Another ElectrumS stuck in "Waiting for Bitcoin Node to finish syncing..."
Hey everyone,
I’m getting stuck with my Umbrel (Rpi4), I’ve setup the node and installed Electrum server and am stuck with " Waiting for Bitcoin Node to finish syncing…" for a few days now.
I’ve tried reflashing the SD, reinstalling Electrum Server; deleting the bitcoin.conf files, commenting the file etc…
(I am non-technical)
I’ve checked out this thread but can’t really figure out where the issue is or how to solve it.
Pasting logs below in case you’re able to help, thanks!!
Umbrel logs:
0.5.4
Flashed OS version
v0.5.4-patch-1
Raspberry Pi Model
Revision : d03115
Serial : 1000000048eba08b
Firmware
May  9 2023 12:16:34
Copyright (c) 2012 Broadcom
Temperature
temp=44.3'C
Throttling
throttled=0x0
Mem:           7.8G        1.6G        132M        2.0M        6.1G        6.1G
Swap:          4.1G        778M        3.3G
total: 20.1%
bitcoin: 9.3%
mempool: 5%
electrs: 3.1%
system: 2.7%
Memory monitor logs
2023-10-30 01:58:52 Memory monitor running!
2023-10-30 01:54:41 Memory monitor running!
2023-10-30 02:22:12 Memory monitor running!
2023-10-30 02:33:56 Memory monitor running!
2023-10-31 20:09:08 Memory monitor running!
2023-10-31 20:43:28 Memory monitor running!
2023-10-31 21:27:17 Memory monitor running!
2023-11-01 04:51:23 Memory monitor running!
2023-11-01 23:12:38 Memory monitor running!
2023-11-02 02:23:39 Memory monitor running!
/dev/root        30G  3.2G   25G  12% /
/dev/sda1       1.8T  718G 1023G  42% /home/umbrel/umbrel
Startup service logs
Nov 02 02:23:56 umbrel umbrel startup[1116]: Creating mempool_app_proxy_1 ...
Nov 02 02:23:56 umbrel umbrel startup[1116]: Creating mempool_mariadb_1   ...
Nov 02 02:23:56 umbrel umbrel startup[1116]: Creating electrs_app_proxy_1 ...
Nov 02 02:23:57 umbrel umbrel startup[1116]: Creating electrs_electrs_1   ...
Nov 02 02:23:57 umbrel umbrel startup[1116]: Creating bitcoin_app_proxy_1 ...
Nov 02 02:23:57 umbrel umbrel startup[1116]: Creating bitcoin_bitcoind_1  ...
Nov 02 02:23:57 umbrel umbrel startup[1116]: Creating electrs_tor_1       ...
Nov 02 02:23:57 umbrel umbrel startup[1116]: Creating bitcoin_tor_1       ...
Nov 02 02:23:57 umbrel umbrel startup[1116]: Creating bitcoin_i2pd_daemon_1 ...
Nov 02 02:23:58 umbrel umbrel startup[1116]: Creating mempool_web_1       ... done
Nov 02 02:23:59 umbrel umbrel startup[1116]: Creating mempool_api_1       ... done
Nov 02 02:24:00 umbrel umbrel startup[1116]: Creating mempool_mariadb_1   ... done
Nov 02 02:24:00 umbrel umbrel startup[1116]: Creating mempool_app_proxy_1 ... done
Nov 02 02:24:00 umbrel umbrel startup[1116]: Creating electrs_tor_1       ... done
Nov 02 02:24:00 umbrel umbrel startup[1116]: Creating electrs_app_proxy_1 ... done
Nov 02 02:24:03 umbrel umbrel startup[1116]: Creating bitcoin_tor_1         ... done
Nov 02 02:24:03 umbrel umbrel startup[1116]: Creating electrs_electrs_1   ... done
Nov 02 02:24:03 umbrel umbrel startup[1116]: Creating bitcoin_i2pd_daemon_1 ... done
Nov 02 02:24:03 umbrel umbrel startup[1116]: Creating electrs_app_1       ...
