Up to a point there was no problem with umbrel,
But now, when I access umbrel, I get Error: Failed to connect external drive
Do you have any advice?
↓ Here’s what I did
At one point, I couldn’t access umbrel.
I turned off the power of the raspberry pie and started it.
The following screen came to appear.
Restarting doesn’t help.
After reading the umbrel-troubleshooting-guide, I ran ~ / umbrel / scripts / debug --upload and got the following log. This is part of the log.
==== Result ====
You have either no external drive connected to your Raspberry Pi or the drive is not being detected.
Please shutdown your Raspberry Pi ('sudo shutdown'), then plug the SSD into the other USB3 port.
After you've finished that, boot your Raspberry Pi back up. If it still still doesn't work,
you can contact us on Telegram (t.me/getumbrel) and share the output of this script.
Shutting down and changing the USB port doesn’t help.
