Help. No clue what im doing
So, im trying to install umbrel on my pi. Got through the login, and this popped up….
Hi that is normal. Only thing is that I don’t see it mentioning the IP address it’s using. Can you check that you have an ethernet cord connecting your device to your router?
Please keep in mind that Umbrel is accessed through a web browser so the device running it will always be a terminal. You can access it by http://umbrel.local or http://.
Super appreciate you replying. Ill give this a go when I get home.
Super struggling to get my pi to work. I assume that the sd has been flased. I assume that I have my bridge connected. But when I plug the sd card into the pi, I get nothing.
Did you follow the installation instructions? did you try to connect to it using a web browser?
Where do you get nothing?
Another thing you can add if you can get logged in to find the IP Address is this command:
umbrel@umbrel:~$ ip a | grep 192.168
inet 192.168.1.116/24 brd 192.168.1.255
Then, http://192.168.1.116
I FINALLY got it figured out. Much appreciated the response.
