How to upgrade Raspberry Pi 4 GB to 8 GB?
Do I just have to shutdown the node, unplug, move the microSD card over to the “RPi 8gb”, turn on, then put it back together again?
Hello Ali2k,
I saw the same question answered last week on twitter, but can’t find it now.
Also found this topic:
Found Mayank’s response here
Yes it’s as simple as shutting down, and swapping out the board since the OS is on the SD card and the blockchain is on the SSD.
