I’m having troubles to install any app in the app store. I’m using a raspberry pi 4 8 gb hdd 4tb. the raspberry is connected to the internet via lan cable and has a static ip in my network. every time I try to install umbrel stays in the “installing” stage. If I try to install it via ssh any application ends with a “layer does not exist” error. I collected the logs. umbrel-1675718127371-debug.log (19.8 KB) I try already reset the raspberry and flashing the sd card again and nothing works. If anyone have an idea about the error please replay.
I’m a little confused, I looked into your logs and it appears Umbrel is running, is it apps in the App Store that are failing to install or Umbrel itself?
are the apps in the app store that do not install. If I try to install them manually I get an error “layer does not exist.” If I try to install them from the app store the installing message hangs and keeps saying that is installing.
I found some reference to the issue your having here
you might try checking the status of the Docker daemon, I use linux, but I believe on a pi that should be
systemctl status docker
or maybe restart it with
systemctl stop docker && systemctl start docker
looking at the logs I also see
ERROR: for core-lightning_app_1 Cannot create container for service app: error creating overlay mount to /var/lib/docker/overlay2/9d72b52d9466e0d4f9c3dde5fff446c0c0f0dcd327468c52dfb27737fa48a933-init/merged: no such file or directory
Creating core-lightning_tor_1 ... done
Creating core-lightning_lightningd_1 ... done
Creating core-lightning_app_proxy_1 ... done
Creating core-lightning_c-lightning-rest_1 ... done
ERROR: for app Cannot create container for service app: error creating overlay mount to /var/lib/docker/overlay2/9d72b52d9466e0d4f9c3dde5fff446c0c0f0dcd327468c52dfb27737fa48a933-init/merged: no such file or directory
Got signal: debug
karen is getting triggered!
so everything is pointing towards docker misbehaving.