Nov 02 02:24:03 umbrel umbrel startup[1116]: Creating bitcoin_bitcoind_1    ... done
Nov 02 02:24:04 umbrel umbrel startup[1116]: Creating bitcoin_app_proxy_1   ... done
Nov 02 02:24:04 umbrel umbrel startup[1116]: Creating bitcoin_server_1      ...
Nov 02 02:24:06 umbrel umbrel startup[1116]: Creating bitcoin_server_1      ... done
Nov 02 02:24:09 umbrel umbrel startup[1116]: Creating electrs_app_1       ... done
Nov 02 02:24:10 umbrel umbrel startup[1116]: Umbrel is now accessible at
Nov 02 02:24:10 umbrel umbrel startup[1116]:   http://umbrel.local
Nov 02 02:24:10 umbrel umbrel startup[1116]:   http://192.168.1.111
Nov 02 02:24:10 umbrel systemd[1]: Started Umbrel Startup Service.
Nov 02 02:26:42 umbrel passwd[8354]: pam_unix(passwd:chauthtok): password changed for umbrel
Nov 02 03:32:44 umbrel passwd[20051]: pam_unix(passwd:chauthtok): password changed for umbrel
External storage service logs
Oct 16 13:26:03 umbrel external storage mounter[509]: e2fsck 1.44.5 (15-Dec-2018)
Oct 16 13:26:04 umbrel external storage mounter[509]: Superblock last mount time (Wed Nov  1 23:12:29 2023,
Oct 16 13:26:04 umbrel external storage mounter[509]:         now = Mon Oct 16 13:26:03 2023) is in the future.
Oct 16 13:26:04 umbrel external storage mounter[509]: Fix? yes
Oct 16 13:26:04 umbrel external storage mounter[509]: Superblock last write time (Thu Nov  2 01:34:27 2023,
Oct 16 13:26:04 umbrel external storage mounter[509]: Pass 1: Checking inodes, blocks, and sizes
Oct 16 13:26:12 umbrel external storage mounter[509]: Pass 2: Checking directory structure
Oct 16 13:26:14 umbrel external storage mounter[509]: Pass 3: Checking directory connectivity
Oct 16 13:26:15 umbrel external storage mounter[509]: Pass 4: Checking reference counts
Oct 16 13:26:20 umbrel external storage mounter[509]: Pass 5: Checking group summary information
Oct 16 13:26:21 umbrel external storage mounter[509]: umbrel: 252598/122101760 files (5.3% non-contiguous), 193968939/488378368 blocks
Oct 16 13:26:21 umbrel external storage mounter[509]: Mounting partition...
Oct 16 13:26:21 umbrel external storage mounter[509]: Checking if device contains an Umbrel install...
Oct 16 13:26:21 umbrel external storage mounter[509]: Yes, it contains an Umbrel install
Oct 16 13:26:21 umbrel external storage mounter[509]: Bind mounting external storage over local Umbrel installation...
Oct 16 13:26:21 umbrel external storage mounter[509]: Bind mounting external storage over local Docker data dir...
Oct 16 13:26:21 umbrel external storage mounter[509]: Bind mounting external storage to /swap
Oct 16 13:26:21 umbrel external storage mounter[509]: Bind mounting SD card root at /sd-card...
Oct 16 13:26:21 umbrel external storage mounter[509]: Checking Umbrel root is now on external storage...
Oct 16 13:26:22 umbrel external storage mounter[509]: Checking /var/lib/docker is now on external storage...
Oct 16 13:26:22 umbrel external storage mounter[509]: Checking /swap is now on external storage...
Oct 16 13:26:22 umbrel external storage mounter[509]: Setting up swapfile
Oct 16 13:26:23 umbrel external storage mounter[509]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
Oct 16 13:26:23 umbrel external storage mounter[509]: no label, UUID=f0bfcc3e-528c-4079-a841-c571aff17af5
Oct 16 13:26:23 umbrel external storage mounter[509]: Checking SD Card root is bind mounted at /sd-root...
Oct 16 13:26:23 umbrel external storage mounter[509]: Starting external drive mount monitor...
Oct 16 13:26:23 umbrel external storage mounter[509]: Mount script completed successfully!
Oct 16 13:26:23 umbrel systemd[1]: Started External Storage Mounter.
