys-devices-virtual-block-ram4.device loaded active plugged /sys/devices/vir*
  • sys-devices-virtual-block-ram5.device loaded active plugged /sys/devices/vir*
  • sys-devices-virtual-block-ram6.device loaded active plugged /sys/devices/vir*
  • sys-devices-virtual-block-ram7.device loaded active plugged /sys/devices/vir*
  • sys-devices-virtual-block-ram8.device loaded active plugged /sys/devices/vir*
  • sys-devices-virtual-block-ram9.device loaded active plugged /sys/devices/vir*
  • sys-devices-virtual-misc-rfkill.device loaded active plugged /sys/devices/vi*
  • sys-devices-virtual-net-docker0.device loaded active plugged /sys/devices/vi*
  • sys-devices-virtual-tty-ttyprintk.device loaded active plugged /sys/devices/*
  • sys-module-configfs.device loaded active plugged /sys/module/configfs *
  • sys-subsystem-bluetooth-devices-hci0.device loaded active plugged /sys/subsy*
  • sys-subsystem-net-devices-docker0.device loaded active plugged /sys/subsyste*
  • sys-subsystem-net-devices-eth0.device loaded active plugged /sys/subsystem/n*
  • sys-subsystem-net-devices-wlan0.device loaded active plugged /sys/subsystem/*
  • -.mount loaded active mounted / *
  • boot.mount loaded active mounted /boot *
  • dev-mqueue.mount loaded active mounted POSIX Message Queue File *
  • run-rpc_pipefs.mount loaded active mounted RPC Pipe File System *
  • run-user-1000.mount loaded active mounted /run/user/1000 *
  • status\x2dserver.mount loaded active mounted /status-server *
  • sys-kernel-config.mount loaded active mounted Kernel Configuration File*
  • sys-kernel-debug.mount loaded active mounted Kernel Debug File System *
  • systemd-ask-password-console.path loaded active waiting Dispatch Password Re*
  • systemd-ask-password-wall.path loaded active waiting Forward Password Reques*
  • init.scope loaded active running System and Service Manage*
  • session-1.scope loaded active running Session 1 of user umbrel *
  • alsa-restore.service loaded active exited Save/Restore Sound Card S*
  • alsa-state.service loaded active running Manage Sound Card State (*
  • avahi-daemon.service loaded active running Avahi mDNS/DNS-SD Stack *
  • bluetooth.service loaded active running Bluetooth service *
  • bthelper@hci0.service loaded active exited Raspberry Pi bluetooth he*
  • console-setup.service loaded active exited Set console font and keym*
  • containerd.service loaded active running containerd container runt*
  • cron.service loaded active running Regular background progra*
  • dbus.service loaded active running D-Bus System Message Bus *
  • dhcpcd.service loaded active running dhcpcd on all interfaces *
  • docker.service loaded active running Docker Application Contai*
  • fake-hwclock.service loaded active exited Restore / save the curren*
  • getty@tty1.service loaded active running Getty on tty1 *
  • hciuart.service loaded active running Configure Bluetooth Modem*
  • ifupdown-pre.service loaded active exited Helper to synchronize boo*
  • keyboard-setup.service loaded active exited Set the console keyboard *
  • kmod-static-nodes.service loaded active exited Create list of required s*
  • networking.service loaded active exited Raise network interfaces *
  • raspi-config.service loaded active exited LSB: Switch to ondemand c*
  • rc-local.service loaded active exited /etc/rc.local Compatibili*
  • rng-tools.service loaded active running rng-tools.service *
  • rpi-eeprom-update.service loaded active exited Check for Raspberry Pi EE*
  • rsyslog.service loaded active running System Logging Service *
  • ssh.service loaded active running OpenBSD Secure Shell serv*
  • systemd-fsck-root.service loaded active exited File System Check on Root*
  • systemd-fsck@dev-disk-by\x2dpartuuid-e6186fd7\x2d01.service loaded active exit*
  • systemd-journal-flush.service loaded active exited Flush Journal to Persist*
  • systemd-journald.service loaded active running Journal Service *
  • systemd-logind.service loaded active running Login Service *
  • systemd-modules-load.service loaded active exited Load Kernel Modules *
  • systemd-random-seed.service loaded active exited Load/Save Random Seed *
  • systemd-remount-fs.service loaded active exited Remount Root and Kernel F*
  • systemd-sysctl.service loaded active exited Apply Kernel Variables *
  • systemd-sysusers.service loaded active exited Create System Users *
  • systemd-timesyncd.service loaded active running Network Time Synchronizat*
  • systemd-tmpfiles-setup-dev.service loaded active exited Create Static Devic*
  • systemd-tmpfiles-setup.service loaded active exited Create Volatile Files a*
  • systemd-udev-trigger.service loaded active exited udev Coldplug all Devices*
  • systemd-udevd.service loaded active running udev Kernel Device Manage*
  • systemd-update-utmp.service loaded active exited Update UTMP about System *
  • systemd-user-sessions.service loaded active exited Permit User Sessions *
  • triggerhappy.service loaded active running triggerhappy global hotke*
    ● umbrel-external-storage.service loaded failed failed External Storage Mount
  • umbrel-service-monitor.service loaded active exited Service Monitor *
  • umbrel-status-server.service loaded active running Status Server *
  • unattended-upgrades.service loaded active running Unattended Upgrades Shutd*
