Error loading address data. Error: Connection to server lost, please retry
When trying to use Mempool or BTC RPC Explorer I get – Error loading address data.
Error: Connection to server lost, please retry and
Error: No Electrum connection available. This could mean that the connection was lost or that the Electrum server is processing transactions and therefore not accepting requests. This tool will try to reconnect. If you manage your own Electrum server you may want to check your server’s logs.
Clean install and full sync. Raspberry pi 4, 1TB SSD, Ethernet cable.
Any advice?
Some redditers having same issue - https://www.reddit.com/r/getumbrel/comments/mgazp0/btc_rpc_explorer_cant_find_electrumx/
I would say about 48h by now.
Definitely an Electrum server status information on UI is a need to reduce this type of things.
If the sync is done for some time (more than 24h), I would suggest to reinstall the Mempool app.
Yep, reinstalled apps and it is working now! Thank you.
I have similar error but bech32 address works, but old ones does not work, any idea?