-- Logs begin at Mon 2023-10-16 13:25:49 UTC, end at Thu 2023-11-02 03:32:44 UTC. --
Nov 02 02:23:38 umbrel systemd[1]: Starting External Storage SDcard Updater...
Nov 02 02:23:38 umbrel external storage updater[1034]: Checking if SD card Umbrel is newer than external storage...
Nov 02 02:23:39 umbrel external storage updater[1034]: No, SD version is not newer, exiting.
Nov 02 02:23:39 umbrel systemd[1]: Started External Storage SDcard Updater.
Karen logs
Removing bitcoin_server_1      ...
Removing bitcoin_app_proxy_1   ...
Removing bitcoin_bitcoind_1    ...
Removing bitcoin_i2pd_daemon_1 ...
Removing bitcoin_tor_1         ...
Removing bitcoin_i2pd_daemon_1 ... done
Removing bitcoin_bitcoind_1    ... done
Removing bitcoin_tor_1         ... done
Removing bitcoin_server_1      ... done
Removing bitcoin_app_proxy_1   ... done
Going to remove bitcoin_server_1, bitcoin_app_proxy_1, bitcoin_bitcoind_1, bitcoin_i2pd_daemon_1, bitcoin_tor_1
Stopping Docker services...
Stopping nginx     ...
Stopping manager   ...
Stopping dashboard ...
Stopping tor_proxy ...
Stopping auth      ...
Stopping tor_proxy ... done
Stopping nginx     ... done
Stopping auth      ... done
Stopping dashboard ... done
Stopping manager   ... done
Removing nginx     ...
Removing manager   ...
Removing dashboard ...
Removing tor_proxy ...
Removing auth      ...
Removing dashboard ... done
Removing auth      ... done
Removing tor_proxy ... done
Removing nginx     ... done
Removing manager   ... done
Got signal:
karen is getting triggered!
Got signal:
Got signal: change-password
Got signal: debug
Docker containers
NAMES                   STATUS
bitcoin_server_1        Up About an hour
electrs_app_1           Up About an hour
bitcoin_tor_1           Up About an hour
bitcoin_i2pd_daemon_1   Up About an hour
bitcoin_app_proxy_1     Up About an hour
bitcoin_bitcoind_1      Up About an hour
electrs_electrs_1       Up About an hour
electrs_tor_1           Up About an hour
electrs_app_proxy_1     Up About an hour
mempool_mariadb_1       Up About an hour
mempool_app_proxy_1     Up About an hour
mempool_api_1           Up About an hour
mempool_web_1           Up About an hour
nginx                   Up About an hour
auth                    Up About an hour
tor_proxy               Up About an hour
manager                 Up About an hour
dashboard               Up About an hour
Umbrel logs
Attaching to manager
manager      | ::ffff:10.21.21.2 - - [Thu, 02 Nov 2023 03:39:28 GMT] "GET /v1/apps?installed=1 HTTP/1.0" 304 - "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/116.0.0.0 Safari/537.36"
manager      |
manager      | umbrel-manager
manager      | ::ffff:10.21.21.2 - - [Thu, 02 Nov 2023 03:39:28 GMT] "GET /v1/apps HTTP/1.0" 304 - "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/116.0.0.0 Safari/537.36"
manager      |
manager      | ::ffff:10.21.21.2 - - [Thu, 02 Nov 2023 03:39:31 GMT] "POST /v1/system/debug HTTP/1.0" 200 17 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/116.0.0.0 Safari/537.36"
manager      |
manager      | ::ffff:10.21.21.2 - - [Thu, 02 Nov 2023 03:39:32 GMT] "GET /v1/system/debug-result HTTP/1.0" 200 23 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/116.0.0.0 Safari/537.36"
manager      |
manager      | ::ffff:10.21.21.2 - - [Thu, 02 Nov 2023 03:39:33 GMT] "GET /v1/system/debug-result HTTP/1.0" 304 - "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/116.0.0.0 Safari/537.36"
manager      |
manager      | ::ffff:10.21.21.2 - - [Thu, 02 Nov 2023 03:39:34 GMT] "GET /v1/system/debug-result HTTP/1.0" 304 - "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/116.0.0.0 Safari/537.36"
manager      |
manager      | ::ffff:10.21.21.2 - - [Thu, 02 Nov 2023 03:39:35 GMT] "GET /v1/system/debug-result HTTP/1.0" 304 - "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/116.0.0.0 Safari/537.36"