  • user-runtime-dir@1000.service loaded active exited User Runtime Directory /*
  • user@1000.service loaded active running User Manager for UID 1000*
  • wpa_supplicant.service loaded active running WPA supplicant *
  • -.slice loaded active active Root Slice *
  • system-bthelper.slice loaded active active system-bthelper.slice *
  • system-getty.slice loaded active active system-getty.slice *
  • system-systemd\x2dfsck.slice loaded active active system-systemd\x2dfsck.sl*
  • system.slice loaded active active System Slice *
  • user-1000.slice loaded active active User Slice of UID 1000 *
  • user.slice loaded active active User and Session Slice *
  • avahi-daemon.socket loaded active running Avahi mDNS/DNS-SD Stack A*
  • dbus.socket loaded active running D-Bus System Message Bus *
  • docker.socket loaded active running Docker Socket for the API*
  • syslog.socket loaded active running Syslog Socket *
  • systemd-fsckd.socket loaded active listening fsck to fsckd communicati*
  • systemd-initctl.socket loaded active listening initctl Compatibility Nam*
  • systemd-journald-audit.socket loaded active running Journal Audit Socket *
  • systemd-journald-dev-log.socket loaded active running Journal Socket (/dev/l*
  • systemd-journald.socket loaded active running Journal Socket *
  • systemd-rfkill.socket loaded active listening Load/Save RF Kill Switch *
  • systemd-udevd-control.socket loaded active running udev Control Socket *
  • systemd-udevd-kernel.socket loaded active running udev Kernel Socket *
  • triggerhappy.socket loaded active running triggerhappy.socket *
  • basic.target loaded active active Basic System *
  • bluetooth.target loaded active active Bluetooth *
  • cryptsetup.target loaded active active Local Encrypted Volumes *
  • getty.target loaded active active Login Prompts *
  • graphical.target loaded active active Graphical Interface *
  • local-fs-pre.target loaded active active Local File Systems (Pre) *
  • local-fs.target loaded active active Local File Systems *
  • multi-user.target loaded active active Multi-User System *
  • network-online.target loaded active active Network is Online *
  • network.target loaded active active Network *
  • nfs-client.target loaded active active NFS client services *
  • paths.target loaded active active Paths *
  • remote-fs-pre.target loaded active active Remote File Systems (Pre)*
  • remote-fs.target loaded active active Remote File Systems *
  • slices.target loaded active active Slices *
  • sockets.target loaded active active Sockets *
  • sound.target loaded active active Sound Card *
  • swap.target loaded active active Swap *
  • sysinit.target loaded active active System Initialization *
  • time-sync.target loaded active active System Time Synchronized *
  • timers.target loaded active active Timers *
  • apt-daily-upgrade.timer loaded active waiting Daily apt upgrade and cle*
  • apt-daily.timer loaded active waiting Daily apt download activi*
  • logrotate.timer loaded active waiting Daily rotation of log fil*
  • man-db.timer loaded active waiting Daily man-db regeneration*
  • systemd-tmpfiles-clean.timer loaded active waiting Daily Cleanup of Temporar*
LOAD = Reflects whether the unit definition was properly loaded.
ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
SUB = The low-level unit activation state, values depend on unit type.
141 loaded units listed. Pass --all to see loaded but inactive units, too.
To show all installed unit files use ‘systemctl list-unit-files’.
  • ESCOC*
    *ive active NFS client services *
    *ive active Paths *
    *ive active Remote File Systems *
    *ive active Slices *
    *ive active Sockets *
    *ive active Sound Card *
    *ive active Swap *
    *ive active System Initialization *
    *ive active System Time Synchronized *
    *ive active Timers *
  • ESCOD*
lines 127-149/149 (END)
does anyone have an idea what this can be?
perhaps it is still important to say that at my Raspberry exclusively the SD card with the operating system umbrel and a 2 TB USB stick are connected as storage… the stick is fat32 formated…
thanks for your efforts…
now comes the next problem…
i accessed the rpi via ssh and wanted to change the locale in raspi-config as root user… after the reboot the error message “bash: warning: setlocale: LC_ALL: cannot change locale (de_DE.UTF-8)”
why i dont can change the locale? what am i doing wrong, i am not too stupid to read an instruction… am really irritated…
Hi @b88, firstly just to confirm, what SSD are you using with the Pi?
and after SSHing back into Umbrel, could you please run the following
sudo ~/umbrel/scripts/debug
hey smolgrrr,
thanks for your replay…
i use an fat32 formated 2tb noname usb-stick…
because 0bin net not works i share the logs on my cryptpad…
umbrel logs
Unfortunately a USB-stick based drive is not going to suffice for storage with UmbrelOS on the Pi. You will need to upgrade to a SSD like the following
SSD
Case
ok, i change to sandisk extreme 1tb…
I had a problem with the Sandisk Ultra II SSD working on my Pi 4 with Umbrel. I hope you had more success. It would never format the drive and I tried a few times. I used another drive to set it up and cloned it over to the Sandisk in Windows with partition software and that made it work. I had a silicon power and a samsung drive work out of the box but not the sandisk.
