Hi there! I’m no longer able to see my GUI of Umbrel, since changing ISP a week ago.
Old local IP address with previous ISP: 192.168.0.178
New local IP address with current ISP: 192.168.129.1
I have already:
- checked with a buddy of mine who is IT manager at a school.
- been going through the issues with Venice AI
- have removed the SD card from my Raspberry PI 4, downloaded the latest ISO, etched it with BalenaEtcher to the SD card & did a clean install.
- the newly installed version is also on 192.168.129.1 but if I browse to it or to umbrel.local, I get a Page not Found issue in my browser.
- I have added port mapping to my current ISP’s router (something which I didn’t do anywhere in the past with previous ISP’s router); I have added port 8333 to the LAN settings and 8080 to the WAN settings.
I’m a bit out of options now…
I can SSH (now, since the new clean install, with umbrel/umbrel) into umbrel.local and now also into 192.168.129.1 after having removed older keysets.
I did a sudo apt update/sudo apt upgrade in the Umbrel SSH screen.
I now turn to the community for guidance in this matter… ![]()