manager      |
manager      | ::ffff:10.21.21.2 - - [Thu, 02 Nov 2023 03:39:37 GMT] "GET /v1/system/debug-result HTTP/1.0" 304 - "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/116.0.0.0 Safari/537.36"
manager      |
manager      | ::ffff:10.21.21.2 - - [Thu, 02 Nov 2023 03:39:39 GMT] "GET /v1/system/debug-result HTTP/1.0" 304 - "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/116.0.0.0 Safari/537.36"
manager      |
manager      | ::ffff:10.21.21.2 - - [Thu, 02 Nov 2023 03:39:41 GMT] "GET /v1/system/debug-result HTTP/1.0" 304 - "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/116.0.0.0 Safari/537.36"
manager      |
Tor Proxy logs
Attaching to tor_proxy
tor_proxy    | Nov 02 02:24:01.000 [notice] Bootstrapped 56% (loading_descriptors): Loading relay descriptors
tor_proxy    | Nov 02 02:24:03.000 [notice] Bootstrapped 63% (loading_descriptors): Loading relay descriptors
tor_proxy    | Nov 02 02:24:04.000 [notice] Bootstrapped 71% (loading_descriptors): Loading relay descriptors
tor_proxy    | Nov 02 02:24:04.000 [notice] Bootstrapped 75% (enough_dirinfo): Loaded enough directory info to build circuits
tor_proxy    | Nov 02 02:24:04.000 [notice] Bootstrapped 80% (ap_conn): Connecting to a relay to build circuits
tor_proxy    | Nov 02 02:24:05.000 [notice] Bootstrapped 85% (ap_conn_done): Connected to a relay to build circuits
tor_proxy    | Nov 02 02:24:05.000 [notice] Bootstrapped 89% (ap_handshake): Finishing handshake with a relay to build circuits
tor_proxy    | Nov 02 02:24:05.000 [notice] Bootstrapped 90% (ap_handshake_done): Handshake finished with a relay to build circuits
tor_proxy    | Nov 02 02:24:05.000 [notice] Bootstrapped 95% (circuit_create): Establishing a Tor circuit
tor_proxy    | Nov 02 02:24:06.000 [notice] Bootstrapped 100% (done): Done
App logs
bitcoin
Attaching to bitcoin_server_1, bitcoin_tor_1, bitcoin_i2pd_daemon_1, bitcoin_app_proxy_1, bitcoin_bitcoind_1
bitcoind_1     | 2023-11-02T03:24:16Z Saw new header hash=000000000000000000045887f89dcb43745a98123b8d60482b8c9ccd73eb9186 height=814918
bitcoind_1     | 2023-11-02T03:24:16Z [net] Saw new cmpctblock header hash=000000000000000000045887f89dcb43745a98123b8d60482b8c9ccd73eb9186 peer=20
bitcoind_1     | 2023-11-02T03:24:20Z UpdateTip: new best=000000000000000000045887f89dcb43745a98123b8d60482b8c9ccd73eb9186 height=814918 version=0x29ffe000 log2_work=94.513334 tx=912449986 date='2023-11-02T03:23:46Z' progress=1.000000 cache=66.9MiB(477844txo)
bitcoind_1     | 2023-11-02T03:25:58Z New outbound peer connected: version: 70016, blocks=814918, peer=35 (block-relay-only)
bitcoind_1     | 2023-11-02T03:27:02Z Saw new header hash=00000000000000000002ca975c3e1b3e7d5275a77ac9c577bdadfcf5e281026c height=814919
bitcoind_1     | 2023-11-02T03:27:02Z [net] Saw new cmpctblock header hash=00000000000000000002ca975c3e1b3e7d5275a77ac9c577bdadfcf5e281026c peer=8
bitcoind_1     | 2023-11-02T03:27:04Z UpdateTip: new best=00000000000000000002ca975c3e1b3e7d5275a77ac9c577bdadfcf5e281026c height=814919 version=0x2e3f6000 log2_work=94.513348 tx=912453971 date='2023-11-02T03:26:47Z' progress=1.000000 cache=67.6MiB(483292txo)
bitcoind_1     | 2023-11-02T03:30:13Z Saw new header hash=00000000000000000003121c1b2eac6026bb4454f505597ae62672b50ba2b24c height=814920
bitcoind_1     | 2023-11-02T03:30:13Z [net] Saw new cmpctblock header hash=00000000000000000003121c1b2eac6026bb4454f505597ae62672b50ba2b24c peer=20
bitcoind_1     | 2023-11-02T03:30:19Z UpdateTip: new best=00000000000000000003121c1b2eac6026bb4454f505597ae62672b50ba2b24c height=814920 version=0x2000a000 log2_work=94.513361 tx=912454870 date='2023-11-02T03:29:17Z' progress=1.000000 cache=69.6MiB(497445txo)
app_proxy_1    | Validating token: d465d6389138 ...
app_proxy_1    | [HPM] ECONNRESET: Error: socket hang up
app_proxy_1    |     at connResetException (node:internal/errors:705:14)
app_proxy_1    |     at Socket.socketOnEnd (node:_http_client:518:23)
app_proxy_1    |     at Socket.emit (node:events:525:35)
app_proxy_1    |     at endReadableNT (node:internal/streams/readable:1358:12)
app_proxy_1    |     at processTicksAndRejections (node:internal/process/task_queues:83:21) {
app_proxy_1    |   code: 'ECONNRESET'
app_proxy_1    | }
i2pd_daemon_1  | 03:39:18@37/error - SSU2: RelayIntro unknown router to introduce
i2pd_daemon_1  | 03:39:23@37/error - SSU2: RelayIntro unknown router to introduce
i2pd_daemon_1  | 03:39:24@37/error - SSU2: RelayIntro unknown router to introduce
i2pd_daemon_1  | 03:39:27@37/error - SSU2: RelayIntro unknown router to introduce
i2pd_daemon_1  | 03:39:33@37/error - SSU2: RelayIntro unknown router to introduce
i2pd_daemon_1  | 03:39:35@37/error - SSU2: RelayIntro unknown router to introduce
i2pd_daemon_1  | 03:39:41@37/error - SSU2: RelayIntro unknown router to introduce
i2pd_daemon_1  | 03:39:43@37/error - SSU2: RelayIntro unknown router to introduce
i2pd_daemon_1  | 03:39:46@37/error - SSU2: RelayIntro unknown router to introduce
server_1       | umbrel-middleware
server_1       | ::ffff:10.21.0.5 - - [Thu, 02 Nov 2023 02:27:39 GMT] "GET /v1/bitcoind/info/stats HTTP/1.1" 200 125 "-" "Mozilla/5.0 (Linux; Android 10; K) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/118.0.0.0 Mobile Safari/537.36"
server_1       |
server_1       | ::ffff:10.21.0.5 - - [Thu, 02 Nov 2023 02:27:40 GMT] "GET /v1/bitcoind/info/connections HTTP/1.1" 304 - "-" "Mozilla/5.0 (Linux; Android 10; K) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/118.0.0.0 Mobile Safari/537.36"
server_1       |
server_1       | ::ffff:10.21.0.5 - - [Thu, 02 Nov 2023 02:28:50 GMT] "GET /v1/bitcoind/info/blocks?from=814767&to=814910 HTTP/1.1" - - "-" "Mozilla/5.0 (Linux; Android 10; K) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/118.0.0.0 Mobile Safari/537.36"
server_1       |
tor_1          | Nov 02 02:30:22.000 [notice] Bootstrapped 73% (loading_descriptors): Loading relay descriptors
tor_1          | Nov 02 02:30:22.000 [notice] Bootstrapped 75% (enough_dirinfo): Loaded enough directory info to build circuits
tor_1          | Nov 02 02:30:23.000 [notice] Bootstrapped 80% (ap_conn): Connecting to a relay to build circuits
tor_1          | Nov 02 02:30:23.000 [notice] Bootstrapped 85% (ap_conn_done): Connected to a relay to build circuits
tor_1          | Nov 02 02:30:23.000 [warn] Bad element "$E7480E57C25BF55A" while parsing a node family.
tor_1          | Nov 02 02:30:23.000 [notice] Bootstrapped 89% (ap_handshake): Finishing handshake with a relay to build circuits
tor_1          | Nov 02 02:30:24.000 [notice] Bootstrapped 90% (ap_handshake_done): Handshake finished with a relay to build circuits
tor_1          | Nov 02 02:30:24.000 [notice] Bootstrapped 95% (circuit_create): Establishing a Tor circuit
tor_1          | Nov 02 02:30:24.000 [warn] Bad element "$5450CC0E3D08BB001E8229B899032" while parsing a node family.
tor_1          | Nov 02 02:30:24.000 [notice] Bootstrapped 100% (done): Done
electrs
Attaching to electrs_app_1, electrs_electrs_1, electrs_tor_1, electrs_app_proxy_1
app_1        | umbrel-middleware
app_1        | ::ffff:10.21.0.3 - - [Thu, 02 Nov 2023 03:32:47 GMT] "GET /ping HTTP/1.1" 304 - "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/116.0.0.0 Safari/537.36"
app_1        |
app_1        | ::ffff:10.21.0.3 - - [Thu, 02 Nov 2023 03:32:47 GMT] "GET /img/umbrel-qr-icon.a521c058.svg HTTP/1.1" 304 - "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/116.0.0.0 Safari/537.36"
app_1        |
app_1        | ::ffff:10.21.0.3 - - [Thu, 02 Nov 2023 03:32:47 GMT] "GET /v1/electrs/electrum-connection-details HTTP/1.1" 304 - "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/116.0.0.0 Safari/537.36"
app_1        |
app_proxy_1  | Validating token: 97be0e1c5a70 ...
electrs_1    | [2023-11-02T02:24:57.843Z INFO  electrs::daemon] waiting for 4 blocks to download
electrs_1    | [2023-11-02T02:25:10.709Z INFO  electrs::daemon] waiting for 3 blocks to download
electrs_1    | [2023-11-02T02:25:15.619Z INFO  electrs::daemon] waiting for 2 blocks to download
electrs_1    | [2023-11-02T02:25:22.538Z INFO  electrs::daemon] waiting for 1 blocks to download
electrs_1    | [2023-11-02T02:25:26.442Z INFO  electrs::index] indexing 14 blocks: [814897..814910]
electrs_1    | [2023-11-02T02:25:27.998Z INFO  electrs::chain] chain updated: tip=000000000000000000002f69a18f801c11a31a88dee82617a4b72773bf71ab30, height=814910
electrs_1    | [2023-11-02T02:25:28.536Z INFO  electrs::db] starting config compaction
electrs_1    | [2023-11-02T02:25:28.572Z INFO  electrs::db] starting headers compaction
electrs_1    | [2023-11-02T02:25:33.703Z INFO  electrs::db] starting txid compaction
electrs_1    | [2023-11-02T02:50:56.907Z INFO  electrs::db] starting funding compaction
tor_1        | Nov 02 02:27:25.000 [notice] Bootstrapped 56% (loading_descriptors): Loading relay descriptors
tor_1        | Nov 02 02:28:28.000 [notice] Bootstrapped 61% (loading_descriptors): Loading relay descriptors
tor_1        | Nov 02 02:28:41.000 [notice] Bootstrapped 68% (loading_descriptors): Loading relay descriptors
tor_1        | Nov 02 02:29:03.000 [notice] Bootstrapped 75% (enough_dirinfo): Loaded enough directory info to build circuits
tor_1        | Nov 02 02:29:03.000 [notice] Bootstrapped 80% (ap_conn): Connecting to a relay to build circuits
tor_1        | Nov 02 02:29:03.000 [notice] Bootstrapped 85% (ap_conn_done): Connected to a relay to build circuits
tor_1        | Nov 02 02:29:04.000 [notice] Bootstrapped 89% (ap_handshake): Finishing handshake with a relay to build circuits
tor_1        | Nov 02 02:29:04.000 [notice] Bootstrapped 90% (ap_handshake_done): Handshake finished with a relay to build circuits
tor_1        | Nov 02 02:29:04.000 [notice] Bootstrapped 95% (circuit_create): Establishing a Tor circuit
tor_1        | Nov 02 02:29:05.000 [notice] Bootstrapped 100% (done): Done
mempool
Attaching to mempool_mariadb_1, mempool_app_proxy_1, mempool_api_1, mempool_web_1
api_1        |     at async Blocks.$updateBlocks (/backend/package/api/blocks.js:545:34)
api_1        |     at async Server.runMainUpdateLoop (/backend/package/index.js:190:13)
api_1        | Nov  2 03:39:27 [112] INFO: 150 blocks since tip. Fast forwarding to the 8 recent blocks
api_1        | Nov  2 03:39:27 [112] INFO: Re-indexing skipped blocks and corresponding hashrates data
api_1        | Nov  2 03:39:30 [112] ERR: Cannot fetch coinbase tx 7cbad97cd0f58fba9e8bbcc721fde978e751e5d36654977a2fd5bfd757354380. Reason: No such mempool transaction. Use -txindex or provide a block hash to enable blockchain transaction queries. Use gettransaction for wallet transactions.
api_1        | Nov  2 03:39:30 [112] WARN: Exception in runMainUpdateLoop(). Retrying in 60 sec. Reason: Cannot fetch coinbase tx 7cbad97cd0f58fba9e8bbcc721fde978e751e5d36654977a2fd5bfd757354380. Reason: No such mempool transaction. Use -txindex or provide a block hash to enable blockchain transaction queries. Use gettransaction for wallet transactions.. Stack trace: Error: Cannot fetch coinbase tx 7cbad97cd0f58fba9e8bbcc721fde978e751e5d36654977a2fd5bfd757354380. Reason: No such mempool transaction. Use -txindex or provide a block hash to enable blockchain transaction queries. Use gettransaction for wallet transactions.
api_1        |     at Blocks.$getTransactionsExtended (/backend/package/api/blocks.js:127:35)
api_1        |     at processTicksAndRejections (node:internal/process/task_queues:96:5)
mariadb_1    | 2023-11-02  2:24:01 0 [Note] InnoDB: Loading buffer pool(s) from /var/lib/mysql/ib_buffer_pool
mariadb_1    | 2023-11-02  2:24:01 0 [Note] Server socket created on IP: '::'.
mariadb_1    | 2023-11-02  2:24:01 0 [Warning] 'proxies_priv' entry '@% root@1f5d813a343c' ignored in --skip-name-resolve mode.
mariadb_1    | 2023-11-02  2:24:02 0 [Note] Reading of all Master_info entries succeeded
mariadb_1    | 2023-11-02  2:24:02 0 [Note] Added new Master_info '' to hash table
mariadb_1    | 2023-11-02  2:24:02 0 [Note] mysqld: ready for connections.
mariadb_1    | Version: '10.5.12-MariaDB-1:10.5.12+maria~focal'  socket: '/run/mysqld/mysqld.sock'  port: 3306  mariadb.org binary distribution
mariadb_1    | 2023-11-02  2:24:02 3 [Warning] Aborted connection 3 to db: 'unconnected' user: 'unauthenticated' host: '10.21.21.27' (This connection closed normally without authentication)
mariadb_1    | 2023-11-02  2:24:02 4 [Warning] Aborted connection 4 to db: 'unconnected' user: 'unauthenticated' host: '10.21.21.26' (This connection closed normally without authentication)
mariadb_1    | 2023-11-02  2:24:03 0 [Note] InnoDB: Buffer pool(s) load completed at 231102  2:24:03
web_1        | /var/www/mempool/browser/resources
app_proxy_1  | yarn run v1.22.19
app_proxy_1  | $ node ./bin/www
app_proxy_1  | [HPM] Proxy created: /  -> http://10.21.21.26:3006
app_proxy_1  | Waiting for 10.21.21.26:3006 to open...
app_proxy_1  | mempool is now ready...
app_proxy_1  | Listening on port: 3006
==== Result ====
==== END =====
And then it magically worked, seems like electumS took a bit more than a few days
